查看: 4556|回復(fù): 0
VHDL數(shù)組
ID:51269 發(fā)表于 2014-11-10 15:13 | 顯示全部樓層 |閱讀模式
Library ieee;
use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
entity ddd is
port(clk:in std_logic;
     sec:out std_logic;
     Q:out std_logic_vector(17 downto 0));
end ;
Architecture dd of ddd is
   type ram2 is array(0 to 59) of std_logic_vector(17 downto 0);
   constant cgram:ram2:=(
          ("100000000000000001"),
          ("110000000000000011"),
          ("111000000000000111"),
          ("111100000000001111"),
          ("111110000000011111"),
          ("111111000000111111"),
          ("111111100001111111"),
          ("111111110011111111"),
          ("111111111111111111"),
          ("010000000000000010"),
          ("001000000000000100"),
          ("000100000000001000"),
          ("000010000000010000"),
          ("000001000000100000"),
          ("000000100001000000"),
          ("000000010010000000"),
          ("000000001100000000"),
          ("100000000000000000"),
          ("010000000000000000"),
         ("001000000000000000"),
         ("000100000000000000"),
         ("000010000000000000"),
         ("000001000000000000"),
         ("000000100000000000"),
          ("000000010000000000"),
          ("000000001000000000"),
    ("000000000100000000"),
    ("000000000010000000"),
    ("000000000001000000"),
    ("000000000000100000"),
    ("000000000000010000"),
    ("000000000000001000"),
          ("000000000000000100"),
    ("000000000000000010"),
    ("000000000000000001"),
    ("100000000000000000"));
signal cp:std_logic;
signal ww:integer range 0 to 5000000;
signal cnt:integer range 0 to 59;
begin
process(clk)
   begin
   if clk'event and clk='1' then
       ww<=ww+1;
    if ww=0 then
       cp<=not cp;
   end if;
   end if;
   end process;
  process(cp)
  begin
    if cp'event and cp='1' then
     cnt<=cnt+1;
   Q<=cgram(cnt);
   end if;
  end process;
end;
Library ieee;
entity ddd is
     sec:out std_logic;
end ;
   type ram2 is array(0 to 55) of std_logic_vector(19 downto 0);
--用16進(jìn)制表示數(shù)X“2f”,每個數(shù)字代表四位二進(jìn)制,等于“00101111”
      (X"20001"),(X"30003"),(X"38007"),(X"3c00f"),(X"3e01f"),
  (X"3f03f"),(X"3f87f"),(X"3fcff"),(X"3ffff"),(X"3fcff"),
  (X"3f87f"),(X"3f03f"),(X"3e01f"),(X"3c00f"),(X"38007"),
  (X"30003"),(X"20001"),(X"00000"),(X"20000"),(X"10000"),
  (X"08000"),(X"04000"),(X"02000"),(X"01000"),(X"00800"),
  (X"00400"),(X"00200"),(X"00100"),(X"00080"),(X"00040"),
  (X"00020"),(X"00010"),(X"00008"),(X"00004"),(X"00002"),
  (X"00001"),(X"00000"),(X"00001"),(X"00002"),(X"00004"),
      (X"00008"),(X"00010"),(X"00020"),(X"00040"),(X"00080"),
  (X"00100"),(X"00200"),(X"00400"),(X"00800"),(X"01000"),
  (X"02000"),(X"04000"),(X"08000"),(X"10000"),(X"20000"),
  (X"00000")
    type ram1 is array(0 to 5) of std_logic_vector(5 downto 0);
   constant dat:ram1:=(
--用8進(jìn)制表示數(shù)O“235”,每個數(shù)字代表三位二進(jìn)制數(shù),等于“010 011 101“
     (o"01"),(o"02"),(O"04"),(o"10"),(o"20"),(o"40")
signal ww:integer range 0 to 1000000;
signal cnt:integer range 0 to 55;
begin
process(clk)
   begin
       ww<=ww+1;
    if ww=0 then
       cp<=not cp;
   end if;
   end if;
   end process;
  process(cp)
  begin
     cnt<=cnt+1;
   Q<=cgram(cnt)(17 downto 0);
   end if;
  end process;
end;
主站蜘蛛池模板: 青草视频网站 | 中国a一片一级一片 | 亚洲最大av网站 | 在线精品一区 | 免费在线观看黄 | 影音先锋国产精品 | 青青青草视频 | 色激情网 | 夜夜操夜夜爽 | 欧美日韩一区二区三区视频 | 黄色一级免费看 | 免费看a级片| 永久免费看mv网站入口亚洲 | 欧美成人免费 | 97视频免费在线观看 | 黄色片91 | 午夜专区| 国产精品视频一区二区三区 | 久久九九免费视频 | 精品热久久 | 欧美日韩国产中文 | 九九在线视频 | 九九在线| 中文字幕av一区 | 91成人免费| av在线播放免费 | 久久久久国产精品视频 | 日韩精品视频在线 | 国产香蕉在线观看 | 午夜av在线 | 成年免费视频黄网站在线观看 | 亚洲国产三级 | 日韩视频免费大全中文字幕 | 狠狠草视频 | 亚洲精品中文字幕乱码三区91 | 日本成人一区二区三区 | 欧美三级韩国三级日本三斤在线观看 | 四虎影视在线 | 日韩在线观看中文字幕 | 天天摸天天爽 | 一级免费片 |
