查看: 2449|回復: 0
VB寫的查找特征碼的模塊
ID:108531 發表于 2016-3-12 16:02 | 顯示全部樓層 |閱讀模式
示例:
'定義游戲路徑,以及各種特征碼
Private Const Game_Path = "D:\Game\7fgame\7FGameApp.dll"
Private Const Game_Base_Feature_Codes = "90909081EC780500008B0D"
Private Const Code_Check_Feature_Codes = "50518BCBE86C0200008B4C242C"
Private Const Code_Check1_Feature_Codes = "50518BCBE8A80100008B4C2428"
Private Const Date_Check_Feature_Codes = "83C41485C07414FFD3"
Private Const Date_Check1_Feature_Codes = "03C283C41C3BC874"
Private Const Date_Check2_Feature_Codes = "0F858700000033DB3BD3895C"
Private Const Room_On_Feature_Codes = "85C07408C74424100000"
Private Const Hall_Check_Feature_Codes = "C744242C140000008B48"
Private Const Room_Check_Feature_Codes = "8D94244E040000C1E902F3"
Private Const Game_Check_Feature_Codes = "8954242E894424328D93"
Private Const Date_Lock_Feature_Codes = "66ABAA8B45103BC80F"
Private Const Date_Lock1_Feature_Codes = "8B531033ED85D2C744241401"
'定義SCO結構體變量
Private SCO As Sanguo_Check_Offset
'過程搜索游戲個特征碼的偏移
Private Sub Call_Search_Offset()
Dim FileBin() As Byte
    ReadFileBin FileBin, Game_Path
    SCO.Game_Base_offset = Find_Location(FileBin, Game_Base_Feature_Codes, 1)
    SCO.Code_Check_offset = Find_Location(FileBin, Code_Check_Feature_Codes, 7)
    SCO.Code_Check1_offset = Find_Location(FileBin, Code_Check1_Feature_Codes, 7)
    SCO.Date_Check_offset = Find_Location(FileBin, Date_Check_Feature_Codes, -3)
    SCO.Date_Check1_offset = Find_Location(FileBin, Date_Check1_Feature_Codes)
    SCO.Date_Check2_offset = Find_Location(FileBin, Date_Check2_Feature_Codes, 3)
    SCO.Room_On_offset = Find_Location(FileBin, Room_On_Feature_Codes, -1)
    SCO.Hall_Check_offset = Find_Location(FileBin, Hall_Check_Feature_Codes, 8)
    SCO.Room_Check_offset = Find_Location(FileBin, Room_Check_Feature_Codes, &H16D)
    SCO.Game_Check_offset = Find_Location(FileBin, Game_Check_Feature_Codes, -&HF)
    SCO.Date_Lock_offset = Find_Location(FileBin, Date_Lock_Feature_Codes, 0)
    SCO.Date_Lock1_offset = Find_Location(FileBin, Date_Lock1_Feature_Codes, 4)
    Show_List_Result
    Label1.Caption = "掃描完畢!"
End Sub
以下是模塊:
Option Explicit
Private Declare Function OpenProcess Lib "kernel32" (ByVal dwDesiredAccess As Long, ByVal bInheritHandle As Long, ByVal dwProcessId As Long) As Long
Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
Private Declare Function ReadProcessMemory Lib "kernel32.dll" (ByVal hProcess As Long, ByVal lpBaseAddress As Long, ByRef lpBuffer As Any, ByVal nSize As Long, ByRef lpNumberOfBytesWritten As Long) As Long
Private Const PROCESS_ALL_ACCESS = &H1F0FFF
'以二進制形式讀取文件存放在FileBin()數組中
Public Sub ReadFileBin(FileBin() As Byte, FilePath As String)
    Open FilePath For Binary As #1
    ReDim FileBin(FileLen(FilePath))
    While Not EOF(1)
        Get #1, , FileBin
    DoEvents
    Wend
    Close #1
End Sub
'讀取內存進程代碼存放在FileBin()數組中
Public Sub ReadExeBin(FileBin() As Byte, Pid As Long)
Dim Hand As Long
    Hand = OpenProcess(PROCESS_ALL_ACCESS, False, Pid)
        If Hand Then
            ReDim FileBin(61440) As Byte
            ReadProcessMemory Hand, &H971000, FileBin(0), 61440, 0&
        End If
    CloseHandle Hand
End Sub
'將要比較的特征碼轉化為Byte數組并存放在s2中
Private Sub StrBin(ByVal s1 As String, s2() As Byte)
Dim i As Long
    ReDim s2(Len(s1) / 2 - 1) As Byte
    For i = 0 To UBound(s2)
        s2(i) = CByte("&H" & Mid(s1, i * 2 + 1, 2))
    Next i
End Sub
'從s1中查找出特征碼,并返回該特征碼的首位置
Private Function StrStr(ByRef s1() As Byte, ByRef s2() As Byte) As Long
Dim c1 As Long, c2 As Long, i As Long, j As Long
    c1 = UBound(s1): c2 = UBound(s2)
    If c2 > c1 Then StrStr = -1: Exit Function
    For i = 0 To c1 - c2
        For j = 0 To c2 - 1
            If (s1(i + j) <> s2(j)) Then Exit For
            If (j = c2 - 1) Then StrStr = i: Exit Function
        Next j
    Next i
    StrStr = -1
End Function
'Location:位置
'此函數的功能:返回特征碼最后一個位置+j偏移的位置
Public Function Find_Location(ByRef FileBin() As Byte, s1 As String, Optional j As Long = 0) As Long
Dim i As Long, Str As String, s2() As Byte
        StrBin s1, s2
        i = StrStr(FileBin, s2)
        If i = -1 Then
            Find_Location = -1: Exit Function
        End If
        Find_Location = i + UBound(s2) + j
End Function
主站蜘蛛池模板: 欧美在线一区二区三区 | 天天干夜夜爱 | 国产999久久久 | 天堂中文字幕免费一区 | 中国毛片视频 | 久草视频免费看 | 精品国产视频 | 91白浆| 99国产免费| 国产成人免费在线视频 | 日韩不卡一区二区 | 免费观看av网站 | 日韩视频一区二区 | 亚洲高清免费 | 青娱乐福利视频 | 亚洲精品在线视频观看 | 手机在线看片1024 | 天堂资源 | h视频免费在线观看 | 亚洲黄色小视频 | 超碰成人网 | 欧美做爰xxxⅹ性欧美大片 | 欧美黑人一区二区三区 | 伊人久久在线 | 欧美国产日韩在线 | 免费毛片在线播放免费 | 欧美成人一区二区三区片免费 | 中文字幕手机在线观看 | 亚洲精品成人网 | 黄色成人在线 | 日韩一区二区三区在线播放 | 91午夜精品 | 在线观看免费毛片 | 亚洲精品国产精品国自产观看浪潮 | 1级黄色大片 | 中文字幕免费av | 欧美黑人一区二区三区 | 精品福利在线观看 | www.国产精品 | 欧美性猛交99久久久久99按摩 | 国产h视频 |
