查看: 3519|回復: 0
檢測內存泄露工具 Visual Leak Detector for Visual C++ 2008/2010
ID:77367 發(fā)表于 2015-4-18 21:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
下載地址:http://vld.codeplex.com/
安裝這個工具后添加上它的的include和lib目錄即可,然后比如在stdafx.h中
#inclide<vld.h>
即可。。。。
在Debug運行后,在“輸出”窗口就會出現下面這樣的提示,定義出了泄露內存的地方。。。
WARNING: Visual Leak Detector detected memory leaks!
---------- Block 128546 at 0x02059550: 8 bytes ----------
  Call Stack:
    f:\medical\medical\imgprocessdlg.cpp (773): Medical.exe!CImgProcessDlg::SaveCurrentToUndo + 0x7 bytes
    f:\medical\medical\imgprocessdlg.cpp (193): Medical.exe!RunImageToolsThread
    0x7C80B729 (File and line number not available): kernel32.dll!GetModuleFileNameA + 0x1BA bytes
  Data:
    D8 6F 5B 01    CD CD CD CD                                   .o[..... ........
---------- Block 92549 at 0x02059898: 8 bytes ----------
  Call Stack:
  Data:
    08 2D 5B 01    CD CD CD CD                                   .-[..... ........
---------- Block 96150 at 0x020598E0: 8 bytes ----------
  Call Stack:
  Data:
    08 E0 81 04    CD CD CD CD                                   ........ ........
---------- Block 121344 at 0x02059A08: 8 bytes ----------
  Call Stack:
  Data:
    08 95 77 04    CD CD CD CD                                   ..w..... ........
---------- Block 132149 at 0x02059E60: 8 bytes ----------
  Call Stack:
  Data:
    B8 4F 7F 04    CD CD CD CD                                   .O...... ........
---------- Block 96149 at 0x0205C1A0: 8 bytes ----------
  Call Stack:
  Data:
    68 93 77 04    CD CD CD CD                                   h.w..... ........
---------- Block 128547 at 0x0205CB28: 8 bytes ----------
  Call Stack:
  Data:
    68 4E 7F 04    CD CD CD CD                                   hN...... ........
---------- Block 124945 at 0x0205CBC8: 8 bytes ----------
  Call Stack:
  Data:
    40 94 77 04    CD CD CD CD                                   @.w..... ........
---------- Block 92546 at 0x0205FC88: 8 bytes ----------
  Call Stack:
  Data:
    88 95 77 04    CD CD CD CD                                   ..w..... ........
---------- Block 298054 at 0x0205FF10: 8 bytes ----------
  Call Stack:
  Data:
    B8 94 77 04    CD CD CD CD                                   ..w..... ........
---------- Block 135750 at 0x04030A68: 8 bytes ----------
  Call Stack:
  Data:
    18 91 AE 04    CD CD CD CD                                   ........ ........
---------- Block 135752 at 0x0403D3F8: 8 bytes ----------
  Call Stack:
  Data:
    C0 91 AE 04    CD CD CD CD                                   ........ ........
---------- Block 124946 at 0x04040300: 8 bytes ----------
  Call Stack:
  Data:
    30 6F 5B 01    CD CD CD CD                                   0o[..... ........
---------- Block 128549 at 0x04040620: 8 bytes ----------
  Call Stack:
  Data:
    10 4F 7F 04    CD CD CD CD                                   .O...... ........
---------- Block 135749 at 0x04040D50: 8 bytes ----------
  Call Stack:
  Data:
    70 90 AE 04    CD CD CD CD                                   p....... ........
Visual Leak Detector detected 15 memory leaks (660 bytes).
Largest number used: 930882 bytes.
Total allocations: 40291554 bytes.
Visual Leak Detector is now exiting.
Detected memory leaks!
Dumping objects ->
{301788} normal block at 0x0205FF10, 8 bytes long.
Data: <  w     > B8 94 77 04 CD CD CD CD
{139037} normal block at 0x0403D3F8, 8 bytes long.
