查看: 5280|回復(fù): 0
基于51單片機(jī)精確到0.1秒可回看記錄的秒表程序
ID:156338 發(fā)表于 2016-12-20 20:05 | 顯示全部樓層 |閱讀模式
可回看計(jì)時(shí)記錄
下載:
miaobiao5.rar (20.28 KB, 下載次數(shù): 21)
  1. #include <reg51.h>
  2. unsigned char code leddata[]= {  0x3F,  0x06,  0x5B,  0x4F, //0 1 2 3
  3.                                  0x66,  0x6D,  0x7D,  0x07,  //4 5 6 7
  4.                                  0x7F,  0x6F,  0x77,  0x7C,  //8 9 A b
  5.                                  0x39,  0x5E,  0x79,  0x71,  //c d E F
  6.                                  0x76,  0x38,  0x37,  0x3E,  //H L n u
  7.                                  0x73,  0x5C,  0x40,  0x00,  //P o - 清屏
  8.                               };
  9. #define digitData P0          //數(shù)碼管數(shù)據(jù)
  10. #define startBtn    0       //按鍵值
  11. #define resetBtn    1
  12. #define counterBtn  2
  13. sbit DX = P2^6;//段選
  14. sbit WX = P2^7;//位選
  15. sbit kaiShi = P3^4;//開始、暫停按鍵
  16. sbit chongZhi = P3^5;//重置按鍵
  17. sbit jiCi = P3^6;//計(jì)次、記錄查看按鍵
  18. unsigned int recode[8] = {0};//記錄數(shù)據(jù)
  19. unsigned char recodeNum = 0;//記錄數(shù)據(jù)值位置
  20. unsigned char showRe = 0; //查看哪項(xiàng)記錄值
  21. unsigned int times = 0; //當(dāng)前計(jì)時(shí)時(shí)間
  22. unsigned int saveTimes = 0;//暫停查看記錄時(shí)保存時(shí)間數(shù)據(jù)
  23. unsigned char counter = 0;//定時(shí)器次數(shù),構(gòu)成100ms
  24. unsigned char shuanXi = 0,sXW = 1;//刷新數(shù)碼管
  25. unsigned char runState = 0;//0表示停止,1表示運(yùn)行
  26. unsigned char keyTemp[3]= {0}; //按鍵按下狀態(tài)持續(xù)時(shí)間
  27. //六位數(shù)碼管顯示 dat:顯示內(nèi)容下標(biāo) wei:哪一個(gè)數(shù)碼管
  28. void display(unsigned char dat,unsigned char wei)//wei 1-6
  29. {
  30.     digitData = 0xff; //關(guān)掉顯示 消除重影
  31.     WX = 1;
  32.     WX = 0;
  33.     //如果不先關(guān)閉顯示,不論先段選還位選(位選前關(guān)閉都不行),而且必須先送段選,再送位選,
  34.     //先位選則當(dāng)前位置會(huì)顯示上次殘留段選數(shù)據(jù) 導(dǎo)致重影
  35.     digitData = leddata[dat];//段選
  36.     DX = 1;
  37.     DX = 0;
  38.     digitData = ~(1<<(wei-1));//位選
  39.     WX = 1;
  40.     WX = 0;
  41. }
  42. //判斷當(dāng)前按鍵
  43. unsigned char scanKey()
  44. {
  45.     P3 = 0x70;//k1 k2 k3給高
  46.     if(kaiShi==0)//開始鍵按下
  47.     {
  48.         if(keyTemp[0] == 0) keyTemp[0]=1 ;//按鍵按下 開始記延時(shí)
  49.     }
  50.     else
  51.     {
  52.         keyTemp[0] = 0; //有抖動(dòng)重新延時(shí)
  53.     }
  54.     if(chongZhi==0)
  55.     {
  56.         if(keyTemp[1] == 0) keyTemp[1]=1 ;
  57.     }
  58.     else
  59.     {
  60.         keyTemp[1] = 0;
  61.     }
  62.     if(jiCi==0)
  63.     {
  64.         if(keyTemp[2] == 0) keyTemp[2]=1 ;
  65.     }
  66.     else
  67.     {
  68.         keyTemp[2] = 0;
  69.     }
  70.     if(keyTemp[0]>5) return startBtn;  //5次 5*2ms 超過10ms 消抖
  71.     if(keyTemp[1]>5) return resetBtn;
  72.     if(keyTemp[2]>5) return counterBtn;
  73.     return 0xFF; //沒有按鍵
  74. }
  75. void Timer0Init(void)        //2毫秒@11.0592MHz
  76. {
  77.     //AUXR &= 0x7F;        //定時(shí)器時(shí)鐘12T模式
  78.     TMOD &= 0xF0;        //設(shè)置定時(shí)器模式
  79.     TMOD |= 0x01;        //設(shè)置定時(shí)器模式
  80.     TL0 = 0xCF;        //設(shè)置定時(shí)初值
  81.     TH0 = 0xF8;        //設(shè)置定時(shí)初值
  82.     TF0 = 0;        //清除TF0標(biāo)志
  83.     TR0 = 1;        //定時(shí)器0開始計(jì)時(shí)
  84.     ET0 = 1;         //運(yùn)行定時(shí)器0中斷
  85.     EA = 1;         //開全局中斷
  86. }
  87. void main()
  88. {
  89.     unsigned char keyValue = 0xFF,keyT = 0xFF;//按鍵值
  90.     unsigned char weiXian[6] = {0,22,0,0,22,0};
  91.     Timer0Init();
  92.     while(1)
  93.     {
