查看: 4892|回復: 1
ISP下載器 電路圖 原代碼 驅(qū)動程序
ID:124161 發(fā)表于 2016-6-7 15:58 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
       該ISP編程器采用ATMEGA8_DIP28作為主控制芯片,預留MOSI,MISO,RET,SCK,VCC,GND。6PIN接口,方便使用者根據(jù)需要連接目標板。
同時預留PROGRAMMING編程接口,用戶可自行升級下載器固件。
ISP下載器電路原理圖截圖:
ISP下載器源碼:
  1. /*
  2.   USBasp - USB in-circuit programmer for Atmel AVR controllers
  3.   Thomas Fischl <tfischl@gmx.de>
  4.   License:
  5.   The project is built with AVR USB driver by Objective Development, which is
  6.   published under an own licence based on the GNU General Public License (GPL).
  7.   USBasp is also distributed under this enhanced licence. See Documentation.
  8.   Target.........: ATMega8 at 12 MHz
  9.   Creation Date..: 2005-02-20
  10.   Last change....: 2006-12-29
  11.   PC2 SCK speed option. GND  -> slow (8khz SCK),
  12.                         open -> fast (375kHz SCK)
  13. */
  14. #include <avr/io.h>
  15. #include <avr/interrupt.h>
  16. #include <avr/pgmspace.h>
  17. #include <avr/wdt.h>
  18. #include "usbdrv.h"
  19. #include "isp.h"
  20. #include "clock.h"
  21. #define USBASP_FUNC_CONNECT     1
  22. #define USBASP_FUNC_DISCONNECT  2
  23. #define USBASP_FUNC_TRANSMIT    3
  24. #define USBASP_FUNC_READFLASH   4
  25. #define USBASP_FUNC_ENABLEPROG  5
  26. #define USBASP_FUNC_WRITEFLASH  6
  27. #define USBASP_FUNC_READEEPROM  7
  28. #define USBASP_FUNC_WRITEEEPROM 8
  29. #define PROG_STATE_IDLE         0
  30. #define PROG_STATE_WRITEFLASH   1
  31. #define PROG_STATE_READFLASH    2
  32. #define PROG_STATE_READEEPROM   3
  33. #define PROG_STATE_WRITEEEPROM  4
  34. #define PROG_BLOCKFLAG_FIRST    1
  35. #define PROG_BLOCKFLAG_LAST     2
  36. #define ledRedOn()    PORTC &= ~(1 << PC1)
  37. #define ledRedOff()   PORTC |= (1 << PC1)
  38. #define ledGreenOn()  PORTC &= ~(1 << PC0)
  39. #define ledGreenOff() PORTC |= (1 << PC0)
  40. static uchar replyBuffer[8];
  41. static uchar prog_state = PROG_STATE_IDLE;
  42. static unsigned int prog_address;
  43. static unsigned int prog_nbytes = 0;
  44. static unsigned int prog_pagesize; //TP: Mega128 fix
  45. static uchar prog_blockflags;
  46. static uchar prog_pagecounter;
  47. uchar usbFunctionSetup(uchar data[8]) {
  48.   uchar len = 0;
  49.   if(data[1] == USBASP_FUNC_CONNECT){
  50.     /* set SCK speed */
  51.     if ((PINC & (1 << PC2)) == 0) {
  52.       ispSetSCKOption(ISP_SCK_SLOW);
  53.     } else {
  54.       ispSetSCKOption(ISP_SCK_FAST);
  55.     }
  56.     ispConnect();
  57.     ledRedOn();
  58.   } else if (data[1] == USBASP_FUNC_DISCONNECT) {
  59.     ispDisconnect();
  60.     ledRedOff();
  61.   } else if (data[1] == USBASP_FUNC_TRANSMIT) {
  62.           if(chip==ATM){
  63.             replyBuffer[0] = ispTransmit(data[2]);
  64.             replyBuffer[1] = ispTransmit(data[3]);
  65.             replyBuffer[2] = ispTransmit(data[4]);
  66.             replyBuffer[3] = ispTransmit(data[5]);
  67.           }else{
  68.                   if(data[2]==0x24){
  69.                           replyBuffer[0] = ispTransmit(data[2]);
  70.                     replyBuffer[1] = ispTransmit(data[3]);
  71.                     replyBuffer[2] = ispTransmit(data[4]);
