查看: 2302|回復: 0
電子琴設計VHDL代碼
ID:1024028 發表于 2022-5-5 14:45 | 顯示全部樓層 |閱讀模式
程序設計與仿真
電子琴VHDL程序包含有:頂層程序、音階發生器程序、數控分頻模塊程序和自動演奏模塊程序。
1.頂層程序與仿真
(1)頂層VHDL程序
--文件名:top.vhd
--功能:頂層文件
--最后修改日期:2004.3.20
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity top is
Port ( clk32MHz  :in std_logic;                     --32MHz系統時鐘
handTOauto : in std_logic;                     --鍵盤輸入/自動演奏
code1      :out std_logic_vector(6 downto 0);    --音符顯示信號
index1     :in std_logic_vector(7 downto 0);     --鍵盤輸入信號
high1      :out std_logic;                    --高低音節信號
spkout     :out std_logic);                    --音頻信號
end top;
architecture Behavioral of top is
component automusic
Port ( clk :in std_logic;
Auto: in std_logic;
index2:in std_logic_vector(7 downto 0);
index0 : out std_logic_vector(7 downto 0));
end component;
component tone
Port ( index : in std_logic_vector(7 downto 0);
code : out std_logic_vector(6 downto 0);
high : out std_logic;
tone0 : out integer range 0 to 2047);
end component;
component speaker
Port ( clk1 : in std_logic;
tone1 : in integer range 0 to 2047;
spks : out std_logic);
end component;
signal tone2: integer range 0 to 2047;
signal indx:std_logic_vector(7 downto 0);
begin
u0:automusic port map(clk=>clk32MHZ,index2=>index1,index0=>indx,Auto=>handtoAuto);
u1: tone port map(index=>indx,tone0=>tone2,code=>code1,high=>high1);
u2: speaker port map(clk1=>clk32MHZ,tone1=>tone2,spks=>spkout);
end Behavioral;
(2)仿真
頂層文件仿真圖如圖8.18.2所示。
圖8.18.2 頂層文件仿真圖
2. 音階發生器程序與仿真
  • 音階發生器VHDL程序
--文件名:tone.vhd。
--功能:
library IEEE;
entity tone is
Port ( index : in std_logic_vector(7 downto 0);          --音符輸入信號
code  : out std_logic_vector(6 downto 0);        --音符顯示信號
high  : out std_logic;                         --高低音顯示信號
tone0 : out integer range 0 to 2047);             --音符的分頻系數
end tone;
architecture Behavioral of tone is
begin
search :process(index)    --此進程完成音符到音符的分頻系數譯碼,音符的顯示,高低音階
begin
case index is
when "00000001" => tone0<=773;code<="1001111";high<='1';
when "00000010"=> tone0<=912;code<="0010010";high<='1';
when "00000100" => tone0<=1036;code<="0000110";high<='1';
when "00001000" => tone0<=1116;code<="1001100";high<='1';
when "00010000" => tone0<=1197;code<="0100100";high<='1';
when "00100000" => tone0<=1290;code<="0100000";high<='0';
when "01000000" => tone0<=1372;code<="0001111";high<='0';
when "10000000" => tone0<=1410;code<="0000000";high<='0';
when   others   => tone0<=2047;code<="0000001";high<='0';
end case;
end process;
end Behavioral;
(2)音階發生器程序仿真
音階發生器程序仿真圖如圖8.18.3所示。
圖8.18.3   音階發生器仿真圖
3. 數控分頻模塊程序與仿真
  • 數控分頻模塊VHDL程序
--文件名:speaker.vhd。
--功  能:實現數控分頻。
--最后修改日期:20004.3.19。
library IEEE;
entity speaker is
Port ( clk1  : in std_logic;                        --系統時鐘
tone1 : in integer range 0 to 30624;            --音符分頻系數
spks  : out std_logic);                      --驅動揚聲器的音頻信號
end speaker;
architecture Behavioral of speaker is
signal  preclk,fullspks:std_logic;
begin
pulse1:process(clk1)                               --此進程對系統時鐘進行4分頻
variable count:integer range 0 to 8;
begin
if clk1'event and clk1='1' then count:=count+1;
if count=2 then preclk<='1';
elsif count=4 then preclk<='0';count:=0;
end if;
end if;
end process pulse1;
genspks:process(preclk,tone1)
--此進程按照tone1輸入的分頻系數對8MHz的脈沖再次分頻,得到所需要的音符頻率
variable count11:integer range 0 to 30624;
begin
if preclk'event and preclk='1' then
