查看: 19780|回復: 4
VHDL-LCD1602顯示程序 包括英文數字簡單漢字
ID:77367 發表于 2015-4-19 03:10 | 顯示全部樓層 |閱讀模式
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity LCD1602 is
Port(clk,CR:in std_logic;
     RW,EN,RS:out std_logic;
       Qdata:out std_logic_vector(7 downto 0));
end;
Architecture LCD of LCD1602 is
signal Qfp:integer range 0 to 4999999;
signal cp:std_logic;
begin
  process(clk,CR)
     begin
          if CR='0' then
                Qfp<=0;
                    cp<='0';
               elsif clk'event and clk='1' then
                     Qfp<=Qfp+1;
                         if Qfp=0 then
                            cp<=not cp;
                         end if;
               end if;
     end process;
     RW<='0';
     EN<=cp;
     process(cp)
        variable cnt:integer range 0 to 37;
        begin
          if CR='0' then
             cnt:=0;
               Qdata<="00000001";
          elsif cp'event and cp='1' then
              cnt:=cnt+1;
          end if;
          case cnt is
          -------Init LCD1602-----------
          when 0 =>RS<='0';Qdata<="00111000";  --0x38,
          when 1 =>RS<='0';Qdata<="00001100";  --0x0C
          when 2 =>RS<='0';Qdata<="00000001";  --0x01
          when 3 =>RS<='0';Qdata<="00000110";  --0x60
          when 4 =>RS<='0';Qdata<="10000000";  --display,0x00+0x80,1h1w
          -------data display-------------
          when 5=>RS<='1';Qdata<="10100000";--空格
      when 6=>RS<='1';Qdata<="10100000";--空格
      when 7=>RS<='1';Qdata<="10100000";--空格
      when 8=>RS<='1';Qdata<="01011001"; --Y
      when 9=>RS<='1';Qdata<="01110101";--u
      when 10=>RS<='1';Qdata<="01101010";--j
      when 11=>RS<='1';Qdata<="01101001";--i
      when 12=>RS<='1';Qdata<="01100001";--a
      when 13=>RS<='1';Qdata<="01101110";--n
      when 14=>RS<='1';Qdata<="01110001";--q
      when 15=>RS<='1';Qdata<="01110101";--u
      when 16=>RS<='1';Qdata<="01100001";--a
      when 17=>RS<='1';Qdata<="01101110";--n
      when 18=>RS<='1';Qdata<="10100000";---空格
      when 19=>RS<='1';Qdata<="10100000";---空格
      when 20=>RS<='1';Qdata<="10100000";---空格
        when 21=>RS<='0';Qdata<="11000000";--設定顯示的位置在10H+80H,
       when 22=>RS<='1';Qdata<="01000100";---D diangong xueyuan
     when 23=>RS<='1';Qdata<="01101001";---i
     when 24=>RS<='1';Qdata<="01100001";---a
     when 25=>RS<='1';Qdata<="01101110";---n
     when 26=>RS<='1';Qdata<="01100111";---g
     when 27=>RS<='1';Qdata<="01101111";---o
     when 28=>RS<='1';Qdata<="01101110";--n
     when 29=>RS<='1';Qdata<="01100111";---g
     when 30=>RS<='1';Qdata<="10100000";--- 空格
     when 31=>RS<='1';Qdata<="01011000";---X
     when 32=>RS<='1';Qdata<="01110101";---u
     when 33=>RS<='1';Qdata<="01100101";---e
