查看: 49511|回復: 98
基于51單片機的RC522的CPU卡(FM1208)的例程
ID:179677 發(fā)表于 2017-3-22 11:22 | 顯示全部樓層 |閱讀模式
使用51單片機,飛利浦RC522的射頻芯片,
讀寫CPU卡(復旦的FM1208)的例程,
PS: RC522模塊(淘寶上有賣7塊錢左右一個)
完整例程下載:
RC522_串口操作FM1208.rar (119.84 KB, 下載次數(shù): 887)
主程序預覽:
  1. #include   <STDIO.H>
  2. #include <string.h>
  3. #include "reg52.h"
  4. #include "main.h"
  5. #include "rc522.h"
  6. #include "1602.h"
  7. //////////////////CPU卡的指令/////////////////////////////////////////////////////////////////////////////////
  8. unsigned char code Keyfile[7] ={0x3F, 0x00, 0xB0, 0x01, 0xF0, 0xFF, 0xFF};        //建密鑰文件
  9. unsigned char code DefaultKey[8] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};  //原始外部密鑰
  10. unsigned char code ExKey[5]   ={0x39, 0xF0, 0xF0, 0xAA, 0x55};             ////外部密鑰建立的指令信息
  11. unsigned char code DFfile[13] ={0x38,0x05,0x20,0xF0,0xF0,0x95,0xFF,0xFF,0x44,0x44,0x46,0x30,0x31};//建立的DF文件
  12. unsigned char code EF_KEY_File[7]={0x3F, 0x01, 0x8F, 0x95, 0xF0, 0xFF, 0xFF};//建立EF密鑰文件
  13. unsigned char code C_KEY[8]={0x3A, 0xF0, 0xEF, 0x44, 0x55, 0x12, 0x34, 0x56};    //增加口令密鑰
  14. unsigned char code EF_File1[7]={0x28, 0x00, 0x1E, 0xF0, 0xF0, 0xFF, 0xFF};//        基本文件EF 建立的二進制文件1
  15. unsigned char code EF_File2[7]={0x28, 0x00, 0x0F, 0xF4, 0xF0, 0xFF, 0xFF};//        基本文件EF 建立的二進制文件2
  16. /////////////////////////////////////////////////////////////////////////////////////////////////////////////////
  17. //////////////////文件標識的定義/////////////////////////////////////////////////////////////////////////////////
  18. unsigned char code MF_File_Flag[2] = {0x3f,0x00};       //MF文件標識3F00//
  19. unsigned char code KEY_File_Flag[2] = {0x00,0x00};      //密鑰文件標識0000//
  20. unsigned char code KEY_Flag = {0x00};                //密鑰標識00,即放在MF下密鑰文件里面的密鑰,用1個字節(jié)表示 //
  21. unsigned char code DF_File_Flag[2] = {0x3f,0x01};       //DF文件標識3F01//
  22. unsigned char code KEY_DF_File_Flag[2] = {0x00,0x01};   //DF下的密鑰文件標識0001//
  23. unsigned char code Keyword_DF_Flag = {0x01};         //密鑰標識01,即放在DF下密鑰文件里面的密鑰,用1個字節(jié)表示 //
  24. unsigned char code EF_File3_Flag[2]        = {0x00,0x03};       //EF文件標識0003//
  25. unsigned char code EF_File4_Flag[2]        = {0x00,0x04};       //EF文件標識0004//
  26. //////////////////////////////////////////////////////////////////////////////////////////////////////////////////
  27. unsigned char xdata g_ucTempbuf[MAXRLEN];
  28. unsigned char  xdata Rec_Buf[MAXRLEN];        //接收到串口助手的數(shù)據(jù)緩存器
  29. unsigned char WorkInt;        //成功接收指令的標志
  30. unsigned char Cmd_Len;  //指令長度
  31. void delay1(unsigned int z)
  32. {
  33.         unsigned int x,y;
  34.         for(x=z;x>0;x--)
  35.         for(y=110;y>0;y--);
  36. }
  37. void UART_Init()
  38. {
  39. PCON|=0x80; //PCON的最高位SMOD=1時波特率加倍
  40. TMOD=0x20;  //時器1為方式2 初值自動裝入 產(chǎn)生波特率
  41. TH1=0xfd;   //定時器初始為0XFd,晶振為22.1184MHz,本函數(shù)實際產(chǎn)生的波特率為38400bps
  42. TL1=0xfd;         //同上
  43. SCON=0x50;         //串口設置為方式1,REN=1,允許接收
  44. TR1=1;      //啟動定時器1
  45. ES=1;       //使能串口接收中斷,
  46. EA=1;       //打開所有中斷
  47. }
