查看: 8369|回復(fù): 4
PIC單片機(jī)上實(shí)時(shí)時(shí)鐘PCF8563測(cè)試程序
ID:1 發(fā)表于 2014-6-12 20:53 | 顯示全部樓層 |閱讀模式
...............................PCF8563測(cè)試程序主函數(shù)............................
#include
#include "pcf8563.h"
#include "IIC.h"
__CONFIG(FOSC_INTOSC&WDTE_OFF&MCLRE_OFF);  //PIC配置位設(shè)置
void init_fosc()    //PIC內(nèi)部晶振設(shè)置
OSCCON=0x61;
...................在PCF8563.h頭文件里定義的結(jié)構(gòu)體.....................
struct Time
uchar second;
uchar minute;
uchar hour;
uchar day;
uchar week;
uchar month;
uchar year;
struct Time time;
init_fosc();
time.second=55;
time.minute=51;
time.hour=11;
time.day=2;
time.week=6;
time.month=4;
time.year=14;
P8563_Set_Time();   //PCF8563設(shè)置時(shí)間子函數(shù)
nop();nop();
P8563_Read_Time();//讀取PCF8563子程序
TRISB=0b00000000;
PORTB=~time.second;
uint n;
for(n=0;n<600;n++)
nop();
while(1);
...............................IIC通訊子程序.................................
#include
#include "IIC.h"
void start()   //IIC起始程序
TRISC5=0;   //SCL輸出
TRISC4=0;   //SDA輸出
    SDA_OUT=1;
    SCL_OUT=1;
nop();
SDA_OUT=0;
nop();      //大于4us
SCL_OUT=0;
void stop()  //IIC停止子程序
TRISC5=0;
TRISC4=0;
        SDA_OUT=0;
        SCL_OUT=1;
nop();        //大于4us
SDA_OUT=1;
TRISC4 = 1;   //  結(jié)束后釋放總線,sda輸入
uchar IIC_Get_Ack(void)   //檢測(cè)應(yīng)答信號(hào)
TRISC4=1;        //應(yīng)答信號(hào)由從機(jī)發(fā)出,所以SDA設(shè)為輸入
SCL_OUT=0;
SCL_OUT=1;
nop();
if(SDA_IN==1)    //讀取SDA狀態(tài)時(shí),SCL保持高電平
ACK=1;
ACK=0;
SCL_OUT=0;
return (ACK);
void IIC_Ack()           //主機(jī)向從機(jī)應(yīng)答,發(fā)送繼續(xù)信號(hào)
TRISC4=0;
TRISC5=0;
SDA_OUT=0;
        SCL_OUT=0;
SCL_OUT=1;
nop();            //大于4us
SCL_OUT=0;
SDA_OUT=1;
void IIC_NOAck()         //主機(jī)向從機(jī)非應(yīng)答,停止繼續(xù)讀取
TRISC4=0;
TRISC5=0;
SDA_OUT=1;
SCL_OUT=0;
SCL_OUT=1;
    nop();
SCL_OUT=0;
SDA_OUT=0;
void IIC_Write_Byte(uchar dat)     //發(fā)送一個(gè)字節(jié)
uchar bitcount=8;
do
TRISC4=0;
TRISC5=0;
if((dat&0x80)==0x80)       //dat最高位為1,SDA拉高;dat最高位為0,SDA拉低
SDA_OUT=1;
SDA_OUT=0;
SCL_OUT=0;
SCL_OUT=1;
nop();
SCL_OUT=0;       //SCL為低電平時(shí),允許SDA電平變化
dat=dat<<1;
bitcount--;
}while(bitcount);
TRISC4=1;
nop();nop();
uchar IIC_Read_Byte()            //接受一個(gè)字節(jié)
uchar temp1=0;
uchar bitcount1=8;
TRISC4=1;                //SDA設(shè)置為輸入
TRISC5=0;
do
SCL_OUT=0;
SCL_OUT=1;
nop();
if(SDA_IN)
temp1=temp1|0x01;    //如果SDA為1,則置高temp1最低位
temp1=temp1&0xfe;    //如果SDA為0,則置低temp1最低位
SCL_OUT=0;
if(bitcount1-1)
temp1=temp1<<1;
bitcount1--;
}while(bitcount1);
return (temp1);
................................PCF8563子程序.......................................