     when 34=>RS<='1';Qdata<="01111001";---y
     when 35=>RS<='1';Qdata<="01110101";---u
     when 36=>RS<='1';Qdata<="01100001";---a
     when 37=>RS<='1';Qdata<="01101110";---n
     end case;
      end process;
     end;
LCD1602顯示自定義字符或漢字
Library ieee;
Use ieee.std_logic_arith.all;
Entity LCD1602 is
end;
signal Qfp:integer range 0 to 499999;
Type GCROM is array(0 to 63)of std_logic_vector(7 downto 0);
constant xx:GCROM:=(
X"00",X"00",X"00",X"1F",X"00",X"00",X"00",X"00",--一
X"00",X"00",X"0E",X"00",X"1F",X"00",X"00",X"00",--二
X"00",X"1F",X"00",X"0E",X"00",X"1F",X"00",X"00",--//三
X"02",X"04",X"0F",X"12",X"0F",X"0A",X"1F",X"02",--//年
X"0F",X"09",X"0F",X"09",X"0F",X"09",X"09",X"11",--//月
X"1F",X"11",X"11",X"1F",X"11",X"11",X"1F",X"00",--//日
X"00",X"00",X"00",X"0A",X"15",X"0A",X"04",X"00",--//心型
X"00",X"04",X"15",X"0E",X"1F",X"0E",X"11",X"00"
constant yy:GCROM:=(
"01000000","01000001","01000010","01000011", "01000100","01000101","01000110","01000111",
"01001000","01001001","01001010","01001011", "01001100","01001101","01001110","01001111",
"01010000","01010001","01010010","01010011", "01010100","01010101","01010110","01010111",
"01011000","01011001","01011010","01011011", "01011100","01011101","01011110","01011111",
"01100000","01100001","01100010","01100011", "01100100","01100101","01100110","01100111",
"01101000","01101001","01101010","01101011", "01101100","01101101","01101110","01101111",
"01110000","01110001","01110010","01110011", "01110100","01110101","01110110","01110111",
"01111000","01111001","01111010","01111011", "01111100","01111101","01111110","01111111"
begin
  process(clk,CR)
     begin
      if CR='0' then
        Qfp<=0;
    cp<='0';
         Qfp<=Qfp+1;
     if Qfp=0 then
        cp<=not cp;
     end if;
   end if;
end process;
RW<='0';
EN<=cp;
process(cp)
    variable cnt:integer range 0 to 195;
  begin
  if CR='0' then
     cnt:=0;
   Qdata<="00000001";
       cnt:=cnt+1;
  end if;
  case cnt is
  when 0=>RS<='0';Qdata<="01000000";
      when 1=>RS<='1';Qdata<=xx(cnt-1);
  when 2=>RS<='0';Qdata<="01000001";
      when 3=>RS<='1';Qdata<=xx(cnt-2);
      when 4=>RS<='0';Qdata<="01000010";
      when 5=>RS<='1';Qdata<=xx(cnt-3);
  when 6=>RS<='0';Qdata<="01000011";
      when 7=>RS<='1';Qdata<=xx(cnt-4);
      when 8=>RS<='0';Qdata<="01000100";
      when 9=>RS<='1';Qdata<=xx(cnt-5);
  when 10=>RS<='0';Qdata<="01000101";
      when 11=>RS<='1';Qdata<=xx(cnt-6);
      when 12=>RS<='0';Qdata<="01000110";
      when 13=>RS<='1';Qdata<=xx(cnt-7);
  when 14=>RS<='0';Qdata<="01000111";
      when 15=>RS<='1';Qdata<=xx(cnt-8);
      when 16=>RS<='0';Qdata<="01001000";
      when 17=>RS<='1';Qdata<=xx(cnt-9);
  when 18=>RS<='0';Qdata<="01001001";
