查看: 16245|回復: 0
stm32滴答時鐘SYStick的優先級設定方法詳解
ID:82781 發表于 2015-6-14 01:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
SYStick優先級設置的點點
本文檔為個人編制,BUG難免  與天津第四項目部宿舍
STV3.50固件為對象,:
1.     滴答寄存器的定義和地址分配在內核.H文件中如下
typedef struct
  __IO uint32_t CTRL;                         /*!< Offset: 0x00  SysTick Control and Status Register */
  __IO uint32_t LOAD;                         /*!< Offset: 0x04  SysTick Reload Value Register     */
  __IO uint32_t VAL;                          /*!< Offset: 0x08  SysTick Current Value Register     */
  __I  uint32_t CALIB;                        /*!< Offset: 0x0C  SysTick Calibration Register      */
} SysTick_Type;
#define SysTick             ((SysTick_Type *)       SysTick_BASE)
定義結構指針SYSTICK,并賦值為物理存儲器首地址0xE000E010,由于結構是順序的所以可以用結構指針來訪問寄存器。
因為滴答事件是內核的異常所以還要牽扯到另一個寄存器SCB寄存器(系統控制塊)
typedef struct
__I  uint32_t CPUID;        /*!< Offset: 0x00  CPU ID Base Register                          */
  __IO uint32_t ICSR;       /*!< Offset: 0x04  Interrupt Control State Register                      */
  __IO uint32_t VTOR;     /*!< Offset: 0x08  Vector Table Offset Register                          */
  __IO uint32_t AIRCR;    /*!< Offset: 0x0C  Application Interrupt / Reset Control Register        */
  __IO uint32_t SCR;    /*!< Offset: 0x10  System Control Register                               */
  __IO uint32_t CCR;     /*!< Offset: 0x14  Configuration Control Register                        */
  __IO uint8_t  SHP[12];    /*!< Offset: 0x18  System Handlers Priority Registers (4-7, 8-11, 12-15) */
  __IO uint32_t SHCSR;  /*!< Offset: 0x24  System Handler Control and State Register             */
  __IO uint32_t CFSR;  /*!< Offset: 0x28  Configurable Fault Status Register                    */
  __IO uint32_t HFSR;   /*!< Offset: 0x2C  Hard Fault Status Register                            */
  __IO uint32_t DFSR;   /*!< Offset: 0x30  Debug Fault Status Register                           */
  __IO uint32_t MMFAR; /*!< Offset: 0x34  Mem Manage Address Register                           */
  __IO uint32_t BFAR; /*!< Offset: 0x38  Bus Fault Address Register                            */
  __IO uint32_t AFSR; /*!< Offset: 0x3C  Auxiliary Fault Status Register                        */
  __I  uint32_t PFR[2]; /*!< Offset: 0x40  Processor Feature Register                           */
  __I  uint32_t DFR;  /*!< Offset: 0x48  Debug Feature Register                              */
  __I  uint32_t ADR; /*!< Offset: 0x4C  Auxiliary Feature Register                            */
  __I  uint32_t MMFR[4]; /*!< Offset: 0x50  Memory Model Feature Register                    */
  __I  uint32_t ISAR[5]; /*!< Offset: 0x60  ISA Feature Register                                  */
} SCB_Type;
這里面寄存器很多,在這里大部分我們不用去管,有一個數組SHP[12],一定要看清他是8位數組啊!這個數組是很重要的,他是用來設置內核異常的優先級別,并不是想的在NVIC里設置,那個是大于15號中斷的優先組別,換句話就是外部中斷什么看門狗,定時器,串口啥的,外設的中斷優先級設置在NVICIP數組中,而小于這個的都是內部異常,他不歸NVIC管制,他受誰管呢?就是這個SHP[12],滴答屬于內核的異常所以他要用SHP[12]來設置,和內核手冊中講到的那三個(SHRP1-SHRP3)32位寄存器一一對應,算下來正好有12個字節,最后一個字節就是我要的SYStick的優先級設置,他只用了他的高四位,而第四位保留,所以他的范圍是0-15之間的任意數!!
2.系統設置函數:
NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1);
這就是固件庫里對SYSTICK的優先級設置,,后面參數,這里的__NVIC_PRIO_BITS=4,變形=1《《4-1=0xf;第一個參數是表明這是對滴答進行設置,SysTick_IRQn=-1,看實體:
static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
if(IRQn < 0) {
    SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff); } /* set Priority for Cortex-M3 System Interrupts */
  else {
NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);    }
這里有個IF,就是這個IF來判別是內核異常還是外部異常的優先級,如果是內核異常那么由SCB解決,如果不是那么有NVIC解決。顯然這個是由SCB解決的。
SHP[((uint32_t)(IRQn) & 0xF)-4]變換=SHP[f-4]=SHP[11],那么這個SHP[11]就是設置滴答的優先級!他的優先級是多少?
((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);=priority<<4=(f<<4)=0xf0;
顯然這就是他的優先級是15!!!!!!!!!!!!!!!
有了優先級就了解滴答了,即使沒有固件庫函數依然可以設置看看自己設置的函數:
void mysystickint()
SysTick->LOAD=71999;//加載值=1ms
SCB->SHP[11]=15;//設置SYSTICK的優先級為15,注意SYSTICK屬于系統異常,所以他的優先級在SCB里設置。
SysTick->CTRL=7;//開啟中斷,開啟定時器,時鐘設置為HCLK=72mhz
}這是中斷模式,另外也可以選擇查詢模式,只是占CPU時間,查詢模式下根本不用設置什么優先級!他只要開開滴答,查詢標志位即可!
哈哈,,直接去操作寄存器,效果是一樣的,但是這樣的好處是速度快,缺點是不直觀!我認為還是直接操作寄存器好,一來是符合我以前的邏輯,另一方面不受固件庫的限制!即使沒有固件庫一樣可以設置!所以底層的東西要努力學習啊!
主站蜘蛛池模板: 国产精品二区一区二区aⅴ污介绍 | 国产一级在线播放 | 久久久久免费视频 | 国产精品视频久久久 | 久热综合 | 国产精品视频免费看 | 日韩精品免费在线观看 | 欧美啪啪网 | 欧美精品色 | 十八岁毛片| 91精品久久久久久粉嫩 | 蜜桃视频一区二区 | 日日夜夜精品 | 成人高清在线 | 亚洲综合二区 | 欧美mv日韩mv国产 | 糖心vlog精品一区二区 | 天堂网在线资源 | 国内精品国产成人国产三级 | 日韩一级在线观看 | 一级肉体全黄裸片 | 在线观看的av网站 | 日韩在线小视频 | 日本视频免费 | 亚洲男人天堂网 | 在线观看91 | 黄色网页免费 | 国产免费高清视频 | av免费网站 | 国产一级片免费观看 | 亚洲精品91天天久久人人 | 国产一区二区精品丝袜 | 亚洲国产免费 | 日韩av在线影院 | 欧美激情一区 | 黄色三级av | 免费成人蒂法网站 | 日本丰满少妇做爰爽爽 | 天天插天天透 | 日韩欧美精品在线 | 成人免费视频一区二区 |
