查看: 14582|回復: 9
SI4730 收音機芯片資料與程序
ID:72519 發表于 2015-1-20 15:33 | 顯示全部樓層 |閱讀模式
在網上看到關于這個SI4730的收音機芯片的資料比較少,所以現在特發上來,共有緣人參考,
如有不對之處,請指出。!!
由于時間倉促,自動搜臺就沒有編寫,望有緣人寫好后發上來分享。!!!!
晶振:24MHz
單片機:at89s52
注:轉載請注明出處,否則追究法律責任!!!
日期:2010-03-06
版本:v1.0
設計者:sws
#include"reg52.h"
#include"intrins.h"
typedef unsigned char uchar;
typedef unsigned int uint;
#define HIGH 1
#define LOW 0
#define SI4730_HIGH    //4730選擇地址定義
//#define SI4730_LOW
#define Max_freq_FM 10800      //108MHz
#define Min_freq_FM 8750   //87.5MHz
#define max_freq_AM 1701 //1701KHz
#define min_freq_AM 531
#define    FM_RECEIVER 0x20 //FM調諧頻率 page.52
#define    FM_TRNSMITTER 0x30
#define    AM_RECEIVER 0x40 //AM調諧頻率
#define    TX_TUNE_MEASURE 0x32
uint Frequency_fm=875;
uint Frequency_am=531;
bit Mode = 0;
sbit KEY_UP = P2^2;   //向上搜臺
sbit KEY_DW = P2^3;   //向下搜臺
sbit FM_AM_Choose = P2^4; //FM與AM選擇
bit FM_AM_ = 0;
START condition:
SCLK: -----------|______
SDIO:-----|_____________
       1 |   2 | 3
STOP condition:
SCLK: ____|--------------
SDIO:____________|-------
1 | 2   |   3
DATA:
SCLK:_______________|---|________|----|_______
SDIO:___________|------------|____________|----
RESET:
SENB:__|---------------------------------------------
SDIO:_________________________________________|------
RST: ___________|------------------------------------
SCLK:__|---------------------------------------------
       |    1    |      2               |   3
sbit Si4730_Reset = P1^3;
sbit Si4730_SCLK = P1^2;
sbit Si4730_SDIO = P1^1;
//如果SI4730的第六腳(SEN)接高電平那么地址是0x23,0x22
//如果SI4730的第六腳(SEN)接低電平那么地址是0xc7,0xc6
//#if 0 //address switch
#ifdef SI4730_LOW
#define READ_ADDR   0x23
#define WRITE_ADDR 0x22
#endif
#ifdef SI4730_HIGH
#define READ_ADDR   0xc7
#define WRITE_ADDR 0xc6
#endif
#define SCLK_HIGH Si4730_SCLK = HIGH
#define SCLK_LOW Si4730_SCLK = LOW
#define SDIO_HIGH Si4730_SDIO = HIGH
#define SDIO_LOW Si4730_SDIO = LOW
#define READ_SDIO Si4730_SDIO
//===============FM START===================
void _NOP()
_nop_();_nop_();
_nop_();_nop_();
_nop_();_nop_();
void Si4730_Delay(unsigned char k)
uchar i,j;
for(i=150;i>0;i--)
   for(j=k;j>0;j--);
#define I2C_CLK_Delay() _NOP()
void ResetSi47XX_2w()
   Si4730_Reset = LOW;
   SCLK_HIGH;
   Si4730_Delay(100);
   SDIO_HIGH;
   Si4730_Delay(250);
   Si4730_Reset = HIGH;
void Si4730_start()
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_ack()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
    I2C_CLK_Delay();
    SDIO_HIGH;
void Si4730_stop()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_writebyte(uchar write_data)
uchar i;
for(i=8;i!=0;i--)    // 循環移入8個位
   READ_SDIO = (bit)(write_data & 0x80);
   SCLK_HIGH;
   I2C_CLK_Delay();
   SCLK_LOW; //SDA數據線上數據變化
   write_data <<= 1;   //調整發送位
void Operation_Si4730_Write(uchar *data1,uchar numByte)
uchar j;
Si4730_start();
Si4730_writebyte(WRITE_ADDR);//器件地址 0xc6
Si4730_ack();
