查看: 4099|回復: 0
printf的格式詳解
ID:102668 發表于 2016-1-16 03:38 | 顯示全部樓層 |閱讀模式
經常在寫一些字符串的程序,會用到printf,sscanf,sprintf,FORMAT.......之類的函數,這些函數,非常好用,代碼少,有的時候會起到意想不到的作用,但是一直對這個格式,不是很清楚的了解,今天上網仔細查找了一番,有點收獲。
Print formatted data to stdout
Writes to the standard output (stdout) a sequence of data formatted as the format argument specifies. After the format parameter, the function expects at least as many additional arguments as specified in format. Parametersformat String that contains the text to be written to stdout.It can optionally contain embedded format tags that are substituted by the values specified in subsequent argument(s) and formatted as requested.The number of arguments following the format parameters should at least be as much as the number of format tags.The format tags follow this prototype:
%[flags][width][.precision][length]specifier
Where specifier is the most significant one and defines the type and the interpretation of the value of the coresponding argument:
specifier    Output                                                   Example
c            Character                                                a
d            or i Signed decimal integer 392
e            Scientific notation (mantise/exponent) using e character 3.9265e+2
E            Scientific notation (mantise/exponent) using E character 3.9265E+2
f            Decimal floating point 392.65
g            Use the shorter of %e or %f 392.65
G            Use the shorter of %E or %f 392.65
o            Signed octal 610
s            String of characters sample
u            Unsigned decimal integer 7235
x            Unsigned hexadecimal integer 7fa
X            Unsigned hexadecimal integer (capital letters) 7FA
p            Pointer address B800:0000
n            Nothing printed. The argument must be a pointer to a signed int, where the number of characters written so far is stored.
% A %        followed by another % character will write % to stdout.
The tag can also contain flags, width, .precision and modifiers sub-specifiers, which are optional and follow these specifications:
flags       description
-           Left-justify within the given field width; Right justification is the default (see width sub-specifier).
+           Forces to preceed the result with a plus or minus sign (+ or -) even for positive numbers. By default, only negative numbers are preceded with a - sign.
(space)     If no sign is going to be written, a blank space is inserted before the value.
#           Used with o, x or X specifiers the value is preceeded with 0, 0x or 0Xrespectively for values different than zero.Used with e, E and f, it forces the written output to contain a decimal point even if no digits would follow. By default, if no digits follow, no decimal point is written.Used with g or G the result is the same as with e or E but trailing zeros are not removed.
0         Left-pads the number with zeroes (0) instead of spaces, where padding is specified (see width sub-specifier).
width      description
(number)   Minimum number of characters to be printed. If the value to be printed is shorter than this number, the result is padded with blank spaces. The value is not truncated even if the result is larger.
*          The width is not specified in the format string, but as an additional integer value argument preceding the argument thas has to be formatted.
.          precision description
.          number For integer specifiers (d, i, o, u, x, X): precision specifies the minimum number of digits to be written. If the value to be written is shorter than this number, the result is padded with leading zeros. The value is not truncated even if the result is longer. A precision of 0 means that no character is written for the value 0.For e, E and f specifiers: this is the number of digits to be printed after the decimal point.For g and G specifiers: This is the maximum number of significant digits to be printed.For s: this is the maximum number of characters to be printed. By default all characters are printed until the ending null character is encountered.For c type: it has no effect.When no precision is specified, the default is 1. If the period is specified without an explicit value for precision, 0 is assumed.
.*       The precision is not specified in the format string, but as an additional integer value argument preceding the argument thas has to be formatted.
length   description
h        The argument is interpreted as a short int or unsigned short int (only applies to integer specifiers: i, d, o, u, x and X).
l        The argument is interpreted as a long int or unsigned long int for integer specifiers (i, d, o, u, x and X), and as a wide character or wide character string for specifiers c and s.
L        The argument is interpreted as a long double (only applies to floating point specifiers: e, E, f, g and G).
Depending on the format string, the function may expect a sequence of additional arguments, each containing one value to be inserted instead of each %-tag specified in the format parameter, if any. There should be the same number of these arguments as the number of %-tags that expect a value.
Return Value
On success, the total number of characters written is returned.
On failure, a negative number is returned.
Example
/* fprintf example */
#include <stdio.h>
int main()
   printf ("Characters: %c %c \n", 'a', 65);
   printf ("Decimals: %d %ld\n", 1977, 650000);
   printf ("Preceding with blanks: %10d \n", 1977);
   printf ("Preceding with zeros: %010d \n", 1977);
   printf ("Some different radixes: %d %x %o %#x %#o \n", 100, 100, 100, 100, 100);
   printf ("floats: %4.2f %+.0e %E \n", 3.1416, 3.1416, 3.1416);
   printf ("Width trick: %*d \n", 5, 10);
   printf ("%s \n", "A string");
   return 0;
And here is the output:
Characters: a A
Decimals: 1977 650000
Preceding with blanks:       1977
Preceding with zeros: 0000001977
Some different radixes: 100 64 144 0x64 0144
floats: 3.14 +3e+000 3.141600E+000
Width trick:    10
A string
看了這篇文章以后,格式字符串,基本不成問題了。希望對大家有點幫助
主站蜘蛛池模板: 中文在线观看免费视频 | 国产区在线视频 | 中文字幕精品一区久久久久 | 亚洲一级黄色片 | 深夜免费福利 | 91av免费观看 | 国产在线观看免费 | 欧美一二 | 日本免费一级片 | 欧美在线视频免费 | 日韩午夜片 | 日韩欧美精品一区 | 欧美日韩亚洲一区二区三区 | 国产精品久久久久久妇女6080 | 日韩精品免费 | 一区二区国产在线 | 欧美久久一区二区 | 欧美国产精品 | 亚洲一区二区在线 | 日韩1级片 | 欧美一二三 | 婷婷一区二区三区 | av网站免费在线观看 | 欧美在线视频播放 | 97人人视频 | 国产欧美在线播放 | 天堂va蜜桃一区二区三区 | 在线看的av | 国内精品一区二区三区 | 日韩毛片网 | 香蕉视频一区二区 | 4438成人网 | 日本美女一级片 | 国产日本在线观看 | 一区二区免费视频 | 中国毛片视频 | 亚洲视频在线一区 | 亚洲毛片网| 亚洲一区二区久久 | 国产精品欧美激情 | 日韩精品三级 |
