查看: 4922|回復: 4
51單片機12864液晶做的密碼鎖程序
ID:76556 發表于 2015-4-10 01:51 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
/**********端口定義*************/
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P1^5;
sbit KEY_IN1 = P2^4;
sbit KEY_IN2 = P2^5;
sbit KEY_IN3 = P2^6;
sbit KEY_IN4 = P2^7;
sbit KEY_OUT1 = P2^3;
sbit KEY_OUT2 = P2^2;
sbit KEY_OUT3 = P2^1;
sbit KEY_OUT4 = P2^0;
unsigned char Key_Buff[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
#define  Date P0   //定義Date口為數據口P0
void Delays_Lcd(unsigned int x)                //延時子函數
{  unsigned int i,j;
   for(i=45;i>0;i--)
      for(j=x;j>0;j--);
void T0_Init()
EA = 1;
TMOD = 0x01;
TH0 = 0xFC;
TL0 = 0x67;
ET0 = 1;
TR0 = 1;
void Write_Instruction(unsigned char Parameter) //寫指令(Write/Instruction)。。形參(Parameter)
RS=0;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void Write_Date(unsigned char Parameter) //寫數據(Write/Date)。。形參(Parameter)
RS=1;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void init_Lcd()                                                //液晶初始化(init/lcd)
Write_Instruction(0x01);
Write_Instruction(0x0c);
Write_Instruction(0x30);
void Position_Lcd(unsigned char x,unsigned char y)        //進入點設定,,液晶顯示位置(Lcd/Position)
unsigned char  Position;
if(x==1)
        {x=0x80;}
else if(x==2)
        {x=0x90;}
else if(x==3)
        {x=0x88;}
else if(x==4)
        {x=0x98;}
Position=x+y;
Write_Instruction(Position);     //顯示地址
void Staret()
unsigned char code TV1[]={"輸入密碼"};
unsigned char code TV2[]={":"};
unsigned char Num1;
RS=0;
RW=0;
E=0;
init_Lcd();
Position_Lcd(1,2);
Num1=0;
while(TV1[Num1]!='\0')                //教材P176頁講述了TV1[Num1]!='\0'的意思特別是'\0'的意思("空"在儲存器中的存儲形式是"\0")
         Write_Date(TV1[Num1]);
         Num1++;
Position_Lcd(2,0);
Num1=0;
while(TV2[Num1]!='\0')                //教材P176頁講述了TV1[Num1]!='\0'的意思特別是'\0'的意思("空"在儲存器中的存儲形式是"\0")
         Write_Date(TV2[Num1]);
         Num1++;
Position_Lcd(2,1);
unsigned char Key_Loosen[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
Staret();
P2=0xff;
T0_Init();
        static unsigned char Num_Password2=0;
        unsigned char Num2,Num4,Num_Password3;
        static unsigned char Num_Password4=0;
        static unsigned char Num_Password1=0;
        static bit Num_Bit1=0;
        static bit Num_Bit2=0;
        unsigned char Num1;
        static unsigned char Num_Pa1=0;
        static unsigned char Num_Pa2=0;
        static unsigned char Num_Pa3=0;
        static unsigned char Num_Pa4=0;
        static unsigned char Num_Pa5=0;
        static unsigned char Num_Pa6=0;
        static unsigned char Num_Pa7=0;
        static unsigned char Num_Pa8=0;
        static unsigned char Num_Pa9=0;
        static unsigned char Num_Pa0=0;
        if(Num_Bit2==1)
                switch(Num_Password2)
                        case 1:if(Num_Password1==1){Num_Pa1++;}break;
                        case 2:if(Num_Password1==3){Num_Pa3++;}break;
                        case 3:if(Num_Password1==1){Num_Pa1++;}break;
                        case 4:if(Num_Password1==4){Num_Pa4++;}break;
                        case 5:if(Num_Password1==5){Num_Pa5++;}break;
                        case 6:if(Num_Password1==2){Num_Pa2++;}break;
