查看: 9886|回復: 3
STM32單片機進入和退出睡眠模式程序
ID:73735 發表于 2015-2-19 00:16 | 顯示全部樓層 |閱讀模式
main.c
#include "stm32f10x_lib.h"
#include "hw_conf.h"
#include "main.h"
extern vu32 TimingDelay;
void Delay(vu32 nTime);
int main(void)
# ifdef DEBUG
  debug();
#endif
  Setup_System();
  GPIO_SetBits(GPIOC,GPIO_Pin_4);
  GPIO_ResetBits(GPIOC,GPIO_Pin_5);
  Delay(2000);
  RTC_ClearFlag(RTC_FLAG_SEC);
  while(RTC_GetFlagStatus(RTC_FLAG_SEC)==RESET);
  RTC_SetAlarm(RTC_GetCounter()+3);
  RTC_WaitForLastTask();
  GPIO_SetBits(GPIOC,GPIO_Pin_5);
  GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  PWR_EnterSTOPMode(PWR_Regulator_ON, PWR_STOPEntry_WFI);
  SYSCLKConfig_STOP();
SysTick_CounterCmd(SysTick_Counter_Enable);
TimingDelay = nTime;
while(TimingDelay !=0);
SysTick_CounterCmd(SysTick_Counter_Disable);
SysTick_CounterCmd(SysTick_Counter_Clear);
#ifdef DEBUG
void assert_failed(u8* file,u32 line)
  printf("wrong parameters value:file %s on line %d\r\n",file,line);
#endif
hw_conf.c
#include"stm32f10x_lib.h"
#include "main.h"
ErrorStatus HSEStartUpStatus;
void RCC_Configuration(void)
   RCC_DeInit();
   RCC_HSEConfig(RCC_HSE_ON);
   HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus==SUCCESS)
   RCC_HCLKConfig(RCC_SYSCLK_Div1);
   RCC_PCLK2Config(RCC_HCLK_Div1);
   RCC_PCLK1Config(RCC_HCLK_Div2);
   FLASH_SetLatency(FLASH_Latency_2);
   FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
   RCC_PLLCmd(ENABLE);
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET)
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
   while (RCC_GetSYSCLKSource()!=0x08)
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO,ENABLE);
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP,ENABLE);
void GPIO_Configuration()
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO,ENABLE);
  GPIO_InitStructure.GPIO_Pin= GPIO_Pin_4 | GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  GPIO_Init(GPIOC,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOD,&GPIO_InitStructure);
void EXTI_Configuration(void)
   EXTI_InitTypeDef EXTI_InitStructure;
   GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource3);
   EXTI_ClearITPendingBit(EXTI_Line3);
   EXTI_InitStructure.EXTI_Line = EXTI_Line3;
   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
   EXTI_Init(&EXTI_InitStructure);
   EXTI_ClearITPendingBit(EXTI_Line17);
   EXTI_InitStructure.EXTI_Line = EXTI_Line17;
   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  #ifdef VECT_TAB_RAM
    NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
  #else
    NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
  #endif
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    NVIC_InitStructure.NVIC_IRQChannel = RTCAlarm_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
void SYSCLKConfig_STOP(void)
   if(HSEStartUpStatus == SUCCESS)
     RCC_PLLCmd(ENABLE);
     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
     while(RCC_GetSYSCLKSource() != 0x08)
void SysTick_Configuration(void)
   SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
   NVIC_SystemHandlerPriorityConfig(SystemHandler_SysTick,3,0);
   SysTick_SetReload(72000);
   SysTick_ITConfig(ENABLE);
void RTC_Configuration(void)
   PWR_BackupAccessCmd(ENABLE);
   BKP_DeInit();
   RCC_LSEConfig(RCC_LSE_ON);
   while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
   RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
   RCC_RTCCLKCmd(ENABLE);
   RTC_WaitForSynchro();
   RTC_SetPrescaler(32767);
   RTC_ITConfig(RTC_IT_ALR,ENABLE);
void Setup_System(void)
RCC_Configuration();
RTC_Configuration();
SysTick_Configuration();
GPIO_Configuration();
EXTI_Configuration();
NVIC_Configuration();
it.c
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* File Name          : stm32f10x_it.c
* Author             : MCD Application Team
* Version            : V1.0
* Date               : 10/08/2007
* Description        : Main Interrupt Service Routines.
*                      This file can be used to describe all the exceptions
*                      subroutines that may occur within user application.
*                      When an interrupt happens, the software will branch
*                      automatically to the corresponding routine.
*                      The following routines are all empty, user can write code
*                      for exceptions handlers and peripherals IRQ interrupts.
* THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
#include "main.h"
vu32 TimingDelay = 0;
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : NMIException
* Description    : This function handles NMI exception.
* Input          : None
* Output         : None
* Return         : None
void NMIException(void)
* Function Name  : HardFaultException
* Description    : This function handles Hard Fault exception.
