查看: 7902|回復: 2
STM32 Lib TIM1 CH1~4通道PWM使能
ID:80436 發表于 2015-5-18 23:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
void TIM1_PWM_RmapInit(u16 arr, u16 psc)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    TIM_DeInit(TIM1);//初始化TIM1寄存器
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOE  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外設和AFIO復用功能模塊時鐘
    GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE); //Timer1完全重映射  TIM1_CH1->PE9
//  設置該引腳為復用輸出功能,輸出TIM1 CH1的PWM脈沖波形    GPIOE.9
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_11 | GPIO_Pin_13 | GPIO_Pin_14  ; //TIM1_CH1
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復用推挽輸出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化GPIO
//  TIM_InternalClockConfig(TIM1);//使用TIM1內部時鐘
    TIM_TimeBaseStructure.TIM_Period =  arr;//f=72MHz/2/(3600+1)=10K
    TIM_TimeBaseStructure.TIM_Prescaler = psc;//2分頻
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
//  TIM_TimeBaseStructure.TIM_RepetitionCounter=0;//重復寄存器,用于自動更新pwm占空比
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    //TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Disable;//選擇互補輸出比較狀態
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//設置輸出極性
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; //設置互補輸出極性
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; //空閑狀態下得非工作模式
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset; //互補空閑狀態下得非工作模式
    /* PWM1 Mode configuration: Channel1 */
    TIM_OCInitStructure.TIM_Pulse = arr / 2;
    TIM_OC1Init(TIM1, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
    /* PWM1 Mode configuration: Channel2 */
    TIM_OC2Init(TIM1, &TIM_OCInitStructure);
    TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
    /* PWM1 Mode configuration: Channel3 */
    TIM_OC3Init(TIM1, &TIM_OCInitStructure);
    TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
    /* PWM1 Mode configuration: Channel4 */
    TIM_OC4Init(TIM1, &TIM_OCInitStructure);
    TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIM1, ENABLE);
    TIM_Cmd(TIM1, ENABLE);
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
ID:324780 發表于 2018-8-29 14:04 | 只看該作者
很好的資料,學習中
主站蜘蛛池模板: 久久视频免费在线观看 | 黄色片免费看 | 日韩在线欧美 | 欧美综合一区二区三区 | 91精品国产99久久久久久红楼 | 日韩伦理一区二区 | 亚洲一区二区三区在线 | 成年人网站在线免费观看 | 欧美日韩一二三 | 国产美女视频网站 | 日韩亚洲欧美在线观看 | 一级特黄视频 | 黄色一级免费看 | 欧美a一级 | 日韩在线免费视频 | 久久久久久毛片 | 日韩精品三区 | 国产黄a三级三级看三级 | 色污污 | 国产精品视频一区二区三区 | 天堂网中文 | 亚洲色欲色欲www在线观看 | 欧美激情小视频 | 中文字幕在线观看免费 | 国产一区二区三区精品视频 | 久久三级视频 | 欧美激情综合 | 国产精品成人一区 | 又黄又爽又色视频 | 在线观看av的网站 | 可以看的毛片 | 一区二区三区在线免费 | 日韩视频网 | 欧美一级片 | 久久精品免费看 | 欧美不卡在线 | 精品一区久久 | 不卡在线视频 | 黄色片一区二区 | 三级在线免费观看 | 黄色小视频免费 |
