查看: 3035|回復: 1
定時中斷 固定頻率紅外線信號 長短接收控制
ID:53254 發表于 2017-4-8 18:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
最近在利用STM8 TIM4定時中斷 做一個固定頻率紅外線信號 長短接收控制LED燈 程序,但是就是執行不了,大俠們幫我看看,問題出在哪了?
描述:1. 紅外線(PWM方波)F=125HZ ,T=8ms , D=0.4;
         2. 單片機PC5口接收紅外信號;
         3. TIM4定時時間100 us;
         3. 先是判斷紅外信號頻率是否正確,然后根據接收信號時間的長短來控制不同LED燈亮滅。接收信號時間T_js:
             1) 短接收:T_js>3s時,LED1亮;2)長接收:0.2s<T_js<3s時,LED3亮。3)T_js<0.2s 無效
程序如下:
#define PT_INPUT_HIGH_COUNTER_MAX  40 //4ms
#define PT_INPUT_LOW_COUNTER_MAX 520  //5.2ms
#define PT_TRACE_PEROID_LOW_THRESHOLD   70 //7ms
#define PT_TRACE_PEROID_HIGH_THRESHOLD  90 //9ms
#define IR_SENSE_SHORT_PRESS_THRESHOLD  2000 //200ms
#define IR_SENSE_LONG_PRESS_THRESHOLD  30000  //3s
void PT91_Recv_Handle(void)
  static u8 flag = 0;   //反轉的標志
  //PT_Level_Read_Temp=GPIO_ReadInputPin(PT91_PORT,PT91_PIN);
  IR_Input_Level=GPIO_ReadInputPin(PT91_PORT,PT91_PIN);
  // PT_PIN Trace follow start
  if(IR_Input_Level==HIGH)//High
      if(PT_Input_High_Counter<PT_INPUT_HIGH_COUNTER_MAX)// prevent to flow
         PT_Input_High_Counter++;
         PT_Input_High_Counter=0;
  else//Low
      if(PT_Input_Low_Counter<PT_INPUT_LOW_COUNTER_MAX)// prevent to flow
         PT_Input_Low_Counter++;
         PT_Input_Low_Counter=0;
   // PT_PIN Trace follow end
   // PT_PIN wave peroid judge start
   PT_Trace_Peroid=PT_Input_Low_Counter+PT_Input_High_Counter;
   PT_Input_PR=PT_Trace_Peroid;
   if(PT_Trace_Peroid>PT_TRACE_PEROID_LOW_THRESHOLD && PT_Trace_Peroid<PT_TRACE_PEROID_HIGH_THRESHOLD) //trace success
      PT_Trace_Success_Counter++;
      if(PT_Trace_Success_Counter>IR_SENSE_LONG_PRESS_THRESHOLD)// long IR sensed
         Short_IR_sense_judge_state=NO;
         Long_IR_sense_judge_state=YES;
         PT_Trace_Success_Counter=0;
         // long IR sense handle
         LED1_L;
      else if(PT_Trace_Success_Counter>IR_SENSE_SHORT_PRESS_THRESHOLD)
         if(flag)
         Short_IR_sense_judge_state=YES;
         // short IR sense handle
         LED3_L;
       flag = !flag;
   else //trace fail
           Long_IR_sense_judge_state=NO;
     // PT_PIN wave peroid judge end
INTERRUPT_HANDLER(TIM4_UPD_OVF_IRQHandler, 23)
   /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
   TIM4_ClearITPendingBit(TIM4_IT_UPDATE);//清除更新標志位
   PT91_Recv_Handle();
ID:53254 發表于 2017-4-8 21:36 | 只看該作者
自己頂一下
主站蜘蛛池模板: 亚洲福利网站 | 天天躁日日躁狠狠躁 | 黄色片免费 | 日韩不卡一区二区 | 性视频在线 | 午夜性影院 | 欧美一区二区三区在线 | 久久久精品一区二区三区 | 中文字幕超清在线观看 | 在线观看视频一区二区 | 成 人 黄 色 片 在线播放 | 二区三区视频 | www国产亚洲精品久久网站 | 欧美日韩a | 欧美一级片 | 免费日韩视频 | 国产一级片网站 | 四虎影院最新网址 | 欧美日韩国产激情 | 国产成人免费在线 | 国产乱码一区二区三区 | 国产一区精品视频 | www.伊人网| 成人免费视频国产免费 | 日韩视频在线观看 | 亚洲精品中文字幕乱码三区91 | 三级网站| 一区二区三区免费 | 中文字幕精品在线观看 | 亚洲成人精品视频 | 午夜性色 | 久久18| 久久午夜剧场 | 国产人成一区二区三区影院 | 中文字幕一二三四区 | 特黄aaaaaaaaa真人毛片 | 欧美在线免费观看 | 夜夜嗨av一区二区三区 | 日韩av免费在线播放 | av基地网 | 青青草久久 |