  48. /**************************************************************************
  49. - 功能描述:51單片機的串口發(fā)送字節(jié)的函數(shù)
  50. - 隸屬模塊:STC51串口操作
  51. - 函數(shù)屬性:外部,使用戶使用
  52. - 參數(shù)說明:mydata:要發(fā)送的一個字節(jié)
  53. - 返回說明:無
  54. - 注:發(fā)送一個字節(jié),是串口發(fā)送的基礎操作
  55. **************************************************************************/
  56. void UART_Send_Byte(unsigned char mydata)
  57. {
  58. ES=0;
  59. TI=0;
  60. SBUF=mydata;
  61. while(!TI);
  62. TI=0;
  63. ES=1;
  64. }
  65. /**************************************************************************
  66. - 功能描述:51單片機的串口發(fā)送0d 0a ,即回車換行
  67. - 隸屬模塊:STC51串口操作
  68. - 函數(shù)屬性:外部,使用戶使用
  69. - 參數(shù)說明:無
  70. - 返回說明:無
  71. - 注:此函數(shù)就是發(fā)送0d 0a這兩個字節(jié),在“超級終端”上會有回車換行的效果
  72. **************************************************************************/
  73. void UART_Send_Enter()
  74. {
  75. UART_Send_Byte(0x0d);
  76. UART_Send_Byte(0x0a);
  77. }
  78. /**************************************************************************
  79. - 功能描述:51單片機的串口發(fā)送字符串
  80. - 隸屬模塊:STC51串口操作
  81. - 函數(shù)屬性:外部,使用戶使用
  82. - 參數(shù)說明:s:指向字符串的指針
  83. - 返回說明:無
  84. - 注:如果在字符串中有'\n',則會發(fā)送一個回車換行
  85. **************************************************************************/
  86. void UART_Send_Str(char *s)
  87. {
  88. int len=strlen(s)-1;
  89. int i;
  90. for(i=0;i<len;i++)
  91. UART_Send_Byte(s[i]);
  92. if(s[i]=='\n')
  93. {
  94.   UART_Send_Enter();
  95. }
  96. else
  97. {
  98.   UART_Send_Byte(s[i]);
  99. }
  100. }
  101. /////////////////////////////////////////////////////////////////////
  102. //串行中斷,接收串口助手發(fā)來的數(shù)據(jù)
  103. /////////////////////////////////////////////////////////////////////
  104. seri_int () interrupt 4 using 1
  105. {
  106. unsigned char len, i;
  107. unsigned int j=0;
  108.    if (RI)
  109.    {
  110.                 ES=0;
  111.                 len=SBUF;
  112.                 RI=0;
  113.                 for(i=0;i<len;i++)
  114.                 {
  115.                         while(!RI)
  116.                         {
  117.                                 j++;
  118.                                 if(j>1000)
  119.                                 {
  120.                                    ES=1;
  121.                                     break;
  122.                                 }
  123.                         }
  124.                         if(j<1000)
  125.                         {
  126.                                 Rec_Buf[i]=SBUF;
  127.                                 RI=0;
  128.                                 j=0;
  129.                         }
  130.                         else
  131.                         {
  132.                            ES=1;
  133.                             break;
  134.                         }
  135.                 }
  136.                 if(i==len)
  137.                 {
  138.                         ES=1;
  139.                         Cmd_Len=len;
  140.                         WorkInt  = 1;
  141.
  142.                 }
  143.     }
  144. }
  145.
