查看: 4555|回復: 4
DIY光立方設計
ID:105332 發表于 2016-3-30 17:09 | 顯示全部樓層 |閱讀模式
效果網址:http://www.tudou.com/programs/view/Z0e4FqTXdP8/
程序:
  1. #include <REG52.H>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar display[8][8];//此處的disply為一個空數組用于存放64個數據(8*8*8光立方底座共64個引腳,分別接8片573的8個引腳)
  6. /*rank:A,1,2,3,4,I,心,U*/
  7. uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
  8. /*the "ideasoft"*/
  9. uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
  10. /*railway*/
  11. uchar code dat[128]={0x00,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  12. /*railway 2*/
  13. uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  14. /*railway 3*/
  15. uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
  16. /*3p char*/
  17. uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
  18. /*        //初始化
  19. 這是初始化程序。
  20. 這是寫在單片機設置定時器。所以程序可以更新光立方在固定時間使用中斷函數。
  21. //中斷函數控制LED亮滅的速度。*/
  22. void sinter()
  23. {
  24.          IE=0x82;
  25.          TCON=0x01;
  26.          TH0=0xF5;
  27.          TL0=0;
  28.          TR0=1;
  29. }
  30. //誤差 -0.026765046296us STC 1T 22.1184Mhz
  31. void delay5us(void)
  32. {
  33.     unsigned char a,b;
  34.     for(b=7;b>0;b--)
  35.         for(a=2;a>0;a--);
  36. }
  37. //12t的mcu 注釋這個延時即可
  38. void delay(uint i)
  39. {
  40.          while (i--){
  41.                  delay5us();}
  42. }
  43. /**********判斷數字的位***********/
  44. uchar judgebit(uchar num,uchar b)
  45. {
  46.          char n;
  47.          num=num&(1<<b);
  48.          if (num)
  49.          n=1;
  50.          else
  51.          n=0;
  52.          return n;
  53. }
  54. /*To figure out the round number*///計算出圓的數量
  55. uchar abs(uchar a)
  56. {
  57.          uchar b;
  58.          b=a/10;
  59.          a=a-b*10;
  60.          if (a>=5)
  61.          b++;
  62.          return b;
  63. }
  64. //找出的絕對值
  65. uchar abss(char a)
  66. {
  67.          if (a<0)
  68.          a=-a;
  69.          return a;
  70. }
  71. /*可以比較。和刪除后面的大。 */
  72. void max(uchar *a,uchar *b)
  73. {
  74.    uchar t;
  75.    if ((*a)>(*b))
  76.    {
  77.        t=(*a);
  78.        (*a)=(*b);
  79.        (*b)=t;
  80.    }
  81. }
  82. //函數是找出最大數量和返回它。
  83. uchar maxt(uchar a,uchar b,uchar c)
  84. {
  85.          if (a<b)
  86.          a=b;
  87.          if (a<c)
  88.          a=c;
  89.          return a;
  90. }
  91. /*le控制573 le為P2(位清零)*/
  92. void clear(char le)
  93. {
  94.          uchar i,j;
  95.          for (j=0;j<8;j++)
  96.          {
  97.                for (i=0;i<8;i++)
  98.                display[j][i]=le;
  99.          }
  100. }
  101. /*******此函數將display[][]數組中的值顯示出來*******/
  102. void trailler(uint speed)
  103. {
  104.          char i,j;
  105.          for(i=6;i>=-3;i--)
  106.          {
  107.                    if (i>=0)
  108.                    {
  109.                             for (j=0;j<8;j++)
  110.                             display[j][i]=display[j][i+1];
  111.                    }
  112.                    if (i<4)
  113.                    {
  114.                             for (j=0;j<8;j++)
  115.                             display[j][i+4]=0;
  116.                    }
  117.                    delay(speed);
  118.          }
  119. }
  120. //光立法燈的立體坐標以及控制其亮的LE端
  121. void point(uchar x,uchar y,uchar z,uchar le)
  122. {
  123.      uchar ch1,ch0;
  124.      ch1=1<<x;
  125.      ch0=~ch1;
  126.      if (le)
  127.      display[z][y]=display[z][y]|ch1;
  128.      else
  129.      display[z][y]=display[z][y]&ch0;
  130. }
  131. /**y表示第幾個,cha表示第幾個數組(字模原理每個數字或者圖形產生8個16進制數)***/
  132. void type(uchar cha,uchar y)
  133. {
  134.          uchar xx;
  135.          for (xx=0;xx<8;xx++)
  136.          {
  137.                  display[xx][y]=table_cha[cha][xx];//將取模好的數字或者圖形的字模16進制,放入顯示的數組。
  138.          }
  139. }
  140. /*第一個變量是中點的距離。第二個是層。第三是LED走的速度每兩個點之間的時間。*/
  141. void cirp(char cpp,uchar dir,uchar le)
  142. {
  143.          uchar a,b,c,cp;
  144.          if ((cpp<128)&(cpp>=0))
  145.          {
  146.                if (dir)
  147.                cp=127-cpp;
  148.                else
  149.                cp=cpp;
  150.                a=(dat[cp]>>5)&0x07;
  151.                b=(dat[cp]>>2)&0x07;
  152.                c=dat[cp]&0x03;
  153.                if (cpp>63)
  154.                c=7-c;
  155.                point (a,b,c,le);
  156.          }
  157. }
  158. void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
  159. {
  160.      char t,a,b,c,a1,b1,c1,i;
  161.      a1=x2-x1;
  162.      b1=y2-y1;
  163.      c1=z2-z1;
  164.      t=maxt(abss(a1),abss(b1),abss(c1));
  165.      a=x1*10;
  166.      b=y1*10;
  167.      c=z1*10;
  168.      a1=a1*10/t;
  169.      b1=b1*10/t;
  170.      c1=c1*10/t;
  171.      for (i=0;i<t;i++)
  172.      {
  173.                    point(abs(a),abs(b),abs(c),le);
  174.                    a+=a1;
  175.                    b+=b1;
  176.                    c+=c1;
  177.      }
  178.      point(x2,y2,z2,le);
  179. }
  180. void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  181. {
  182.          uchar i,j,t=0;
  183.          max(&x1,&x2);
  184.          max(&y1,&y2);
  185.          max(&z1,&z2);
  186.          for (i=x1;i<=x2;i++)
  187.                    t|=1<<i;
  188.          if (!le)
  189.                    t=~t;
  190.          if (fill)
  191.          {
  192.                    if (le)
  193.                    {
  194.                             for (i=z1;i<=z2;i++)
  195.                             {
  196.                                      for (j=y1;j<=y2;j++)
  197.                                                display[j][i]|=t;
  198.                             }
  199.                    }
  200.                    else