* Input          : None
* Output         : None
* Return         : None
void HardFaultException(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
* Function Name  : MemManageException
* Description    : This function handles Memory Manage exception.
* Input          : None
* Output         : None
* Return         : None
void MemManageException(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
* Function Name  : BusFaultException
* Description    : This function handles Bus Fault exception.
* Input          : None
* Output         : None
* Return         : None
void BusFaultException(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
* Function Name  : UsageFaultException
* Description    : This function handles Usage Fault exception.
* Input          : None
* Output         : None
* Return         : None
void UsageFaultException(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
* Function Name  : DebugMonitor
* Description    : This function handles Debug Monitor exception.
* Input          : None
* Output         : None
* Return         : None
void DebugMonitor(void)
* Function Name  : SVCHandler
* Description    : This function handles SVCall exception.
* Input          : None
* Output         : None
* Return         : None
void SVCHandler(void)
* Function Name  : PendSVC
* Description    : This function handles PendSVC exception.
* Input          : None
* Output         : None
* Return         : None
void PendSVC(void)
* Function Name  : SysTickHandler
* Description    : This function handles SysTick Handler.
* Input          : None
* Output         : None
* Return         : None
void SysTickHandler(void)
  TimingDelay--;
* Function Name  : WWDG_IRQHandler
* Description    : This function handles WWDG interrupt request.
* Input          : None
* Output         : None
* Return         : None
void WWDG_IRQHandler(void)
* Function Name  : PVD_IRQHandler
* Description    : This function handles PVD interrupt request.
* Input          : None
* Output         : None
* Return         : None
void PVD_IRQHandler(void)
* Function Name  : TAMPER_IRQHandler
* Description    : This function handles Tamper interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TAMPER_IRQHandler(void)
* Function Name  : RTC_IRQHandler
* Description    : This function handles RTC global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RTC_IRQHandler(void)
* Function Name  : FLASH_IRQHandler
* Description    : This function handles Flash interrupt request.
* Input          : None
* Output         : None
* Return         : None
void FLASH_IRQHandler(void)
* Function Name  : RCC_IRQHandler
* Description    : This function handles RCC interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RCC_IRQHandler(void)
* Function Name  : EXTI0_IRQHandler
* Description    : This function handles External interrupt Line 0 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI0_IRQHandler(void)
* Function Name  : EXTI1_IRQHandler
* Description    : This function handles External interrupt Line 1 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI1_IRQHandler(void)
* Function Name  : EXTI2_IRQHandler
* Description    : This function handles External interrupt Line 2 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI2_IRQHandler(void)
* Function Name  : EXTI3_IRQHandler
* Description    : This function handles External interrupt Line 3 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI3_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line3) != RESET)
    GPIO_WriteBit(GPIOC,GPIO_Pin_6,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_6)));
* Function Name  : EXTI4_IRQHandler
* Description    : This function handles External interrupt Line 4 request.
* Input          : None
* Output         : None
* Return         : None
void EXTI4_IRQHandler(void)
* Function Name  : DMAChannel1_IRQHandler
* Description    : This function handles DMA Stream 1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel1_IRQHandler(void)
* Function Name  : DMAChannel2_IRQHandler
* Description    : This function handles DMA Stream 2 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel2_IRQHandler(void)
* Function Name  : DMAChannel3_IRQHandler
* Description    : This function handles DMA Stream 3 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel3_IRQHandler(void)
* Function Name  : DMAChannel4_IRQHandler
* Description    : This function handles DMA Stream 4 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel4_IRQHandler(void)
* Function Name  : DMAChannel5_IRQHandler
* Description    : This function handles DMA Stream 5 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel5_IRQHandler(void)
* Function Name  : DMAChannel6_IRQHandler
* Description    : This function handles DMA Stream 6 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel6_IRQHandler(void)
* Function Name  : DMAChannel7_IRQHandler
* Description    : This function handles DMA Stream 7 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void DMAChannel7_IRQHandler(void)
* Function Name  : ADC_IRQHandler
* Description    : This function handles ADC global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void ADC_IRQHandler(void)
* Function Name  : USB_HP_CAN_TX_IRQHandler
* Description    : This function handles USB High Priority or CAN TX interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_HP_CAN_TX_IRQHandler(void)
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN_RX0_IRQHandler(void)
* Function Name  : CAN_RX1_IRQHandler
* Description    : This function handles CAN RX1 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void CAN_RX1_IRQHandler(void)
* Function Name  : CAN_SCE_IRQHandler
* Description    : This function handles CAN SCE interrupt request.