  146. void u8tostr(unsigned char dat)
  147. {
  148. switch(dat>>4)         //高位
  149. {
  150.         case 0: UART_Send_Byte(0x30);  break;
  151.         case 1: UART_Send_Byte(0x31);  break;
  152.         case 2: UART_Send_Byte(0x32);  break;
  153.         case 3: UART_Send_Byte(0x33);  break;
  154.         case 4: UART_Send_Byte(0x34);  break;
  155.         case 5: UART_Send_Byte(0x35);  break;
  156.         case 6: UART_Send_Byte(0x36);  break;
  157.         case 7: UART_Send_Byte(0x37);  break;
  158.         case 8: UART_Send_Byte(0x38);  break;
  159.         case 9: UART_Send_Byte(0x39);  break;
  160.         case 0x0A: UART_Send_Byte(0x41);  break;
  161.         case 0x0B: UART_Send_Byte(0x42); break;
  162.         case 0x0C: UART_Send_Byte(0x43); break;
  163.         case 0x0D: UART_Send_Byte(0x44); break;
  164.         case 0x0E: UART_Send_Byte(0x45); break;
  165.         case 0x0F: UART_Send_Byte(0x46); break;
  166. }
  167. switch(dat&0x0f)        //低位
  168. {
  169.         case 0: UART_Send_Byte(0x30);  break;
  170.         case 1: UART_Send_Byte(0x31);  break;
  171.         case 2: UART_Send_Byte(0x32);  break;
  172.         case 3: UART_Send_Byte(0x33);  break;
  173.         case 4: UART_Send_Byte(0x34);  break;
  174.         case 5: UART_Send_Byte(0x35);  break;
  175.         case 6: UART_Send_Byte(0x36);  break;
  176.         case 7: UART_Send_Byte(0x37);  break;
  177.         case 8: UART_Send_Byte(0x38);  break;
  178.         case 9: UART_Send_Byte(0x39);  break;
  179.         case 0x0A: UART_Send_Byte(0x41);  break;
  180.         case 0x0B: UART_Send_Byte(0x42); break;
  181.         case 0x0C: UART_Send_Byte(0x43); break;
  182.         case 0x0D: UART_Send_Byte(0x44); break;
  183.         case 0x0E: UART_Send_Byte(0x45); break;
  184.         case 0x0F: UART_Send_Byte(0x46); break;
  185. }
  186.
  187. }
  188. void UART_Put_Num(unsigned char * dat,unsigned char len)
  189. {
  190.         unsigned char i;
  191.
  192.         for(i=0;i<len;i++)
  193.         {
  194.                 u8tostr(dat[i]);
  195.         }
  196.         UART_Send_Enter();
  197. }
  198. //////////////////////////////////////////////////////////////////////////////
  199. void main( )
  200. {
  201.         unsigned char status;
  202.         unsigned char tt[2];
  203.         unsigned int sst=0;
  204.            InitSystem( );
  205.          lcd1602_init();
  206.      RC522_Init();
  207.      PcdAntennaOff();
  208.      PcdAntennaOn();
  209.          display_welcome();
  210.          delay1(500);
  211.          BEEP=0;
  212.          delay1(100);
  213.          BEEP=1;
  214.           memset(g_ucTempbuf, 0x00, MAXRLEN); //清0
  215.           while(1)
  216.           {
  217.                    if(WorkInt)
  218.                    {
  219.                                 WorkInt=0;
  220.
  221.                                 if((Cmd_Len==1)&&(Rec_Buf[0]==0xAA))           //尋卡及復位只操作一次  約定指令為:01AA
  222.                                 {
  223.                                         Rec_Buf[0]=0;
  224.                                         Cmd_Len=0;
  225.                                         if(GetCard(PICC_REQALL,tt,g_ucTempbuf)!=ST_OK)  //尋卡函數(shù)
  226.                                         {
  227.                                                 UART_Send_Str("無卡!");
  228.                                                 UART_Send_Enter();
  229.                                                 continue;
  230.                                         }          //尋卡失敗返回
  231.
  232.
  233.                                         memset(g_ucTempbuf, 0x00, MAXRLEN);        //清0
  234.                                         if (CardReset(g_ucTempbuf,tt)!=ST_OK)                  //CPU卡復位函數(shù)
  235.                                         { continue; }
  236.                                         UART_Send_Str("復位成功!");
  237.                                         UART_Send_Str("返回ATS值:");
  238.                                         UART_Put_Num(g_ucTempbuf,tt[0]);         //串口助手顯示返回
  239.                                         UART_Send_Enter();
  240.                                         memset(g_ucTempbuf, 0x00, MAXRLEN);        //清0
  241.                                         BEEP=0;
  242.                                         delay1(500);
  243.                                         BEEP=1;
  244.                                         continue;
  245.                                 }
  246.                                 status=Pcd_Cmd(Rec_Buf, Cmd_Len, g_ucTempbuf,tt);
  247.                                 if(status)        //1時出錯了
  248.                                 {
  249.                                         Cmd_Len=0;
  250.                                         memset(Rec_Buf, 0x00, MAXRLEN);
  251.                                         memset(g_ucTempbuf, 0x00, MAXRLEN);        //清0
  252.                                         UART_Send_Str("操作失敗!");
  253.
  254.                                         UART_Send_Enter();
  255.                                         continue;                                                //返回
  256.                                 }
  257.
  258.                                 UART_Put_Num(&g_ucTempbuf[2],tt[0]);         //串口助手顯示返回狀態(tài)
  259.                                 BEEP=0;
  260.                                 delay1(100);
  261.                                 BEEP=1;
  262.                                 delay1(100);
  263.                                 BEEP=0;
  264.                                 delay1(100);
  265.                                 BEEP=1;
  266.