I2C_CLK_Delay();
for(j=LOW;j<numByte;j++,*data1++)
   Si4730_writebyte(*data1);
   Si4730_ack();
   I2C_CLK_Delay();
Si4730_stop(); //發送結束
void Si4730_Power_Up_FM_AM_Choose(unsigned char mod) //fm,am選擇
unsigned char write_buf[3]={0x01,0xd0,0x05};
switch(mod)
   case FM_RECEIVER:        //si4730
      write_buf[1] = 0xd0; //使用時鐘晶振,32.768khz ,FM模式
      write_buf[2] = 0x05; //模擬L/R輸出
      break;
     case AM_RECEIVER:           //si4730
       write_buf[1] = 0xd1; //使用時鐘晶振,32.768khz ,AM模式
       break;
Operation_Si4730_Write(&(write_buf[0]), 3);//need wait >=300mS
Si4730_Delay(250);
Si4730_Delay(250);
Si4730_Delay(120);
void Si4730_Tune(char mod,unsigned short Channel_Freq)
unsigned char write_buf[5];
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[2] = Channel_Freq >> 8;   //寫入高字節
write_buf[3] = Channel_Freq;     //寫入低字節
write_buf[4]= 0x00;
   Operation_Si4730_Write(&(write_buf[0]), 5);
void Search_FM()   //調用手動FM 頻率調整子程序 menu = 15
   if(Mode)
    Frequency_fm += 10;   //步進+0.1MHz
    if(Frequency_fm > Max_freq_FM)
     Frequency_fm = Min_freq_FM;
    Frequency_fm -= 10;   //步進-0.1MHz
    if(Frequency_fm < Min_freq_FM)
     Frequency_fm = Max_freq_FM;
// Si4730_Power_Up(FM_RECEIVER); //向上搜臺
Si4730_Tune(FM_RECEIVER,Frequency_fm); //FM收音芯片數據刷新一次
//=================fm end============
//===============am start==============
void Si4730_Tune_AM(char mod,unsigned short Channel_Freq)
unsigned char write_buf[6];
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
write_buf[5]= 0x00;
   Operation_Si4730_Write(&(write_buf[0]), 6);
void Search_AM()   //調用手動FM 頻率調整子程序 menu = 95
   if(Mode)
    Frequency_am += 9;   //步進+9KHz
    if(Frequency_am > max_freq_AM)
     Frequency_am = min_freq_AM;
    Frequency_am -= 9;   //步進-9KHz
    if(Frequency_am < min_freq_AM)
     Frequency_am = max_freq_AM;
// Si4730_Power_Up(AM_RECEIVER); //向上搜臺
Si4730_Tune_AM(AM_RECEIVER,Frequency_am); //AM收音芯片數據刷新一次
//=======================am end========================
//==============main start=======================
ResetSi47XX_2w();
Si4730_Delay(250);
   if(!FM_AM_Choose)
    Si4730_Delay(100);
    if(!FM_AM_Choose)
      FM_AM_ = ~FM_AM_;
      if(!FM_AM_)
         Si4730_Power_Up_FM_AM_Choose(FM_RECEIVER); //fm選擇
      else if(FM_AM_)
         Si4730_Power_Up_FM_AM_Choose(AM_RECEIVER ); //am選擇
    if(!FM_AM_)
   // ResetSi47XX_2w();
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜臺
      Search_FM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜臺
      Search_FM();
    else if(FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜臺
      Search_AM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜臺
      Search_AM();
//=================main end=====================
ID:71523 發表于 2015-1-20 16:02 | 顯示全部樓層
這個沒有顯示頻率的,我不會加上顯示頻率,用的是1602,
ID:71523 發表于 2015-1-20 16:08 | 顯示全部樓層
include"reg52.h"
#include"intrins.h"
#include "LCD1602_4w.h"
