查看: 3674|回復: 0
基于STC15單片機+OLED的貪吃蛇大作戰程序 原理圖與PCB文件
ID:677834 發表于 2021-12-13 16:56 | 顯示全部樓層 |閱讀模式
基于STC15408AS的貪吃蛇游戲程序與硬件設計
制作出來的實物圖如下:
實物圖
實物圖
貪吃蛇PCB設計
貪吃蛇PCB設計
貪吃蛇原理圖設計
貪吃蛇原理圖設計
  1. #include "snake.h"
  2. #include "oled.h"
  3. #include "adc.h"
  4. #include "stdlib.h"
  5. #include "timer.h"
  6. int snake_Grid[32][2];//蛇身的存儲數組,snake_Grid[][0]代表x坐標,snake_Grid[][1]代表y坐標
  7. extern u8 if_end;
  8. u8 snake_length = 5;//蛇身初始長度
  9. unsigned char squre[8]= {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
  10. void snake_delay_ms(int ms)                //延時函數
  11. {
  12.         unsigned char i, j;
  13. while(ms--)
  14. {
  15.         _nop_();
  16.         _nop_();
  17.         _nop_();
  18.         i = 11;
  19.         j = 190;
  20.         do
  21.         {
  22.                 while (--j);
  23.         } while (--i);
  24.   }
  25. }
  26. void Draw_squre(unsigned char x,unsigned char y)//畫方塊,即地圖顯示部分
  27. {
  28.    u8 i;
  29.    OLED_Set_Pos(x*8,y);
  30.    for(i=0;i<8;i++)
  31.    {
  32.       OLED_WR_Byte(squre[i],OLED_DATA);
  33.    }
  34. }
  35. void Draw_Map()//畫地圖
  36. {
  37.         u8 i;
  38.         for(i=0;i<15;i++)
  39.         {
  40.   Draw_squre(i,0);
  41.         Draw_squre(i,7);
  42.         }
  43.         for(i=0;i<8;i++)
  44.         {
  45.         Draw_squre(0,i);
  46.         Draw_squre(15,i);
  47.         }
  48. }
  49. unsigned char snake_head[8] = {0xFF,0x9F,0x9D,0xFD,0xFD,0x9D,0x9F,0xFF};
  50. void Draw_Head(unsigned char x,unsigned char y)//畫蛇頭函數
  51. {
  52.          u8 i;
  53.    OLED_Set_Pos(x*8,y);
  54.    for(i=7;i>0;i--)
  55.    {
  56.       OLED_WR_Byte(snake_head[i],OLED_DATA);
  57.    }
  58. }
  59. u8 Direction = 0;
  60. Coordinate old1 = {0};
  61. Coordinate old2 = {0};
  62. Coordinate snake_food = {1,1};
  63. Coordinate snake_body = {0,0};
  64. void Check_KEY()//搖桿檢測函數
  65. {
  66.         int x_value,y_value;
  67.         x_value = Get_ADC10bitResult(0);
  68.         y_value = Get_ADC10bitResult(1);
  69.   if(x_value<30&&Direction!=Left_Direction)Direction = Right_Direction;
  70.   if(x_value>1000&&Direction!=Right_Direction)Direction = Left_Direction;
  71.   if(y_value>1000&&Direction!=Up_Direction)Direction = Down_Direction;
  72.         if(y_value<30&&Direction!=Down_Direction)Direction = Up_Direction;
  73. }
  74. void Record_Coordinate()//記錄上一次的坐標
  75. {
  76.         old1.x = snake_Grid[0][0];
  77.         old1.y = snake_Grid[0][1];
  78.         old2.x = snake_Grid[snake_length-1][0];
  79.         old2.y = snake_Grid[snake_length-1][1];
  80. }
  81. int score = 0;
  82. void Check_State()//檢測蛇的狀態
  83. {
  84.         u8 i;
  85.         snake_body.x = snake_Grid[0][0];
  86.         snake_body.y = snake_Grid[0][1];
  87.   if(snake_Grid[0][0]==snake_food.x&&snake_Grid[0][1]==snake_food.y)//當食物的坐標和蛇頭一致則記錄一次
  88.         {
  89.                 score++;
  90.                 snake_food.x = rand()%14+1;
  91.                 snake_food.y = rand()%6+1;
  92.                 snake_length++;
  93.                 Rrfresh_Body(snake_food.x,snake_food.y);
  94.                 Draw_Food(snake_food.x,snake_food.y);
  95.
