查看: 4536|回復: 0
計數器——VHDL源碼
ID:72519 發表于 2015-1-23 21:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本來這段代碼早就應該公布了的,可是我直到昨天才在開發板上進行調試,剛開始調試結果不是我想要的結果,不過仔細跟住結果想一下就找到問題所在,并很快解決調試通過,呵呵,挺高興的。這段代碼中是循環掃描數碼管位,所以最后一個文件是一個譯碼的文件,中間是進行按鍵處理并顯示的文件,第一個文件是將譯碼和按鍵處理顯示的例化文件啦。
///////////////cout10.vhd文件
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity cout10 is
port(
        clk_in,rest_in:in std_logic;
        clk_key_in:in std_logic;--按鍵
        clk_md_in:in std_logic_vector(2 downto 0);--加模式位--000 加1 --001 加10 010 加100 011 加1000
        bt_out:out std_logic_vector(3 downto 0);--數碼管位選
        cout:out std_logic_vector(6 downto 0)
end;
architecture lammy02 of cout10 is
        component showled
                port(
                        indata:in std_logic_vector(3 downto 0);
                        outdata:out std_logic_vector(6 downto 0)
        end component showled;
        component cnt10
                port(
                        rest,clk:in std_logic;
                        clk_key:in std_logic;--按鍵
                        clk_md:in std_logic_vector(2 downto 0);--加模式位--000 加1 --001 加10 010 加100 011 加1000
                        bt:out std_logic_vector(3 downto 0);--數碼管位選
                        cout1:out std_logic_vector(3 downto 0)--個位
        end component cnt10;
                        signal d_cout1:std_logic_vector(3 downto 0);
        begin
                u1: cnt10 port map (clk=>clk_in,rest=>rest_in,clk_key=>clk_key_in,clk_md=>clk_md_in,bt=>bt_out,cout1=>d_cout1);
                u2: showled port map (indata=>d_cout1,outdata=>cout);
end;
/////////////////////showled.vhd
library ieee;
entity showled is
port(
end;
architecture lammy01 of showled is
--signal in_data:std_logic_vector(3 downto 0);
begin
        process(indata)
        begin
                case indata is
                when "0000" => outdata<="0111111";--0
                when "0001" => outdata<="0000110";--1
                when "0010" => outdata<="1011011";--2
                when "0011" => outdata<="1001111";--3
                when "0100" => outdata<="1100110";--4
                when "0101" => outdata<="1101101";--5
                when "0110" => outdata<="1111101";--6
                when "0111" => outdata<="0000111";--7
                when "1000" => outdata<="1111111";--8
                when "1001" => outdata<="1101111";--9
                when others => null;
                end case;
        end process;
end;
///////////////cnt10.vhd
library ieee;
entity cnt10 is
port(
end;
architecture lammy02 of cnt10 is
        type state is(s0,s1,s2,s3);
        signal led_state:state;
        signal outdata_1,outdata_2,outdata_3,outdata_4:std_logic_vector(3 downto 0):="0000";
begin
lammy_01:process(rest,clk,led_state)
        begin
                if rest='1' then cout1<="0000";led_state<=s0;
                elsif clk'event and clk='1' then
                case led_state is
                        when s0 => bt<="1000";cout1<=outdata_1;led_state<=s1;
                        when s1 => bt<="0100";cout1<=outdata_2;led_state<=s2;
                        when s2 => bt<="0010";cout1<=outdata_3;led_state<=s3;
                        when s3 => bt<="0001";cout1<=outdata_4;led_state<=s0;
                end case;
                end if;
        end process;
lammy_02:process(clk_key)
        variable cout_1,cout_2,cout_3,cout_4:std_logic_vector(3 downto 0);
        begin
                if rising_edge(clk_key) then
                        if clk_md="000" then
                                if cout_1="1001" and cout_2="1001" and cout_3="1001" and cout_4="1001"
                                        then cout_1:="1001" ; cout_2:="1001" ; cout_3:="1001" ; cout_4:="1001";
                                        elsif cout_1="1001" and cout_2="1001" and cout_3="1001" then cout_4:=cout_4+1;cout_1:="0000";cout_2:="0000";cout_3:="0000";
                                                elsif cout_1="1001" and cout_2="1001" then cout_3:=cout_3+1;cout_1:="0000";cout_2:="0000";
                                                        elsif cout_1="1001" then cout_2:=cout_2+1;cout_1:="0000";
        else cout_1:=cout_1+1;
                                end if;
                        elsif clk_md="001" then
                                if cout_2="1001" and cout_3="1001" and cout_4="1001"
                                        then cout_2:="1001" ; cout_3:="1001" ; cout_4:="1001";
                                        elsif cout_2="1001" and cout_3="1001" then cout_4:=cout_4+1;cout_2:="0000";cout_3:="0000";
                                                elsif cout_2="1001" then cout_3:=cout_3+1; cout_2:="0000";
                                                else cout_2:=cout_2+1;
                                end if;
                        elsif clk_md="010" then
                                if cout_3="1001" and cout_4="1001"
                                        then cout_3:="1001" ; cout_4:="1001";
                                        elsif cout_3="1001" then cout_4:=cout_4+1;cout_3:="0000";
                                        else cout_3:=cout_3+1;
                                end if;
                        elsif clk_md="011" then
                                if cout_4="1001" then cout_4:="1001";
                                else cout_4:=cout_4+1;
                                end if;
                        end if;
                end if;
                outdata_1<=cout_1;
                outdata_2<=cout_2;
                outdata_3<=cout_3;
                outdata_4<=cout_4;
        end process;
end;
主站蜘蛛池模板: av一区二区三区在线观看 | 亚洲精品久久久久久久久久久 | 久草综合网 | 亚洲精品少妇 | 夜夜骑夜夜操 | 黄色一节片| 欧洲精品一区二区三区 | 国产精品国产三级国产 | 久久中文网 | 国产欧美在线观看 | av片免费 | 欧美一级片免费看 | 日韩中文字幕视频 | 综合色在线 | 婷婷久久五月天 | 人人草av| 亚洲无av在线中文字幕 | 精品久久国产 | 日本一区二区不卡 | 日本少妇中文字幕 | 一区二区三区在线播放 | 欧美国产日韩一区二区 | 日韩精品一区二区在线 | 五月天网址| 中文字幕av在线播放 | 久久久久亚洲精品 | 99久久婷婷国产综合精品草原 | 久久久在线 | 日韩一区二区三 | 91色国产 | 欧美视频在线一区 | 成人免费看片 | 在线观看免费毛片 | 色综合99| 久久色av| 欧美一级精品 | 成人一区二区三区 | 黑人精品xxx一区一二区 | 亚洲精品乱码久久久久久 | 午夜快播 | 一区视频在线 |