      when 19=>RS<='1';Qdata<=xx(cnt-10);
      when 20=>RS<='0';Qdata<="01001010";
      when 21=>RS<='1';Qdata<=xx(cnt-11);
  when 22=>RS<='0';Qdata<="01001011";
      when 23=>RS<='1';Qdata<=xx(cnt-12);
      when 24=>RS<='0';Qdata<="01001100";
      when 25=>RS<='1';Qdata<=xx(cnt-13);
  when 26=>RS<='0';Qdata<="01001101";
      when 27=>RS<='1';Qdata<=xx(cnt-14);
      when 28=>RS<='0';Qdata<="01001110";
      when 29=>RS<='1';Qdata<=xx(cnt-15);
  when 30=>RS<='0';Qdata<="01001111";
      when 31=>RS<='1';Qdata<=xx(cnt-16);
      when 32=>RS<='0';Qdata<="01010000";
      when 33=>RS<='1';Qdata<=xx(cnt-17);
  when 34=>RS<='0';Qdata<="01010001";
      when 35=>RS<='1';Qdata<=xx(cnt-18);
      when 36=>RS<='0';Qdata<="01010010";
      when 37=>RS<='1';Qdata<=xx(cnt-19);
  when 38=>RS<='0';Qdata<="01010011";
      when 39=>RS<='1';Qdata<=xx(cnt-20);
      when 40=>RS<='0';Qdata<="01010100";
      when 41=>RS<='1';Qdata<=xx(cnt-21);
  when 42=>RS<='0';Qdata<="01010101";
      when 43=>RS<='1';Qdata<=xx(cnt-22);
      when 44=>RS<='0';Qdata<="01010110";
      when 45=>RS<='1';Qdata<=xx(cnt-23);
  when 46=>RS<='0';Qdata<="01010111";
      when 47=>RS<='1';Qdata<=xx(cnt-24);
      when 48=>RS<='0';Qdata<="01011000";
      when 49=>RS<='1';Qdata<=xx(cnt-25);
  when 50=>RS<='0';Qdata<="01011001";
      when 51=>RS<='1';Qdata<=xx(cnt-26);
      when 52=>RS<='0';Qdata<="01011010";
      when 53=>RS<='1';Qdata<=xx(cnt-27);
  when 54=>RS<='0';Qdata<="01011011";
      when 55=>RS<='1';Qdata<=xx(cnt-28);
      when 56=>RS<='0';Qdata<="01011100";
      when 57=>RS<='1';Qdata<=xx(cnt-29);
  when 58=>RS<='0';Qdata<="01011101";
      when 59=>RS<='1';Qdata<=xx(cnt-30);
      when 60=>RS<='0';Qdata<="01011110";
      when 61=>RS<='1';Qdata<=xx(cnt-31);
  when 62=>RS<='0';Qdata<="01011111";
      when 63=>RS<='1';Qdata<=xx(cnt-32);
  when 64=>RS<='0';Qdata<="01100000";
      when 65=>RS<='1';Qdata<=xx(cnt-33);
  when 66=>RS<='0';Qdata<="01100001";
      when 67=>RS<='1';Qdata<=xx(cnt-34);
      when 68=>RS<='0';Qdata<="01100010";
      when 69=>RS<='1';Qdata<=xx(cnt-35);
  when 70=>RS<='0';Qdata<="01100011";
      when 71=>RS<='1';Qdata<=xx(cnt-36);
      when 72=>RS<='0';Qdata<="01100100";
      when 73=>RS<='1';Qdata<=xx(cnt-37);
  when 74=>RS<='0';Qdata<="01100101";
      when 75=>RS<='1';Qdata<=xx(cnt-38);
      when 76=>RS<='0';Qdata<="01100110";
      when 77=>RS<='1';Qdata<=xx(cnt-39);
  when 78=>RS<='0';Qdata<="01100111";
      when 79=>RS<='1';Qdata<=xx(cnt-40);
      when 80=>RS<='0';Qdata<="01101000";
      when 81=>RS<='1';Qdata<=xx(cnt-41);
  when 82=>RS<='0';Qdata<="01101001";
      when 83=>RS<='1';Qdata<=xx(cnt-42);
      when 84=>RS<='0';Qdata<="01101010";
      when 85=>RS<='1';Qdata<=xx(cnt-43);
