查看: 3245|回復(fù): 0
AD轉(zhuǎn)換的C語(yǔ)言代碼
ID:110389 發(fā)表于 2016-3-23 16:16 | 顯示全部樓層 |閱讀模式
/*編寫(xiě)時(shí)間2016.2.9*/
#include <iom16v.h>
#include <macros.h>
#define uint unsigned int
#define uchar unsigned char
#define PC7_1 PORTC|=1<<7
#define PC7_0 PORTC&=~(1<<7)
#define PC6_1 PORTC|=1<<6
#define PC6_0 PORTC&=~(1<<6)
void m16_init()//單片機(jī)初始化
DDRA=0x00;
PORTA=0x00;
DDRB=0xff;
PORTB=0x00;
DDRD=0xff;
PORTD=0x00;
DDRC=0xC0;
PORTC=0x00;
void delay(uint ms)        //延時(shí)0.25ms
        uint i,j;
        for(i=0; i<ms; i++)
                for(j = 0; j < 250; j++);
//AD初始化
void adc7_init()
ADMUX = 0x07;   //外部參考電源,右對(duì)齊選,擇通道7
ADCSRA = 0x80;         //使能,轉(zhuǎn)換器2分頻IE=0
uint16_t ADC_Convert(void)              // 得到AD結(jié)果
    uint16_t temp1,temp2;
    temp1=(uint16_t)ADCL;
    temp2=(uint16_t)ADCH;
    temp2=(temp2<<8)+temp1;
    return(temp2);
uint ADC_Convert(void)
    uint i;
    uint ret;
    uint max_id, min_id, max_value, min_value;
    ADMUX  = (1<<MUX0);               // 外部參考電壓,5通道
    ADCSRA = (1<<ADEN);               // 使能ADC,單次轉(zhuǎn)換模式
    // 連續(xù)轉(zhuǎn)換8次
    for(i=0;i<8;i++)
        ADCSRA |= (1<<ADSC);          //開(kāi)始
        delay(100);
        while(ADIF==1)
        delay(100);
        ret = ADCL;
        ret |= (uint16_t)(ADCH<<8);
        g_aAdValue[i] = ret;            //單次
    ret = 0;
    for(i=1;i<8;i++)
        ret += g_aAdValue[i];
    // 找到最大和最小值索引
    ret /= 7;
    max_id = min_id = 1;
    max_value = min_value = 0;
    for(i=1;i<8;i++)
        if(g_aAdValue[i] > ret)
            if(g_aAdValue[i] - ret > max_value)
                max_value = g_aAdValue[i] - ret;
                max_id = i;
            if(ret - g_aAdValue[i] > min_value)
                min_value = ret - g_aAdValue[i];
                min_id = i;
    // 去掉第一個(gè)和最大最小值后的平均值
    ret = 0;
    for(i=1;i<8;i++)
        if((i!=min_id) && (i!=max_id))
    if(min_id != max_id)
        ret /= 5;
        ret /= 6;
    ADCSRA = 0x00;                  // 關(guān)閉ADC
    return ret;
void Process(uint16_t i,uint8_t *p)
    p[0]=i/1000;
    i=i%1000;
    p[1]=i/100;
    i=i%100;
    p[2]=i/10;
    i=i%10;
    p[3]=i;
int main(void)
    uint16_t ret;
    m16_init();
    adc7_init();//就是這里卡住了  不往下執(zhí)行了
        ret = ADC_Convert();
        //i = (i*5.0/1024)*1000;    // 此處浮點(diǎn)也,MCU開(kāi)支可不!
        ret *= 4.88;            // 輸出原值
        Process(ret,Data);
        Display(Data);
    return 0;
評(píng)分
查看全部評(píng)分
相關(guān)帖子
主站蜘蛛池模板: 色中色综合 | 成人网战 | 亚洲成人自拍 | 色综合视频 | 久久免费国产视频 | 欧美成人午夜 | 久久免费国产视频 | 一起操在线 | 亚洲欧美日韩一区二区三区四区 | 欧美成人一级片 | 咪咪色影院 | 亚洲欧美精品一区二区 | a在线视频 | 国产男女无遮挡猛进猛出 | 伊人精品在线 | 亚洲精品社区 | 这里只有精品视频在线观看 | 国产高清av | 免费毛片在线 | 91精品国产乱码久久久 | a级片在线观看 | 在线观看视频一区二区三区 | 日韩视频在线观看 | 欧美极品一区 | 亚洲精品www久久久久久广东 | 久久精品久久久 | 欧美爱爱网站 | 成人一级黄色片 | 91看片看淫黄大片 | 一级免费黄色片 | 狠狠的干 | 黄色三级免费 | 国产欧美成人 | 日韩欧美三级 | 91人人爽| 国产人成一区二区三区影院 | 国产一级免费观看 | 国产又爽又黄免费视频 | 永久免费看mv网站入口亚洲 | 福利片国产 | 久久国产精品视频 |
