查看: 4523|回復: 1
單片機溫控系統程序代碼
ID:115502 發表于 2016-4-20 18:18 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit key0=P1^0;
sbit key1=P1^2;
sbit key2=P1^4;
sbit key3=P1^6;
sbit led0=P3^0;
sbit led1=P3^3;
sbit beep=P3^7;
sbit rs=P2^0;
sbit rw=P2^1;
sbit en=P2^2;
sbit DQ=P2^3;
bit DS_OK=1; //溫度傳感器正常標志
bit HI_alarm=0;LO_alarm=0;        //溫度正常標志,超出上下限時,=1
char alarm_HL[]={10,-10};
uint time=0;
uchar temp_num[]={0x00,0x00};  //用于存儲高字節與低字節
uchar display_digit[]={0,0,0,0};//存儲顯示溫度字符
uchar current_count=0;   //存儲整數(高字節低三位與低字節高四位)
uchar alarm_HI_LO[]={"HI:     LO:      "};
uchar temperature_display[]={"TEMP:           "};
uchar code tab0[]={"welcome to here"};
uchar code tab1[]={"----sky"};
uchar code temperature_title[]={"THE TEMPPERATURE"};
uchar code alarm_title[]={"ALARM TEMP HI LO"};
uchar code df_tab[]={0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};
void delay(uint z)
        uint x;
        while(z--)
                for(x=120;x>0;x--);
void delay_4us()
{_nop_();_nop_();_nop_();_nop_();}
void delay_us(uint a)
        while(a--);
uchar LCD_check_busy()
        uchar state;
        rs=0;
        rw=1;
        delay_4us();
        en=1;
        state=P0;
        delay_4us();
        en=0;
        delay_4us();
        return state;
void LCD_write_cmd(uchar cmd)
    while((LCD_check_busy()&0x80)==0x80);
        rs=0;
        rw=0;
        delay_4us();
        en=1;
        P0=cmd;
        delay_4us();
        en=0;
        delay_4us();
void LCD_write_data(uchar dat)
        rs=1;
        rw=0;
        delay_4us();
        en=1;
        P0=dat;
        delay_4us();
        en=0;
        delay_4us();
void LCD_display(uchar *s)
        uchar i;
        for(i=0;i<16;i++)
                LCD_write_data(s[i]);
void LCD_init()
        LCD_write_cmd(0x38);
        LCD_write_cmd(0x0c);
        LCD_write_cmd(0x06);
        LCD_write_cmd(0x01);
//LCD*************************************************
uchar DS_init()   //檢查溫度傳感器
        uchar state;
        DQ=1;
        delay_us(8); //精確定時
        DQ=0;
        delay_us(80);
        DQ=1;
        delay_us(8);
        state=DQ;
        delay(100);
        return state;
void DS_write_byte(uchar dat)
        uchar i;
        for(i=0;i<8;i++)
                if((dat&0x01)==0) //寫0
                        DQ=0;
                        delay_us(5);
                        DQ=1;
                else                                 //寫1
                        DQ=0;
                        delay_us(1);
                        DQ=1;
                        delay_us(4);
                dat>>=1;
uchar DS_read_byte() //讀一個字節
        uchar i,dat=0;
        for(i=0;i<8;i++)
                DQ=0;
                dat>>=1;
                DQ=1;
                if(DQ==1)
                        dat|=0x80;
                        dat|=0x00;
                delay_us(30);
                DQ=1;
        return dat;
void DS_read_temperature()
        uchar a=15;
        alarm_HL[0]=a%10;
        alarm_HL[1]=-(a/10);
        if(DS_init()==1)         //檢查初始化溫度傳感器
                DS_OK=0;
                DS_init();
                DS_write_byte(0xcc); //跳過序列號
                DS_write_byte(0x44); //啟動溫度轉換
                DS_init();                   //重新檢查溫度傳感器
                DS_write_byte(0xcc);//
                DS_write_byte(0xbe);//啟動讀取溫度
/****先讀低8位,再讀高8位,不可調換************/
                temp_num[1]=DS_read_byte();
                temp_num[0]=DS_read_byte();
/***先裝載TH,再裝載TL******************************/
                alarm_HL[0]=DS_read_byte();         //讀警報數據
                alarm_HL[1]=DS_read_byte();
                DS_OK=1;                         //正常工作
/*void key_set_HL()
