查看: 3922|回復: 0
單片機完美設計之光立方仿真 含proteus仿真文件及程序
ID:3721 發表于 2016-5-29 15:38 | 顯示全部樓層 |閱讀模式
利用課余時間做的51單片機仿真光立方如下:
制作過程詳解:http://m.zg4o1577.cn/bbs/dpj-50791-1.html
光立方仿真文件下載:http://m.zg4o1577.cn/bbs/dpj-50777-1.html
光立方程序:
  1. #include <REG52.H>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar display[8][8];
  6. /*rank:A,1,2,3,4,I,心,U*/
  7. uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
  8. /*the "ideasoft"*/
  9. uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
  10. /*railway*/
  11. uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  12. /*railway 2*/
  13. uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  14. /*railway 3*/
  15. uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
  16. /*3p char*/
  17. uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
  18. /*initializtion
  19. That is to initialize the program .
  20. It is write to set the timer in c52 mcu.
  21. So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
  22. void sinter()
  23. {
  24.          IE=0x82;
  25.          TCON=0x01;
  26.          TH0=0xc0;
  27.          TL0=0;
  28.          TR0=1;
  29. }
  30. void delay5us(void)   //誤差 -0.026765046296us STC 1T 22.1184Mhz
  31. {
  32.     unsigned char a,b;
  33.     for(b=1;b>0;b--)
  34.         for(a=1;a>0;a--);
  35. }
  36. void delay(uint i)
  37. {
  38.                  i /= 5;
  39.          while (i--){
  40.                  delay5us();}//12t的mcu 注釋這個延時即可
  41. }
  42. /*To judge the num bit*/
  43. uchar judgebit(uchar num,uchar b)
  44. {
  45.          char n;
  46.          num=num&(1<<b);
  47.          if (num)
  48.          n=1;
  49.          else
  50.          n=0;
  51.          return n;
  52. }
  53. /*To figure out the round number*/
  54. uchar abs(uchar a)
  55. {
  56.          uchar b;
  57.          b=a/10;
  58.          a=a-b*10;
  59.          if (a>=5)
  60.          b++;
  61.          return b;
  62. }
  63. /*To figure out the absolute value*/
  64. uchar abss(char a)
  65. {
  66.          if (a<0)
  67.          a=-a;
  68.          return a;
  69. }
  70. /*The function can comparat the character.
  71. And remove the big one to the back.*/
  72. void max(uchar *a,uchar *b)
  73. {
  74.    uchar t;
  75.    if ((*a)>(*b))
  76.    {
  77.                    t=(*a);
  78.                    (*a)=(*b);
  79.                    (*b)=t;
  80.    }
  81. }
  82. /*The function is to figure out the max number and return it.*/
  83. uchar maxt(uchar a,uchar b,uchar c)
  84. {
  85.          if (a<b)
  86.          a=b;
  87.          if (a<c)
  88.          a=c;
  89.          return a;
  90. }
  91. void clear(char le)
  92. {
  93.          uchar i,j;
  94.          for (j=0;j<8;j++)
  95.          {
  96.                    for (i=0;i<8;i++)
  97.                    display[j][i]=le;
  98.          }
  99. }
  100. void trailler(uint speed)
  101. {
  102.          char i,j;
  103.          for (i=6;i>=-3;i--)
  104.          {
  105.                    if (i>=0)
  106.                    {
  107.                             for (j=0;j<8;j++)
  108.                             display[j][i]=display[j][i+1];
  109.                    }
  110.                    if (i<4)
  111.                    {
  112.                             for (j=0;j<8;j++)
  113.                             display[j][i+4]=0;
  114.                    }
  115.                    delay(speed);
  116.          }
  117. }
  118. void point(uchar x,uchar y,uchar z,uchar le)
  119. {
  120.          uchar ch1,ch0;
  121.          ch1=1<<x;
  122.          ch0=~ch1;
  123.          if (le)
  124.          display[z][y]=display[z][y]|ch1;
  125.          else
  126.          display[z][y]=display[z][y]&ch0;
  127. }
  128. void type(uchar cha,uchar y)
  129. {
  130.          uchar xx;
  131.          for (xx=0;xx<8;xx++)
  132.          {
  133.          display[xx][y]=table_cha[cha][xx];
  134.          }
  135. }
  136. /*The first variable is the distance from the midpoint.
  137. The second is the layer.
  138. the third is the flash speed of the time between each two point.