#define HIGH 1
#define LOW 0
bit Mode = 0;
bit FM_AM_ = 0;
//LCD1602_4w
sbit LCD_RS = P1^0;
sbit LCD_RW = P1^1;
sbit LCD_EP = P1^2;
#define LCD_EN  LCD_EP
#define LCD_DATA    P0
START condition:
       1 |   2 | 3
STOP condition:
1 | 2   |   3
DATA:
RESET:
       |    1    |      2               |   3
#ifdef SI4730_LOW
#endif
#ifdef SI4730_HIGH
#endif
void _NOP()
_nop_();_nop_();
_nop_();_nop_();
_nop_();_nop_();
uchar i,j;
for(i=150;i>0;i--)
   for(j=k;j>0;j--);
   Si4730_Reset = LOW;
   SCLK_HIGH;
   Si4730_Delay(100);
   SDIO_HIGH;
   Si4730_Delay(250);
void Si4730_start()
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_ack()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
    I2C_CLK_Delay();
    SDIO_HIGH;
void Si4730_stop()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
uchar i;
   SCLK_HIGH;
   I2C_CLK_Delay();
uchar j;
Si4730_start();
Si4730_ack();
I2C_CLK_Delay();
   Si4730_ack();
   I2C_CLK_Delay();
switch(mod)
      break;
       break;
Si4730_Delay(250);
Si4730_Delay(250);
Si4730_Delay(120);
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
   if(Mode)
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
write_buf[5]= 0x00;
   if(Mode)
ResetSi47XX_2w();
Si4730_Delay(250);
   if(!FM_AM_Choose)
    Si4730_Delay(100);
    if(!FM_AM_Choose)
      FM_AM_ = ~FM_AM_;
      if(!FM_AM_)
      else if(FM_AM_)
    if(!FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜臺
      Search_FM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜臺
      Search_FM();
    else if(FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜臺
      Search_AM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜臺
      Search_AM();
新建文件夾 (3).rar (5.93 KB, 下載次數: 74)
先不管1602怎么定義接MCU,現在報錯,說什么沒定義,你幫看一下
ID:71523 發表于 2015-1-20 16:11 | 顯示全部樓層
我只是你這程序加上#include "LCD1602_4w.h",然后加上1602的接線定義后翻譯出錯,請求版主大家幫看一下,怎么樣在你發的程序上加上頻率顯示,MCU你可隨便定義,我改就行,期盼你的回復
ID:75609 發表于 2015-3-29 15:02 | 顯示全部樓層
我現在也要做si4730收音機,一起努力吧
ID:88407 發表于 2015-8-16 00:13 | 顯示全部樓層
好東西,學習,學習,
ID:229361 發表于 2019-1-10 16:35 | 顯示全部樓層
好東西,學習,學習,
ID:403593 發表于 2019-11-8 08:59 | 顯示全部樓層
正在找它的資料,感謝分享!
ID:166475 發表于 2021-11-8 12:24 來自觸屏版 | 顯示全部樓層
timer.h:  #ifndef __TIMER_H_  #define __TIMER_H_  //如果外部需要使用這些變量或函數,直接包含頭文件即可。  //如果不對外開放的函數,就不需要添加  //注:在C源文件中,函數聲明要補全  extern int timerCnt;  extern int timerStatu;  extern void TimerStart();  extern void TimerStop();  extern void TimerInit();  #endif
ID:838732 發表于 2024-9-23 21:34 | 顯示全部樓層
這個程序用不了哦
主站蜘蛛池模板: 91在线精品秘密一区二区 | 国产乱淫av | 亚洲精品视频在线 | 最新理论片 | 久久久97| 青草视频网站 | 免费三片在线观看网站v888 | 日韩av一级片 | 国产永久视频 | av动漫在线观看 | 精品久久久久久久久久久久久久 | 精品欧美在线 | 亚洲狠狠 | 日韩欧美一级片 | 欧美一区二区三区的 | 久久九九精品 | 欧美日韩国产在线 | 天天射av| 伊人久久精品 | 亚洲欧洲综合 | 国产理论片| 成人黄色免费视频 | 亚洲国产天堂 | 97精品国产露脸对白 | 97在线视频免费观看 | 欧美一级视频 | 少妇在线 | 日韩网站免费观看 | 一级特黄aaaaaa大片 | 午夜视频免费 | 青青视频网 | 欧美美女一区二区 | 欧美国产激情 | 欧美日韩国产三级 | 青娱乐福利视频 | 日韩免费在线 | 男女激情视频网站 | 亚洲三级在线观看 | 天堂а√在线中文在线新版 | 黄色三级视频在线观看 | 四虎影院最新网址 |