  94.         if(shuanXi)//刷新sXW位置的數(shù)碼管中
  95.         {
  96.             if(times>=6000) //十分鐘
  97.             {
  98.                 times = 0;
  99.             }
  100.             weiXian[0] = times/600;//分鐘
  101.             weiXian[2] = times/10%60/10;
  102.             weiXian[3] = times/10%60%10;
  103.             weiXian[5] = times%10;
  104.             display(weiXian[sXW-1],sXW);
  105.             shuanXi = 0;
  106.         }
  107.         keyT = scanKey();//當(dāng)前按鍵值
  108.         if(keyT!=keyValue)//當(dāng)前按鍵值與上次按鍵值不同,則表示按鍵狀態(tài)改變。需要做按鍵處理
  109.         {
  110.             keyValue = keyT;
  111.             //P1 = keyValue;
  112.             switch(keyValue)//按鍵處理
  113.             {
  114.             case startBtn://開始暫停按下
  115.                 //if(runState) TR0 = 0; else TR0 = 1;
  116.                 //runState ? (TR0 = 0) : (TR0 = 1);
  117.                 runState = !runState;//改變狀態(tài)
  118.                 if(runState)//恢復(fù)時(shí)間
  119.                 {
  120.                     times = saveTimes;
  121.                 }
  122.                 else//保存時(shí)間
  123.                 {
  124.                     saveTimes = times;
  125.                 }
  126.                 break;
  127.             case resetBtn:  //重置
  128.                 if(!runState)
  129.                 {
  130.                     times = 0;
  131.                     saveTimes = 0;
  132.                     recodeNum = 0;
  133.                     P1 = 0xFF;
  134.                 }
  135.                 break;
  136.             case counterBtn:  //記錄或查看記錄
  137.                 if(runState)//運(yùn)行時(shí),記錄
  138.                 {
  139.                     if(recodeNum<8)
  140.                     {
  141.                         recode[recodeNum++] = times;
  142.                         P1 = (0xFF<<recodeNum);//點(diǎn)亮recodeNum個(gè)燈
  143.                     }
  144.                 }
  145.                 else//暫停查看記錄
  146.                 {
  147.                     P1 = (0xFF ^(1 << showRe));//點(diǎn)亮showRe位置的燈
  148.                     times = recode[showRe++];
  149.                     if(showRe >= recodeNum)
  150.                     {
  151.                         showRe = 0;//循環(huán)查看記錄
  152.                     }
  153.                 }
  154.                 break;
  155.             }
  156.         }
  157.     }
  158. }
  159. void T0_2ms() interrupt 1
  160. {
  161.     //定時(shí)器重新賦初值 放在終端服務(wù)程序最開始有利于降低定時(shí)中斷誤差
  162.     TL0 = 0xCF;        //設(shè)置定時(shí)初值
  163.     TH0 = 0xF8;        //設(shè)置定時(shí)初值
  164.     if(++counter>=50 && runState)//運(yùn)行狀態(tài)下100ms 加0.1秒
  165.     {
  166.         times++;
  167.         counter = 0;
  168.     }
  169.     shuanXi = 1;//數(shù)碼管周期刷新
  170.     if(++sXW>6) //六位循環(huán)刷新
  171.     {
  172.         sXW = 1;
  173.     }
  174.     if(keyTemp[0]) keyTemp[0]++;//按鍵持續(xù)
  175.     if(keyTemp[1]) keyTemp[1]++;//按鍵持續(xù)
  176.     if(keyTemp[2]) keyTemp[2]++;//按鍵持續(xù)
  177. }
相關(guān)帖子
主站蜘蛛池模板: 国产成人三级一区二区在线观看一 | 在线观看黄色小视频 | 国产成人av在线 | 在线播放中文字幕 | www视频在线观看 | www国产亚洲精品久久网站 | 国产精品福利在线 | 欧美视频在线播放 | 91午夜理伦私人影院 | 亚洲精选在线观看 | 午夜激情网 | 午夜视频免费 | 在线免费观看日韩av | 黄视频网站在线观看 | 久久99精品久久久久久国产越南 | 黄色大片免费观看 | 精品国产一区二区三 | 天天撸夜夜操 | 欧美性视频在线 | 成人在线免费视频观看 | 国产欧美日韩在线视频 | 免费成人黄色网址 | 法国极品成人h版 | 亚洲在线视频 | 亚洲va视频| 黑人操亚洲女人 | 亚洲天堂久久久 | 日韩视频中文字幕 | 国产精品主播一区二区 | 国产精品99久久久久久久久 | 日韩免费在线观看视频 | 成年人视频在线播放 | 欧美一级黄 | 91在线小视频 | 欧美丰满少妇 | 日韩精品一区二区在线 | 国产激情小说 | 国产又粗又猛视频免费 | av观看免费| 在线网站免费观看18 | 91在线精品秘密一区二区 |