  139. The forth is the enable io,it controls weather draw or claen.*/
  140. void cirp(char cpp,uchar dir,uchar le)
  141. {
  142.          uchar a,b,c,cp;
  143.          if ((cpp<128)&(cpp>=0))
  144.          {
  145.                    if (dir)
  146.                    cp=127-cpp;
  147.                    else
  148.                    cp=cpp;
  149.                    a=(dat[cp]>>5)&0x07;
  150.                    b=(dat[cp]>>2)&0x07;
  151.                    c=dat[cp]&0x03;
  152.                    if (cpp>63)
  153.                    c=7-c;
  154.                    point (a,b,c,le);
  155.          }
  156. }
  157. void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
  158. {
  159.          char t,a,b,c,a1,b1,c1,i;
  160.          a1=x2-x1;
  161.          b1=y2-y1;
  162.          c1=z2-z1;
  163.          t=maxt(abss(a1),abss(b1),abss(c1));
  164.          a=x1*10;
  165.          b=y1*10;
  166.          c=z1*10;
  167.          a1=a1*10/t;
  168.          b1=b1*10/t;
  169.          c1=c1*10/t;
  170.          for (i=0;i<t;i++)
  171.          {
  172.                    point(abs(a),abs(b),abs(c),le);
  173.                    a+=a1;
  174.                    b+=b1;
  175.                    c+=c1;
  176.          }
  177.          point(x2,y2,z2,le);
  178. }
  179. void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  180. {
  181.          uchar i,j,t=0;
  182.          max(&x1,&x2);
  183.          max(&y1,&y2);
  184.          max(&z1,&z2);
  185.          for (i=x1;i<=x2;i++)
  186.                    t|=1<<i;
  187.          if (!le)
  188.                    t=~t;
  189.          if (fill)
  190.          {
  191.                    if (le)
  192.                    {
  193.                             for (i=z1;i<=z2;i++)
  194.                             {
  195.                                      for (j=y1;j<=y2;j++)
  196.                                                display[j][i]|=t;
  197.                             }
  198.                    }
  199.                    else
  200.                    {
  201.                             for (i=z1;i<=z2;i++)
  202.                             {
  203.                                      for (j=y1;j<=y2;j++)
  204.                                                display[j][i]&=t;
  205.                             }
  206.                    }
  207.          }
  208.          else
  209.          {
  210.                    if (le)
  211.                    {
  212.                             display[y1][z1]|=t;
  213.                             display[y2][z1]|=t;
  214.                             display[y1][z2]|=t;
  215.                             display[y2][z2]|=t;
  216.                    }
  217.                    else
  218.                    {
  219.                            display[y1][z1]&=t;
  220.                             display[y2][z1]&=t;
  221.                             display[y1][z2]&=t;
  222.                             display[y2][z2]&=t;
  223.                    }
  224.                    t=(0x01<<x1)|(0x01<<x2);
  225.                    if (!le)
  226.                             t=~t;
  227.                    if (le)
  228.                    {
  229.                             for (j=z1;j<=z2;j+=(z2-z1))
  230.                             {
  231.                                      for (i=y1;i<=y2;i++)
  232.                                                display[i][j]|=t;
  233.                             }
  234.                             for (j=y1;j<=y2;j+=(y2-y1))
  235.                             {
  236.                                      for (i=z1;i<=z2;i++)
  237.                                                display[j][i]|=t;
  238.                             }
  239.                    }
  240.                    else
  241.                    {
  242.                             for (j=z1;j<=z2;j+=(z2-z1))
  243.                             {
  244.                                      for (i=y1;i<=y2;i++)
  245.                                      {
  246.                                      display[i][j]&=t;
  247.                                      }
  248.                             }
  249.                             for (j=y1;j<=y2;j+=(y2-y1))
  250.                             {
  251.                                      for (i=z1;i<=z2;i++)
  252.                                      {
  253.                                      display[j][i]&=t;
  254.                                      }
  255.                             }
  256.                    }
  257.          }
  258. }
  259. void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  260. {
  261.          uchar i;
  262.          max(&z1,&z2);
  263.          if (fill)
  264.          {
  265.                    for (i=z1;i<=z2;i++)
  266.                    {
  267.                             line (x1,y1,i,x2,y2,i,le);
  268.                    }
  269.          }
  270.          else
  271.          {
  272.                    line (x1,y1,z1,x2,y2,z1,le);
  273.                    line (x1,y1,z2,x2,y2,z2,le);
  274.                    line (x2,y2,z1,x2,y2,z2,le);
  275.                    line (x1,y1,z1,x1,y1,z2,le);
  276.          }
  277. }
  278. void poke(uchar n,uchar x,uchar y)
  279. {
  280.          uchar i;
  281.          for (i=0;i<8;i++)
  282.          {
  283.           point(x,y,i,judgebit(n,i));
  284.          }
  285. }
  286. void boxtola(char i,uchar n)
  287. {
  288.          if ((i>=0)&(i<8))