  201.                    {
  202.                             for (i=z1;i<=z2;i++)
  203.                             {
  204.                                      for (j=y1;j<=y2;j++)
  205.                                                display[j][i]&=t;
  206.                             }
  207.                    }
  208.          }
  209.          else
  210.          {
  211.                    if (le)
  212.                    {
  213.                             display[y1][z1]|=t;
  214.                             display[y2][z1]|=t;
  215.                             display[y1][z2]|=t;
  216.                             display[y2][z2]|=t;
  217.                    }
  218.                    else
  219.                    {
  220.                             display[y1][z1]&=t;
  221.                             display[y2][z1]&=t;
  222.                             display[y1][z2]&=t;
  223.                             display[y2][z2]&=t;
  224.                    }
  225.                    t=(0x01<<x1)|(0x01<<x2);
  226.                    if (!le)
  227.                             t=~t;
  228.                    if (le)
  229.                    {
  230.                             for (j=z1;j<=z2;j+=(z2-z1))
  231.                             {
  232.                                      for (i=y1;i<=y2;i++)
  233.                                                display[i][j]|=t;
  234.                             }
  235.                             for (j=y1;j<=y2;j+=(y2-y1))
  236.                             {
  237.                                      for (i=z1;i<=z2;i++)
  238.                                                display[j][i]|=t;
  239.                             }
  240.                    }
  241.                    else
  242.                    {
  243.                             for (j=z1;j<=z2;j+=(z2-z1))
  244.                             {
  245.                                      for (i=y1;i<=y2;i++)
  246.                                      {
  247.                                      display[i][j]&=t;
  248.                                      }
  249.                             }
  250.                             for (j=y1;j<=y2;j+=(y2-y1))
  251.                             {
  252.                                      for (i=z1;i<=z2;i++)
  253.                                      {
  254.                                      display[j][i]&=t;
  255.                                      }
  256.                             }
  257.                    }
  258.          }
  259. }
  260. void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  261. {
  262.      uchar i;
  263.      max(&z1,&z2);//比較z1 = 0和z2 = 7;
  264.      if(fill) //fill為標志
  265.      {
  266.            for(i=z1;i<=z2;i++)
  267.            {
  268.                line (x1,y1,i,x2,y2,i,le);
  269.            }
  270.      }
  271.      else
  272.      {
  273.                line (x1,y1,z1,x2,y2,z1,le);
  274.                line (x1,y1,z2,x2,y2,z2,le);
  275.                line (x2,y2,z1,x2,y2,z2,le);
  276.                line (x1,y1,z1,x1,y1,z2,le);
  277.      }
  278. }
  279. void poke(uchar n,uchar x,uchar y)
  280. {
  281.          uchar i;
  282.          for (i=0;i<8;i++)
  283.          {
  284.           point(x,y,i,judgebit(n,i));
  285.          }
  286. }
  287. /**********僅僅進行三面顯示,字母*******/
  288. void boxtola(char i,uchar n)
  289. {
  290.          if ((i>=0)&(i<8))
  291.          {
  292.                    poke(n,0,7-i);//在最邊緣的地方顯示第一面。
  293.          }
  294.          if ((i>=8)&(i<16))
  295.          {
  296.                    poke(n,i-8,0);//在最邊緣的地方顯示第二面。
  297.          }
  298.          if ((i>=16)&(i<24))
  299.          {
  300.                    poke(n,7,i-16);//在最邊緣的地方顯示第三面。
  301.          }
  302. /***此處也可以寫第四面也顯示,但是在下一個函數中a的值為3*8=24,僅僅3面*****/
  303. }
  304. /**按speed速度將table_id[]中的字母顯示出來**/
  305. void rolldisplay(uint speed)
  306. {
  307.          uchar j;
  308.          char i,a;
  309.                  //以下語句是僅顯示3面,如果顯示4面則i的值需要改變。
  310.          for (i=23;i>-40;i--)//i的值一共為64個
  311.          {
  312.                    for (j=0;j<40;j++)//j為數組table_id[]的容量。
  313.                    {
  314.                             a=i+j;
  315.                             if ((a>=0)&(a<24))
  316.                             boxtola(a,table_id[j]);//該函數是在指定面顯示出字母
  317.                    }
  318.                    delay(speed);
  319.          }
  320. }
  321. void roll_apeak_yz(uchar n,uint speed)
  322. {
  323.          uchar i;
  324.          switch(n)
  325.          {
  326.                    case 1:
  327.                             for (i=0;i<7;i++)
  328.                             {
  329.                                      display[i][7]=0;
  330.                                      display[7][6-i]=255;
  331.                                      delay(speed);
  332.                             };
  333.                             break;
  334.                    case 2:
  335.                             for (i=0;i<7;i++)
  336.                             {
  337.                                      display[7][7-i]=0;
  338.                                      display[6-i][0]=255;
  339.                                      delay(speed);
  340.                             };
  341.                             break;
  342.                    case 3:
  343.                             for (i=0;i<7;i++)
  344.                             {
  345.                                      display[7-i][0]=0;
  346.                                      display[0][i+1]=255;
  347.                                      delay(speed);
  348.                             };
  349.                             break;
