查看: 6366|回復: 0
LPC11xx單片機系統配置_system_LPC11xx.c
ID:73735 發表于 2015-2-18 23:07 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
* @file:    system_LPC11xx.c
* @purpose: CMSIS Cortex-M0 Device Peripheral Access Layer Source File
*           for the NXP LPC11xx Device Series
* @version: V1.0
* @date:    26. Nov. 2008
* Copyright (C) 2008 ARM Limited. All rights reserved.
* ARM Limited (ARM) is supplying this software for use with Cortex-M3
* processor based microcontrollers.  This file can be freely distributed
* within development tools that are supporting such ARM based processors.
* THIS SOFTWARE IS PROVIDED "AS IS".  NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#include <stdint.h>
#include "LPC11xx.h"
//-------- <<< Use Configuration Wizard in Context Menu >>> ------------------
/*--------------------- Clock Configuration ----------------------------------
// <e> Clock Configuration
//   <h> System Controls and Status Register (SCS)
//     <o1.4>    OSCRANGE: Main Oscillator Range Select
//                     <0=>  1 MHz to 20 MHz
//                     <1=> 15 MHz to 24 MHz
//     <e1.5>       OSCEN: Main Oscillator Enable
//     </e>
//   </h>
//   <h> Clock Source Select Register (CLKSRCSEL)
//     <o2.0..1>   CLKSRC: PLL Clock Source Selection
//                     <0=> Internal RC oscillator
//                     <1=> Main oscillator
//                     <2=> RTC oscillator
//   </h>
//   <e3> PLL0 Configuration (Main PLL)
//     <h> PLL0 Configuration Register (PLL0CFG)
//                     <i> F_cco0 = (2 * M * F_in) / N
//                     <i> F_in must be in the range of 32 kHz to 50 MHz
//                     <i> F_cco0 must be in the range of 275 MHz to 550 MHz
//       <o4.0..14>  MSEL: PLL Multiplier Selection
//                     <6-32768><#-1>
//                     <i> M Value
//       <o4.16..23> NSEL: PLL Divider Selection
//                     <1-256><#-1>
//                     <i> N Value
//     </h>
//   </e>
//   <h> CPU Clock Configuration Register (CCLKCFG)
//     <o7.0..7>  CCLKSEL: Divide Value for CPU Clock from PLL0
//                     <0-255>
//                     <i> Divide is CCLKSEL + 1. Only 0 and odd values are valid.
//   </h>
// </e>
#define CLOCK_SETUP           0
#define MAIN_PLL_SETUP        0
#define MAIN_CLKSRCSEL_Val    0x00000001
#define MAIN_PLL_M_Val        0x00000003
#define MAIN_PLL_P_Val        0x00000001
#define SYS_AHB_DIV_Val       1                        /* 1 through 255, typical is 1 or 2 or 4 */
//-------- <<< end of configuration section >>> ------------------------------
  DEFINES
  Define clocks
#define XTAL        (12000000UL)        /* Oscillator frequency               */
#define OSC_CLK     (      XTAL)        /* Main oscillator frequency          */
#define IRC_OSC     (12000000UL)        /* Internal RC oscillator frequency   */
#define WDT_OSC     (  250000UL)        /* WDT oscillator frequency           */
  Clock Variable definitions
uint32_t ClockSource = IRC_OSC;
uint32_t SystemFrequency = IRC_OSC; /*!< System Clock Frequency (Core Clock)  */
uint32_t SystemAHBFrequency = IRC_OSC;
* Misc. clock generation modules
* @param  none
* @return none
* @brief  Setup the microcontroller system.
*         Initialize the System and update the SystemFrequency variable.