  289.          {
  290.                    poke(n,0,7-i);
  291.          }
  292.          if ((i>=8)&(i<16))
  293.          {
  294.                    poke(n,i-8,0);
  295.          }
  296.          if ((i>=16)&(i<24))
  297.          {
  298.                    poke(n,7,i-16);
  299.          }
  300. }
  301. void rolldisplay(uint speed)
  302. {
  303.          uchar j;
  304.          char i,a;
  305.          for (i=23;i>-40;i--)
  306.          {
  307.                    for (j=0;j<40;j++)
  308.                    {
  309.                             a=i+j;
  310.                             if ((a>=0)&(a<24))
  311.                             boxtola(a,table_id[j]);
  312.                    }
  313.                    delay(speed);
  314.          }
  315. }
  316. void roll_apeak_yz(uchar n,uint speed)
  317. {
  318.          uchar i;
  319.          switch(n)
  320.          {
  321.                    case 1:
  322.                             for (i=0;i<7;i++)
  323.                             {
  324.                                      display[i][7]=0;
  325.                                      display[7][6-i]=255;
  326.                                      delay(speed);
  327.                             };
  328.                             break;
  329.                    case 2:
  330.                             for (i=0;i<7;i++)
  331.                             {
  332.                                      display[7][7-i]=0;
  333.                                      display[6-i][0]=255;
  334.                                      delay(speed);
  335.                             };
  336.                             break;
  337.                    case 3:
  338.                             for (i=0;i<7;i++)
  339.                             {
  340.                                      display[7-i][0]=0;
  341.                                      display[0][i+1]=255;
  342.                                      delay(speed);
  343.                             };
  344.                             break;
  345.                    case 0:
  346.                             for (i=0;i<7;i++)
  347.                             {
  348.                                      display[0][i]=0;
  349.                                      display[i+1][7]=255;
  350.                                      delay(speed);
  351.                             };
  352.          }
  353. }
  354. void roll_apeak_xy(uchar n,uint speed)
  355. {
  356.          uchar i;
  357.          switch(n)
  358.          {
  359.                    case 1:
  360.                             for (i=0;i<7;i++)
  361.                             {
  362.                                      line(0,i,0,0,i,7,0);
  363.                                      line(i+1,7,0,i+1,7,7,1);
  364.                                      delay(speed);
  365.                             };
  366.                             break;
  367.                    case 2:
  368.                             for (i=0;i<7;i++)
  369.                             {
  370.                                      line(i,7,0,i,7,7,0);
  371.                                      line(7,6-i,0,7,6-i,7,1);
  372.                                      delay(speed);
  373.                             };
  374.                             break;
  375.                    case 3:
  376.                             for (i=0;i<7;i++)
  377.                             {
  378.                                      line(7,7-i,0,7,7-i,7,0);
  379.                                      line(6-i,0,0,6-i,0,7,1);
  380.                                      delay(speed);
  381.                             };
  382.                             break;
  383.                    case 0:
  384.                             for (i=0;i<7;i++)
  385.                             {
  386.                                      line(7-i,0,0,7-i,0,7,0);
  387.                                      line(0,i+1,0,0,i+1,7,1);
  388.                                      delay(speed);
  389.                             };
  390.          }
  391. }
  392. void roll_3_xy(uchar n,uint speed)
  393. {
  394.          uchar i;
  395.          switch(n)
  396.          {
  397.                    case 1:
  398.                             for (i=0;i<8;i++)
  399.                             {
  400.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  401.                                      delay(speed);
  402.                                      if (i<7)
  403.                                      box_apeak_xy (3,3,0,0,i,7,1,0);
  404.                             };
  405.                             break;
  406.                    case 2:
  407.                             for (i=0;i<8;i++)
  408.                             {
  409.                                       box_apeak_xy (7-i,0,0,i,7,7,1,1);
  410.                                      delay(speed);
  411.                                      if (i<7)
  412.                                      box_apeak_xy (3,4,0,i,7,7,1,0);
  413.                             };
  414.                             break;
  415.                    case 3:
  416.                             for (i=0;i<8;i++)
  417.                             {
  418.                                      box_apeak_xy (0,i,0,7,7-i,7,1,1);
  419.                                      delay(speed);
  420.                                      if (i<7)
  421.                                      box_apeak_xy (4,4,0,7,7-i,7,1,0);