  96.         }
  97.         for(i=1;i<snake_length-1;i++)
  98.            if(snake_body.x==snake_Grid[i][0]&&snake_body.y==snake_Grid[i][1])
  99.                          if_end = 1;
  100.         for(i=0;i<snake_length-1;i++)
  101.          while(snake_Grid[0][0]==snake_food.x&&snake_Grid[0][1]==snake_food.y)
  102.                 {
  103.                 snake_food.x = rand()%13+1;//隨機生成食物
  104.                 snake_food.y = rand()%6+1;
  105.                 }
  106. }
  107. unsigned char food[8] = {0xFF,0xFF,0xC3,0xDB,0xDB,0xC3,0xFF,0xFF,};
  108. void Draw_Food(unsigned char x,unsigned char y)//畫食物
  109. {
  110.    u8 i;
  111.    OLED_Set_Pos(x*8,y);
  112.    for(i=0;i<8;i++)
  113.    {
  114.       OLED_WR_Byte(food[i],OLED_DATA);
  115.    }
  116. }
  117. void Snake_Move()//移動函數
  118. {
  119.         u8 i;
  120.         Check_State();
  121.   for(i=snake_length-1;i>0;i--)
  122.         {
  123.           snake_Grid[i][0] = snake_Grid[i-1][0];
  124.                 snake_Grid[i][1] = snake_Grid[i-1][1];
  125.         }
  126.         switch(Direction)
  127.         {
  128.          case Right_Direction:
  129.          Record_Coordinate();
  130.          snake_Grid[0][0]++;
  131.          Rrfresh_Body(old1.x,old1.y);
  132.          Rrfresh_Body(old2.x,old2.y);
  133.          if(snake_Grid[0][0]>15)
  134.          {
  135.           if_end = 1;
  136.                 OLED_Clear();
  137.          }
  138.                 break;
  139.          case Left_Direction:
  140.          Record_Coordinate();
  141.          snake_Grid[0][0]--;
  142.          Rrfresh_Body(old1.x,old1.y);
  143.          Rrfresh_Body(old2.x,old2.y);
  144.          if(snake_Grid[0][0]<=0)
  145.          {
  146.                  if_end = 1;
  147.                  OLED_Clear();
  148.          }
  149.                 break;
  150.          case Up_Direction:
  151.          Record_Coordinate();
  152.          snake_Grid[0][1]--;
  153.          Rrfresh_Body(old1.x,old1.y);
  154.          Rrfresh_Body(old2.x,old2.y);
  155.          if(snake_Grid[0][1]<=0)
  156.          {
  157.                  if_end = 1;
  158.                          OLED_Clear();
  159.          }
  160.                 break;
  161.          case Down_Direction:
  162.          Record_Coordinate();
  163.          snake_Grid[0][1]++;
  164.          Rrfresh_Body(old1.x,old1.y);
  165.          Rrfresh_Body(old2.x,old2.y);
  166.          if(snake_Grid[0][1]>7)
  167.          {
  168.                  if_end = 1;
  169.                  OLED_Clear();
  170.          }
  171.                 break;
  172.         }
  173. }
  174. void Draw_Start_Interface()//開始界面的繪制
  175. {
  176.         u8 i;
  177.         for(i=0;i<6;i++)
  178.         {
  179.         OLED_ShowCHinese(16+i*16,3,i+4);
  180.         OLED_ShowCHinese(16+i*16,5,i+10);
  181.         }
  182.         snake_delay_ms(500);
  183.         OLED_Clear();
  184. }
  185. int snake_sum = 3;
  186. void Snake_Init()//初始化蛇
  187. {
  188.         u8 i;
