查看: 7759|回復: 3
STM32&AD9833信號發生器代碼
1.本信號發生器采用STM32F103C8T6作為主控,AD9833作為DDS信號發生器,代碼可直接燒錄
2.本信號發生器實現了方波、正弦波、三角波的輸出與頻率、幅度按鍵調控
3.另外實現了STM32定時器產生一路方波,占空比可調
  1. #include "stm32f10x.h"
  2. #include "led.h"
  3. #include "ad9833.h"
  4. #include "systemconfig.h"
  5. #include "key.h"
  6. #include "oled.h"
  7. #include "bsp_i2c_gpio.h"
  8. #include "delay.h"
  9. #include "usart.h"
  10. #include "timer.h"
  11. void Delay(u32 count)
  12. {
  13.    u32 i=0;
  14.    for(;i<count;i++);
  15. }
  16. int main(void)
  17. {
  18.          u8 i;
  19.         uint16_t pwm = 400;
  20.         LED_Init();
  21.         delay_init();
  22.         OLED_Init();                                         /* OLED初始化 */
  23.         uart_init(115200);
  24.         SystemConfiguration();                    //系統初始化
  25.         TIM3_PWM_Init(899,0);         //不分頻。PWM頻率=72000000/900=80Khz
  26.         AD9833_Init_GPIO(); //AD9833 GPIO 初始化
  27. //        AD9833_WaveSeting(8000000.5,0,TRI_WAVE,0 );//1.0005KHz,頻率寄存器0,三角波輸出 ,初相位0
  28. /*        AD9833_WaveSeting(5000,0,SQU_WAVE,90);        //5KHz,                頻率寄存器0,方波輸出         ,初相位90 */
  29. /*        AD9833_WaveSeting(100000,0,SIN_WAVE,0 );//100KHz,        頻率寄存器0,正弦波輸出 ,初相位0 */
  30.
  31.
  32.         AD9833_WaveSeting(10000,0,SIN_WAVE,0 );
  33.         AD9833_AmpSet(100); //設置幅值,幅值最大 255
  34.
  35.         u16 f=1000;
  36.         u16 l=100;
  37.         u8 flag;u8 flag1;
  38.         u8 t = '0';
  39.         u16 b;
  40.         u16 m=0;
  41.         u16 a=0;
  42.         while(1)
  43.         {
  44.                 TIM_SetCompare2(TIM3,pwm);
  45.                 OLED_Clear();
  46.                 OLED_DisplayUpdate();
  47.                 t = KEY_Scan();        //得到鍵值
  48.                 switch(t)                //波形檢測
  49.                 {
  50.                         case '1':t='0';SystemConfiguration();                AD9833_WaveSeting(f,0,TRI_WAVE,0 );break;//說明PB4接收到低電平,第一行第一列對應第一個按鍵
  51.                         case '5':t='0';SystemConfiguration();                AD9833_WaveSeting(f,0,SQU_WAVE,90);break;
  52.                         case '9':t='0';SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  53.                         case '2':t='0';f--;SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  54.                         case '3':t='0';f=f-10;SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  55.                         case '4':t='0';f=f-100;SystemConfiguration();                AD9833_WaveSeting(f,0,SQU_WAVE,0 );break;
  56.                         case '6':t='0';f++;SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  57.                         case '7':t='0';f=f+10;SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  58.                         case '8':t='0';f=f+100;SystemConfiguration();                AD9833_WaveSeting(f,0,SIN_WAVE,0 );break;
  59.                         case 'f':t='0';pwm=pwm-10;        break;
  60.                         case 'g':t='0';pwm=pwm+10;        break;
  61.                         default:break;
  62.                 }
  63.         }
  64. }
  65. //                switch(t)
  66. //                {
  67. //                        case 'g':
  68. //                        {
  69. //                                a=0;
  70. //                                b=0;
  71. //                                delay_ms(1000);           //延時
  72. //                                flag = KEY_Scan();
  73. //                                while(flag!='d')
  74. //                                {
  75. //                                        if(flag!='0'&&flag!=flag1)
  76. //                                        {
  77. //                                        flag=flag1;
  78. //                                        switch(flag)
  79. //                                        {
  80. //                                                m++;
  81. //                                                case '4': b=1;break;
  82. //                                                case '3': b=2;break;
  83. //                                                case '2': b=3;break;
  84. //                                                case '8': b=4;break;