        if(key2==0)
                alarm_HL[0]++;
                if(alarm_HL[0]==40)
                        alarm_HL[0]=20;
        if(key3==0)
                alarm_HL[1]--;
                if(alarm_HL[1]==-30)
                        alarm_HL[1]=-10;
void DS_set_alarm()
        DS_init();
        //key_set_HL();
        DS_write_byte(0x4e);
/***        //寫數據到RAM,先寫TH,再寫TL,不可調換*/
        DS_write_byte(alarm_HL[0]);
        DS_write_byte(alarm_HL[1]);
        DS_write_byte(0x7f); //12位高精確度
        DS_init();
        DS_write_byte(0x48);//復制數據到存儲器
void LCD_display_temperature()
        char sign_current_count;        //有符號型變量
        uchar flag=0;//負數標識
        /***高5位為1(0XF8)則為負數,為負數時取反加一****/
        if((temp_num[0]&0xf8)==0xf8)
                temp_num[0]=~temp_num[0];  //負數取反
                temp_num[1]=~temp_num[1]+1;
                if(temp_num[1]==0x00)
                        temp_num[0]++;
                flag=1;//負數標識
        /****溫度小數部分*********/
        display_digit[3]=df_tab[temp_num[1]&0x0f];
    /*溫度整數部分(高字節低4位與低字節高4位,無符號)***/
        current_count=((temp_num[1]&0xf0)>>4)|((temp_num[0]&0x07)<<4);
         /*有符號的當前溫度值,注意定義是char           */
/***判斷sign_current_count是否等于current_count*****
***若相等則選擇-current_count,否則選擇current_count*****/
        sign_current_count=flag?
                -current_count:current_count;
        /*高低溫報警標志(與char類型alarm_HL比較,可以區分正負號比較)           */
/**先比較大小,再選擇1或者0;再賦值***********可以用IF語句代替******/
        HI_alarm=sign_current_count>=alarm_HL[0]?
                1:0;
        LO_alarm=sign_current_count<=alarm_HL[1]?
                1:0;
/*        //分解整數部分                  */
        display_digit[0]=current_count/100;
        display_digit[1]=current_count%100/10;
        display_digit[2]=current_count%10;
   /***刷新LCD顯示緩沖***/
    temperature_display[11]=display_digit[3]+'0';
        temperature_display[10]='.';
        temperature_display[9]=display_digit[2]+'0';
        temperature_display[8]=display_digit[1]+'0';
        temperature_display[7]=display_digit[0]+'0';
        /*百位為0時不顯示*/
        if(display_digit[0]==0)
                temperature_display[7]=' ';
                /*百位為0,且十位為0時不顯示          */
        if((display_digit[0]==0)&(display_digit[1]==0))
                temperature_display[8]=' ';
   // 負號顯示在恰當位置
        if(flag)
                if(temperature_display[8]==' ')
                        temperature_display[8]='-';
                        if(temperature_display[7]==' ')
                                temperature_display[7]='-';
                                temperature_display[6]='-';
        LCD_write_cmd(0x80+0x00);
        LCD_display(temperature_title);
        LCD_write_cmd(0x80+0x40);
        LCD_display(temperature_display);
        LCD_write_cmd(0x80+0x4e);
        LCD_write_data('C');
/*****顯示報警溫度************************************/
void LCD_display_alarm_temperature()
/****顯示高溫*****************************************************/
        uchar i;
        uchar flag=0;//負號標志
        if(alarm_HL[0]<0)
                alarm_HL[0]=~alarm_HL[0]+1;
                flag=1;
        /***分解高溫****************************************/
        alarm_HI_LO[4]=alarm_HL[0]/100+'0';
        alarm_HI_LO[5]=alarm_HL[0]%100/10+'0';
        alarm_HI_LO[6]=alarm_HL[0]%10+'0';
  /****屏蔽高位不顯示******************************************/
        if(alarm_HI_LO[4]=='0')
                alarm_HI_LO[4]=' ';
        if(alarm_HI_LO[4]==' '&&alarm_HI_LO[5]=='0')
                alarm_HI_LO[5]=' ';
  /****負號放在適當的位置**************************************/
        if(flag)
                if(alarm_HI_LO[4]==' ')
                        alarm_HI_LO[4]='-';
