查看: 4262|回復: 0
μVISION: Pack Installer Reports Errors
ID:104126 發表于 2016-1-23 02:48 | 顯示全部樓層 |閱讀模式
Information in this knowledgebase article applies to:
  • MDKversion 5.01 and earlier
SYMPTOM
When the pack installer of MDK 5.00 performs a 'Check for Updates',you may see the error message:
Reading one or more Pack descriptions failed
The error window may look like this:
CAUSE
On February 21, 2014 some new Device FamilyPack (DFP) files have been published in a evennewer file-format. The change from format specification V1.1 toV1.2 was necessary to fully support new devices. The error shows upbecause μVision version 5.00 (and later) andits Pack Installer are notdesigned to work with version 1.2 files.
On December 19th 2013, some new Device FamilyPack (DFP) files have been published in a newfile-format. The change from format specification V1.0 to V1.1 wasnecessary to fully support new devices. The error shows up becauseμVision version 5.00 and its PackInstaller are not designed to work withversion 1.1 DFP files.
RESOLUTION
The error window can be closed and existing projects can becontinued. However, no new Device Family Packs can be installedwith MDK 5.00 only packs with the 1.0 schema will work. Pleaseupdate to MDK version 5.10 or newer. Youmay download the latestupdates from the Keil Website.
If an update is not possible for any reason, you can close thiserror window and the PackInstaller will continue to work without thosenew device family packs listed in the error dialog. Your μVisionproject will also continue to work as expected.
Please note that it is possible to install a new DFP manually onMDK 5.0 but μVision will not be able to use the new devices. DFPscan be downloaded from http://www.keil.com/dd2/pack/ andcan then be imported and installed withthe Pack Installer. Whenever μVision 5.00needs to read the device database, the following error messageswill show up:
Last Reviewed: Friday, February 21, 2014
主站蜘蛛池模板: 理论片中文字幕 | 久久精品国产免费 | 97自拍视频| 91麻豆精品一区二区三区 | 午夜一区 | 国产一区久久 | 国产九九 | 色片在线观看 | 日日夜夜综合 | 亚洲国产精品网站 | 国产福利在线 | 亚洲精品一区二三区不卡 | 99精品久久 | 欧美日韩四区 | 青青草视频污 | 久久久久久久影院 | 动漫av在线 | 日韩国产一区 | 四虎网站 | 一道本在线视频 | 91午夜精品亚洲一区二区三区 | 性色av网站 | 国产一区中文字幕 | 天天视频国产 | 日韩欧美视频一区 | 国产午夜免费 | 日韩和的一区二区 | 亚洲不卡在线观看 | 能看的av网站 | 一级黄色免费 | 国产一区二区在线看 | 精品国产乱码久久久久久88av | 久久久夜色精品 | 欧美日韩激情视频 | 精品一区二区三区三区 | 久久久不卡 | 免费一级a毛片 | 青青青草视频在线观看 | 色偷偷噜噜噜亚洲男人 | 久久激情视频 | 久久久久久一区二区 |