* Input          : None
* Output         : None
* Return         : None
void CAN_SCE_IRQHandler(void)
* Function Name  : EXTI9_5_IRQHandler
* Description    : This function handles External lines 9 to 5 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void EXTI9_5_IRQHandler(void)
* Function Name  : TIM1_BRK_IRQHandler
* Description    : This function handles TIM1 Break interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_BRK_IRQHandler(void)
* Function Name  : TIM1_UP_IRQHandler
* Description    : This function handles TIM1 overflow and update interrupt
*                  request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_UP_IRQHandler(void)
* Function Name  : TIM1_TRG_COM_IRQHandler
* Description    : This function handles TIM1 Trigger and commutation interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void TIM1_TRG_COM_IRQHandler(void)
* Function Name  : TIM1_CC_IRQHandler
* Description    : This function handles TIM1 capture compare interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM1_CC_IRQHandler(void)
* Function Name  : TIM2_IRQHandler
* Description    : This function handles TIM2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM2_IRQHandler(void)
* Function Name  : TIM3_IRQHandler
* Description    : This function handles TIM3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM3_IRQHandler(void)
* Function Name  : TIM4_IRQHandler
* Description    : This function handles TIM4 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM4_IRQHandler(void)
* Function Name  : I2C1_EV_IRQHandler
* Description    : This function handles I2C1 Event interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C1_EV_IRQHandler(void)
* Function Name  : I2C1_ER_IRQHandler
* Description    : This function handles I2C1 Error interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C1_ER_IRQHandler(void)
* Function Name  : I2C2_EV_IRQHandler
* Description    : This function handles I2C2 Event interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C2_EV_IRQHandler(void)
* Function Name  : I2C2_ER_IRQHandler
* Description    : This function handles I2C2 Error interrupt request.
* Input          : None
* Output         : None
* Return         : None
void I2C2_ER_IRQHandler(void)
* Function Name  : SPI1_IRQHandler
* Description    : This function handles SPI1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SPI1_IRQHandler(void)
* Function Name  : SPI2_IRQHandler
* Description    : This function handles SPI2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void SPI2_IRQHandler(void)
* Function Name  : USART1_IRQHandler
* Description    : This function handles USART1 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART1_IRQHandler(void)
* Function Name  : USART2_IRQHandler
* Description    : This function handles USART2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART2_IRQHandler(void)
* Function Name  : USART3_IRQHandler
* Description    : This function handles USART3 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USART3_IRQHandler(void)
* Function Name  : EXTI15_10_IRQHandler
* Description    : This function handles External lines 15 to 10 interrupt request.
* Input          : None
* Output         : None
* Return         : None
void EXTI15_10_IRQHandler(void)
* Function Name  : RTCAlarm_IRQHandler
* Description    : This function handles RTC Alarm interrupt request.
* Input          : None
* Output         : None
* Return         : None
void RTCAlarm_IRQHandler(void)
  if(RTC_GetITStatus(RTC_IT_ALR) != RESET)
    GPIO_WriteBit(GPIOC,GPIO_Pin_7,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_7)));
    if(PWR_GetFlagStatus(PWR_FLAG_WU) != RESET)
      PWR_ClearFlag(PWR_FLAG_WU);
    RTC_ClearITPendingBit(RTC_IT_ALR);
* Function Name  : USBWakeUp_IRQHandler
* Description    : This function handles USB WakeUp interrupt request.
* Input          : None
* Output         : None
* Return         : None
void USBWakeUp_IRQHandler(void)
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
ID:74706 發表于 2015-3-16 11:29 | 顯示全部樓層
感謝樓主
ID:74953 發表于 2015-3-20 19:57 | 顯示全部樓層
這不是睡眠模式吧,明明是停止模式。低功耗三種模式 睡眠模式 停止模式 待機模式  官方 睡眠模式例程沒給,不過CUBEMX里面有例程不過庫函數不太一樣
ID:384025 發表于 2018-11-7 16:29 | 顯示全部樓層
盡管還有點問題,不過樓主還是很厲害!
主站蜘蛛池模板: 成年人一级片 | 精品网站999www | 亚洲精品乱码久久久久久动漫 | 一区二区三区四区在线 | 国产二区视频在线观看 | 国产午夜精品一区二区三区四区 | 中文字幕一区二 | 亚洲欧美日本在线 | 亚洲免费视频网站 | 黄色小视频在线免费观看 | 特级黄色片 | 九九精品在线观看 | 成人在线网| 亚洲免费在线视频 | 一级黄色性生活片 | 欧美成人一级片 | 欧美日韩国产在线播放 | 亚洲天堂一区二区三区 | 午夜视频免费观看 | 国产免费久久 | 天天澡天天狠天天天做 | 97视频免费 | 特级黄色大片 | 成人在线一区二区 | 黄色三级网站 | 亚洲一区二区三区四区在线 | 久久精品二区 | 一级免费黄色片 | 亚洲黄色一级 | 久久人人爽 | 成人午夜在线视频 | 亚洲第一综合 | 日韩精品国产一区 | 国产黄色大片 | 黄色小视频在线观看免费 | 又黄又爽又刺激的视频 | 欧美www| 久久亚洲精品视频 | 一区二区三区在线免费 | 亚洲一级片| 国产精品爽爽爽 |
