//功能:完成8只LED得明燈流動
//出口參數(shù):無
//入口參數(shù):無
void main(void)
unsigned char loop_index; /*定義變量
DDRB=0xFF; /*定義PORTB端口為輸出口
loop_index=0; /*變量初始化,程序起始點亮燈D0
switch(loop_index)
case 0:PORTB=0xFE;break;
case 1:PORTB=0xFD;break;
case 2:PORTB=0xFB;break;
case 3:PORTB=0xF7;break;
case 4:PORTB=0xEF;break;
case 5:PORTB=0xDF;break;
case 6:PORTB=0xBF;break;
case 7:PORTB=0x7f;break;
loop_index++;
if(loop_index==18)
loop_index=0;
delay();
void delay(void) /*定義延時delay函數(shù)
unsinged int loop_i,loop_j;
for (loop_i=0;loop_i<500;loop_i++)
for(loop_j=0;loop_j<500;loop_j++)