  350.                    case 0:
  351.                             for (i=0;i<7;i++)
  352.                             {
  353.                                      display[0][i]=0;
  354.                                      display[i+1][7]=255;
  355.                                      delay(speed);
  356.                             };
  357.          }
  358. }
  359. void roll_apeak_xy(uchar n,uint speed)
  360. {
  361.          uchar i;
  362.          switch(n)
  363.          {
  364.                    case 1:
  365.                             for (i=0;i<7;i++)
  366.                             {
  367.                                      line(0,i,0,0,i,7,0);
  368.                                      line(i+1,7,0,i+1,7,7,1);
  369.                                      delay(speed);
  370.                             };
  371.                             break;
  372.                    case 2:
  373.                             for (i=0;i<7;i++)
  374.                             {
  375.                                      line(i,7,0,i,7,7,0);
  376.                                      line(7,6-i,0,7,6-i,7,1);
  377.                                      delay(speed);
  378.                             };
  379.                             break;
  380.                    case 3:
  381.                             for (i=0;i<7;i++)
  382.                             {
  383.                                      line(7,7-i,0,7,7-i,7,0);
  384.                                      line(6-i,0,0,6-i,0,7,1);
  385.                                      delay(speed);
  386.                             };
  387.                             break;
  388.                    case 0:
  389.                             for (i=0;i<7;i++)
  390.                             {
  391.                                      line(7-i,0,0,7-i,0,7,0);
  392.                                      line(0,i+1,0,0,i+1,7,1);
  393.                                      delay(speed);
  394.                             };
  395.          }
  396. }
  397. void roll_3_xy(uchar n,uint speed)
  398. {
  399.          uchar i;
  400.          switch(n)
  401.          {
  402.                    case 1:
  403.                             for (i=0;i<8;i++)
  404.                             {
  405.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  406.                                      delay(speed);
  407.                                      if (i<7)
  408.                                      box_apeak_xy (3,3,0,0,i,7,1,0);
  409.                             };
  410.                             break;
  411.                    case 2:
  412.                             for (i=0;i<8;i++)
  413.                             {
  414.                                       box_apeak_xy (7-i,0,0,i,7,7,1,1);
  415.                                      delay(speed);
  416.                                      if (i<7)
  417.                                      box_apeak_xy (3,4,0,i,7,7,1,0);
  418.                             };
  419.                             break;
  420.                    case 3:
  421.                             for (i=0;i<8;i++)
  422.                             {
  423.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  424.                                      delay(speed);
  425.                                      if (i<7)
  426.                                      box_apeak_xy (4,4,0,7,7-i,7,1,0);
  427.                             };
  428.                             break;
  429.                    case 0:
  430.                             for (i=0;i<8;i++)
  431.                             {
  432.                                      box_apeak_xy (7-i,0,0,i,7,7,1,1);
  433.                                      delay(speed);
  434.                                      if (i<7)
  435.                                      box_apeak_xy (4,3,0,7-i,0,7,1,0);
  436.                             };
  437.          }
  438. }
  439. void trans(uchar z,uint speed)
  440. {
  441.          uchar i,j;
  442.          for (j=0;j<8;j++)
  443.          {
  444.                    for (i=0;i<8;i++)
  445.                    {
  446.                             display[z][i]>>=1;
  447.                    }
  448.                    delay(speed);//亮的時間
  449.          }
  450. }
  451. void tranoutchar(uchar c,uint speed)
  452. {
  453.          uchar i,j,k,a,i2=0;
  454.          for (i=0;i<8;i++)
  455.          {
  456.                    if (i<7)
  457.                    box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
  458.                    box_apeak_xy (i2,0,0,i2,7,7,1,0);
  459.                    a=0;
  460.                    i2=i+1;
  461.                    for (j=0;j<=i;j++)
  462.                    {
  463.                             a=a|(1<<j);
  464.                    }
  465.                    for (k=0;k<8;k++)
  466.                    {
  467.                             display[k][3]|=table_cha[c][k]&a;
  468.                             display[k][4]|=table_cha[c][k]&a;
  469.                    }
  470.                    delay(speed);
  471.          }
  472. }
  473. /*64個數據依次放入數組disply中*/
  474. void transss()
  475. {
  476.          uchar i,j;
  477.          for (i=0;i<8;i++)
  478.          {
  479.                    for (j=0;j<8;j++)
  480.                    display[i][j]<<=1;
  481.          }
  482. }
  483. void flash_1()
  484. {
  485.          clear(0);
  486.          type(1,4);//定位1顯示到第四排
  487.          delay(60000);
  488.          type(2,4);//定位2顯示到第四排
  489.          delay(60000);
  490.          type(3,4);//定位3顯示到第四排
  491.          delay(60000);
  492.          type(4,4);//定位4顯示到第四排
  493.          delay(60000);
  494.
