Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
entity dianzibiao is
Port(clk,key:in std_logic;
ww:out std_logic_vector(1 downto 0);
qqq:out std_logic_vector(3 downto 0);
Q:out std_logic_vector(6 downto 0));
end;
Architecture dzb of dianzibiao is
signal q1,q2,disp:std_logic_vector(3 downto 0);
signal tt:std_logic_vector(7 downto 0);
signal d1,d2,d3,d4,cp,c1,c2:std_logic;
signal t:std_logic_vector(25 downto 0);
begin
process(clk)
begin
if clk'event and clk='1' then t<=t+1;tt<=tt+1;
if t=19999999 then
t<="00000000000000000000000000";c1<='1';
else c1<='0';
end if;
end if;
end process;
process(c1)
begin
if c1'event and c1='1' then q1<=q1+1;
if q1=9 then q1<="0000";q2<=q2+1;
end if;
if q2=5 and q1=9 then q2<="0000";
end if;
end if;
end process;
process(q1,q2)
begin
if tt<128 then disp<=q1;ww<="01"; --位顯示1顯示,0不顯示
else disp<=q2;ww<="10";
end if;
end process;
process(disp)
begin
case disp is
when "0000"=>Q<="0000001"; --段碼顯示開發板共陽極,所以0顯示,1不顯示。
when "0001"=>Q<="1001111" ;
when "0010"=>Q<="0010010" ;
when "0011"=>Q<="0000110" ;
when "0100"=>Q<="1001100" ;
when "0101"=>Q<="0100100" ;
when "0110"=>Q<="0100000" ;
when "0111"=>Q<="0001111" ;
when "1000"=>Q<="0000000" ;
when "1001"=>Q<="0000100" ;
when others=>null;
end case;
end process;
end;
