查看: 4564|回復: 1
密碼程序與計時程序的結合-基于51MCU-C語言
ID:76556 發表于 2015-4-10 03:01 | 顯示全部樓層 |閱讀模式
啟動顯示  1602液晶示第一行顯示you win!第二行顯示I Iove 51MCU!
設定的密碼61513
輸入密碼時 1602液晶第一行顯示*號 (每按下一次鍵盤*號增加一個)
第一次密碼輸入錯誤后 1602液晶示第一行顯示Error!第二行顯示Call 13808197643
第二次密碼輸入錯誤后  程序自鎖只有重新啟動51單片機
密碼輸入正確后  1602液晶示第一行顯示My Name is第二行顯示Xue Yu Hao 之后延時一會兒(這里我沒有測試過到底延時多少秒)就進入計時程序秒記一次,可以計時1小時) 按下key6計時停止,
{,,,,,C語言程序如下,,,,,,,}
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar code xian1[]="you win!";
uchar code xian2[]="I Iove 51MCU!";
uchar code good1[]="My Name is";
uchar code good2[]="Xue Yu Hao";
uchar code cuowu1[]="Error!";
uchar code cuowu2[]="Call 13808197643";
uchar code mimi[]="*";
uchar code shizhongdd[]="into the clock";
uchar code maohao[]=":";
uchar code ling[]="00";
uchar code shu0[]="0";
uchar code shu1[]="1";
uchar code shu2[]="2";
uchar code shu3[]="3";
uchar code shu4[]="4";
uchar code shu5[]="5";
uchar code shu6[]="6";
uchar code shu7[]="7";
uchar code shu8[]="8";
uchar code shu9[]="9";
uchar cc,mima0,mima1,mima2,mima3,mima4,mima5,mima6,mima7,mima1zy,num1,num2,num3,dsd1,dsd2,dsd3,fen1,fen2,fen3,fen4;
sbit rs=P1^0;
sbit rw=P1^1;
sbit e=P1^2;
sbit key0=P0^0;
sbit key1=P0^1;
sbit key2=P0^2;
sbit key3=P0^3;
sbit key4=P0^4;
sbit key5=P0^5;
sbit key6=P0^6;
sbit key7=P0^7;
void timer(uint s)
uint x,c;
for(x=s;x>0;x--)
        for(c=110;c>0;c--);
void zhiling(uchar p)
rs=0;
rw=0;
P2=p;
timer(5);
e=1;
timer(5);
e=0;
void shuju(uchar y)
rs=1;
rw=0;
P2=y;
timer(5);
e=1;
timer(5);
e=0;
void init()
zhiling(0x38);
zhiling(0x0c);
zhiling(0x06);
zhiling(0x01);
void jianpan()
if(key0==0)
        timer(5);
        if(key0==0)
                mima0=1;
                num1++;
                while(!key0);
if(key1==0)
        timer(5);
        if(key1==0)
                mima1=1;
                num1++;
                mima1zy++;
                while(!key1);
if(key2==0)
        timer(5);
        if(key2==0)
                mima2=1;
                num1++;
                while(!key2);
if(key3==0)
        timer(5);
        if(key3==0)
                mima3=1;
                num1++;
                while(!key3);
if(key4==0)
        timer(5);
        if(key4==0)
                mima4=1;
                num1++;
                while(!key4);
if(key5==0)
        timer(5);
        if(key5==0)
                mima5=1;
                num1++;
                while(!key5);
if(key6==0)
        timer(5);
        if(key6==0)
                mima6=1;
                num1++;
                while(!key6);
if(key7==0)
        timer(5);
        if(key0==0)
                mima7=1;
                num1++;
                while(!key0);
void xianshide()
init();
zhiling(0x80);
for(cc=0;cc<10;cc++)
        shuju(good1[cc]);
        timer(5);
zhiling(0x80+0x43);
        shuju(good2[cc]);
        timer(5);
void cuowude()
num1=0;
init();
zhiling(0x80+0x05);
if(num3==0)
        for(cc=0;cc<5;cc++)
                shuju(cuowu1[cc]);
                timer(5);
        zhiling(0x80+0x40);
        for(cc=0;cc<16;cc++)
                shuju(cuowu2[cc]);
                timer(5);
        num3=1;
void mimide()
if(num1==1)
        init();
        zhiling(0x80);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==2)
        zhiling(0x80+0x01);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==3)
        zhiling(0x80+0x02);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==4)
        zhiling(0x80+0x03);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==5)
        zhiling(0x80+0x04);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==6)
        zhiling(0x80+0x05);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
if(num1==7)
        zhiling(0x80+0x06);
        for(cc=0;cc<1;cc++)
                shuju(mimi[cc]);
                timer(5);
void gaibian()
EA=0;
        jianpan();
        if(mima0==1)
                zhiling(0x0f);
                zhiling(0x80+0x46);
                dsd2++;
                mima0=0;
        if(mima0==0)
                zhiling(0x0c);
void laozhong()
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
init();
zhiling(0x80);
for(cc=0;cc<14;cc++)
        shuju(shizhongdd[cc]);
        timer(5);
zhiling(0x80+0x44);
                for(cc=0;cc<1;cc++)
                        shuju(maohao[cc]);
                        timer(5);
zhiling(0x80+0x42);
                for(cc=0;cc<2;cc++)
                        shuju(ling[cc]);
                        timer(5);
        if(dsd2==0)
                zhiling(0x80+0x46);
                for(cc=0;cc<1;cc++)
                        shuju(shu0[cc]);
                        timer(5);
                zhiling(0x80+0x45);
                for(cc=0;cc<1;cc++)
                        shuju(shu0[cc]);
                        timer(5);
        if(dsd2==1)
                zhiling(0x80+0x46);
                for(cc=0;cc<1;cc++)
                        shuju(shu1[cc]);
                        timer(5);
        if(dsd2==2)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu2[cc]);
                                timer(5);
        if(dsd2==3)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu3[cc]);
                                timer(5);
        if(dsd2==4)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu4[cc]);
                                timer(5);
        if(dsd2==5)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu5[cc]);
                                timer(5);
        if(dsd2==6)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu6[cc]);
                                timer(5);
        if(dsd2==7)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu7[cc]);
                                timer(5);
        if(dsd2==8)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu8[cc]);
                                timer(5);
        if(dsd2==9)
                        zhiling(0x80+0x46);
                        for(cc=0;cc<1;cc++)
                                shuju(shu9[cc]);
                                timer(5);
                        if(dsd3==0)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu0[cc]);
                                        timer(5);
                        if(dsd3==1)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu1[cc]);