if count11<tone1 then count11:=count11+1;fullspks<='1';
else count11:=0;fullspks<='0';
end if;
end if;
end process;
delaysps:process(fullspks)                           --此進程對fullspks進行2分頻
variable count2 :std_logic:='0';
begin
if fullspks'event and fullspks='1' then count2:=not count2;
if count2='1' then spks<='1';
else spks<='0';
end if;
end if;
end process;
end Behavioral;
(2) 數控分頻模塊程序仿真
數控分頻模塊程序仿真圖如圖8.18.4所示。
圖8.18.4  數控分頻模塊仿真圖
4. 自動演奏模塊程序與仿真
  • 自動演奏模塊VHDL程序
--文件名:automusic.vhd
--功  能:實現自動演奏功能。
--最后修改日期:2004.3.19。
library IEEE;
entity automusic is
Port ( clk,Auto : in std_logic;                   --系統時鐘;鍵盤輸入/自動演奏
index2 : in std_logic_vector(7 downto 0);    --鍵盤輸入信號
index0 : out std_logic_vector(7 downto 0));  --音符信號輸出
end automusic;
architecture Behavioral of automusic is
signal count0:integer range 0 to 31;--change
signal clk2:std_logic;
begin
pulse0:process(clk,Auto)         --此進程完成對系統時鐘8M的分頻,得到4Hz的信號clk2
variable count:integer range 0 to 8000000;
begin
if Auto='1' then count:=0;clk2<='0';
elsif clk'event and clk='1' then count:=count+1;
if count=4000000(4) then clk2<='1';
elsif count=8000000 (8)then clk2<='0';count:=0;
end if;
end if;
end process;
music:process(clk2)                   --此進程完成自動演奏部分曲的地址累加
begin
if clk2'event and clk2='1' then
if count0=31 then count0<=0;
else count0<=count0+1;
end if;
end if;
end process;
com1:process(count0,Auto,index2)
begin
if Auto='0' then
case count0 is                   --此case語句:存儲自動演奏部分的曲
when 0 => index0<="00000100";  --3
when 1 => index0<="00000100";  --3
when 2 => index0<="00000100";  --3
when 3 => index0<="00000100";  --3
when 4 => index0<="00010000";  --5
when 5 => index0<="00010000";  --5
when 6 => index0<="00010000";  --5
when 7 => index0<="00100000";  --6
when 8 => index0<="10000000";  --8
when 9 => index0<="10000000";  --8
when 10 =>index0<="10000000";  --8
when 11=> index0<="00000100";  --3
when 12=> index0<="00000010";  --2
when 13=> index0<="00000010";  --2
when 14=> index0<="00000001";  --1
when 15=> index0<="00000001";  --1
when 16=> index0<="00010000";  --5
when 17=> index0<="00010000";  --5
when 18=> index0<="00001000";  --4
when 19=> index0<="00001000";  --4
when 20=> index0<="00001000";  --4
when 21=> index0<="00000100";  --3
when 22=> index0<="00000010";  --2
when 23=> index0<="00000010";  --2
when 24=> index0<="00010000";  --5
when 25=> index0<="00010000";  --5
when 26=> index0<="00001000";  --4
when 27=> index0<="00001000";  --4
when 28=> index0<="00000100";  --3
when 29=> index0<="00000100";  --3
when 30=> index0<="00000010";  --2
when 31=> index0<="00000010";  --2
when others => null;
end case;
else index0<=index2;                 --鍵盤輸入音符信號輸出
end if;
end process;
end Behavioral;
(2)自動演奏模塊程序仿真
自動演奏模塊仿真圖如圖8.17.5所示。
圖8.18.5  自動演奏模塊仿真圖
(注:由于輸入頻率太高,實驗條件所限,如按源程序仿真將看不到輸出波形,因此將原脈沖的分頻點4000000和8000000改為4和8,得到如圖的仿真結果,在實際燒制芯片中不作此處理。)
參與人數 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
主站蜘蛛池模板: 久久久久久综合 | 超碰成人免费 | 一区二区三区日本 | 国产激情91久久精品导航 | 一区免费观看 | av天天爽 | 男女免费视频网站 | 日韩高清电影 | 欧美中文字幕在线观看 | 精品视频国产 | 午夜日韩 | 99久久久99久久国产片鸭王 | 久久久久久久久久久蜜桃 | 亚洲一二三区av | 95国产精品| 电影午夜精品一区二区三区 | 一本色道精品久久一区二区三区 | 另类亚洲视频 | 在线视频h | 国产精品久久久久久一级毛片 | 在线不卡视频 | 亚洲精品永久免费 | 国产黑丝av | 国产中文字幕网 | 中文在线视频观看 | 日韩精品a在线观看图片 | 99免费精品视频 | 99久久精品免费看国产小宝寻花 | 国产精品毛片久久久久久 | 国产高清视频在线观看播放 | 国产不卡一 | 国产成人一区二区三区 | 成人不卡在线 | 黄色在线免费观看视频 | 成年人网站国产 | 亚洲国产精品久久久 | 日韩视频―中文字幕 | 欧美一区日韩一区 | 免费在线观看一区二区 | 日韩精品在线视频免费观看 | 中文字幕在线视频网站 |