  189.   snake_Grid[0][0] = 5;//身體為5
  190.         snake_Grid[0][1] = 5;
  191.   Draw_Start_Interface();
  192.         while(snake_sum)//加載界面
  193.         {
  194.                 snake_sum--;
  195.                 for(i=0;i<3;i++)
  196.         {
  197.         OLED_ShowCHinese(16+i*16,3,i+16);
  198.         }
  199.         for(i=0;i<3;i++)
  200.         {
  201.         OLED_ShowString(64+i*16,3,".");
  202.         snake_delay_ms(500);
  203.         }
  204.         OLED_Clear();
  205.   }
  206.         OLED_Clear();
  207.         Draw_Food(snake_food.x,snake_food.y);
  208.         Draw_Map();
  209.   for(i = snake_length-1;i>0;i--)
  210.         {
  211.           snake_Grid[i][0] = snake_Grid[0][0]-i;
  212.                 snake_Grid[i][1] = snake_Grid[0][1];
  213.         }
  214.         LED1 = 0;
  215.         LED2 = 0;
  216.         LED3 = 0;
  217. }
  218. const unsigned char code body[8]={0xFF,0xFF,0xC3,0xC3,0xC3,0xC3,0xFF,0xFF};
  219. void Draw_Body(unsigned char x,unsigned char y)//畫身體
  220. {
  221.    u8 i;
  222.    OLED_Set_Pos(x*8,y);
  223.    for(i=0;i<8;i++)
  224.    {
  225.       OLED_WR_Byte(body[i],OLED_DATA);
  226.    }
  227. }
  228. void Rrfresh_Body(unsigned char x,unsigned char y)//刷新身體
  229. {
  230.    u8 i;
  231.    OLED_Set_Pos(x*8,y);
  232.    for(i=0;i<8;i++)
  233.    {
  234.       OLED_WR_Byte(0,OLED_DATA);
  235.    }
  236. }
  237. void Game_if_continue()//游戲是否繼續
  238. {
  239.         Direction = 5;
  240.         Check_KEY();
  241.   switch(Direction)
  242.         {
  243.           case Left_Direction:
  244.     Continue_Game();
  245.                 Direction = Right_Direction;
  246.                 snake_Grid[0][0] = 5;
  247.                 snake_Grid[0][1] = 5;
  248.                 Draw_Map();
  249.                 snake_food.x = 1;
  250.                 snake_food.y = 1;
  251.                 score = 0;
  252.                 Draw_Food(snake_food.x,snake_food.y);
  253.                 break;
  254.                 case Right_Direction:
  255.                 End_Game();
  256.     break;
  257.         }
  258. }
  259. void Continue_Game()//繼續游戲
  260. {
  261.           if_end = 0;
  262.    snake_length = 5;
  263.          OLED_Clear();
  264. }
  265. void End_Game()//結束游戲
  266. {
  267.           static u8 n = 1;
  268.          if(n)
  269.          {
  270.                  n = 0;
  271.          OLED_Clear();
  272.          }
  273.    OLED_ShowString(0,3,"Thank you for your help",16);
  274.          while(1);
  275. }
所有資料51hei附件下載:
貪吃蛇代碼及pcB.7z (3.16 MB, 下載次數: 39)
主站蜘蛛池模板: 国产精品一区av | 久久久中文字幕 | 精品在线免费视频 | 成人亚洲天堂 | 婷婷久| 成人欧美日韩 | 日韩精品在线观看视频 | 国产福利视频在线观看 | 九九热这里只有 | 国产黄色在线观看 | 国产精品96 | 亚洲福利影院 | 亚洲免费小视频 | 亚洲综合五月天婷婷丁香 | 日韩欧美在线一区二区 | 涩涩999 | 国产日韩在线视频 | 亚洲精品18在线观看 | 国产日韩中文字幕 | 一区二区欧美日韩 | 欧美激情成人 | 久久免费国产视频 | 亚洲综合五月 | 精品视频在线观看 | av最新网址| 国产午夜在线观看 | 欧美网站在线观看 | 国产成人三级一区二区在线观看一 | 岛国av在线免费观看 | 欧美国产在线观看 | 欧美高清一区二区 | 亚洲国产区 | 久久久夜| 欧美视频a | 欧洲一区二区三区 | 91精品国产99久久久久久红楼 | 激情91| avtt久久| av网站在线免费观看 | 国产农村妇女aaaaa视频 | 麻豆三级视频 |
