查看: 12242|回復: 0
The directory pointed by the FileDir INI file entry cannot be found.Aborting
ID:90228 發表于 2015-9-29 02:35 | 顯示全部樓層 |閱讀模式
點擊PADS后就會出現以下: "The directory pointed by the FileDir INI file entry cannot be found.Aborting."點確定后,
軟件自動關閉。
解決辦法:
打開(X:\MentorGraphics\2005PADS)\SDD_HOME\Programs\powerlogic.ini,注意:括號中的路徑為PADS在用戶磁盤上的安裝路徑;
按PADS Logic軟件的錯誤提示框中顯示的內容,定位至powerlogic.ini文件中相應設置項,如“FileDir”等逐一修改為磁盤上存在的路徑,即可。
Pads, Power Logic:
Notes, tips & workarounds.
Logic default settings & paths in the ‘ini’ file V2005.
Sadly Pads logic doesn’t allow you to set the default paths & settings of a project from within the program itself. So a little digging around in the ‘ini’ file is required.
Go to:
C:\MentorGraphics\2005PADS\SDD_HOME\Programs\powerlogic.ini
Open the file in Notepad or a text editor & near the top you’ll see;
FileDir=C:\PADS Projects\
LibDir=C:\MentorGraphics\2005PADS\SDD_HOME\Libraries
UserDir=C:\MentorGraphics\2005PADS\SDD_HOME\Settings
SystemDir=C:\MentorGraphics\2005PADS\SDD_HOME\Programs
ReuseDir=C:\PADS Projects\Reuse
CAMDir=C:\PADS Projects\Cam
FileDir: This is where the program will open a file from, so if you have a project location or mapped drive you wish to work from, place it here.
LibDir: This is set in the Library menu under ‘Manage Lib List’
UserDir: This is the settings location & is normal left as the default path set by Mentor, unless of course you want to move the settings files also!
SystemDir: As the name suggests this is the Logics system path & really needs to be left as the default installation intended.
ReuseDir: Location for Reuse libraries
CAMDir: Location for CAM output.
However if you have many different clients with different library sets etc, a quick tip to get around re-setting these settings all the time is to keep separate ‘ini’ files for each client named with the clients name & just copy it & rename it to the default name each time you need to change over settings.
《搞不定的, 請加下面的群,找群主》
Logic default page for a ‘New file’.
[size=11.333333015441895px]Got a specific clients border sheet that you want to automatically bring in to a schematic each time or appear when you select a ‘New File’? First open the sheet & set-up the setting to your liking, go into all the settings & menus that you want to set & wouldn’t want to keep having to re-set each time, like Grid size, Sheet size etc. Then export this out from ‘File > Export’ save asdefault.txt
Next go to:
C:\MentorGraphics\2005PADS\SDD_HOME\Settings\default.txt
Keep a copy of this Mentor default somewhere safe, but you can now take your new file & over write this default.txt. So now as long as the UserDir path in your ‘powerlogic.ini’ file is still set to the Mentor default path, the next time you open Logic it will display your new Border with all the settings already set for you.
[size=11.333333015441895px]If the[size=11.333333015441895px] UserDir[size=11.333333015441895px] [size=11.333333015441895px]path is different, then your new default.txt most be located there instead.
[size=11.333333015441895px]e default installation intended.
[size=11.333333015441895px]ReuseDir: Location for Reuse libraries
Next go to:
主站蜘蛛池模板: 色爱av | 亚洲天堂国产 | 精品福利在线观看 | 九色91popny蝌蚪新疆 | 黄色一级大片在线免费看产 | 日本免费视频 | 91成人精品 | 久久精品久久久久久久 | 69视频网站 | 国产又粗又猛视频免费 | 亚洲日本高清 | 亚洲看片 | 成人深夜福利 | 亚洲人成免费 | 黄频在线观看 | 小镇姑娘国语版在线观看免费 | 黄色片一级片 | 欧美一级特黄视频 | 亚洲视频一区在线观看 | av免费看网站 | 麻豆av在线播放 | 久久久久精 | 亚洲国产欧美在线 | 一级做a爰片久久毛片潮喷 亚洲黄色天堂 | 免费视频毛片 | 日韩欧美在线播放 | 成人午夜在线视频 | 天天拍天天射 | 在线观看欧美日韩视频 | 午夜影院黄 | 婷婷久久综合 | 日韩免费在线观看 | 91欧美大片| 国产成人小视频 | 国产日韩av在线 | 亚洲激情欧美 | 欧美伊人久久 | 男人天堂网av | 草少妇| 国产一级免费观看 | 国产一区二区三区免费播放 |