  267.                                 memset(g_ucTempbuf, 0x00, MAXRLEN);        //清0
  268.
  269.                    }
  270.           }
  271. }
  272. /////////////////////////////////////////////////////////////////////
  273. //系統(tǒng)初始化
  274. /////////////////////////////////////////////////////////////////////
  275. void InitSystem()
  276. {
  277.     P0 = P1 = P2 = P3 = 0xFF;
  278.         UART_Init();
  279. }
參與人數(shù) 3黑幣 +70 收起 理由
JACKLI + 15 共享資料的黑幣獎勵!
efefeq + 5 很給力!
ID:179677 發(fā)表于 2017-10-26 19:25 | 顯示全部樓層
開始的時候,我是用的M1卡的,那個很容易被破解的,為了安全考慮,后來采用的CPU卡,這個只是簡單的用串口操作的例程,實際應用中,外部密鑰我們一般是不會把次數(shù)設置成F的,像我的話,我一般設置成5次,這樣就不怕破解了,只要密碼不對,超過5次,卡被鎖死,就成廢品。某寶上賣的這個模塊,有些電感用的精度不高,CPU卡只能讀取個卡號,后面的操作做不了,至于硬件怎么接?好像模塊上都有絲印!自己怎么接的單片機,記得把對應的頭文件里設置成一樣的就行吧
參與人數(shù) 2黑幣 +85 收起 理由
n841115849 + 5 絕世好帖!
admin + 80 回帖助人的獎勵!
ID:179677 發(fā)表于 2017-11-15 17:36 | 顯示全部樓層
FM1208的09和10,其實兩種卡都能用,一種是純CPU卡,一種是CPU+M1卡!但是要注意的一點是,用那種含M1卡容量的,由于它的CPU容量要小一些,在建立DF文件,EF文件的時候,分配文件空間的時候就盡量別劃分的太大,不然可能會回復錯誤代碼(好象是6D01?我也不太記得了!)只要把對應的文件空間大小改小一些就可以!我兩種卡都買過,就算是同一家店買的同一批次的卡片的實際容量也有差別的,所以最好,根據(jù)自己的實際需求來,要用到多大的空間,就劃多大的
admin + 50 回帖助人的獎勵!
ID:210179 發(fā)表于 2017-6-11 17:53 | 顯示全部樓層
推一個
ID:210179 發(fā)表于 2017-6-11 17:56 | 顯示全部樓層
請問一下RC522可以複製卡片嗎?
ID:228989 發(fā)表于 2017-8-24 14:41 | 顯示全部樓層
感謝大神分享!
ID:230285 發(fā)表于 2017-8-31 16:54 | 顯示全部樓層
感謝大神分享!
ID:230293 發(fā)表于 2017-8-31 17:12 | 顯示全部樓層
學習一下
ID:230429 發(fā)表于 2017-9-1 15:45 | 顯示全部樓層
非常感謝分享!正在研究這個
ID:232405 發(fā)表于 2017-9-11 15:18 | 顯示全部樓層
CPU卡  可以完全防復制嗎?
ID:233809 發(fā)表于 2017-9-18 11:28 | 顯示全部樓層
給力,mark,等積分夠了下載看看,我目前也在搞CPU卡,卡在不知道發(fā)什么指令,怎么個過程讀CPU卡了
ID:234818 發(fā)表于 2017-9-22 10:15 | 顯示全部樓層
不是很詳細的吧!!!!
ID:234516 發(fā)表于 2017-9-26 22:40 | 顯示全部樓層
麻煩問下硬件是怎么連接的呢?
ID:234516 發(fā)表于 2017-9-26 23:08 | 顯示全部樓層
還有,有沒有程序現(xiàn)象的說明等等?謝謝了啊
ID:151356 發(fā)表于 2017-9-28 18:31 | 顯示全部樓層
cpu卡確實有很大的優(yōu)勢。
ID:244795 發(fā)表于 2017-11-1 00:00 | 顯示全部樓層
學習了!非常感謝分享!
ID:81808 發(fā)表于 2017-11-6 21:55 | 顯示全部樓層
FM1208有09和10兩個版本,不知樓主是哪個版本
ID:81808 發(fā)表于 2017-11-8 17:22 | 顯示全部樓層
我已經(jīng)證實了,是09版,也就是純CPU卡。已經(jīng)成功地讀取到ATS
ID:255421 發(fā)表于 2017-12-1 11:02 | 顯示全部樓層
非常感謝分享!