  when 86=>RS<='0';Qdata<="01101011";
      when 87=>RS<='1';Qdata<=xx(cnt-44);
      when 88=>RS<='0';Qdata<="01101100";
      when 89=>RS<='1';Qdata<=xx(cnt-45);
  when 90=>RS<='0';Qdata<="01001101";
      when 91=>RS<='1';Qdata<=xx(cnt-46);
      when 92=>RS<='0';Qdata<="01101110";
      when 93=>RS<='1';Qdata<=xx(cnt-47);
  when 94=>RS<='0';Qdata<="01101111";
      when 95=>RS<='1';Qdata<=xx(cnt-48);
      when 96=>RS<='0';Qdata<="01110000";
      when 97=>RS<='1';Qdata<=xx(cnt-49);
  when 98=>RS<='0';Qdata<="01110001";
      when 99=>RS<='1';Qdata<=xx(cnt-50);
      when 100=>RS<='0';Qdata<="01110010";
      when 101=>RS<='1';Qdata<=xx(cnt-51);
  when 102=>RS<='0';Qdata<="01110011";
      when 103=>RS<='1';Qdata<=xx(cnt-52);
      when 104=>RS<='0';Qdata<="01010100";
      when 105=>RS<='1';Qdata<=xx(cnt-53);
  when 106=>RS<='0';Qdata<="01110101";
      when 107=>RS<='1';Qdata<=xx(cnt-54);
      when 108=>RS<='0';Qdata<="01110110";
      when 109=>RS<='1';Qdata<=xx(cnt-55);
  when 110=>RS<='0';Qdata<="01110111";
      when 111=>RS<='1';Qdata<=xx(cnt-56);
      when 112=>RS<='0';Qdata<="01111000";
      when 113=>RS<='1';Qdata<=xx(cnt-57);
  when 114=>RS<='0';Qdata<="01111001";
      when 115=>RS<='1';Qdata<=xx(cnt-58);
      when 116=>RS<='0';Qdata<="01111010";
      when 117=>RS<='1';Qdata<=xx(cnt-59);
  when 118=>RS<='0';Qdata<="01111011";
      when 119=>RS<='1';Qdata<=xx(cnt-60);
      when 120=>RS<='0';Qdata<="01111100";
      when 121=>RS<='1';Qdata<=xx(cnt-61);
  when 122=>RS<='0';Qdata<="01111101";
      when 123=>RS<='1';Qdata<=xx(cnt-62);
      when 124=>RS<='0';Qdata<="01111110";
      when 125=>RS<='1';Qdata<=xx(cnt-63);
  when 126=>RS<='0';Qdata<="01111111";
      when 127=>RS<='1';Qdata<=xx(cnt-64);
  when 128 =>RS<='0';Qdata<="00111000";  --0x38,
  when 129 =>RS<='0';Qdata<="00001100";  --0x0C
  when 130=>RS<='0';Qdata<="00000001";  --0x01
  when 131 =>RS<='0';Qdata<="00000110";  --0x60
  when 132 =>RS<='0';Qdata<="10000000";  --display,0x00+0x80,1h1w
  when 133=>RS<='1';Qdata<="00000000";--空格
      when 134=>RS<='1';Qdata<="00000001";--空格
      when 135=>RS<='1';Qdata<="00000010";--空格
      when 136=>RS<='1';Qdata<="00000011"; --Y
      when 137=>RS<='1';Qdata<="00000100";--u
      when 138=>RS<='1';Qdata<="00000101";--j
      when 139=>RS<='1';Qdata<="00000110";--i
      when 140=>RS<='1';Qdata<="00000111";--a
      when 141=>RS<='1';Qdata<="00000000";--n
      when 142=>RS<='1';Qdata<="00000001";--q
      when 143=>RS<='1';Qdata<="00000010";--u
      when 144=>RS<='1';Qdata<="00000100";--a
      when 145=>RS<='1';Qdata<="00000110";--n
      when 146=>RS<='1';Qdata<="00000111";---空格
      when 147=>RS<='1';Qdata<="10100100";---空格