  495.          type(5,4);//定位大寫字母I顯示到第四排
  496.          delay(60000);
  497.          type(6,4);//定位“心”顯示到第四排
  498.          delay(60000);
  499.          type(7,4);//定位大寫字母U顯示到第四排
  500.          delay(60000);
  501.          delay(60000);
  502.          clear(0);
  503.          rolldisplay(30000);
  504.          type(0,7);
  505.          delay(60000);
  506.          trailler(6000);
  507.          delay(60000);
  508. }
  509. void flash_2()
  510. {
  511.          uchar i;
  512. /*         for (i=129;i>0;i--)//此處為2個為1組,一起閃。走一圈
  513.          {
  514.                    cirp(i-2,0,1);
  515.                    delay(8000);
  516.                    cirp(i-1,0,0);
  517.          }
  518.          delay(8000);
  519.          for (i=0;i<136;i++)//此處為8個為一組亮136 = 128 + 8;走一圈。
  520.          {
  521.                    cirp(i,1,1);
  522.                    delay(8000);
  523.                    cirp(i-8,1,0);
  524.
  525.          }
  526.          delay(8000); */
  527.          for (i=129;i>0;i--)//此處為走一圈亮一圈
  528.          {
  529.                    cirp(i-2,0,1);
  530.                    delay(8000);
  531.          }
  532.          delay(8000);
  533.         for (i=0;i<128;i++)//此處為滅一圈
  534.         {
  535.                    cirp(i-8,1,0);
  536.                    delay(8000);
  537.          }
  538.          delay(60000);
  539. }
  540. void flash_3()
  541. {
  542.      char i;
  543.      for(i=0;i<8;i++)
  544.      {
  545.            box_apeak_xy(0,i,0,7,i,7,1,1);//0層-6層以delay(20000)的依次亮。
  546.            delay(20000);
  547.            if(i<7)
  548.            box_apeak_xy(0,i,0,7,i,7,1,0);//到第7層時就到下一個for語句。
  549.      }
  550.      for (i=7;i>=0;i--)
  551.      {
  552.            box_apeak_xy(0,i,0,7,i,7,1,1);//7層-1層以delay(20000)的依次亮。
  553.            delay(20000);
  554.            if (i>0)
  555.            box_apeak_xy(0,i,0,7,i,7,1,0);//到第0層時就到下一個for語句。
  556.      }
  557.      for (i=0;i<8;i++)//傾斜的亮(每層只有一排亮,依次錯開)
  558.      {
  559.            box_apeak_xy(0,i,0,7,i,7,1,1);
  560.            delay(20000);
  561.            if (i<7)
  562.            box_apeak_xy(0,i,0,7,i,7,1,0);
  563.      }
  564. }
  565. void flash_4()//向內凹陷和向外凹陷的顯示
  566. {
  567.          char i,j,an[8];
  568.          for(j=7;j<15;j++)
  569.               an[j-7]=j;//裝入0-7值
  570.          for(i=0;i<=16;i++)
  571.          {
  572.                for(j=0;j<8;j++)
  573.                {
  574.                     if((an[j]<8)&(an[j]>=0))
  575.                     line(0,an[j],j,7,an[j],j,1);
  576.                }
  577.                for(j=0;j<8;j++)
  578.                {
  579.                     if(((an[j]+1)<8)&(an[j]>=0))
  580.                     line(0,an[j]+1,j,7,an[j]+1,j,0);
  581.                }
  582.                for (j=0;j<8;j++)
  583.                {
  584.                     if (an[j]>0)
  585.                     an[j]--;
  586.                }
  587.             delay(15000);
  588.          }
  589.          for(j=0;j<8;j++)
  590.              an[j]=1-j;
  591.          for(i=0;i<=16;i++)
  592.          {
  593.                for(j=0;j<8;j++)
  594.                {
  595.                     if((an[j]<8)&(an[j]>=0))
  596.                     line(0,an[j],j,7,an[j],j,1);
  597.                }
  598.                for(j=0;j<8;j++)
  599.                {
  600.                     if(((an[j]-1)<7)&(an[j]>0))
  601.                     line(0,an[j]-1,j,7,an[j]-1,j,0);
  602.                }
  603.                for(j=0;j<8;j++)
  604.                {
  605.                     if(an[j]<7)
  606.                     an[j]++;
  607.                }
  608.              delay(15000);
  609.          }
  610. }
  611. void flash_5()
  612. {
  613.          uint a=15000;//a=delay
  614.          char i=8,j,an[4];
  615.          //1 1-4為4個面循環的轉。
  616.          for (j=7;j<11;j++)
  617.                    an[j-7]=j;
  618.          while(i--)
  619.          {
  620.                    for (j=0;j<4;j++)
  621.                    {
  622.                             if (an[j]<8)
  623.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  624.                             if (an[j]<7)
  625.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  626.                    }
  627.                    for (j=0;j<4;j++)
  628.                    {
  629.                             if (an[j]>3)
  630.                             an[j]--;
  631.                    }
  632.                    delay(a);
  633.          }
  634.          //2
  635.          i=3;
  636.          for (j=0;j<4;j++)
  637.          an[j]=5-j;
  638.          while(i--)
  639.          {
  640.                    for (j=1;j<4;j++)
  641.                    {
  642.                             if (an[j]<4)
  643.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  644.                             if (an[j]<3)