  422.                             };
  423.                             break;
  424.                    case 0:
  425.                             for (i=0;i<8;i++)
  426.                             {
  427.                                      box_apeak_xy (7-i,0,0,i,7,7,1,1);
  428.                                      delay(speed);
  429.                                      if (i<7)
  430.                                      box_apeak_xy (4,3,0,7-i,0,7,1,0);
  431.                             };
  432.          }
  433. }
  434. void trans(uchar z,uint speed)
  435. {
  436.          uchar i,j;
  437.          for (j=0;j<8;j++)
  438.          {
  439.                    for (i=0;i<8;i++)
  440.                    {
  441.                             display[z][i]>>=1;
  442.                    }
  443.                    delay(speed);
  444.          }
  445. }
  446. void tranoutchar(uchar c,uint speed)
  447. {
  448.          uchar i,j,k,a,i2=0;
  449.          for (i=0;i<8;i++)
  450.          {
  451.                    if (i<7)
  452.                    box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
  453.                    box_apeak_xy (i2,0,0,i2,7,7,1,0);
  454.                    a=0;
  455.                    i2=i+1;
  456.                    for (j=0;j<=i;j++)
  457.                    {
  458.                             a=a|(1<<j);
  459.                    }
  460.                    for (k=0;k<8;k++)
  461.                    {
  462.                             display[k][3]|=table_cha[c][k]&a;
  463.                             display[k][4]|=table_cha[c][k]&a;
  464.                    }
  465.                    delay(speed);
  466.          }
  467. }
  468. void transss()
  469. {
  470.          uchar i,j;
  471.          for (i=0;i<8;i++)
  472.          {
  473.                    for (j=0;j<8;j++)
  474.                    display[i][j]<<=1;
  475.          }
  476. }
  477. /*From now on,the function below is to display the flash.*/
  478. void flash_1()
  479. {
  480.          clear(0);
  481.          type(1,0);
  482.          delay(60000);
  483.          type(2,0);
  484.          delay(60000);
  485.          type(3,0);
  486.          delay(60000);
  487.          type(4,0);
  488.          delay(60000);
  489.          delay(60000);
  490.          clear(0);
  491.          rolldisplay(30000);
  492.          type(0,7);
  493.          delay(60000);
  494.          trailler(6000);
  495.          delay(60000);
  496. }
  497. void flash_2()
  498. {
  499.          uchar i;
  500.          for (i=129;i>0;i--)
  501.          {
  502.                    cirp(i-2,0,1);
  503.                    delay(8000);
  504.                    cirp(i-1,0,0);
  505.          }
  506.          delay(8000);
  507.          for (i=0;i<136;i++)
  508.          {
  509.                    cirp(i,1,1);
  510.                    delay(8000);
  511.                    cirp(i-8,1,0);
  512.          }
  513.          delay(8000);
  514.                   for (i=129;i>0;i--)
  515.          {
  516.                    cirp(i-2,0,1);
  517.                    delay(8000);
  518.          }
  519.          delay(8000);
  520.                    for (i=0;i<128;i++)
  521.          {
  522.                    cirp(i-8,1,0);
  523.                    delay(8000);
  524.          }
  525.          delay(60000);
  526. }
  527. void flash_3()
  528. {
  529.          char i;
  530.          for (i=0;i<8;i++)
  531.          {
  532.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  533.                    delay(20000);
  534.                    if (i<7)
  535.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  536.          }
  537.          for (i=7;i>=0;i--)
  538.          {
  539.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  540.                    delay(20000);
  541.                    if (i>0)
  542.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  543.          }
  544.          for (i=0;i<8;i++)
  545.          {
  546.                    box_apeak_xy(0,i,0,7,i,7,1,1);
  547.                    delay(20000);
  548.                    if (i<7)
  549.                    box_apeak_xy(0,i,0,7,i,7,1,0);
  550.          }
  551. }
  552. void flash_4()
  553. {
  554.          char i,j,an[8];
  555.          for (j=7;j<15;j++)
  556.                    an[j-7]=j;
  557.          for (i=0;i<=16;i++)
  558.          {
  559.                    for (j=0;j<8;j++)
  560.                    {
  561.                             if ((an[j]<8)&(an[j]>=0))
  562.                             line(0,an[j],j,7,an[j],j,1);
  563.                    }
  564.                    for (j=0;j<8;j++)
  565.                    {
  566.                             if (((an[j]+1)<8)&(an[j]>=0))
  567.                             line(0,an[j]+1,j,7,an[j]+1,j,0);
  568.                    }
  569.                    for (j=0;j<8;j++)
  570.                    {
  571.                             if (an[j]>0)
  572.                             an[j]--;
  573.                    }
  574.                    delay(15000);
  575.          }
  576.          for (j=0;j<8;j++)
  577.                    an[j]=1-j;
  578.          for (i=0;i<=16;i++)
  579.          {
  580.                    for (j=0;j<8;j++)
  581.                    {
  582.                             if ((an[j]<8)&(an[j]>=0))
  583.                             line(0,an[j],j,7,an[j],j,1);
  584.                    }
  585.                    for (j=0;j<8;j++)