      when 148=>RS<='1';Qdata<="10100110";---空格
    when 149=>RS<='0';Qdata<="11000000";--設定顯示的位置在10H+80H,
   when 150=>RS<='1';Qdata<="00000111";---D diangong xueyuan
     when 151=>RS<='1';Qdata<="00000110";---i
     when 152=>RS<='1';Qdata<="00000101";---a
     when 153=>RS<='1';Qdata<="00000100";---n
     when 154=>RS<='1';Qdata<="00000011";---g
     when 155=>RS<='1';Qdata<="00000010";---o
     when 156=>RS<='1';Qdata<="00000001";--n
     when 157=>RS<='1';Qdata<="00000000";---g
     when 158=>RS<='1';Qdata<="00000000";--- 空格
     when 159=>RS<='1';Qdata<="00000001";---X
     when 160=>RS<='1';Qdata<="00000010";---u
     when 161=>RS<='1';Qdata<="00000011";---e
     when 162=>RS<='1';Qdata<="00000100";---y
     when 163=>RS<='1';Qdata<="00000101";---u
     when 164=>RS<='1';Qdata<="00000110";---a
     when 165=>RS<='1';Qdata<="00000111";---n
      when 166 =>RS<='0';Qdata<="10000000";  --display,0x00+0x80,1h1w
  when 167=>RS<='1';Qdata<="00000000";--空格
      when 168=>RS<='1';Qdata<="00000001";--空格
      when 169=>RS<='1';Qdata<="00000010";--空格
      when 170=>RS<='1';Qdata<="00000011"; --Y
      when 171=>RS<='1';Qdata<="00000100";--u
      when 172=>RS<='1';Qdata<="00000101";--j
      when 173=>RS<='1';Qdata<="00000110";--i
      when 174=>RS<='1';Qdata<="00000111";--a
      when 175=>RS<='1';Qdata<="00000000";--n
      when 176=>RS<='1';Qdata<="00000001";--q
      when 177=>RS<='1';Qdata<="00000010";--u
      when 178=>RS<='1';Qdata<="00000011";--a
      when 179=>RS<='1';Qdata<="00000100";--n
      when 180=>RS<='1';Qdata<="00000101";---空格
  when 181 =>RS<='1';Qdata<="00000110";  --display,0x00+0x80,1h1w
  when 182=>RS<='1';Qdata<="00000000";--空格
      when 183=>RS<='1';Qdata<="00000001";--空格
      when 184=>RS<='1';Qdata<="00000010";--空格
      when 185=>RS<='1';Qdata<="00000011"; --Y
      when 186=>RS<='1';Qdata<="00000100";--u
      when 187=>RS<='1';Qdata<="00000101";--j
      when 188=>RS<='1';Qdata<="00000110";--i
      when 189=>RS<='1';Qdata<="00000111";--a
      when 190=>RS<='1';Qdata<="00000000";--n
      when 191=>RS<='1';Qdata<="00000001";--q
      when 192=>RS<='1';Qdata<="00000010";--u
      when 193=>RS<='1';Qdata<="00000100";--a
      when 194=>RS<='1';Qdata<="00000110";--n
      when 195=>RS<='1';Qdata<="00000111";---空格
     when others=>null;
     end case;
  end process;
end;
LCD1602相比大家都比較了解,但是我們一般只用來顯示字符,數字。
最近在網上看許多人用LCD1602來顯示漢字,覺得有趣
于是拜讀了一些資料,教程,但感覺大部分相當晦澀難懂,本人認為既然是教程,就不必要相當的復雜,畢竟人家看完許久后還是不能得出實驗結果~!!
接下我談談我得做法,保證你10分鐘之內一樣可以在LCD1602上顯示你想顯示的各種符號,漢字!!!
首先:我們要弄清楚一個概念,其實我們使用1602顯示中文漢字,就是利用其內部的自定義字節空間,我們都知道LCD1602內部有一個64字節的自定義CGRAM,那么好,我們就是要利用自定義字節來達到顯示漢字的效果.
我們知道一個字符占8個字節,所以在CGRAM能夠存放8個字符。
也就是說,這個64字節的CGRAM是給我們提供寫入數據的,
那么我們怎么把我們要的漢字寫入CGRAM呢?
