查看: 2999|回復: 0
求大神將下面這篇c語程序轉換成匯編語言程序(關于M、T法測轉速的))
ID:136516 發表于 2016-8-11 19:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define        uchar        unsigned char
#define uint        unsigned int
#define   DataPort P0        //LCD1602數據端口
sbit    LCM_RS=P2^5;   //LCD1602命令端口
sbit    LCM_EN=P2^7;   //LCD1602命令端口
sbit    KEY1=P1^1;     //確認按鍵
sbit    KEY2=P1^3;            //減按鍵
sbit    KEY3=P1^5;     //加按鍵
uchar table[] = "Mode selection:";
uint M1 = 0;bit M_FLAG = 0;    //M法測速參數
uint M2 = 0;bit T_FLAG = 0;    //T法測速參數
uint Z = 1,T = 1000,n = 100;   //倍頻系數*編碼器光柵數 采樣周期
bit flag = 0;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
                LCM_RS=0;
                DataPort=com;
                delay(5);
                LCM_EN=1;
                delay(5);
                LCM_EN=0;
void write_data(uchar date)
                LCM_RS=1;
                DataPort=date;
                delay(5);
                LCM_EN=1;
                delay(5);
                LCM_EN=0;
void init()
                LCM_EN=0;
                write_com(0x38);
                write_com(0x0e);
                write_com(0x06);
                write_com(0x01);
                write_com(0x80+0x00);
void main(void)
                uchar i;
                init();      //液晶初始化
                write_com(0x80);
                for(i = 0;i < 15;i++)
                                write_data(table);
                while(!flag)
                                if(!KEY2)
                                                delay(15);write_com(0x80 + 15);write_data('M');
                                                M_FLAG = 1;T_FLAG = 0;while(!KEY2);
                                if(!KEY3)
                                                delay(15);write_com(0x80 + 15);write_data('T');
                                                T_FLAG = 1;M_FLAG = 0;while(!KEY3);
                                if(!KEY1 &&(T_FLAG || M_FLAG))
                                {flag = 1;while(!KEY1);}
                write_com(0x80 + 0x40);
                write_data('Z');
                write_data('=');
                write_data(Z / 100 + '0');
                write_data(Z / 10 % 10 + '0');
                write_data(Z % 10 + '0');
                flag = 0;
                while(!flag)
                                if(!KEY2)
                                                delay(15);
                                                Z--;
                                                write_com(0x80 + 0x42);
                                                delay(15);while(!KEY2);
                                if(!KEY3)
                                                delay(15);
                                                Z++;
                                                delay(15);while(!KEY3);
                                if(!KEY1)
                write_com(0x80 + 0x48);
                write_data('T');
                write_data('=');
                write_data(T / 1000 + '0');
                write_data(T / 100 % 10 + '0');
                write_data(T / 10 % 10 + '0');
                write_data(T % 10 + '0');
                write_com(0x80 + 0x4E);
                write_data('m');
                write_data('s');
                flag = 0;
                while(!flag)
                                if(!KEY2)
                                                delay(15);
                                                T--;
                                                write_com(0x80 + 0x4A);
                                                while(!KEY2);
                                if(!KEY3)
                                                delay(15);
                                                T++;
                                                while(!KEY3);
                                if(!KEY1)
                flag = 0;write_com(0x01);
                IT0 = 1;       //下降沿觸發
                EX0 = 1;
    TMOD = 0x11;   //定時/計數器0、1工作于方式1
                TH0 = 0xFC;    //12.000
                TL0 = 0x18;
    ET0=1;       //允許定時/計數器0 中斷
    if(M_FLAG) TR0=1;       //啟動定時/計數器0 中斷
                else if(T_FLAG) TR0=0;       //啟動定時/計數器0 中斷
                EA=1;
void Int0(void) interrupt 0
                if(M_FLAG) M1++;
                if(T_FLAG)
                                TR0=1;
                                if(flag)
                                                flag = 0;
                                                n = T*60/Z/M2;
                                                write_com(0x80);
                                                write_data('S');
                                                write_data('p');
                                                write_data('e');
                                                write_data('e');
                                                write_data('d');
                                                write_data(':');
                                                write_data(n / 10000 + '0');
                                                write_data(n / 1000 % 10 + '0');
                                                write_data(n / 100 % 10 + '0');
                                                write_data(n / 10 % 10 + '0');
                                                write_data(n % 10 + '0');
                                                write_data('r');
                                                write_data('/');
                                                write_data('m');
                                                write_data('i');
                                                write_data('n');
                                                EA = 0;
                                flag = 1;M2 = 0;
void Timer0(void) interrupt 1
                TL0 = 0x18;
                M2++;
                if(T == M2)
主站蜘蛛池模板: 欧美一级淫片免费视频魅影视频 | 亚洲福利片| 久久久久一区 | 天天操狠狠操 | 中国第一毛片 | 久久亚洲欧美 | 在线观看h片 | 五月天婷婷视频 | www.少妇| 国产在线欧美 | 青青草视频在线观看 | 99福利视频| 天堂av影视 | 精品国产一区二区三 | 三级网站视频 | 成人网址在线观看 | 91av在线看 | 一级毛片黄色 | 国产日韩欧美亚洲 | 国产一区二区三区视频 | 日本在线观看网站 | 国产欧美在线观看 | 网站毛片 | 91最新网址 | 亚洲精品一区中文字幕乱码 | 色婷婷在线视频 | 亚洲精品成人网 | 好吊视频一区二区三区 | 日本高清网站 | 日本三级一区 | 在线日韩一区 | 国产福利视频 | 欧美一区二区三区在线 | 国产精品欧美激情 | 成人毛片在线观看 | 日本伊人 | 成人福利视频 | 手机成人在线视频 | 日韩免费精品视频 | 日本熟妇毛耸耸xxxxxx | 香蕉久久a毛片 |