  72.                           switch(ispTransmit(data[5])&0x1C){
  73.                                   case(0x00):replyBuffer[3]=0xE0;break;
  74.                                   case(0x04):replyBuffer[3]=0xE5;break;
  75.                                   case(0x0C):replyBuffer[3]=0xEE;break;
  76.                                   case(0x1C):replyBuffer[3]=0xFF;break;
  77.                                   }
  78.                   }
  79.                   else if(data[2]==0x30){
  80.                           replyBuffer[0] = ispTransmit(0x28);
  81.                     replyBuffer[1] = ispTransmit(data[3]);
  82.                     replyBuffer[2] = ispTransmit(data[4]);
  83.                     replyBuffer[3] = ispTransmit(data[5]);
  84.                   }
  85.                   else{
  86.                           replyBuffer[0] = ispTransmit(data[2]);
  87.                     replyBuffer[1] = ispTransmit(data[3]);
  88.                     replyBuffer[2] = ispTransmit(data[4]);
  89.                     replyBuffer[3] = ispTransmit(data[5]);
  90.             }
  91.     }
  92.     len = 4;
  93.   } else if (data[1] == USBASP_FUNC_READFLASH) {
  94.     prog_address = (data[3] << 8) | data[2];
  95.     prog_nbytes = (data[7] << 8) | data[6];
  96.     prog_state = PROG_STATE_READFLASH;
  97.     len = 0xff; /* multiple in */
  98.   } else if (data[1] == USBASP_FUNC_READEEPROM) {
  99.     prog_address = (data[3] << 8) | data[2];
  100.     prog_nbytes = (data[7] << 8) | data[6];
  101.     prog_state = PROG_STATE_READEEPROM;
  102.     len = 0xff; /* multiple in */
  103.   } else if (data[1] == USBASP_FUNC_ENABLEPROG) {
  104.     replyBuffer[0] = ispEnterProgrammingMode();;
  105.     len = 1;
  106.   } else if (data[1] == USBASP_FUNC_WRITEFLASH) {
  107.     prog_address = (data[3] << 8) | data[2];
  108.     prog_pagesize = data[4];
  109.     prog_blockflags = data[5] & 0x0F;
  110.     prog_pagesize += (((unsigned int)data[5] & 0xF0)<<4); //TP: Mega128 fix
  111.     if (prog_blockflags & PROG_BLOCKFLAG_FIRST) {
  112.       prog_pagecounter = prog_pagesize;
  113.     }
  114.     prog_nbytes = (data[7] << 8) | data[6];
  115.     prog_state = PROG_STATE_WRITEFLASH;
  116.     len = 0xff; /* multiple out */
  117.   } else if (data[1] == USBASP_FUNC_WRITEEEPROM) {
  118.     prog_address = (data[3] << 8) | data[2];
  119.     prog_pagesize = 0;
  120.     prog_blockflags = 0;
  121.     prog_nbytes = (data[7] << 8) | data[6];
  122.     prog_state = PROG_STATE_WRITEEEPROM;
  123.     len = 0xff; /* multiple out */
  124.   }
  125.   usbMsgPtr = replyBuffer;
  126.   return len;
  127. }
  128. uchar usbFunctionRead(uchar *data, uchar len) {
  129.   uchar i;
  130.   /* check if programmer is in correct read state */
  131.   if ((prog_state != PROG_STATE_READFLASH) &&
  132.       (prog_state != PROG_STATE_READEEPROM)) {
  133.     return 0xff;
  134.   }
  135.   /* fill packet */
  136.   for (i = 0; i < len; i++) {
  137.     if (prog_state == PROG_STATE_READFLASH) {
  138.       data[i] = ispReadFlash(prog_address);
  139.     } else {
  140.       data[i] = ispReadEEPROM(prog_address);
  141.     }
