查看: 6265|回復: 1
stm8的C語言編程-基本程序與啟動代碼分析
stm8C語言編程(1)--基本程序與啟動代碼分析
現在幾乎所有的單片機都能用C語言編程了,采用C語言編程確實能帶來很多好處,至少可讀性比匯編語言強多了。
在STM8的開發環境中,可以通過新建一個工程,自動地建立起一個C語言的框架,生成后開發環境會自動生成2個C語言的程序,一個是main.c,另一個是stm8_interrupt_vector.c。main.c中就是一個空的main()函數,如下所示:
/* MAIN.C file
* Copyright (c)2002-2005 STMicroelectronics
main()
      while (1);
而在stm8_interrupt_vector.c中,就是聲明了對應該芯片的中斷向量,如下所示:
/*    BASICINTERRUPT VECTOR TABLE FOR STM8 devices
*  Copyright (c) 2007 STMicroelectronics
typedef void @far(*interrupt_handler_t)(void);
struct interrupt_vector {
      unsigned char interrupt_instruction;
      interrupt_handler_t interrupt_handler;
@far @interrupt voidNonHandledInterrupt (void)
      /* in order to detect unexpected events during development,
         it is recommended to set a breakpoint on the following instruction
      return;
extern void_stext();     /* startup routine */
struct interrupt_vectorconst _vectab[] = {
      {0x82, (interrupt_handler_t)_stext}, /* reset */
      {0x82, NonHandledInterrupt}, /* trap  */
      {0x82, NonHandledInterrupt}, /* irq0  */
      {0x82, NonHandledInterrupt}, /* irq1  */
      {0x82, NonHandledInterrupt}, /* irq2  */
      {0x82, NonHandledInterrupt}, /* irq3  */
      {0x82, NonHandledInterrupt}, /* irq4  */
      {0x82, NonHandledInterrupt}, /* irq5  */
      {0x82, NonHandledInterrupt}, /* irq6  */
      {0x82, NonHandledInterrupt}, /* irq7  */
      {0x82, NonHandledInterrupt}, /* irq8  */
      {0x82, NonHandledInterrupt}, /* irq9  */
      {0x82, NonHandledInterrupt}, /* irq10 */
      {0x82, NonHandledInterrupt}, /* irq11 */
      {0x82, NonHandledInterrupt}, /* irq12 */
      {0x82, NonHandledInterrupt}, /* irq13 */
      {0x82, NonHandledInterrupt}, /* irq14 */
      {0x82, NonHandledInterrupt}, /* irq15 */
      {0x82, NonHandledInterrupt}, /* irq16 */
      {0x82, NonHandledInterrupt}, /* irq17 */
      {0x82, NonHandledInterrupt}, /* irq18 */
      {0x82, NonHandledInterrupt}, /* irq19 */
      {0x82, NonHandledInterrupt}, /* irq20 */
      {0x82, NonHandledInterrupt}, /* irq21 */
      {0x82, NonHandledInterrupt}, /* irq22 */
      {0x82, NonHandledInterrupt}, /* irq23 */
      {0x82, NonHandledInterrupt}, /* irq24 */
      {0x82, NonHandledInterrupt}, /* irq25 */
      {0x82, NonHandledInterrupt}, /* irq26 */
      {0x82, NonHandledInterrupt}, /* irq27 */
      {0x82, NonHandledInterrupt}, /* irq28 */
      {0x82, NonHandledInterrupt}, /* irq29 */
在stm8_interrupt_vector.c中,除了定義了中斷向量表外,還定義了空的中斷服務程序,用于那些不用的中斷。當然在自動建立時,所有的中斷服務都是空的,因此,除了第1個復位的向量外,其它都指向那個空的中斷服務函數。
生成框架后,就可以用Build菜單下的Rebuild All對項目進行編譯和連接,生成所需的目標文件,然后就可以加載到STM8的芯片中,這里由于main()函數是一個空函數,因此沒有任何實際的功能。不過我們可以把這個框架對應的匯編代碼反出來,看看C語言生成的代碼,這樣可以更深入地了解C語言編程的特點。
生成的代碼包括4個部分,如圖1、圖2、圖3、圖4所示。
                        圖1
                        圖2
              圖3
               圖4
   圖1顯示的是從內存地址8000H開始的中斷向量表,中斷向量表中的第1行82008083H為復位后單片機運行的第1跳指令的地址。從表中可以看出,單片機復位后,將從8083H開始運行。其它行的中斷向量都指向同一個位置的中斷服務程序80D0H。
   圖2顯示的是3個字節,前2個字節8083H為復位后的第1條指令的地址,第3個字節是一個常量0,后面的啟動代碼要用到。
   圖3顯示的是啟動代碼,啟動代碼中除了初始化堆棧指針外,就是初始化RAM單元。由于目前是一個空的框架,因此在初始化完堆棧指針(設置成0FFFH)后,由于8082H單元的內容為0,因此程序就跳到了80B1H,此處是一個循環,將RAM單元從0到5初始化成0。然后由于寄存器X設置成0100H,就直接通過CALL main進入C的main()函數。
   圖4顯示的是main()函數和中斷服務函數,main()函數對應的代碼就是一個無限的循環,而中斷服務函數就一條指令,即中斷返回指令。
  通過分析,可以看出用C語言編程時,比匯編語言編程時,就是多出了一段啟動代碼。
ID:159044 發表于 2016-12-31 23:15 | 只看該作者
6686666
主站蜘蛛池模板: 欧美日韩国产精品 | 国产福利视频在线 | 欧美亚洲激情 | 国产传媒在线播放 | 国产午夜激情 | 国产免费一级片 | 精品日韩在线观看 | 免费a在线| 日韩国产综合 | 精品欧美在线 | 成人在线视频免费 | 一区二区三区四区精品 | 日韩亚洲欧美在线观看 | 永久黄网站色视频免费观看w | 欧美精品黄色 | 青青青操| 色黄视频在线观看 | 成人免费视频一区二区 | 久久黄色免费视频 | 日韩成人在线观看 | 亚洲精品在线视频 | 国产美女一区二区三区 | 亚洲成人一区 | 91免费网| 国产日韩在线播放 | 日日夜夜精品 | 欧美日韩免费看 | 亚洲欧美中文字幕 | 欧美一区二区三 | 黄色免费一级片 | 国产中文字幕一区 | 久久狠狠干 | 日韩黄网 | av手机天堂网 | 国产一级片免费看 | 亚洲国产欧美日韩在线 | 黄视频在线播放 | 国产草草 | 日韩在线中文字幕 | 一级二级片 | 日韩在线视频一区二区三区 |