                        case 7:if(Num_Password1==0){Num_Pa0++;}break;
                        default : break;
                Num_Bit2=0;
                while(Num_Pa1==2&Num_Pa2==1&Num_Pa3==1&Num_Pa4==1&Num_Pa5==1&Num_Pa0==1)
                unsigned char TV2[]={"    歡迎使用"};
                init_Lcd();
                 Num1=0;
                 Position_Lcd(2,0);
                         Num1++;
                while(1);
         if(Num_Password2==7)
                 unsigned char TV1[]={"              "};
                 unsigned char TV2[]={"密碼錯誤 ^-^ "};
                 unsigned long ss;
                 Num1=0;
                 Position_Lcd(2,1);
                         Num1++;
                for(ss=50000;ss>0;ss--);
                 Num1=0;
                 Position_Lcd(2,1);
                         Num1++;
                 Num_Pa1=0;
                 Num_Pa2=0;
                 Num_Pa3=0;
                 Num_Pa4=0;
                 Num_Pa5=0;
                 Num_Pa6=0;
                 Num_Pa7=0;
                 Num_Pa8=0;
                 Num_Pa9=0;
                 Num_Pa0=0;
                 Num_Bit1=0;
                 Num_Password2=0;
        if(Num_Bit1==1)
                unsigned char TV1[]={"*"};
                Write_Instruction(0x0f);
                Num1=0;
                Position_Lcd(2,Num_Password2);
                         Num1++;
        for(Num4=0;Num4<4;Num4++)
                for(Num2=0;Num2<4;Num2++)
                        if(Key_Loosen[Num4][Num2]!=Key_Buff[Num4][Num2])
                                 if(Key_Loosen[Num4][Num2]==0)
                                         Num_Password1 = Num4*4+Num2;
                                         Num_Password2++;
                                         Num_Bit1=1;
                                         Num_Bit2=1;
                                Key_Loosen[Num4][Num2]=Key_Buff[Num4][Num2];
void InterruptTimer0() interrupt 1
unsigned char Num1;
static unsigned char Keys=0;
TH0 = 0xFC;
TL0 = 0x67;
Key_Buff[Keys][0]=(Key_Buff[Keys][0]<<1)|KEY_IN1;
Key_Buff[Keys][1]=(Key_Buff[Keys][1]<<1)|KEY_IN2;
Key_Buff[Keys][2]=(Key_Buff[Keys][2]<<1)|KEY_IN3;
Key_Buff[Keys][3]=(Key_Buff[Keys][3]<<1)|KEY_IN4;
        for(Num1=0;Num1<4;Num1++)
                 if((Key_Buff[Keys][Num1]&0x0f)==0x00)
                         Key_Buff[Keys][Num1]=0;
Keys++;
Keys=Keys&0x03;
switch(Keys)
        case 0:KEY_OUT4=1;KEY_OUT1=0;break;
        case 1:KEY_OUT1=1;KEY_OUT2=0;break;
        case 2:KEY_OUT2=1;KEY_OUT3=0;break;
        case 3:KEY_OUT3=1;KEY_OUT4=0;break;
ID:61484 發表于 2015-4-14 23:33 | 顯示全部樓層
學習一下
ID:44267 發表于 2015-9-5 14:34 | 顯示全部樓層
太強了,太強了,太強了,太強了,
ID:44267 發表于 2015-9-7 08:29 | 顯示全部樓層
樓主有原理圖嘛
ID:202591 發表于 2017-5-22 19:16 | 顯示全部樓層
date是啥東西呀
主站蜘蛛池模板: 国产视频www| 黄色小视频免费看 | 爱啪啪av | 69av在线播放 | 日韩av在线免费 | 狠狠操av | 一本一道久久a久久精品蜜桃 | 93久久精品日日躁夜夜躁欧美 | 久久国产精品视频 | 91免费看片网站 | 欧美精品在线免费观看 | 特黄网站 | 日韩理论在线 | 色噜噜狠狠一区二区三区果冻 | 日韩精品中文字幕在线观看 | 久久久久国产精品夜夜夜夜夜 | 老司机精品福利视频 | 国产精品国产成人国产三级 | 福利在线看 | 免费看黄色aaaaaa 片 | 伊人色综合网 | 老女人毛片 | 国产成人黄色 | 性爱一级视频 | 亚洲人在线观看 | 波多野结衣亚洲一区 | 免费福利在线观看 | 五十路av | 久久午夜影院 | eeuss一区二区三区 | 日韩免费观看视频 | 美日韩一区二区三区 | 国产精品成人在线观看 | 久久艳片www.17c.com | 伊人网在线观看 | 91久久久久 | 日韩成人中文字幕 | 国产精品毛片一区二区在线看 | 一级片在线播放 | 亚洲日本欧美 | 青青草免费观看 |