  645.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  646.                    }
  647.                    for (j=0;j<4;j++)
  648.                    {
  649.                             if (an[j]>0)
  650.                             an[j]--;
  651.                    }
  652.                    delay(a);
  653.          }
  654.          //3
  655.          i=3;
  656.          for (j=1;j<4;j++)
  657.          an[j]=4-j;
  658.          while(i--)
  659.          {
  660.                    for (j=1;j<4;j++)
  661.                    {
  662.                             if (an[j]>=0)
  663.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  664.                             if (an[j]>0)
  665.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  666.                    }
  667.                    for (j=1;j<4;j++)
  668.                    {
  669.                             if (an[j]<3)
  670.                             an[j]++;
  671.                    }
  672.                    delay(a);
  673.          }
  674.          //4
  675.          i=3;
  676.          for (j=0;j<4;j++)
  677.          an[j]=j+1;
  678.          while(i--)
  679.          {
  680.                    for (j=1;j<4;j++)
  681.                    {
  682.                             if (an[j]>3)
  683.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  684.                             if (an[j]>3)
  685.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  686.                    }
  687.                    for (j=0;j<4;j++)
  688.                             an[j]++;
  689.                    delay(a);
  690.          }
  691.          //5
  692.          i=3;
  693.          for (j=3;j<6;j++)
  694.                    an[j-2]=j;
  695.          while(i--)
  696.          {
  697.                    for (j=1;j<4;j++)
  698.                    {
  699.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  700.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  701.                    }
  702.                    for (j=0;j<4;j++)
  703.                    {
  704.                             if (an[j]>3)
  705.                             an[j]--;
  706.                    }
  707.                    delay(a);
  708.          }
  709.          //6
  710.          i=3;
  711.          for (j=0;j<4;j++)
  712.          an[j]=5-j;
  713.          while(i--)
  714.          {
  715.                    for (j=1;j<4;j++)
  716.                    {
  717.                             if (an[j]<4)
  718.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  719.                             if (an[j]<3)
  720.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  721.                    }
  722.                    for (j=0;j<4;j++)
  723.                    {
  724.                             if (an[j]>0)
  725.                             an[j]--;
  726.                    }
  727.                    delay(a);
  728.          }
  729.          //7
  730.          i=3;
  731.          for (j=0;j<4;j++)
  732.          an[j]=3-j;
  733.          an[0]=2;
  734.          while(i--)
  735.          {
  736.                    for (j=0;j<3;j++)
  737.                    {
  738.                             if (an[j]>=0)
  739.                                      box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  740.                             if (an[j]>=0)
  741.                                      box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  742.                    }
  743.                    for (j=0;j<4;j++)
  744.                    {
  745.                             if (j<5-i)
  746.                             an[j]--;
  747.                    }
  748.                    delay(a);
  749.          }
  750.          //8
  751.          i=10;
  752.          for (j=0;j<4;j++)
  753.                    an[j]=j-2;
  754.          while(i--)
  755.          {
  756.                    for (j=0;j<4;j++)
  757.                    {
  758.                             if (an[j]>=0)
  759.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  760.                             if (an[j]>=0)
  761.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  762.                    }
  763.                    for (j=0;j<4;j++)
  764.                    {
  765.                             if (an[j]<7)
  766.                             an[j]++;
  767.                    }
  768.                    delay(a);
  769.          }
  770. }
  771. /*void flash_6()
  772. {
  773.       uchar i,j,k,z;
  774.       roll_apeak_yz(1,10000);
  775.       roll_apeak_yz(2,10000);
  776.       roll_apeak_yz(3,10000);
  777.       roll_apeak_yz(0,10000);
  778.       roll_apeak_yz(1,10000);
  779.       roll_apeak_yz(2,10000);
  780.       roll_apeak_yz(3,10000);
  781.       for (i=0;i<3;i++)
  782.                {
  783.                          for (j=0;j<8;j++)
  784.                          {
  785.                                   for (k=0;k<8;k++)