Data: <        > C0 91 AE 04 CD CD CD CD
{139025} normal block at 0x04030A68, 8 bytes long.
Data: <        > 18 91 AE 04 CD CD CD CD
{139015} normal block at 0x04040D50, 8 bytes long.
Data: <p       > 70 90 AE 04 CD CD CD CD
{135401} normal block at 0x02059E60, 8 bytes long.
Data: < O      > B8 4F 7F 04 CD CD CD CD
{131787} normal block at 0x04040620, 8 bytes long.
Data: < O      > 10 4F 7F 04 CD CD CD CD
{131775} normal block at 0x0205CB28, 8 bytes long.
Data: <hN      > 68 4E 7F 04 CD CD CD CD
{131765} normal block at 0x02059550, 8 bytes long.
Data: < o[     > D8 6F 5B 01 CD CD CD CD
{128151} normal block at 0x04040300, 8 bytes long.
Data: <0o[     > 30 6F 5B 01 CD CD CD CD
{128140} normal block at 0x0205CBC8, 8 bytes long.
Data: <@ w     > 40 94 77 04 CD CD CD CD
{124526} normal block at 0x02059A08, 8 bytes long.
Data: <  w     > 08 95 77 04 CD CD CD CD
{99272} normal block at 0x020598E0, 8 bytes long.
Data: <        > 08 E0 81 04 CD CD CD CD
{99260} normal block at 0x0205C1A0, 8 bytes long.
Data: <h w     > 68 93 77 04 CD CD CD CD
{95645} normal block at 0x02059898, 8 bytes long.
Data: < -[     > 08 2D 5B 01 CD CD CD CD
{95633} normal block at 0x0205FC88, 8 bytes long.
Data: <  w     > 88 95 77 04 CD CD CD CD
Object dump complete.
Medical.exe 中的 0x7c92100b 處最可能的異常: 0xC0000005: 讀取位置 0x01ae1f40 時發(fā)生訪問沖突
Medical.exe 中的 0x7c92100b 處未處理的異常: 0xC0000005: 讀取位置 0x01ae1f40 時發(fā)生訪問沖突
從上面可以看到是CImgProcessDlg::SaveCurrentToUndo()函數造成的內存泄露,該函數的定義是:
void CImgProcessDlg::SaveCurrentToUndo()
        KFreeImage   * pUndo = new KFreeImage ;
        *pUndo = m_kOrgImage ;
        m_undo.push_back(pUndo) ;
發(fā)現KFreeImage   * pUndo = new KFreeImage ;這句分配了內存但沒有釋放掉,每次調用都泄露一次。修改該函數如下
        pUndo->Unload();
        pUndo = NULL;
輸出窗口提示就沒有內存泄露了
No memory leaks detected.
主站蜘蛛池模板: 三级黄色| 激情婷婷网 | 中文在线免费观看 | 日韩高清一区 | 精品一区二区三区在线观看 | 久久99精品久久久久久琪琪 | 黄色影视大全 | 婷婷六月天 | 人体free性hd | 中文字幕av一区 | 欧美一级片免费观看 | 久久久综合视频 | 一区二区三区四区国产 | 可以看av的网站 | 免费观看全黄做爰大片视频美国 | 最近中文字幕在线观看 | 在线观看黄色片 | 日韩不卡在线观看 | 久久伊人精品 | 成人午夜av | 国产黄色精品视频 | 欧美日韩在线精品 | 九九免费视频 | 在线亚洲天堂 | 成人一区二区在线 | 欧美黄视频 | 国产精品一级 | 欧美日韩一区二区在线 | 久久久婷婷 | 免费观看av网站 | 欧美日皮视频 | 激情网五月天 | 黄色小视频免费观看 | 欧美成人精品一区二区三区在线看 | 亚洲性天堂 | 中文字幕第一区 | 五月婷婷中文字幕 | 国产精品一级二级 | 欧美在线视频一区 | 国产一及片 | 成人一级视频 |
