查看: 4274|回復: 0
怎么讓這個光立方444程序 動畫播放的速度加快,和讓動畫循環播放?
ID:76148 發表于 2015-5-16 10:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "STC12C5A.H"
#include <INTRINS.H>   //包含延時頭文件
#define uint unsigned int
#define uchar unsigned char
#define nop() _nop_();_nop_();
sbit AD=P1^0;   //定義音頻輸入接口
sbit K1=P1^2;   //定義功能按鍵接口
sbit K2=P1^4;   //定義功能按鍵接口
sbit K3=P3^5;   //定義功能按鍵接口
sbit K4=P3^6;   //定義功能按鍵接口
sbit VCC1=P1^5;   //定義電源功能接口必須為高電平
sbit VCC2=P1^7;   //定義電源功能接口必須為高電平
sbit VCC3=P3^2;   //定義電源功能接口必須為高電平
sbit VCC4=P3^4;   //定義電源功能接口必須為高電平
sbit L1=P0^3;  sbit L2=P4^5;  sbit L3=P2^4;  sbit L4=P2^2;   sbit H1=P0^5;
sbit L5=P0^1;  sbit L6=P4^6;  sbit L7=P2^7;  sbit L8=P2^0;   sbit H2=P0^6;
sbit L9=P0^0;  sbit L10=P0^7; sbit L11=P2^6; sbit L12=P1^6;  sbit H3=P4^4;
sbit L13=P1^3; sbit L14=P0^4; sbit L15=P2^5; sbit L16=P3^3;  sbit H4=P2^3;
                    sbit H5=P4^7;
//定義光立方的接口全部高電平有效
sbit LED1=P0^2;  sbit LED2=P2^1;
sbit LED3=P3^7;  sbit LED4=P1^1;
//定義腳底下4個受控制的LED燈-右下角高電平有效其余低電平有效
unsigned char bdata dzzc0;
sbit dzzc07=dzzc0^7;
sbit dzzc06=dzzc0^6;
sbit dzzc05=dzzc0^5;
sbit dzzc04=dzzc0^4;
sbit dzzc03=dzzc0^3;
sbit dzzc02=dzzc0^2;
sbit dzzc01=dzzc0^1;
sbit dzzc00=dzzc0^0;
unsigned char bdata dzzc1;
sbit dzzc17=dzzc1^7;
sbit dzzc16=dzzc1^6;
sbit dzzc15=dzzc1^5;
sbit dzzc14=dzzc1^4;
sbit dzzc13=dzzc1^3;
sbit dzzc12=dzzc1^2;
sbit dzzc11=dzzc1^1;
sbit dzzc10=dzzc1^0;
unsigned char bdata dzzc2;
sbit dzzc27=dzzc2^7;
sbit dzzc26=dzzc2^6;
sbit dzzc25=dzzc2^5;
sbit dzzc24=dzzc2^4;
sbit dzzc23=dzzc2^3;
sbit dzzc22=dzzc2^2;
sbit dzzc21=dzzc2^1;
sbit dzzc20=dzzc2^0;
unsigned char bdata dzzc3;
sbit dzzc37=dzzc3^7;
sbit dzzc36=dzzc3^6;
sbit dzzc35=dzzc3^5;
sbit dzzc34=dzzc3^4;
sbit dzzc33=dzzc3^3;
sbit dzzc32=dzzc3^2;
sbit dzzc31=dzzc3^1;
sbit dzzc30=dzzc3^0;
//調整數字顯示的數據用分別為變的1234
// 4        dzzc6
//3 2 dzzc7  dzzc5
// 1     dzzc4
unsigned char bdata dzzc4;
sbit dzzc47=dzzc4^7;
sbit dzzc46=dzzc4^6;
sbit dzzc45=dzzc4^5;
sbit dzzc44=dzzc4^4;
sbit dzzc43=dzzc4^3;
sbit dzzc42=dzzc4^2;
sbit dzzc41=dzzc4^1;
sbit dzzc40=dzzc4^0;
unsigned char bdata dzzc5;
sbit dzzc57=dzzc5^7;
sbit dzzc56=dzzc5^6;
sbit dzzc55=dzzc5^5;
sbit dzzc54=dzzc5^4;
sbit dzzc53=dzzc5^3;
sbit dzzc52=dzzc5^2;
sbit dzzc51=dzzc5^1;
sbit dzzc50=dzzc5^0;
unsigned char bdata dzzc6;
sbit dzzc67=dzzc6^7;
sbit dzzc66=dzzc6^6;
sbit dzzc65=dzzc6^5;
sbit dzzc64=dzzc6^4;
sbit dzzc63=dzzc6^3;
sbit dzzc62=dzzc6^2;
sbit dzzc61=dzzc6^1;
sbit dzzc60=dzzc6^0;
unsigned char bdata dzzc7;
sbit dzzc77=dzzc7^7;