  142.     prog_address++;
  143.   }
  144.   /* last packet? */
  145.   if (len < 8) {
  146.     prog_state = PROG_STATE_IDLE;
  147.   }
  148.   return len;
  149. }
  150. uchar usbFunctionWrite(uchar *data, uchar len) {
  151.   uchar retVal = 0;
  152.   uchar i;
  153.   /* check if programmer is in correct write state */
  154.   if ((prog_state != PROG_STATE_WRITEFLASH) &&
  155.       (prog_state != PROG_STATE_WRITEEEPROM)) {
  156.     return 0xff;
  157.   }
  158.   for (i = 0; i < len; i++) {
  159.     if (prog_state == PROG_STATE_WRITEFLASH) {
  160.       /* Flash */
  161.       if (prog_pagesize == 0) {
  162.         /* not paged */
  163.         ispWriteFlash(prog_address, data[i], 1);
  164.       } else {
  165.         /* paged */
  166.         ispWriteFlash(prog_address, data[i], 0);
  167.         prog_pagecounter --;
  168.         if (prog_pagecounter == 0) {
  169.           ispFlushPage(prog_address, data[i]);
  170.           prog_pagecounter = prog_pagesize;
  171.         }
  172.       }
  173.     } else {
  174.       /* EEPROM */
  175.       ispWriteEEPROM(prog_address, data[i]);
  176.     }
  177.     prog_nbytes --;
  178.     if (prog_nbytes == 0) {
  179.       prog_state = PROG_STATE_IDLE;
  180.       if ((prog_blockflags & PROG_BLOCKFLAG_LAST) &&
  181.           (prog_pagecounter != prog_pagesize)) {
  182.         /* last block and page flush pending, so flush it now */
  183.         ispFlushPage(prog_address, data[i]);
  184.       }
  185.
  186.           retVal = 1; // Need to return 1 when no more data is to be received
  187.     }
  188.     prog_address ++;
  189.   }
  190.   return retVal;
  191. }
  192. int main(void)
  193. {
  194.   uchar   i, j;
  195.   PORTD = 0;
  196.   PORTB = 0;                /* no pullups on USB and ISP pins */
  197.   DDRD = ~(1 << 2);        /* all outputs except PD2 = INT0 */
  198.   DDRB = ~0;            /* output SE0 for USB reset */
  199.   j = 0;
  200.   while(--j){           /* USB Reset by device only required on Watchdog Reset */
  201.       i = 0;
  202.       while(--i);       /* delay >10ms for USB reset */
  203.   }
  204.   DDRB = 0;             /* all USB and ISP pins inputs */
  205.   DDRC = 0x03;          /* all inputs except PC0, PC1 */
  206.   PORTC = 0xfe;
  207.
  208.         chip=ATM;
  209.
  210.   clockInit();          /* init timer */
  211.   ispSetSCKOption(ISP_SCK_FAST);
  212.   usbInit();
  213.   sei();
  214.   for(;;){                /* main event loop */
  215.     usbPoll();
  216.   }
  217.   return 0;
  218. }
全部資料(壓縮包)下載:
windows端驅(qū)動.zip (32.27 KB, 下載次數(shù): 16) 固件和AVR單片機源碼.zip (146.18 KB, 下載次數(shù): 16) 原理圖和PCB源文件.zip (122.32 KB, 下載次數(shù): 13)
ID:125666 發(fā)表于 2016-6-7 16:21 | 只看該作者
好牛逼
主站蜘蛛池模板: 亚洲视频区 | 黄色日批视频 | 亚洲成人一区 | 中文字幕综合网 | 国产午夜一区二区三区 | 亚洲天堂日本 | 女人黄网站 | 91在线精品一区二区 | 日韩一级黄色片 | 手机福利视频 | 日韩在线视频一区 | 伊人成人在线视频 | 91青青| 久久久在线 | 福利视频免费观看 | 午夜激情影视 | 日韩免费一区二区三区 | 久久激情综合 | 91精品久久久久久久久 | 精品一区二区国产 | 欧美亚洲国产日韩 | 一级特黄毛片 | 中文字幕97 | 青青草精品视频 | 99超碰在线观看 | 日韩福利一区 | 午夜精品一区二区三区在线视频 | 蜜桃成人av | 玖玖在线观看 | 日韩精品一区二区视频 | 能看的av网站 | 成人免费av| 91色视频 | 国产亚洲欧美一区二区 | 久热精品视频在线观看 | www.huangse| 亚洲精品三级 | 伊人成人在线 | 黄视频在线播放 | 人人超碰人人 | 亚洲精品一二 |