不要急,大家查看LCD1602的用戶手冊,里面提到當我們需要想CGRAM寫入數據時,我們需要先寫入CGRAM的地址,從手冊上可知,CGRAM的地址為0x40.所以當我們要寫入數據時,要先寫入一條地址命令 write_com(0x040);
然后把你要寫入的數據通過寫數據命令寫入  write_date( 你要寫得數據);
做完以上步驟了,是不是LCD1602就會顯示你輸入的漢字呢?
不要急,以上你只是把你要顯示漢字的代碼存放在CGRAM里,就相當于其他常用字符一樣固定在LCD里面了,如果你不把它讀出來,LCD是不會顯示的。。
當你把上面的步驟做完后,接下來要做的與你平常怎么使用LCD1602是一樣的,只不過是LCD1602里面增加了一些你自定義的字符,漢字。
可能到這里,也許會有些疑問,既然自定義字符、漢字的代碼需要我們自己輸入,那么我該怎么編寫這些代碼,呵呵,不要著急,接下來就要用到下面這個取字模軟件。。
相信有的朋友應該都用過這個軟件。那么我們怎么來使用這個軟件來獲取代碼呢?大家有沒有注意到,我們的LCD1602是5*8點陣(可以數一數)。但是5*8不能提取代碼,最少只能8*8,所以我們這里只用后前5列,前3列不用。。
新建圖像 8*8.然后再圖像里面點你要顯示的字符,漢字,注意是在后5列中點,黑點表示顯示,白點不顯示,用鼠標左鍵可以切換,下面是我點得一個坦克~~
點好后,就可以產生代碼了,這軟件里面可以選擇C51或匯編,這里選擇C51。
下面的8個代碼就是要產生這個字符的數據。。也就是要輸入到自定義字符CGRAM里面的
好的,怎么把獲取漢字代碼,怎么把代碼輸入到CGRAM里面都知道了,
下面就是要把我們的自定義漢字、字符顯示在LCD1602屏幕上了。。
我們知道常用字符是從0x20開始顯示,而0x00—0x0f都是沒有用的,其實這個正式為我們自定義顯示字符準備的。當你把上面的代碼輸入到CGRAM中,LCD1602機會把漢字或字符賦予地址,這個地址是從0x00開始,因為最多只能8個字符,所以當在CGRAM里面輸入8個字符代碼時,這8個字符的代碼的數據地址就是0x00開始到0x07。
所以當你要在LCD1602上顯示自定義字符時,只需要把這個地址用數據輸入就OK。
  Write_date(0x00—0x07);
也就是說現在你要顯示自定義字符和你顯示常用字符一樣的做法了,先寫地址,然后寫數據
自定義字符的數據就是0x00—0x07。也就是你自定義的8個字符。
這里用 Proteus 仿真軟件演示
附程序
編寫時間:2011-11-25
功能:LCD顯示自定義字符、漢字
  1. #include"reg52.h"
  3. #define uint unsigned int
  4. sbit lcdrs=P2^4;
  5. sbit lcdrw=P2^5;
  6. sbit lcden=P2^6;
  7. uchar code table[]={
  8. 0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,//一
  9. 0x00,0x00,0x0E,0x00,0x1F,0x00,0x00,0x00,//二
  10. 0x00,0x1F,0x00,0x0E,0x00,0x1F,0x00,0x00,//三
  11. 0x02,0x04,0x0F,0x12,0x0F,0x0A,0x1F,0x02,//年
  12. 0x0F,0x09,0x0F,0x09,0x0F,0x09,0x09,0x11,//月
  13. 0x1F,0x11,0x11,0x1F,0x11,0x11,0x1F,0x00,//日
  14. 0x00,0x00,0x00,0x0A,0x15,0x0A,0x04,0x00,//心型
  15. 0x00,0x04,0x15,0x0E,0x1F,0x0E,0x11,0x00//坦克
  16. };
  17. uchar code table1[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};  //自定義字符數據地址
  18. uchar code table2[]="QQ:598852247";
  19. /******************************
  20.               ms延時函數
  21. ******************************/
  22. void delay(uchar z)
  23. {
  24.        uint x,y;
  25.        for(x=z;x>0;x--)
  26.               for(y=122;y>0;y--);
  27. }
  28. /******************************
  29.               lcd1602寫命令函數
  30. ******************************/
  31. void write_cmd(uchar cmd)
  32. {
  33.        lcdrs=0;
  34.        lcdrw=0;    //選擇指令寄存器
  35.        lcden=1;
  36.        P0=cmd;     //寫了命令
  37.        delay(5);
  38.        lcden=0;    //使能拉低
