查看: 7578|回復: 1
stm32l053r8t6的時鐘喚醒程序解析
ID:98924 發表于 2015-12-9 01:18 | 顯示全部樓層 |閱讀模式
  當你學習stm32l053r8t6這款芯片時,必定要用到他的低功耗功能,所以進入低功耗模式是必須要學習一下的。
        官方例程如下
        int main(void)
  /* STM32L0xx HAL library initialization:
       - Configure the Flash prefetch, Flash preread and Buffer caches
       - Systick timer is configured by default as source of time base, but user
             can eventually implement his proper time base source (a general purpose
             timer for example or other time source), keeping in mind that Time base
             duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
             handled in milliseconds basis.
       - Low Level Initialization
  HAL_Init();
  /* Configure LED2 */
  BSP_LED_Init(LED2);
  /* Configure the system clock to 2 MHz */
  SystemClock_Config();
  /* Configure the system power */
  SystemPower_Config();
  /* Check and handle if the system was resumed from StandBy mode */
  if(__HAL_PWR_GET_FLAG(PWR_FLAG_SB) != RESET)
    /* Clear Standby flag */
    __HAL_PWR_CLEAR_FLAG(PWR_FLAG_SB);
  /* Insert 5 seconds delay */
  HAL_Delay(5000);
    /*The Following Wakeup sequence is highly recommended prior to each Standby mode entry
     mainly  when using more than one wakeup source this is to not miss any wakeup event.
       - Disable all used wakeup sources,
       - Clear all related wakeup flags,
       - Re-enable all used wakeup sources,
       - Enter the Standby mode.
  /*Disable all used wakeup sources*/
  HAL_RTCEx_DeactivateWakeUpTimer(&RTCHandle);
  /*Re-enable all used wakeup sources*/
    /*## Setting the Wake up time ############################################*/
  /*  RTC Wakeup Interrupt Generation:
      Wakeup Time Base = (RTC_WAKEUPCLOCK_RTCCLK_DIV /(LSE or LSI))
      Wakeup Time = Wakeup Time Base * WakeUpCounter
                  = (RTC_WAKEUPCLOCK_RTCCLK_DIV /(LSE or LSI)) * WakeUpCounter
      ==> WakeUpCounter = Wakeup Time / Wakeup Time Base
      To configure the wake up timer to 4s the WakeUpCounter is set to 0x1FFF:
        RTC_WAKEUPCLOCK_RTCCLK_DIV = RTCCLK_Div16 = 16
        Wakeup Time Base = 16 /(~39.000KHz) = ~0,410 ms
        Wakeup Time = ~4s = 0,410ms  * WakeUpCounter
        ==> WakeUpCounter = ~4s/0,410ms = 9750 = 0x2616 */
   HAL_RTCEx_SetWakeUpTimer_IT(&RTCHandle, 0x2616, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
  /*Clear all related wakeup flags*/
  __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WU);
  /*Enter the Standby mode*/
  HAL_PWR_EnterSTANDBYMode();
  while (1)
上邊的例子展示了系統是如何進入休眠模式的。以及如何被RTC喚醒的通過外部的引腳20來產生觸發事件。例子還說明了如何進入rtc功耗的休眠模式。
        軟件配置成2Mhz.系統滴答每1ms中斷,低速時鐘LSI被用做RTC。
        20引腳每4s產生一個上升沿來喚醒。
        從休眠模式中喚醒后,程序就相當于復位后的重啟,也不用再配置RTC,
注意:例子不能在調試模式下運行,是因為MO+核不在狀態中在低功耗模式下,所以被禁止了。
核會被占用,當如下配置后。
@note Care must be taken when HAL_RCCEx_PeriphCLKConfig() is used to select
       the RTC clock source; in this case the Backup domain will be reset in
       order to modify the RTC Clock source, as consequence RTC registers (including
       the backup registers) and RCC_CSR register are set to their reset values.
@note Care must be taken when using HAL_Delay(), this function provides accurate delay (in milliseconds)
       based on variable incremented in SysTick ISR. This implies that if HAL_Delay() is called from
       a peripheral ISR process, then the SysTick interrupt must have higher priority (numerically lower)
       than the peripheral interrupt. Otherwise the caller ISR process will be blocked.
       To change the SysTick interrupt priority you have to use HAL_NVIC_SetPriority() function.
@note The application need to ensure that the SysTick time base is always set to 1 millisecond
       to have correct HAL operation.
@par Directory contents
用到的文件目錄
  - PWR/PWR_STANDBY_RTC/Inc/stm32l0xx_conf.h     Library Configuration file
  - PWR/PWR_STANDBY_RTC/Inc/stm32l0xx_it.h       Header for stm32l0xx_it.c
  - PWR/PWR_STANDBY_RTC/Inc/main.h               header file for main.c
  - PWR/PWR_STANDBY_RTC/Src/system_stm32fl0xx.c   STM32L0xx system clock configuration file
  - PWR/PWR_STANDBY_RTC/Src/stm32l0xx_it.c       Interrupt handlers
  - PWR/PWR_STANDBY_RTC/Src/main.c               Main program
  - PWR/PWR_STANDBY_RTC/Src/stm32l0xx_hal_msp.c  HAL MSP module
@par Hardware and Software environment
  - This example runs on STM32L051xx, STM32L052xx, STM32L053xx STM32L062xx and
    STM32L063xx device lines RevZ Rev A.
  - This example has been tested with STMicroelectronics STM32L053R8-Nucleo board Rev C
    and can be easily tailored to any other supported device and development board.
  - STM32L053R8-Nucleo Set-up
    - Use LED2 connected to PA.05 pin
    - Connect an amperemeter to JP6 to measure the IDD current
主站蜘蛛池模板: 97精品国产 | 亚洲精品a| 成人免费片 | 性免费视频 | 福利小视频 | 日韩亚洲欧美在线 | 色噜噜狠狠一区二区三区果冻 | 国产福利在线视频 | 中文一区二区 | 成人一区在线观看 | 亚洲视频在线一区 | 羞羞的视频网站 | 97免费在线视频 | 日韩av在线免费 | 国产永久免费 | 久久免费国产 | 国产日韩精品一区二区 | 九九香蕉视频 | 欧美国产精品 | 黄色a网站 | 日韩精品一二三 | 日本免费在线观看视频 | 黄色片网站免费 | 丁香色婷婷 | 欧美日韩在线不卡 | 黄色网址在线播放 | 日韩欧美中文 | 国产高清免费 | 婷婷色网 | 四虎网站在线观看 | 婷婷六月天 | 黄色三级av | 欧美成人毛片 | 亚洲国产网站 | 五月综合色 | 一区二区av| 亚洲天堂av在线 | 超碰在线中文字幕 | 日本一级大片 | 黄色福利| 91理论片午午伦夜理片久久 |