  786.                                   {
  787.                                            if ((table_3p[i][j]>>k)&1)
  788.                                            {
  789.                                                      for (z=1;z<8;z++)
  790.                                                               {
  791.        point (j,7-k,z,1);
  792.        if (z-1)
  793.        point (j,7-k,z-1,0);
  794.        delay(5000);
  795.                                                               }
  796.                                            }
  797.                                   }
  798.                          }
  799.                          trans(7,15000);
  800.                }
  801. }
  802. void flash_7()
  803. {
  804.       uchar i;
  805.       uint a=3000;
  806.       roll_apeak_yz(0,10000);
  807.       roll_apeak_yz(1,10000);
  808.       roll_apeak_yz(2,10000);
  809.       roll_apeak_yz(3,10000);
  810.       roll_apeak_yz(0,10000);
  811.       roll_apeak_yz(1,10000);
  812.       roll_apeak_yz(2,10000);
  813.       roll_apeak_yz(3,10000);
  814.       roll_apeak_yz(0,10000);
  815.       roll_apeak_yz(1,10000);
  816.       roll_apeak_yz(2,10000);
  817.       roll_apeak_xy(0,10000);
  818.       roll_apeak_xy(1,10000);
  819.       roll_apeak_xy(2,10000);
  820.       roll_apeak_xy(3,10000);
  821.       roll_apeak_xy(0,10000);
  822.       roll_apeak_xy(1,10000);
  823.       roll_apeak_xy(2,10000);
  824.       roll_apeak_xy(3,10000);
  825.       for (i=0;i<8;i++)
  826.       {
  827.                box_apeak_xy (0,i,0,7-i,i,7,1,1);
  828.                delay(a);
  829.       }
  830.       delay(30000);
  831.       roll_3_xy(0,a);
  832.       delay(30000);
  833.       roll_3_xy(1,a);
  834.       delay(30000);
  835.       roll_3_xy(2,a);
  836.       delay(30000);
  837.       roll_3_xy(3,a);
  838.       delay(30000);
  839.       roll_3_xy(0,a);
  840.       delay(30000);
  841.       roll_3_xy(1,a);
  842.       delay(30000);
  843.       roll_3_xy(2,a);
  844.       delay(30000);
  845.       roll_3_xy(3,a);
  846.       for (i=7;i>0;i--)
  847.       {
  848.                box_apeak_xy(i,0,0,i,7,7,1,0);
  849.                delay(a);
  850.       }
  851. }*/
  852. void flash_8()
  853. {
  854.       uchar i;
  855.       for (i=5;i<8;i++)
  856.       {
  857.                tranoutchar(i,10000);
  858.                delay(60000);
  859.                delay(60000);
  860.       }
  861. }
  862. void flash_9()
  863. {
  864.       char i;
  865.       uchar j,an[8],x,y,t,x1,y1;
  866.       for (i=0;i<8;i++)
  867.       {
  868.                box_apeak_xy (i,0,0,i,7,7,1,1);
  869.                if (i)
  870.                box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
  871.                delay(10000);
  872.       }
  873.       roll_apeak_xy(3,10000);
  874.       roll_apeak_xy(0,10000);
  875.       roll_apeak_xy(1,10000);
  876.       for (i=0;i<7;i++)
  877.       {
  878.                line(6-i,6-i,0,6-i,6-i,7,1);
  879.                line(i,7,0,i,7,7,0);
  880.                delay(10000);
  881.       }
  882.       for (i=0;i<8;i++)
  883.                an[i]=14;
  884.       for (i=0;i<85;i++)
  885.       {
  886.                clear(0);
  887.                for (j=0;j<8;j++)
  888.                {
  889.                          t=an[j]%28;
  890.                          x=dat2[t]>>5;
  891.                          y=(dat2[t]>>2)&0x07;
  892.                          t=(an[j]-14)%28;
  893.                          x1=dat2[t]>>5;
  894.                          y1=(dat2[t]>>2)&0x07;
  895.                          line(x,y,j,x1,y1,j,1);
  896.                }
  897.                for (j=0;j<8;j++)
  898.                {
  899.                if ((i>j)&(j>i-71))
  900.                an[j]++;
  901.                }
  902.                delay(5000);
  903.       }
  904.       for (i=0;i<85;i++)
  905.       {
  906.                clear(0);
  907.                for (j=0;j<8;j++)
  908.                {
  909.                          t=an[j]%28;
  910.                          x=dat2[t]>>5;
  911.                          y=(dat2[t]>>2)&0x07;
  912.                          t=(an[j]-14)%28;
  913.                          x1=dat2[t]>>5;
  914.                          y1=(dat2[t]>>2)&0x07;
  915.                          line(x,y,j,x1,y1,j,1);
  916.                }
  917.                for (j=0;j<8;j++)
  918.                {
  919.                if ((i>j)&(j>i-71))
  920.                an[j]--;
  921.                }
  922.                delay(5000);
  923.       }
  924.       for (i=0;i<29;i++)
  925.       {
  926.                clear(0);
  927.                t=an[0]%28;
  928.                x=dat2[t]>>5;
  929.                y=(dat2[t]>>2)&0x07;
  930.                t=(an[0]-14)%28;
  931.                x1=dat2[t]>>5;
  932.                y1=(dat2[t]>>2)&0x07;