                        if(alarm_HI_LO[5]==' ')
                                alarm_HI_LO[5]='-';
                                alarm_HI_LO[3]='-';
/**********低溫報警值****************************************/
         flag=0;
         if(alarm_HL[1]<0)
                alarm_HL[1]=~alarm_HL[1]+1;
                flag=1;
/****分解低溫*********************************************/
        alarm_HI_LO[12]=alarm_HL[1]/100+'0';
        alarm_HI_LO[13]=alarm_HL[1]%100/10+'0';
        alarm_HI_LO[14]=alarm_HL[1]%10+'0';
/*********屏蔽高位不顯示************************************/
        if(alarm_HI_LO[12]=='0')
                alarm_HI_LO[12]=' ';
        if(alarm_HI_LO[12]==' '&&alarm_HI_LO[13]=='0')
                alarm_HI_LO[13]=' ';
/********負號顯示在適當位置************************************/
        if(flag)
                if(alarm_HI_LO[12]==' ')
                        alarm_HI_LO[12]='-';
                        if(alarm_HI_LO[13]==' ')
                                alarm_HI_LO[13]='-';
                                alarm_HI_LO[11]='-';
        /****顯示高低溫報警溫度************************************/
        for(i=0;i<16;i++)
                LCD_write_data(alarm_title[i]);
        for(i=0;i<16;i++)
                LCD_write_data(alarm_HI_LO[i]);
        LCD_write_cmd(0x80+0x47);
        LCD_write_cmd(0x80+0x4f);
        uchar i;
        uchar current_opteration=1;
        LCD_init();
        led0=1;
        led1=1;
        TMOD=0x01;
        TH0=-1000/256;
        TL0=-1000%256;
        EA=1;
        ET0=1;
        key_set_HL();
        DS_set_alarm();
        DS_read_temperature();
        delay(50);
        for(i=0;i<16;i++)
                LCD_write_data(tab0[i]);
                delay(20);
        LCD_write_cmd(0x80+0x48);
        for(i=0;i<8;i++)
                LCD_write_data(tab1[i]);
                delay(20);
        delay(1000);
        for(i=0;i<16;i++)
                LCD_write_cmd(0x1c);
                delay(20);
        delay(50);
                   if(key0==0)
                   if(key1==0)
                                   current_opteration=2;
                        switch(current_opteration)
                                case 1:
                                        if(DS_OK)
                                                if(HI_alarm==1||LO_alarm==1)
                                                        TR0=1;
                                                        TR0=0;
                                                        LCD_display_temperature();
                                                delay(100);
                                 break;
                                 case 2:
                                         LCD_display_alarm_temperature();
                                         delay(100);
                                         break;
void timer0() interrupt 1
        TH0=-1000/256;
        TL0=-1000%256;
        beep=~beep;
        if(++time==400)
                time=0;
                if(HI_alarm)
                        led0=~led0;
                        led0=1;
                if(LO_alarm)
                        led1=~led1;
ID:1 發表于 2016-4-20 18:56 | 顯示全部樓層
void timer0() interrupt 1 函數不完整  待樓主補齊后再加分
主站蜘蛛池模板: 国产一级片视频 | 国产精品久久网 | 亚洲精品黄| 国产精品区二区三区日本 | 欧美色噜噜 | 午夜视频免费观看 | 国产三级午夜理伦三级 | 在线不卡一区二区 | 精品久久久久久久久久久久久久久久 | 黄大色黄大片女爽一次 | 在线播放毛片 | 午夜在线视频观看 | 老司机午夜视频 | 日日夜夜精品免费 | 亚洲欧洲av| 国产一区免费 | 一级片毛片 | 久久久精品影院 | 深夜福利网站 | 久久久免费看 | 欧美在线一区二区三区 | 日韩手机看片 | 天天干网站 | 一区二区不卡视频 | 日韩av一二三区 | 日日拍夜夜拍 | 久久久免费精品视频 | 少妇中文字幕 | 中文字幕欧美激情 | 三级视频在线播放 | 中文字幕一区二区三区在线观看 | 狠狠干综合 | a级片免费观看 | 欧美不卡视频 | 在线欧美 | 色婷婷视频在线观看 | av一区二区三区四区 | 永久免费精品视频 | 天天爽天天爽 | 成人一区二区三区 | 欧洲黄色录像 |
