查看: 6832|回復: 0
JPG圖片C語言解碼顯示例子-期末傾情奉獻
ID:90014 發表于 2015-9-14 18:54 | 顯示全部樓層 |閱讀模式
     企圖解碼JPG的圖片并且代碼完全由自己來寫,那是不容易的,據我所知這種代碼完全可以當做碩士研究生的畢業論文了.
    我今天用的是Tjpg解碼庫庫函數大概1000行,顯示過程中除了需要Tjpg解碼庫提供的兩個庫函數
/* Error code */
typedef enum {
        JDR_OK = 0,        /* 0: Succeeded */
        JDR_INTR,        /* 1: Interrupted by output function */
        JDR_INP,        /* 2: Device error or wrong termination of input stream */
        JDR_MEM1,        /* 3: Insufficient memory pool for the image */
        JDR_MEM2,        /* 4: Insufficient stream input buffer */
        JDR_PAR,        /* 5: Parameter error */
        JDR_FMT1,        /* 6: Data format error (may be damaged data) */
        JDR_FMT2,        /* 7: Right format but not supported */
        JDR_FMT3        /* 8: Not supported JPEG standard */
} JRESULT;
/* Rectangular structure */
typedef struct {
        WORD left, right, top, bottom;
} JRECT;
/* Decompressor object structure */
typedef struct JDEC JDEC;
struct JDEC {
        UINT dctr;                                /* Number of bytes available in the input buffer */
        BYTE* dptr;                                /* Current data read ptr */
        BYTE* inbuf;                        /* Bit stream input buffer */
        BYTE dmsk;                                /* Current bit in the current read byte */
        BYTE scale;                                /* Output scaling ratio */
        BYTE msx, msy;                        /* MCU size in unit of block (width, height) */
        BYTE qtid[3];                        /* Quantization table ID of each component */
        SHORT dcv[3];                        /* Previous DC element of each component */
        WORD nrst;                                /* Restart inverval */
        UINT width, height;                /* Size of the input image (pixel) */
        BYTE* huffbits[2][2];        /* Huffman bit distribution tables [id][dcac] */
        WORD* huffcode[2][2];        /* Huffman code word tables [id][dcac] */
        BYTE* huffdata[2][2];        /* Huffman decoded data tables [id][dcac] */
        LONG* qttbl[4];                        /* Dequaitizer tables [id] */
        void* workbuf;                        /* Working buffer for IDCT and RGB output */
        BYTE* mcubuf;                        /* Working buffer for the MCU */
        void* pool;                                /* Pointer to available memory pool */
        UINT sz_pool;                        /* Size of momory pool (bytes available) */
        UINT (*infunc)(JDEC*, BYTE*, UINT);/* Pointer to jpeg stream input function */
        void* device;                        /* Pointer to I/O device identifiler for the session */
之外,還需要自己寫兩個函數.
先來看下其中一個庫函數的聲明:
JRESULT jd_prepare (
JDEC* jd,/* Blank decompressor object */
UINT (*infunc)(JDEC*, BYTE*, UINT),/* JPEG strem input function */
void* pool,/* Working buffer for the decompression session */
UINT sz_pool,/* Size of working buffer */
void* dev/* I/O device identifier for the session */
UINT (*infunc)(JDEC*, BYTE*, UINT),/* JPEG strem input function */這是這個庫函數的第二個參數的聲明.這是一個指向函數的指針.
為了給這個參數賦值 首先要先寫一個函數 這個函數由庫函數調用.用來從磁盤讀取圖像的數據
UINT InputData(JDEC * jdec , BYTE *buff , UINT nbyte)
    /* 這個函數將被
jd_prepare  調用 調用此函數后希望將得到的數據 保存在buff為首地址的內存中 數據的長度為nbyte */
    if(buff)/* buff 如果不為NULL */
        f_read(&fil , buff , nbyte ,&br);/* &fil 保存圖片數據的地址 */
        return br;
    else/* 否則將移動數據 */
        return (f_lseek(&fil, f_tell(dev->fp) + nbyte) == FR_OK) ? nbyte : 0;
UINT OutputData(JDEC *jdec , void bitmap , JRECT *rect)
    LCD_Disp(rect->left,rect->top,rect->right,rect->bottom,(uint16_t*)bitmap);
    return 1;
int main(void)
    JDEC jdec;
    JRESULT res;
    uint8_t work[4096];
    /* 首先要打開文件 */
    res=jd_prepare(&jdec,InputData,work,4096, ... );/* 根據我的實驗這個函數的最后一個參數可以不用傳 但是為了能編譯通過 隨便傳一個指針就可以了 */
    if(res==JDR_OK)
        res=jd_decomp(&jdec,OutputData,0);
        if(res==JDR_OK)
            /* 成功 */
主站蜘蛛池模板: 五月av| a在线免费观看 | 日韩av免费播放 | 激情综| 麻豆一级片 | 成人免费在线观看 | 日本在线网站 | 香蕉成人网 | 一级片免费观看 | 欧美午夜精品久久久久免费视 | 黄av在线| 亚洲一区二区三区在线播放 | 97成人免费视频 | 日韩在线欧美 | 五月天精品 | 久久久午夜 | 水蜜桃一区二区 | 成人精品在线观看 | h片免费看 | 日韩色在线 | 91三级视频 | 日本高清视频www | 午夜精品久久久 | 欧美在线视频观看 | 国产免费一区二区三区免费视频 | www.超碰| 国产aⅴ爽av久久久久成人 | 超碰97久久 | 国产色站| 免费三级黄色片 | 久久99国产精品 | 激情久久久 | www.一区二区 | 国产精品久久久久久久久久久久久 | 一级片免费观看 | 黄色成人免费网站 | 精品国产va久久久久久久 | 97视频免费在线观看 | 婷婷综合视频 | 极品av在线 | 一级片免费 |