  933.                box_apeak_xy(x,y,0,x1,y1,7,0,1);
  934.                box_apeak_xy(x,y,1,x1,y1,6,0,1);
  935.                an[0]++;
  936.                delay(5000);
  937.       }
  938.       for (i=0;i<16;i++)
  939.       {
  940.                clear(0);
  941.                t=an[0]%28;
  942.                x=dat2[t]>>5;
  943.                y=(dat2[t]>>2)&0x07;
  944.                t=(an[0]-14)%28;
  945.                x1=dat2[t]>>5;
  946.                y1=(dat2[t]>>2)&0x07;
  947.                box_apeak_xy(x,y,0,x1,y1,7,1,1);
  948.                an[0]--;
  949.                delay(5000);
  950.       }
  951.       for (i=0;i<8;i++)
  952.       {
  953.                line(i,i,0,0,0,i,0);
  954.                delay(5000);
  955.       }
  956.       for (i=1;i<7;i++)
  957.       {
  958.                line(i,i,7,7,7,i,0);
  959.                delay(5000);
  960.       }
  961.       for (i=1;i<8;i++)
  962.       {
  963.                clear(0);
  964.                box(7,7,7,7-i,7-i,7-i,0,1);
  965.                delay(10000);
  966.       }
  967.       for (i=1;i<7;i++)
  968.       {
  969.                clear(0);
  970.                box(0,0,0,7-i,7-i,7-i,0,1);
  971.                delay(10000);
  972.       }
  973.       for (i=1;i<8;i++)
  974.       {
  975.                clear(0);
  976.                box(0,0,0,i,i,i,0,1);
  977.                delay(10000);
  978.       }
  979.       for (i=1;i<7;i++)
  980.       {
  981.                clear(0);
  982.                box(7,0,0,i,7-i,7-i,0,1);
  983.                delay(10000);
  984.       }
  985.       for (i=1;i<8;i++)
  986.       {
  987.                box(7,0,0,7-i,i,i,1,1);
  988.                delay(10000);
  989.       }
  990.       for (i=1;i<7;i++)
  991.       {
  992.                clear(0);
  993.                box(0,7,7,7-i,i,i,1,1);
  994.                delay(10000);
  995.       }
  996. }
  997. void flash_10()
  998. {
  999.       uchar i,j,an[4],x,y,t;
  1000.       for (i=1;i<7;i++)
  1001.       {
  1002.
  1003.                clear(0);
  1004.                box(0,6,6,1,7,7,1,1);
  1005.                box(i,6,6-i,i+1,7,7-i,1,1);
  1006.                box(i,6,6,i+1,7,7,1,1);
  1007.                box(0,6,6-i,1,7,7-i,1,1);
  1008.                box(0,6-i,6,1,7-i,7,1,1);
  1009.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  1010.                box(i,6-i,6,i+1,7-i,7,1,1);
  1011.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  1012.                delay(30000);
  1013.       }
  1014.       for (i=0;i<4;i++)
  1015.       {
  1016.                an[i]=6*i;
  1017.       }
  1018.       for (i=0;i<35;i++)
  1019.       {
  1020.                clear(0);
  1021.                for(j=0;j<4;j++)
  1022.                {
  1023.                          t=an[j]%24;
  1024.                          x=dat3[t]>>4;
  1025.                          y=dat3[t]&0x0f;
  1026.                          box(x,y,0,x+1,y+1,1,1,1);
  1027.                          box(x,y,6,x+1,y+1,7,1,1);
  1028.                }
  1029.                for (j=0;j<4;j++)
  1030.                an[j]++;
  1031.                delay(10000);
  1032.       }
  1033.       for (i=0;i<35;i++)
  1034.       {
  1035.                clear(0);
  1036.                for(j=0;j<4;j++)
  1037.                {
  1038.                          t=an[j]%24;
  1039.                          x=dat3[t]>>4;
  1040.                          y=dat3[t]&0x0f;
  1041.                          box(x,y,0,x+1,y+1,1,1,1);
  1042.                          box(x,y,6,x+1,y+1,7,1,1);
  1043.                }
  1044.                for (j=0;j<4;j++)
  1045.                an[j]--;
  1046.                delay(10000);
  1047.       }
  1048.       for (i=0;i<35;i++)
  1049.       {
  1050.                clear(0);
  1051.                for(j=0;j<4;j++)
  1052.                {
  1053.                          t=an[j]%24;
  1054.                          x=dat3[t]>>4;
  1055.                          y=dat3[t]&0x0f;
  1056.                          box(x,0,y,x+1,1,y+1,1,1);
  1057.                          box(x,6,y,x+1,7,y+1,1,1);
  1058.                }
  1059.                for (j=0;j<4;j++)
  1060.                an[j]++;
  1061.                delay(10000);
  1062.       }
  1063.       for (i=0;i<36;i++)
  1064.       {
  1065.                clear(0);
  1066.                for(j=0;j<4;j++)
  1067.                {
  1068.                          t=an[j]%24;
  1069.                          x=dat3[t]>>4;
  1070.                          y=dat3[t]&0x0f;
  1071.                          box(x,0,y,x+1,1,y+1,1,1);
  1072.                          box(x,6,y,x+1,7,y+1,1,1);
  1073.                }
  1074.                for (j=0;j<4;j++)
  1075.                an[j]--;
  1076.                delay(10000);
  1077.       }
  1078.       for (i=6;i>0;i--)
  1079.       {
  1080.