sbit dzzc76=dzzc7^6;
sbit dzzc75=dzzc7^5;
sbit dzzc74=dzzc7^4;
sbit dzzc73=dzzc7^3;
sbit dzzc72=dzzc7^2;
sbit dzzc71=dzzc7^1;
sbit dzzc70=dzzc7^0;
unsigned int CYCLE=100,PWM_LOW=1110,shan=0,saom=0,shuzi1=0,shuzi2=0,shuzi3=0,shuzi4=0;//定義周期并賦值
unsigned char YL1=0,YL2=0,YL3=0,YL4=0,YL5=0,YL6=0,YL7=0,YL8=0,YL9=0,YL10=0,YL11=0,YL12=0,YL13=0,YL14=0,YL15=0,YL16=0;//高度值
unsigned char lie=0,hang=0,ceng=0;
unsigned char yinyue4X4[]= //定義4X4X4整個屏幕的顯示數據,高電平有效,沒有音樂的時候默認不亮
0x0F,0x0F,0x0F,0x0F,0x0F,
unsigned  char code shuzu4X4[]= //定義4X4X4整個屏幕的顯示數據,根據取字模軟件進行提取高電平有效
//////////////正方形 由 大變小////////////////
0X00,0XCF,0XCF,0X00,0X00,0X00,0XCF,0XCF,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,//0幀
0X00,0XEF,0XAF,0XEF,0X00,0X00,0XAF,0X0F,0XAF,0X00,0X00,0XEF,0XAF,0XEF,0X00,0X00,0X00,0X00,0X00,0X00,//1幀
0X00,0XFF,0X9F,0X9F,0XFF,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0XFF,0X9F,0X9F,0XFF,//2幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0XEF,0XAF,0XEF,0X0F,0X00,0XAF,0X0F,0XAF,0X0F,0X00,0XEF,0XAF,0XEF,0X0F,//4幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X0F,0X0F,0X0F,0X0F,0X00,0XCF,0XCF,0X0F,0X0F,0X00,0XCF,0XCF,0X0F,0X0F,//5幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0XEF,0XAF,0XEF,0X0F,0X00,0XAF,0X0F,0XAF,0X0F,0X00,0XEF,0XAF,0XEF,0X0F,//7幀
0X00,0XFF,0X9F,0X9F,0XFF,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0XFF,0X9F,0X9F,0XFF,//8幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X7F,0X5F,0X7F,0X0F,0X00,0X5F,0X0F,0X5F,0X0F,0X00,0X7F,0X5F,0X7F,0X0F,//10幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X3F,0X3F,0X0F,0X0F,0X00,0X3F,0X3F,0X0F,0X0F,//11幀
0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X5F,0X4F,0X7F,0X0F,0X00,0X5F,0X0F,0X5F,0X0F,0X00,0X7F,0X5F,0X7F,0X0F,//13幀
0X00,0XFF,0X9F,0X9F,0XFF,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0X9F,0X0F,0X0F,0X9F,0X00,0XFF,0X9F,0X9F,0XFF,//14幀
0X00,0X7F,0X5F,0X7F,0X0F,0X00,0X5F,0X0F,0X5F,0X0F,0X00,0X7F,0X5F,0X7F,0X0F,0X00,0X0F,0X0F,0X0F,0X0F,//18幀
0X00,0X3F,0X3F,0X0F,0X0F,0X00,0X3F,0X3F,0X0F,0X0F,0X00,0X0F,0X0F,0X0F,0X0F,0X00,0X0F,0X0F,0X0F,0X0F,//19幀
void Delay(unsigned int t)
while(--t);
void init()
P4SW=0xff;                //定義P4口為I/O口
P0M1=0x00;       //I/O口0模式控制器0     Bit7    Bit6    Bit5    Bit4    Bit3    Bit2    Bit1    Bit0
P0M0=0xff;                //定義P0為強上拉輸出.
P1M1=0x01;
P1M0=0xfe;                //定義P1為強上拉輸出.   P.14作為AD此時不能作為強上蠟
P2M1=0x00;
P2M0=0xff;                //定義P2為強上拉輸出.
P3M1=0x00;
P3M0=0xff;                //定義P3為強上拉輸出.