  586.                    {
  587.                             if (((an[j]-1)<7)&(an[j]>0))
  588.                             line(0,an[j]-1,j,7,an[j]-1,j,0);
  589.                    }
  590.                    for (j=0;j<8;j++)
  591.                    {
  592.                             if (an[j]<7)
  593.                             an[j]++;
  594.                    }
  595.                    delay(15000);
  596.          }
  597. }
  598. void flash_5()
  599. {
  600.          uint a=15000;//a=delay
  601.          char i=8,j,an[4];
  602.          //1
  603.          for (j=7;j<11;j++)
  604.                    an[j-7]=j;
  605.          while(i--)
  606.          {
  607.                    for (j=0;j<4;j++)
  608.                    {
  609.                             if (an[j]<8)
  610.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  611.                             if (an[j]<7)
  612.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  613.                    }
  614.                    for (j=0;j<4;j++)
  615.                    {
  616.                             if (an[j]>3)
  617.                             an[j]--;
  618.                    }
  619.                    delay(a);
  620.          }
  621.          //2
  622.          i=3;
  623.          for (j=0;j<4;j++)
  624.          an[j]=5-j;
  625.          while(i--)
  626.          {
  627.                    for (j=1;j<4;j++)
  628.                    {
  629.                             if (an[j]<4)
  630.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  631.                             if (an[j]<3)
  632.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  633.                    }
  634.                    for (j=0;j<4;j++)
  635.                    {
  636.                             if (an[j]>0)
  637.                             an[j]--;
  638.                    }
  639.                    delay(a);
  640.          }
  641.          //3
  642.          i=3;
  643.          for (j=1;j<4;j++)
  644.          an[j]=4-j;
  645.          while(i--)
  646.          {
  647.                    for (j=1;j<4;j++)
  648.                    {
  649.                             if (an[j]>=0)
  650.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  651.                             if (an[j]>0)
  652.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  653.                    }
  654.                    for (j=1;j<4;j++)
  655.                    {
  656.                             if (an[j]<3)
  657.                             an[j]++;
  658.                    }
  659.                    delay(a);
  660.          }
  661.          //4
  662.          i=3;
  663.          for (j=0;j<4;j++)
  664.          an[j]=j+1;
  665.          while(i--)
  666.          {
  667.                    for (j=1;j<4;j++)
  668.                    {
  669.                             if (an[j]>3)
  670.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  671.                             if (an[j]>3)
  672.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  673.                    }
  674.                    for (j=0;j<4;j++)
  675.                             an[j]++;
  676.                    delay(a);
  677.          }
  678.          //5
  679.          i=3;
  680.          for (j=3;j<6;j++)
  681.                    an[j-2]=j;
  682.          while(i--)
  683.          {
  684.                    for (j=1;j<4;j++)
  685.                    {
  686.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  687.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  688.                    }
  689.                    for (j=0;j<4;j++)
  690.                    {
  691.                             if (an[j]>3)
  692.                             an[j]--;
  693.                    }
  694.                    delay(a);
  695.          }
  696.          //6
  697.          i=3;
  698.          for (j=0;j<4;j++)
  699.          an[j]=5-j;
  700.          while(i--)
  701.          {
  702.                    for (j=1;j<4;j++)
  703.                    {
  704.                             if (an[j]<4)
  705.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  706.                             if (an[j]<3)
  707.                             box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  708.                    }
  709.                    for (j=0;j<4;j++)
  710.                    {
  711.                             if (an[j]>0)
  712.                             an[j]--;
  713.                    }
  714.                    delay(a);
  715.          }
  716.          //7
  717.          i=3;
  718.          for (j=0;j<4;j++)
  719.          an[j]=3-j;
  720.          an[0]=2;
  721.          while(i--)
  722.          {
  723.                    for (j=0;j<3;j++)
  724.                    {
  725.                             if (an[j]>=0)
  726.                                      box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  727.                             if (an[j]>=0)
  728.                                      box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
  729.                    }
  730.                    for (j=0;j<4;j++)
  731.                    {
  732.                             if (j<5-i)
  733.                             an[j]--;
  734.                    }
  735.                    delay(a);
  736.          }
  737.          //8
  738.          i=10;
  739.          for (j=0;j<4;j++)
  740.                    an[j]=j-2;