  1081.                clear(0);
  1082.                box(0,6,6,1,7,7,1,1);
  1083.                box(i,6,6-i,i+1,7,7-i,1,1);
  1084.                box(i,6,6,i+1,7,7,1,1);
  1085.                box(0,6,6-i,1,7,7-i,1,1);
  1086.                box(0,6-i,6,1,7-i,7,1,1);
  1087.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  1088.                box(i,6-i,6,i+1,7-i,7,1,1);
  1089.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  1090.                delay(30000);
  1091.       }
  1092. }
  1093. void flash_11()
  1094. {
  1095.       uchar i,j,t,x,y;
  1096.       uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
  1097.       for (j=0;j<5;j++)
  1098.       {
  1099.                for (i=0;i<13;i++)
  1100.                {
  1101.                          if (daa[i]>>4)
  1102.                          {
  1103.                                   t=daa[i]&0x0f;
  1104.                                   line (0,0,t+1,0,7,t+1,1);
  1105.                          }
  1106.                          else
  1107.                                   t=daa[i];
  1108.                          line (0,0,t,0,7,t,1);
  1109.                          transss();
  1110.                          delay(10000);
  1111.                }
  1112.       }
  1113.       for (j=1;j<8;j++)
  1114.       {
  1115.                if (j>3)
  1116.                          t=4;
  1117.                else
  1118.                          t=j;
  1119.                for (i=0;i<24;i+=j)
  1120.                {
  1121.                          x=dat3[i]>>4;
  1122.                          y=dat3[i]&0x0f;
  1123.                          box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
  1124.                          transss();
  1125.                          delay(10000);
  1126.                }
  1127.       }
  1128.       for (j=1;j<8;j++)
  1129.       {
  1130.                if (j>3)
  1131.                          t=4;
  1132.                else
  1133.                          t=j;
  1134.                for (i=0;i<24;i+=j)
  1135.                {
  1136.                          x=dat3[i]>>4;
  1137.                          y=dat3[i]&0x0f;
  1138.                          point (0,x,y,1);
  1139.                          transss();
  1140.                          delay(10000);
  1141.                }
  1142.       }
  1143. }
  1144. void main()
  1145. {
  1146.
  1147.          sinter();
  1148.                  while(1){
  1149.         // clear(0);
  1150.          /*play list*/
  1151.          flash_1();
  1152.          clear(0);
  1153.          flash_2();
  1154.          flash_3();
  1155.          flash_4();
  1156.          flash_4();
  1157.          flash_5();
  1158.       flash_5();
  1159. //      flash_6();
  1160. //     flash_7();
  1161.       flash_8();
  1162.       flash_9();
  1163.       flash_10();
  1164.       clear (0);
  1165.       flash_11();
  1166.       flash_9();
  1167.       flash_5();
  1168. //      flash_7();
  1169.       flash_5();
  1170. //      flash_6();
  1171.       flash_8();
  1172.       flash_9();
  1173.       flash_10();
  1174.          }
  1175. }
  1176. //P0;   //573 in
  1177. //P1;  //uln2803
  1178. //P2;  //573 LE
  1179. void print() interrupt 1
  1180. {
  1181.          uchar i;
  1182.          static uchar layer=0;
  1183.          P1=0;
  1184.          for (i=0;i<8;i++)
  1185.          {
  1186.                    P2=1<<i;
  1187.                    delay(3);
  1188.                    P0=display[layer][i];
  1189.                    delay(3);
  1190.          }
  1191.          P1=1<<layer;
  1192.          if (layer<7)
  1193.                    layer++;
  1194.          else
  1195.                    layer=0;
  1196.          TH0=0xF5;
  1197.          TL0=0;
  1198. }
光立方程序.zip
85.65 KB, 下載次數: 53, 下載積分: 黑幣 -5
DIY光立方設計
ID:137554 發表于 2016-10-7 13:21 | 顯示全部樓層
牛人  這程序不錯 收下了
ID:173689 發表于 2017-3-20 22:07 來自觸屏版 | 顯示全部樓層
真真厲害我也想做一個。
ID:193719 發表于 2017-5-17 20:59 | 顯示全部樓層
這個用89C52就能做嗎?
ID:294624 發表于 2018-4-26 19:35 | 顯示全部樓層
心累  B 下載了  唉
主站蜘蛛池模板: 九九热精品 | 国产亚洲一区二区三区 | 大尺度做爰床戏呻吟舒畅 | 亚洲经典一区二区 | 免费网站www | 日韩视频免费大全中文字幕 | 97青青草| 久久观看| 午夜激情网 | 五月天精品 | 久久精品视频一区 | 超碰在线观看免费版 | 中文字幕一级片 | 在线观看的av | 久久久久久精 | 九九热这里只有 | 97人人草| 日韩中文字幕一区二区三区 | 欧美日日日 | 福利网站在线观看 | www.色偷偷| 久久98| 1级黄色大片| 中文在线字幕免费观 | 成人一级片 | 在线一级片 | 国产成人免费视频 | 波多野结衣之双调教hd | 日韩一级av毛片 | 色天堂视频 | 久草网在线| 天天操夜夜操狠狠操 | 国产午夜视频 | 久久香蕉国产 | 久久日韩精品 | 看免费毛片 | 一区二区三区成人 | 亚洲成人天堂 | 日韩在线视频一区 | 午夜在线观看视频 | 欧美日韩在线播放 |