#include
#include "PCF8563.h"
#include "IIC.h"
struct DownCounter dcounter;
struct Time time;
uchar Val2BCD(uchar x)   //十進(jìn)制轉(zhuǎn)BCD碼子程序
return ((x/10)<<4)+((x)&0x0F);
uchar PCF8563_Write_Bytes(uchar addr,uchar length,uchar *pbuf)  //寫入子程序
uchar send_da;
uchar i=0;
start();
IIC_Write_Byte(0xA2);     //器件地址
do
}while(IIC_Get_Ack());
IIC_Write_Byte(0x02);    //器件讀取起始位
do
for(i=0;i
send_da=*(pbuf++);
IIC_Write_Byte(send_da);
do
stop();
nop();nop();
uchar PCF8563_Read_Bytes(uchar addr,uchar length,uchar *pbuf)  //PCF8563讀取子程序
uint receive_da;
uchar i=0;
start();
IIC_Write_Byte(0xa2);   //器件地址
do
IIC_Write_Byte(0x02);   //最小地址
do
start();
IIC_Write_Byte(0xa3);   //器件讀取地址
do
TRISC4=0;
while(length--)
receive_da=IIC_Read_Byte();
*(pbuf++)=receive_da;
IIC_Ack();
IIC_NOAck();
stop();
nop();nop();nop();nop();nop();nop();
return pbuf[i];
uchar P8563_Read_Time()   //PCF8563讀取時(shí)間子程序
uchar temp[7];
PCF8563_Read_Bytes(0x02,0x07,temp);
time.second=BCD2Val(temp[0]&0x7f);
time.minute=BCD2Val(temp[1]&0x7f);
time.hour=BCD2Val(temp[2]&0x1f);
time.day=BCD2Val(temp[3]&0x3f);
time.week=BCD2Val(temp[4]&0x07);
time.month=BCD2Val(temp[5]&0x1f);
time.year=BCD2Val(temp[6]);
return 0;
uchar BCD2Val(uchar x)   //BCD轉(zhuǎn)十進(jìn)制
return ((x>>4)&0x0f)*10+(x&0x0f);
uchar P8563_Set_Time()   //PCF8563設(shè)置時(shí)間子程序
uchar temp[7];
uchar i;
for(i=0;i<7;i++)
temp[i]=Val2BCD(((uchar *)(&time))[i]);
return PCF8563_Write_Bytes(0x02,7,temp);
uchar P8563_Set_DownCounter()
return PCF8563_Write_Bytes(0x0e,2,(uchar *)&dcounter);
uchar P8563_Read_DownCounter()
return PCF8563_Read_Bytes(0x0e,2,(uchar *)&dcounter);
相關(guān)帖子
ID:55838 發(fā)表于 2014-6-13 23:11 | 顯示全部樓層
感謝分享,收了學(xué)習(xí)學(xué)習(xí)
ID:105313 發(fā)表于 2016-2-16 12:29 來自觸屏版 | 顯示全部樓層
謝謝分享
ID:128391 發(fā)表于 2016-6-28 19:13 | 顯示全部樓層
謝謝大大的分享
ID:128391 發(fā)表于 2016-6-28 19:14 | 顯示全部樓層
謝謝大大的分享
主站蜘蛛池模板: 精品第一页 | 8090理论片午夜理伦片 | 欧美色图一区二区三区 | 综合av网 | 日韩一区二区三区在线 | 91欧美激情一区二区三区成人 | 97色婷婷 | 日本在线小视频 | 一级片欧美 | 一区二区视频在线 | 亚洲精品在 | 国产一级二级三级 | 欧美午夜精品久久久久免费视 | 91久久精品日日躁夜夜躁欧美 | 久草青青草| 永久免费看mv网站入口亚洲 | 久久精品福利 | 在线成人免费视频 | 国产嫩草视频 | 亚洲不卡视频 | 国产亚洲久一区二区 | 免费在线观看www | 午夜网站在线观看 | 一级片观看 | 免费av观看 | 免费三级网站 | 超碰91在线| 国产精品久久免费 | 免费的黄色网址 | 免费a在线观看 | 国产三级做爰高清在线 | 中文字幕在线观看免费 | 亚洲一区二区免费看 | 欧美精品在线视频 | 午夜影院在线 | 国产精品黄 | 久久久久免费视频 | 一级片黄色片 | 毛片aaa | 成人自拍视频在线观看 | 在线观看av不卡 |