  741.          while(i--)
  742.          {
  743.                    for (j=0;j<4;j++)
  744.                    {
  745.                             if (an[j]>=0)
  746.                             box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
  747.                             if (an[j]>=0)
  748.                             box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
  749.                    }
  750.                    for (j=0;j<4;j++)
  751.                    {
  752.                             if (an[j]<7)
  753.                             an[j]++;
  754.                    }
  755.                    delay(a);
  756.          }
  757. }
  758. void flash_6()
  759. {
  760.       uchar i,j,k,z;
  761.       roll_apeak_yz(1,10000);
  762.       roll_apeak_yz(2,10000);
  763.       roll_apeak_yz(3,10000);
  764.       roll_apeak_yz(0,10000);
  765.       roll_apeak_yz(1,10000);
  766.       roll_apeak_yz(2,10000);
  767.       roll_apeak_yz(3,10000);
  768.       for (i=0;i<3;i++)
  769.                {
  770.                          for (j=0;j<8;j++)
  771.                          {
  772.                                   for (k=0;k<8;k++)
  773.                                   {
  774.                                            if ((table_3p[i][j]>>k)&1)
  775.                                            {
  776.                                                      for (z=1;z<8;z++)
  777.                                                               {
  778.        point (j,7-k,z,1);
  779.        if (z-1)
  780.        point (j,7-k,z-1,0);
  781.        delay(5000);
  782.                                                               }
  783.                                            }
  784.                                   }
  785.                          }
  786.                          trans(7,15000);
  787.                }
  788. }
  789. void flash_7()
  790. {
  791.       uchar i;
  792.       uint a=3000;
  793.       roll_apeak_yz(0,10000);
  794.       roll_apeak_yz(1,10000);
  795.       roll_apeak_yz(2,10000);
  796.       roll_apeak_yz(3,10000);
  797.       roll_apeak_yz(0,10000);
  798.       roll_apeak_yz(1,10000);
  799.       roll_apeak_yz(2,10000);
  800.       roll_apeak_yz(3,10000);
  801.       roll_apeak_yz(0,10000);
  802.       roll_apeak_yz(1,10000);
  803.       roll_apeak_yz(2,10000);
  804.       roll_apeak_xy(0,10000);
  805.       roll_apeak_xy(1,10000);
  806.       roll_apeak_xy(2,10000);
  807.       roll_apeak_xy(3,10000);
  808.       roll_apeak_xy(0,10000);
  809.       roll_apeak_xy(1,10000);
  810.       roll_apeak_xy(2,10000);
  811.       roll_apeak_xy(3,10000);
  812.       for (i=0;i<8;i++)
  813.       {
  814.                box_apeak_xy (0,i,0,7-i,i,7,1,1);
  815.                delay(a);
  816.       }
  817.       delay(30000);
  818.       roll_3_xy(0,a);
  819.       delay(30000);
  820.       roll_3_xy(1,a);
  821.       delay(30000);
  822.       roll_3_xy(2,a);
  823.       delay(30000);
  824.       roll_3_xy(3,a);
  825.       delay(30000);
  826.       roll_3_xy(0,a);
  827.       delay(30000);
  828.       roll_3_xy(1,a);
  829.       delay(30000);
  830.       roll_3_xy(2,a);
  831.       delay(30000);
  832.       roll_3_xy(3,a);
  833.       for (i=7;i>0;i--)
  834.       {
  835.                box_apeak_xy(i,0,0,i,7,7,1,0);
  836.                delay(a);
  837.       }
  838. }
  839. void flash_8()
  840. {
  841.       uchar i;
  842.       for (i=5;i<8;i++)
  843.       {
  844.                tranoutchar(i,10000);
  845.                delay(60000);
  846.                delay(60000);
  847.       }
  848. }
  849. void flash_9()
  850. {
  851.       char i;
  852.       uchar j,an[8],x,y,t,x1,y1;
  853.       for (i=0;i<8;i++)
  854.       {
  855.                box_apeak_xy (i,0,0,i,7,7,1,1);
  856.                if (i)
  857.                box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
  858.                delay(10000);
  859.       }
  860.       roll_apeak_xy(3,10000);
  861.       roll_apeak_xy(0,10000);
  862.       roll_apeak_xy(1,10000);
  863.       for (i=0;i<7;i++)
  864.       {
  865.                line(6-i,6-i,0,6-i,6-i,7,1);
  866.                line(i,7,0,i,7,7,0);
  867.                delay(10000);
  868.       }
  869.       for (i=0;i<8;i++)
  870.                an[i]=14;
  871.       for (i=0;i<85;i++)
  872.       {
  873.                clear(0);
  874.                for (j=0;j<8;j++)
  875.                {
  876.                          t=an[j]%28;
  877.                          x=dat2[t]>>5;
  878.                          y=(dat2[t]>>2)&0x07;
  879.                          t=(an[j]-14)%28;
  880.                          x1=dat2[t]>>5;
  881.                          y1=(dat2[t]>>2)&0x07;
  882.                          line(x,y,j,x1,y1,j,1);
  883.                }
  884.                for (j=0;j<8;j++)
  885.                {
  886.                if ((i>j)&(j>i-71))
  887.                an[j]++;
  888.                }
  889.                delay(5000);
  890.       }
  891.       for (i=0;i<85;i++)
  892.       {
  893.                clear(0);
  894.                for (j=0;j<8;j++)
  895.                {
  896.                          t=an[j]%28;
  897.                          x=dat2[t]>>5;
  898.                          y=(dat2[t]>>2)&0x07;
  899.                          t=(an[j]-14)%28;
  900.                          x1=dat2[t]>>5;
  901.                          y1=(dat2[t]>>2)&0x07;
