是用51hei單片機開發板 電路圖詳見:http://m.zg4o1577.cn/f/51hei-5.pdf 的數碼管部分, 用2個74hc573 鎖存,p0口作為數據口 ,p3.6和p3.7分別是段和位的鎖存端口. p2口上面有按鍵 詳見程序的定義:- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit D=P3^6;
- sbit V=P3^7;
- uchar ACT[4]={0xfe,0xfd,0xfb,0xf7};
- uchar data shuzu[4];
- uchar status;
- uchar temp,f;
- void delay_1ms(void)
- uint k;
- for(k=0;k<121;k++);
- void dis_all(void)
- D=1;P0=SEG7[shuzu[0]];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay_1ms();
- D=1;P0=SEG7[shuzu[1]];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay_1ms();
- D=1;P0=SEG7[shuzu[2]];D=0;P0=0xff;V=1;P0=ACT[1];V=0;delay_1ms();
- D=1;P0=SEG7[shuzu[3]];D=0;P0=0xff;V=1;P0=ACT[0];V=0;delay_1ms();
- void dis_shuzu0(void)
- D=1;P0=SEG7[f];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay_1ms();
- void dis_shuzu1(void)
- D=1;P0=SEG7[f];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay_1ms();
- void dis_shuzu2(void)
- D=1;P0=SEG7[f];D=0;P0=0xff;V=1;P0=ACT[1];V=0;delay_1ms();
- void dis_shuzu3(void)
- D=1;P0=SEG7[f];D=0;P0=0xff;V=1;P0=ACT[0];V=0;delay_1ms();
- void key_s1(void)
- P2=0xff;
- if(P2==0xbf)
- {if(temp>50)temp=0;
- if(temp==0)f++;
- if(f>9)f=0;
- temp++;
- delay_1ms();
- void key_s2(void)
- P2=0xff;
- if(P2==0x7f)
- switch (status)
- case 1:shuzu[0]=f;break;
- case 2:shuzu[1]=f;break;
- case 3:shuzu[2]=f;break;
- case 4:shuzu[3]=f;break;
- default:break;
- void key_s4(void)
- P2=0xff;
- if(P2==0xdf)
- if(temp==0)status++;
- if(status>4)status=0;
- temp++;
- delay_1ms();
- void main(void)
- while(1)
- key_s1();
- key_s2();
- key_s4();
- switch (status)
- case 0:dis_all();break;
- case 1:dis_shuzu0();break;
- case 2:dis_shuzu1();break;
- case 3:dis_shuzu2();break;
- case 4:dis_shuzu3();break;
- default:break;