ID:268839 發(fā)表于 2017-12-29 14:32 | 顯示全部樓層
我也能讀取ATS,但是APDU操作不成功,怎么回事?
ID:229788 發(fā)表于 2017-12-29 17:22 | 顯示全部樓層
n841115849 發(fā)表于 2017-12-29 14:32
我的沒反應咋回事,我的晶振時11.0592的,我再串口調試助手測試了不同波特率,也沒反應,我的qq946736858,可以討論一下么,整這個好幾天了惱火啊
ID:271862 發(fā)表于 2018-1-5 12:00 | 顯示全部樓層
ID:261686 發(fā)表于 2018-1-11 17:04 | 顯示全部樓層
你的APDU指令能調了嗎??
ID:255063 發(fā)表于 2018-1-11 20:28 | 顯示全部樓層
CPU 卡是什么?
ID:276348 發(fā)表于 2018-1-21 22:52 | 顯示全部樓層
這個東西可以下來一用。
ID:261686 發(fā)表于 2018-1-22 20:08 | 顯示全部樓層
兄弟你APDU指令能調了嗎
ID:285608 發(fā)表于 2018-2-26 12:09 | 顯示全部樓層
不知道RC522還可以操作CPU卡,來看看能否借鑒一下
ID:285608 發(fā)表于 2018-2-27 15:21 | 顯示全部樓層
黑幣不夠,只能一天天的來刷了。
ID:68603 發(fā)表于 2018-3-25 15:49 | 顯示全部樓層
謝謝分享
ID:223788 發(fā)表于 2018-4-15 16:56 | 顯示全部樓層
這個不錯,先收下了
ID:310333 發(fā)表于 2018-4-17 19:35 | 顯示全部樓層
看一下 謝謝樓主分享
ID:308858 發(fā)表于 2018-4-18 20:02 | 顯示全部樓層
正好有用,可以參考一下了
ID:327558 發(fā)表于 2018-5-12 14:39 | 顯示全部樓層
很有幫助,感謝!
ID:309881 發(fā)表于 2018-5-15 18:48 | 顯示全部樓層
你好,樓主,我的到選卡都沒問題,到發(fā)送RATS時,無回復,一般這是啥情況
ID:325456 發(fā)表于 2018-5-26 13:02 | 顯示全部樓層
版主 ,請問 怎么 開始 測試IC卡
ID:268820 發(fā)表于 2018-6-5 14:44 | 顯示全部樓層
感謝分享
ID:369737 發(fā)表于 2018-7-13 17:18 | 顯示全部樓層
謝謝分享,這幾天都在弄這個東西,也基本沒什么頭緒,
ID:369737 發(fā)表于 2018-7-14 15:55 | 顯示全部樓層
東電逸仙 發(fā)表于 2018-5-26 13:02
版主 ,請問 怎么 開始 測試IC卡
同求,這個怎么驗證,希望能講解一下,謝謝
ID:367839 發(fā)表于 2018-8-14 15:08 | 顯示全部樓層
各位大哥還在不在,小弟最近用RC531在調CPU卡的數(shù)據(jù)交互,RATS已經(jīng)成功復位,但是進行數(shù)據(jù)交互不成功,這個問題困惑我好幾天了,有沒有大哥指點一下。
ID:336834 發(fā)表于 2018-10-5 16:43 | 顯示全部樓層
真的非常好用啊
主站蜘蛛池模板: 怡红院在线播放 | 欧美日韩免费一区二区三区 | 中文字幕在线看 | 神马午夜嘿嘿 | 日韩一区不卡 | 4438xxx| 久久人人爽人人爽人人片 | 午夜你懂的 | 嫩草视频在线观看 | 视频在线观看一区 | 91午夜理伦私人影院 | 亚洲最新网址 | 日本亚洲精品 | 深夜福利免费 | 亚洲久久在线 | 日本黄色片视频 | 亚洲国产黄色 | 日韩欧美在线一区 | 青草久久久 | 久久黄色影院 | 在线视频h| 日本黄色中文字幕 | 亚洲综合精品 | 欧美一级在线观看 | 色综合天天综合网国产成人网 | 欧美一级二级三级 | 亚洲免费成人 | 欧洲一区二区 | 成人免费视屏 | 成人h片在线观看 | 天天操夜夜爽 | 中日韩毛片 | 999国产视频 | 日韩精品在线一区二区 | 中文字幕不卡在线 | 国产精品国产成人国产三级 | 中文天堂在线观看 | 国产黄在线观看 | 免费av在线播放 | 久草资源站 | 自拍偷拍欧美日韩 |