  902.                          line(x,y,j,x1,y1,j,1);
  903.                }
  904.                for (j=0;j<8;j++)
  905.                {
  906.                if ((i>j)&(j>i-71))
  907.                an[j]--;
  908.                }
  909.                delay(5000);
  910.       }
  911.       for (i=0;i<29;i++)
  912.       {
  913.                clear(0);
  914.                t=an[0]%28;
  915.                x=dat2[t]>>5;
  916.                y=(dat2[t]>>2)&0x07;
  917.                t=(an[0]-14)%28;
  918.                x1=dat2[t]>>5;
  919.                y1=(dat2[t]>>2)&0x07;
  920.                box_apeak_xy(x,y,0,x1,y1,7,0,1);
  921.                box_apeak_xy(x,y,1,x1,y1,6,0,1);
  922.                an[0]++;
  923.                delay(5000);
  924.       }
  925.       for (i=0;i<16;i++)
  926.       {
  927.                clear(0);
  928.                t=an[0]%28;
  929.                x=dat2[t]>>5;
  930.                y=(dat2[t]>>2)&0x07;
  931.                t=(an[0]-14)%28;
  932.                x1=dat2[t]>>5;
  933.                y1=(dat2[t]>>2)&0x07;
  934.                box_apeak_xy(x,y,0,x1,y1,7,1,1);
  935.                an[0]--;
  936.                delay(5000);
  937.       }
  938.       for (i=0;i<8;i++)
  939.       {
  940.                line(i,i,0,0,0,i,0);
  941.                delay(5000);
  942.       }
  943.       for (i=1;i<7;i++)
  944.       {
  945.                line(i,i,7,7,7,i,0);
  946.                delay(5000);
  947.       }
  948.       for (i=1;i<8;i++)
  949.       {
  950.                clear(0);
  951.                box(7,7,7,7-i,7-i,7-i,0,1);
  952.                delay(10000);
  953.       }
  954.       for (i=1;i<7;i++)
  955.       {
  956.                clear(0);
  957.                box(0,0,0,7-i,7-i,7-i,0,1);
  958.                delay(10000);
  959.       }
  960.       for (i=1;i<8;i++)
  961.       {
  962.                clear(0);
  963.                box(0,0,0,i,i,i,0,1);
  964.                delay(10000);
  965.       }
  966.       for (i=1;i<7;i++)
  967.       {
  968.                clear(0);
  969.                box(7,0,0,i,7-i,7-i,0,1);
  970.                delay(10000);
  971.       }
  972.       for (i=1;i<8;i++)
  973.       {
  974.                box(7,0,0,7-i,i,i,1,1);
  975.                delay(10000);
  976.       }
  977.       for (i=1;i<7;i++)
  978.       {
  979.                clear(0);
  980.                box(0,7,7,7-i,i,i,1,1);
  981.                delay(10000);
  982.       }
  983. }
  984. void flash_10()
  985. {
  986.       uchar i,j,an[4],x,y,t;
  987.       for (i=1;i<7;i++)
  988.       {
  989.
  990.                clear(0);
  991.                box(0,6,6,1,7,7,1,1);
  992.                box(i,6,6-i,i+1,7,7-i,1,1);
  993.                box(i,6,6,i+1,7,7,1,1);
  994.                box(0,6,6-i,1,7,7-i,1,1);
  995.                box(0,6-i,6,1,7-i,7,1,1);
  996.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  997.                box(i,6-i,6,i+1,7-i,7,1,1);
  998.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  999.                delay(30000);
  1000.       }
  1001.       for (i=0;i<4;i++)
  1002.       {
  1003.                an[i]=6*i;
  1004.       }
  1005.       for (i=0;i<35;i++)
  1006.       {
  1007.                clear(0);
  1008.                for(j=0;j<4;j++)
  1009.                {
  1010.                          t=an[j]%24;
  1011.                          x=dat3[t]>>4;
  1012.                          y=dat3[t]&0x0f;
  1013.                          box(x,y,0,x+1,y+1,1,1,1);
  1014.                          box(x,y,6,x+1,y+1,7,1,1);
  1015.                }
  1016.                for (j=0;j<4;j++)
  1017.                an[j]++;
  1018.                delay(10000);
  1019.       }
  1020.       for (i=0;i<35;i++)
  1021.       {
  1022.                clear(0);
  1023.                for(j=0;j<4;j++)
  1024.                {
  1025.                          t=an[j]%24;
  1026.                          x=dat3[t]>>4;
  1027.                          y=dat3[t]&0x0f;
  1028.                          box(x,y,0,x+1,y+1,1,1,1);
  1029.                          box(x,y,6,x+1,y+1,7,1,1);
  1030.                }
  1031.                for (j=0;j<4;j++)
  1032.                an[j]--;
  1033.                delay(10000);
  1034.       }
  1035.       for (i=0;i<35;i++)
  1036.       {
  1037.                clear(0);
  1038.                for(j=0;j<4;j++)
  1039.                {
  1040.                          t=an[j]%24;
  1041.                          x=dat3[t]>>4;
  1042.                          y=dat3[t]&0x0f;
  1043.                          box(x,0,y,x+1,1,y+1,1,1);
  1044.                          box(x,6,y,x+1,7,y+1,1,1);
  1045.                }
  1046.                for (j=0;j<4;j++)
  1047.                an[j]++;
  1048.                delay(10000);
  1049.       }
  1050.       for (i=0;i<36;i++)
  1051.       {
  1052.                clear(0);
  1053.                for(j=0;j<4;j++)
  1054.                {
  1055.                          t=an[j]%24;
  1056.                          x=dat3[t]>>4;
  1057.                          y=dat3[t]&0x0f;
  1058.                          box(x,0,y,x+1,1,y+1,1,1);
  1059.                          box(x,6,y,x+1,7,y+1,1,1);
  1060.                }
  1061.                for (j=0;j<4;j++)
  1062.                an[j]--;
  1063.                delay(10000);
  1064.       }
  1065.       for (i=6;i>0;i--)
  1066.       {
  1067.