                                        timer(5);
                        if(dsd3==2)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu2[cc]);
                                        timer(5);
                        if(dsd3==3)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu3[cc]);
                                        timer(5);
                        if(dsd3==4)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu4[cc]);
                                        timer(5);
                        if(dsd3==5)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu5[cc]);
                                        timer(5);
                        if(dsd3==6)
                                zhiling(0x80+0x45);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu6[cc]);
                                        timer(5);
                        if(fen1==0)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu0[cc]);
                                        timer(5);
                        if(fen1==1)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu1[cc]);
                                        timer(5);
                        if(fen1==2)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu2[cc]);
                                        timer(5);
                        if(fen1==3)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu3[cc]);
                                        timer(5);
                        if(fen1==4)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu4[cc]);
                                        timer(5);
                        if(fen1==5)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu5[cc]);
                                        timer(5);
                        if(fen1==6)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu6[cc]);
                                        timer(5);
                        if(fen1==7)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu7[cc]);
                                        timer(5);
                        if(fen1==8)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu8[cc]);
                                        timer(5);
                        if(fen1==9)
                                zhiling(0x80+0x43);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu9[cc]);
                                        timer(5);
                        if(fen2==0)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu0[cc]);
                                        timer(5);
                        if(fen2==1)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu1[cc]);
                                        timer(5);
                        if(fen2==2)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu2[cc]);
                                        timer(5);
                        if(fen2==3)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu3[cc]);
                                        timer(5);
                        if(fen2==4)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu4[cc]);
                                        timer(5);
                        if(fen2==5)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu5[cc]);
                                        timer(5);
                        if(fen2==6)
                                zhiling(0x80+0x42);
                                for(cc=0;cc<1;cc++)
                                        shuju(shu6[cc]);
                                        timer(5);
                        mima6=0;
if(key6==0)
        timer(5);
        if(key6==0)
                mima6=1;
                num1++;
                while(!key6);
                        while(mima6==1)
                                gaibian();
void zhuchengxu()
num1=0;
        jianpan();
        while(mima6==1&num1==1)
        mimide();
jianpan();
mima1zy=0;
                while(mima1==1&num1==2)
mimide();
jianpan();
                        while(mima5==1&num1==3)
mimide();
jianpan();
                                while(mima1==1&num1==4&mima1zy==1)
mimide();
jianpan();
                                        while(mima3==1&num1==5)
                                                {mimide();
                                                xianshide();
mima3=0;
                                                num2=2;
                                                timer(2000);
                                                timer(2000);
                                                timer(2000);
                                                mima6=0;
                                                laozhong();
mimide();
        if(num1==7)
                if(num2!=2)
                        if(num3==0)
                        cuowude();
                        num1=0;
                        mima6=0;
                        mima1=0;
                        mima5=0;
        mima3=0;
init();
zhiling(0x80);
for(cc=0;cc<8;cc++)
        shuju(xian1[cc]);
        timer(5);
zhiling(0x80+0x42);
for(cc=0;cc<13;cc++)
        shuju(xian2[cc]);
        timer(5);
        zhuchengxu();
void dsq0() interrupt 1
dsd1++;
if(dsd1==20)     /////////////////////////這里did1==1是錯誤的因改為dsd1==20
        dsd1=0;
        dsd2++;
        if(dsd2==10)
                dsd2=0;
                dsd3++;
                if(dsd3==6)
                        dsd3=0;
                        fen1++;
                        if(fen1==10)
                                fen1=0;
                                fen2++;
                                if(fen2==6)
                                                fen2=0;
相關帖子
ID:76556 發表于 2015-4-10 03:03 | 顯示全部樓層
很復雜的程序  用了三天時間 應該說是寫了一天改了兩天
主站蜘蛛池模板: 免费一区二区 | 亚洲一区高清 | 欧美一级在线观看 | 一级黄色片免费看 | 日韩久久久久久久 | 中文字幕日韩高清 | 亚洲精品免费在线观看 | 国产三级成人 | 欧美一区二区三区在线视频 | 成人午夜激情 | 国产视频一二区 | 日韩一区在线视频 | 色多多视频在线观看 | www.日本高清 | 亚洲天堂av在线 | 国产资源在线观看 | 日日操日日干 | 国产又黄又爽视频 | 国产精品一区二区三区四区 | 深夜福利网 | 亚洲欧美网站 | 欧美mv日韩mv国产网站 | 日本亚洲天堂 | 色婷婷六月 | 欧美色图一区二区三区 | 超碰人人在线 | 亚色网站 | 伊人国产在线 | 神马久久影院 | 天天干天天操天天爽 | 久久久久久爱 | 色中色综合 | 亚洲三级网站 | 久久黄色一级片 | 国产精品嫩草影院桃色 | 亚洲成人免费观看 | 新香蕉视频| 天天干天天爽 | 日本理伦片午夜理伦片 | 长河落日 | 久久综合激情 |