P4M1=0x00;
P4M0=0xff;                //定義P4為強上拉輸出.
void hansao(unsigned char hs,unsigned char shangxia)
if(shangxia==0)
if(hs<5)     //判斷hs的值是否在行掃描的值范圍內,不在范圍內不執行任何操作
  if(hs==0)    //選通第1行     //作為控制顯示高度的時候調用
  H1=1;H2=1;H3=1;H4=1;H5=0;   return;
  if(hs==1)    //選通第2行
  H1=1;H2=1;H3=1;H4=0;H5=1;   return;
  if(hs==2)    //選通第3行
  H1=1;H2=1;H3=0;H4=1;H5=1;   return;
  if(hs==3)    //選通第4行
  H1=1;H2=0;H3=1;H4=1;H5=1;   return;
  if(hs==4)    //選通第5行
  H1=0;H2=1;H3=1;H4=1;H5=1;   return;
else if(shangxia==1)
  if(hs==0)    //選通第1行     //平時的時候調用這個顯示其他圖形和變化
  if(hs==1)    //選通第2行
  if(hs==2)    //選通第3行
  if(hs==3)    //選通第4行
  if(hs==4)    //選通第5行
unsigned int donghua=0;
init();      //初始化IO口為強上蠟輸出狀態
VCC1=1;VCC2=1;VCC3=1;VCC4=1;LED4=1; //關閉開機時候的狀態 使單片機沒有任何反應 LED4通電不初始化會亮可以作為電源指示燈
  while (1)
//26//////////////////////////////////上位機生成動畫數據控制光立方LED燈顯示////////////////////
//數據直接利用上位機去摸取好之后賦值到定義的數組里面shuzu4X4
//8421的數據分別為L1L2L3L4,然后第一行的數據分別為數組的第一個數據從上面到下面數0-5
//H1-H2-H2-H4-H5
//H6-H7-H8-H9-H10
//H11-H12-H13-H14-H15
//H16-H17-H18-H19-H20
for(CYCLE=0;CYCLE<3000;CYCLE++)
for(saom=0;saom<5;saom++)
dzzc0=shuzu4X4[saom+donghua*20]; //將第一個需要分配的數據賦值個為變量進行分配給L1-L4
L1=dzzc07;L2=dzzc06;L3=dzzc05;L4=dzzc04;
dzzc1=shuzu4X4[saom+donghua*20+5]; //將第一個需要分配的數據賦值個為變量進行分配給L5-L8
L5=dzzc17;L6=dzzc16;L7=dzzc15;L8=dzzc14;
dzzc2=shuzu4X4[saom+donghua*20+10]; //將第一個需要分配的數據賦值個為變量進行分配給L9-L12
L9=dzzc27;L10=dzzc26;L11=dzzc25;L12=dzzc24;
dzzc3=shuzu4X4[saom+donghua*20+15]; //將第一個需要分配的數據賦值個為變量進行分配給L13-L16
L13=dzzc37;L14=dzzc36;L15=dzzc35;L16=dzzc34;
hansao(saom,0);
Delay(10);
H1=1;H2=1;H3=1;H4=1;H5=1;
  donghua++;
Delay(10);
if(donghua==65000)
  donghua=0;
主站蜘蛛池模板: 麻豆久久精品 | 最近日韩中文字幕 | 国产 日韩 欧美 中文 在线播放 | 日本不卡一区 | 91精品一区二区三区久久久久 | 亚洲精品国产精品国自产在线 | 日韩一区二区在线看 | 久久久久久999| 久久国产亚洲精品 | 午夜一区二区三区 | 99视频在线免费观看 | 国产成人精品在线播放 | 超碰av免费| 黄色片免费看视频 | 国产乱码精品1区2区3区 | 嫩草视频网站 | 在线视频一区二区三区 | 风间由美一区二区三区在线观看 | 中文字幕一区二区三区日韩精品 | 国产中文字幕在线 | 久久久久免费 | 亚洲一区av在线 | 天堂视频一区 | 国产精品美女久久久久久久网站 | 97精品超碰一区二区三区 | 看a级黄色毛片 | 国产午夜视频 | 成人a免费 | 日韩精品视频在线播放 | 亚洲a一区二区 | 99久久视频 | 欧美一级毛片在线播放 | 亚洲黄色一区二区三区 | 视频在线一区二区 | 超碰人人人人 | 欧美日本韩国一区二区 | 国产一级特黄aaa大片评分 | 在线视频 亚洲 | 精品亚洲一区二区 | 国产精品99久久久久久动医院 | 成人欧美一区二区三区在线观看 |