void Main_PLL_Setup ( void )
  uint32_t regVal;
  ClockSource = OSC_CLK;
  LPC_SYSCON->SYSPLLCLKSEL = MAIN_CLKSRCSEL_Val;   /* Select system OSC--PLL時鐘源選中系統振蕩器 */
  LPC_SYSCON->SYSPLLCLKUEN = 0x01;                 /* Update clock source */
  LPC_SYSCON->SYSPLLCLKUEN = 0x00;                 /* toggle Update register once */
  while ( !(LPC_SYSCON->SYSPLLCLKUEN & 0x01) );    /* Wait until updated 等待系統振蕩器鎖定*/
  regVal = LPC_SYSCON->SYSPLLCTRL;
  regVal &= ~0x1FF;
  LPC_SYSCON->SYSPLLCTRL = (regVal | (MAIN_PLL_P_Val<<5) | MAIN_PLL_M_Val);/* P=1, M=4 */
  /* Enable main system PLL, main system PLL bit 7 in PDRUNCFG. */
  LPC_SYSCON->PDRUNCFG &= ~(0x1<<7);              /* PDRUNCFG第七位寫0,即系統PLL上電 */
  while ( !(LPC_SYSCON->SYSPLLSTAT & 0x01) );            /* Wait until it's locked */
  LPC_SYSCON->MAINCLKSEL = 0x01;                              /* Select PLL clock output--選擇PLL輸出作為主時鐘 */
  LPC_SYSCON->MAINCLKUEN = 0x01;                              /* Update MCLK clock source --允許更新主時鐘*/
  LPC_SYSCON->MAINCLKUEN = 0x00;                              /* Toggle update register once */
  while ( !(LPC_SYSCON->MAINCLKUEN & 0x01) );            /* Wait until updated 等待主時鐘鎖定*/
  LPC_SYSCON->SYSAHBCLKDIV = SYS_AHB_DIV_Val;            /* SYS AHB clock, typical is 1 or 2 or 4 --SYSAHBCLKDIV的值為1,即不分頻 AHB時鐘為12*4=48MHz*/
#if MAIN_PLL_SETUP
  SystemFrequency = ClockSource * (MAIN_PLL_M_Val+1);    /*系統時鐘=時鐘源*4MHz*/
#else
  SystemFrequency = ClockSource;
#endif
  SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val);   /*AHB時鐘=系統時鐘/AHB分頻值*/
  return;
* Initialize the system
* @param  none
* @return none
void SystemInit (void)  /* 復位之后,LPC111x會根據內部12MHz RC振蕩器的頻率運行,直到頻率被軟件切換 */
  //uint32_t i;
#ifdef __DEBUG_RAM
  LPC_SYSCON->SYSMEMREMAP = 0x1;                /* remap to internal RAM */
#else
#ifdef __DEBUG_FLASH
  LPC_SYSCON->SYSMEMREMAP = 0x2;                /* remap to internal flash */
#endif
#endif
#if (CLOCK_SETUP)                       /* Clock Setup */
  /* bit 0 default is crystal bypass,
  bit1 0=0~20Mhz crystal input, 1=15~50Mhz crystal input. */
  LPC_SYSCON->SYSOSCCTRL = 0x01;
  /* main system OSC run is cleared, bit 5 in PDRUNCFG register */
  LPC_SYSCON->PDRUNCFG &= ~(0x1<<5);    /* PDRUNCFG的第五位寫0,即系統振蕩器上電 */
  /* Wait 200us for OSC to be stablized, no status indication, dummy wait. */
  for ( i = 0; i < 0x100; i++ );
#if (MAIN_PLL_SETUP)
  Main_PLL_Setup();
#endif
#endif        /* endif CLOCK_SETUP */
  /* System clock to the IOCON needs to be enabled or most of the I/O related peripherals won't work. */
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<16);                  //使能IO配置模塊的時鐘
        LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);                   //開啟定時器Timer16_1時鐘
        LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5);                   //開啟I2C模塊時鐘
        SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val);  /*AHB時鐘=系統時鐘/AHB分頻值 = 3MHz,AHB時鐘對內核及存儲器和外設分配時鐘*/
  return;
主站蜘蛛池模板: 一级黄色大片 | 精品乱子伦一区二区三区 | 五月天婷婷综合 | 久久手机免费视频 | 日本精品在线观看 | 狠狠做深爱婷婷综合一区 | av毛片在线播放 | www.色网 | a级片免费观看 | 三级黄色在线观看 | 亚洲欧美日韩一区二区 | av观看网站 | 综合色av | 国产精品99999| 亚洲h视频 | 国产对白videos麻豆高潮 | 日韩精品视频免费在线观看 | 国产三级在线看 | 无遮挡在线观看 | 四虎在线观看 | 午夜成人影片 | 神马午夜视频 | 天天cao| 色黄大色黄女片免费中国 | 欧美日韩精品 | www日韩| 日本不卡在线视频 | 中文字幕在线观看免费视频 | 99精品欧美一区二区蜜桃免费 | 色综合色综合 | 日韩av不卡在线 | 国产精品美女久久久久久久久 | 亚洲91av | 大香蕉毛片| 真实人妻互换毛片视频 | 亚洲va视频| 日韩午夜精品 | 成人午夜精品 | 午夜88| 538精品视频 | 激情高潮到大叫狂喷水 |