  1068.                clear(0);
  1069.                box(0,6,6,1,7,7,1,1);
  1070.                box(i,6,6-i,i+1,7,7-i,1,1);
  1071.                box(i,6,6,i+1,7,7,1,1);
  1072.                box(0,6,6-i,1,7,7-i,1,1);
  1073.                box(0,6-i,6,1,7-i,7,1,1);
  1074.                box(i,6-i,6-i,i+1,7-i,7-i,1,1);
  1075.                box(i,6-i,6,i+1,7-i,7,1,1);
  1076.                box(0,6-i,6-i,1,7-i,7-i,1,1);
  1077.                delay(30000);
  1078.       }
  1079. }
  1080. void flash_11()
  1081. {
  1082.       uchar i,j,t,x,y;
  1083.       uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
  1084.       for (j=0;j<5;j++)
  1085.       {
  1086.                for (i=0;i<13;i++)
  1087.                {
  1088.                          if (daa[i]>>4)
  1089.                          {
  1090.                                   t=daa[i]&0x0f;
  1091.                                   line (0,0,t+1,0,7,t+1,1);
  1092.                          }
  1093.                          else
  1094.                                   t=daa[i];
  1095.                          line (0,0,t,0,7,t,1);
  1096.                          transss();
  1097.                          delay(10000);
  1098.                }
  1099.       }
  1100.       for (j=1;j<8;j++)
  1101.       {
  1102.                if (j>3)
  1103.                          t=4;
  1104.                else
  1105.                          t=j;
  1106.                for (i=0;i<24;i+=j)
  1107.                {
  1108.                          x=dat3[i]>>4;
  1109.                          y=dat3[i]&0x0f;
  1110.                          box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
  1111.                          transss();
  1112.                          delay(10000);
  1113.                }
  1114.       }
  1115.       for (j=1;j<8;j++)
  1116.       {
  1117.                if (j>3)
  1118.                          t=4;
  1119.                else
  1120.                          t=j;
  1121.                for (i=0;i<24;i+=j)
  1122.                {
  1123.                          x=dat3[i]>>4;
  1124.                          y=dat3[i]&0x0f;
  1125.                          point (0,x,y,1);
  1126.                          transss();
  1127.                          delay(10000);
  1128.                }
  1129.       }
  1130. }
  1131. void main()
  1132. {
  1133.
  1134.          sinter();
  1135.                  while(1){
  1136.         clear(0);
  1137.
  1138.          flash_1();
  1139.          clear(0);
  1140.          flash_2();
  1141.          flash_3();
  1142.          flash_4();
  1143.          flash_4();
  1144.          flash_5();
  1145.       flash_5();
  1146.       flash_6();
  1147.       flash_7();
  1148.       flash_8();
  1149.       flash_9();
  1150.       flash_10();
  1151.       clear (0);
  1152.       flash_11();
  1153.       flash_9();
  1154.       flash_5();
  1155.       flash_7();
  1156.       flash_5();
  1157.       flash_6();
  1158.       flash_8();
  1159.       flash_9();
  1160.       flash_10();
  1161.          }
  1162. }
  1163. //P0;   //573 in
  1164. //P1;  //uln2803
  1165. //P2;  //573 LE
  1166. void print() interrupt 1
  1167. {
  1168.          uchar i;
  1169.          static uchar layer=0;
  1170.          P1=0;
  1171.          for (i=0;i<8;i++)
  1172.          {
  1173.                    P2=1<<i;
  1174.                    delay(3);
  1175.                    P0=display[layer][i];
  1176.                    delay(3);
  1177.          }
  1178.          P1=1<<layer;
  1179.          if (layer<7)
  1180.                    layer++;
  1181.          else
  1182.                    layer=0;
  1183.          TH0=0xc0;
  1184.          TL0=0;
  1185. }
主站蜘蛛池模板: 成人91视频| 国产九九热 | 成人福利片| 人人九九精 | 欧美 日韩 国产 成人 在线 | 亚洲一区二区国产精品 | 日本美女性生活 | 国产成人三级一区二区在线观看一 | 青草视频网站 | 91免费看视频 | 国产传媒一区二区 | 国产一级生活片 | 精品国产999久久久免费 | 中文在线观看免费视频 | 91成人在线 | 在线国产小视频 | 亚洲精品一区二区三区在线观看 | 国产在线播放av | 婷婷五月在线视频 | 少妇搡bbbb搡bbb搡毛茸茸 | 久久这里只有精品6 | 日韩视频免费在线观看 | 国内自拍一区 | 亚洲精品社区 | 可以免费看av的网站 | 欧美成在线 | 69av在线 | 久草手机在线视频 | aaa黄色| 97久久精品人人澡人人爽 | 国产精品99久久久久久久久 | 黄色小视频免费观看 | 色噜噜狠狠一区二区三区 | 性生活网址 | 国产一区二区日韩 | 台湾av在线 | a级片免费观看 | 91看片在线| 免费午夜视频 | 91精品久久久久久久久久 | 亚洲色在线视频 |