  39.        lcden=1;
  40. }
  41. /******************************
  42.               lcd1602寫數據函數
  43. ******************************/
  44. void write_date(uchar date)
  45. {
  46.        lcdrs=1;
  47.        lcdrw=0;    //選擇數據寄存器
  48.        lcden=1;
  49.        P0=date;     //寫了命令
  50.        delay(5);
  51.        lcden=0;    //使能拉低
  52.        lcden=1;
  53. }
  54. /******************************
  55.               lcd1602初始化
  56. ******************************/
  57. void init_lcd1602()
  58. {
  59.        write_cmd(0x01);  //清屏
  60.        write_cmd(0x38);  //功能設置
  61.        write_cmd(0x0c);  //顯示設置
  62.        write_cmd(0x06);  //輸入方式從左到右
  63.        delay(1);
  64. }
  65. /******************************
  66.                      主函數
  67. ******************************/
  68. void main()
  69. {
  70.        uchar i;
  71.        init_lcd1602();
  72.        delay(1);
  73.
  74.        while(1)
  75.        {
  76.               write_cmd(0x40);    //開始寫入你要顯示的自定義字符、漢字代碼
  77.               for(i=0;i<64;i++)
  78.               {
  79.                      write_date(table[i]);
  80.                      delay(5);
  81.               }
  82.               write_cmd(0x80);    //從第一行第一列開始顯示
  83.               for(i=0;i<8;i++)       //顯示自定義字符
  84.               {
  85.                      write_date(table1[i]);
  86.                      delay(5);
  87.               }
  88.               write_cmd(0xc0);   //顯示QQ:598852247
  89.               for(i=0;i<12;i++)
  90.               {
  91.                      write_date(table2[i]);
  92.                      delay(5);
  93.               }
  94.        }
  95. }
ID:109610 發表于 2016-3-18 22:23 | 顯示全部樓層
帖子很有用,很好
ID:197648 發表于 2017-5-19 15:28 | 顯示全部樓層
好 正好需要 謝謝分享
ID:258682 發表于 2017-12-7 15:55 | 顯示全部樓層
跪求大神解決,燒寫上去之后,只能閃亮一下該怎么解決
ID:730662 發表于 2020-4-16 16:11 | 顯示全部樓層
請問  大神 這個程序  可以從ise實現嗎 我用的basys2開發板  引腳約束 不會寫
主站蜘蛛池模板: 亚洲观看黄色网 | 欧美性猛交一区二区三区精品 | 天天干天天干天天干 | 国产一区在线播放 | 国产三区视频 | 午夜一区| 69免费视频| 日本免费在线观看视频 | 国产精品99久久久久久www | 亚洲免费一区二区 | 久久视频在线 | 国产精品久久久久久久 | 午夜在线影院 | 久久青 | 亚洲福利在线观看 | 欧美福利在线 | 精品亚洲一区二区 | 97免费在线 | 一区二区视频在线 | 婷婷中文网 | 黄色伊人 | 亚洲国产中文字幕 | 在线观看的av网站 | 九九在线精品 | 在线日韩欧美 | 欧美性猛交一区二区三区精品 | 亚洲 欧美 综合 | 一级欧美一级日韩 | 中文字幕三区 | 欧美激情精品 | 久久在线 | 黄色一级免费 | 黄色大片免费观看 | 中文字幕第一区综合 | 欧美一级片免费 | 亚洲免费精品 | 九九精品免费视频 | 四虎久久久 | 老女人毛片| 亚洲综合在线视频 | 91亚洲国产成人久久精品网站 |