  85. //                                                case '7': b=5;break;
  86. //                                                case '6': b=6;break;
  87. //                                                case 'c': b=7;break;
  88. //                                                case 'b': b=8;break;
  89. //                                                case 'a': b=9;break;
  90. //                                                case 'e': b=0;break;
  91. //                                                default:break;
  92. //                                        }
  93. //                                        }
  94. //                                        for(u16 n=0;n<m;n++)
  95. //                                        {
  96. //                                                a=a+10*b;
  97. //                                        }
  98. //                                flag1 = KEY_Scan();
  99. //                                }
  100. //                                f=a;
  101. //                        }
  102. //                        case 'f':
  103. //                        {
  104. //                                a=0;
  105. //                                b=0;
  106. //                                delay_ms(1000);           //延時
  107. //                                flag = KEY_Scan();
  108. //                                while(flag!='d')
  109. //                                {
  110. //                                        if(flag!='0')
  111. //                                        {
  112. //                                        switch(flag)
  113. //                                        {
  114. //                                                m++;
  115. //                                                case '4': b=1;break;
  116. //                                                case '3': b=2;break;
  117. //                                                case '2': b=3;break;
  118. //                                                case '8': b=4;break;
  119. //                                                case '7': b=5;break;
  120. //                                                case '6': b=6;break;
  121. //                                                case 'c': b=7;break;
  122. //                                                case 'b': b=8;break;
  123. //                                                case 'a': b=9;break;
  124. //                                                case 'e': b=0;break;
  125. //                                                default:break;
  126. //                                        }
  127. //                                        }
  128. //                                        for(u16 n=0;n<m;n++)
  129. //                                        {
  130. //                                                a=a+10*b;
  131. //                                        }
  132. //                                flag = KEY_Scan();
  133. //                                }
  134. //                                l=a;
  135. //                        }
  136. //                        default:break;
  137. //                }
  138.                         //顯示2個數字
  139. //x,y :起點坐標
  140. //len :數字的位數
  141. //size:字體大小
  142. //mode:模式        0,填充模式;1,疊加模式
  143. //num:數值(0~4294967295);
  144. //        OLED_ShowNum(48,3,f,10,6);
  145. //        OLED_ShowNum(0,4,l,10,6);
  146. //        }
  147.
所有資料51hei提供下載(PCB還未畫完,也順便發出來,大家有時間幫忙一起完善一下吧,東東還很不完善 大家勿噴,一起學習一起進步):
STM32&amp;AD9833信號發生器PCB和代碼.7z (1.03 MB, 下載次數: 177)
收藏收藏9 分享淘帖 頂2 踩
ID:723161 發表于 2021-1-11 19:18 | 只看該作者
在嗎 可以交流一下這個嘛
ID:645047 發表于 2021-7-30 13:32 來自觸屏版 | 只看該作者
可以用嗎
ID:165291 發表于 2022-8-17 16:37 來自觸屏版 | 只看該作者
這個牛啊!
主站蜘蛛池模板: 成人国产 | 精品久久久久久久久久久久久 | 国产亚洲视频在线观看 | xxxxx国产 | 小sao货撅起屁股扒开c微博 | 天天躁日日躁狠狠躁av麻豆男男 | 欧美日韩一区二区在线 | 精品一区二区三区四区五区 | 天天操天天操天天 | 亚洲精品免费在线观看 | 在线观看欧美日韩视频 | 免费一区二区 | 欧美特黄视频 | 日韩成人在线免费观看 | 久久99精品久久久久久 | 激情久久网| 日韩免费一区二区三区 | 成年人免费看片 | 精品国产乱码久久久久 | 久久手机视频 | 天堂视频在线观看 | 日韩av在线免费看 | 黄色a一级片 | 日韩伦理一区 | 久久只有精品 | 丰满少妇av | 欧美日韩免费一区二区三区 | 高清一区二区 | 日韩视频免费大全中文字幕 | 国产欧美日韩一区 | 国产黄视频在线观看 | 日韩国产一区二区 | 午夜视频 | 成人免费毛片网站 | 免费国产精品视频 | 国产日韩精品一区二区 | 黄色a毛片 | 在线一区二区视频 | 国产精品1区 | www.日韩在线 | 人人爱人人草 |
