查看: 5758|回復: 0
DS18B20溫度傳感器的protues模擬
#include<reg52.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit wela = P2^0;
sbit dula = P2^1;
sbit IO_18B20 = P2^2;  //DS18B20通信引腳
uint temp;
uchar code table[]={0x3f,0x06,0x05b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint ms) // ms延時函數 (AT89C51 @ 11.0592MHz)
        unsigned int i;
        unsigned char j;
        for(i=0;i<ms;i++)
                for(j=0;j<200;j++);
                for(j=0;j<102;j++);
/* 軟件延時函數,延時時間(t*10)us */
void DelayX10us(unsigned char t)
    do {
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
    } while (--t);
bit Get18B20Ack()
        bit ack;
        EA = 0;
        IO_18B20 = 0;
        DelayX10us(50);
        IO_18B20 = 1;
        DelayX10us(6);
        ack = IO_18B20;
        while(!IO_18B20);
        DelayX10us(6);
        EA = 1;
        return ack;
void  Write18B20(unsigned char dat)
        unsigned char mask;
        EA = 0;
        for(mask=0x01; mask!= 0; mask<<=1)
                IO_18B20 = 0;
                _nop_();
                _nop_();
                //_nop_();
                if((mask&dat) == 0)
                        IO_18B20 = 0;
                        IO_18B20 = 1;
                DelayX10us(6);
                IO_18B20 = 1;
                _nop_();
                _nop_();
                _nop_();
        EA = 1;
unsigned char Read18B20()
        unsigned char dat;
        unsigned char mask;
        EA = 0;
        for(mask=0x01; mask!=0; mask<<=1)
                IO_18B20 = 0;
                _nop_();
                _nop_();
                //_nop_();
                IO_18B20 = 1;
                _nop_();
                _nop_();
                _nop_();
                if(!IO_18B20)
                        dat &= ~mask;
                        dat |= mask;
                DelayX10us(6);
        EA = 1;
        return dat;
bit Start18B20()
        bit ack;
        ack = Get18B20Ack();
        if(ack == 0)
                Write18B20(0xCC);
                Write18B20(0x44);
        return ~ack;
bit Get18B20Temp(uint *temp)
        bit ack;
        unsigned char LSB, MSB;
        if(ack == 0)
                Write18B20(0xCC);
                Write18B20(0xBE);
                LSB = Read18B20();
                MSB = Read18B20();
                *temp = ((int)MSB<<8) + LSB;
        return ~ack;
void display(uint num)
        uchar i;
        for(i=0;i<6;i++)
                //位選
                P0 = ~(0x1<<i);
                wela = 1;
                wela = 0;
                //段選
                P0 = table[num%10];
                dula = 1;
        dula = 0;
                num=num/10;
                //去除前面為0的位
                if(num==0)
                        i=6;
                delay(3);
        uint tmp;
                  if(Start18B20())
                        if(Get18B20Temp(&temp))
                                tmp=temp;
                                tmp=tmp>>4;
                                tmp=tmp&0xFF;
                                display(tmp);
主站蜘蛛池模板: 大尺度性做爰的小说金陵春 | 日韩影院在线观看 | 中文字幕亚洲一区 | 日本不卡一区二区 | 在线成人小视频 | 免费观看毛片 | 黄色网页免费 | 天天综合色| 中文在线字幕 | 四虎新网址 | 夜夜嗨av一区二区三区网页 | 亚洲欧美日韩在线 | 精品成人在线 | a级片免费在线观看 | 成人精品三级av在线看 | 超碰91在线 | 69福利视频 | 亚洲一级黄色片 | 亚洲成人一区二区三区 | 99精品久久久久久中文字幕 | 国产传媒在线观看 | 国产区在线视频 | www.成人网 | 日韩在线观看 | 午夜a级片| 亚洲国产精品久久久久久久 | www.桃色| 日韩欧美黄色 | 欧美色影院 | 亚洲欧美日韩一区二区三区四区 | 少妇福利视频 | 欧美特黄 | 久久久久久久久久国产 | 黄色在线观看免费 | 91久久久精品 | 午夜一区二区三区 | 欧美成人极品 | 国产在线一区二区 | 免费视频国产 | 日韩一区二区在线视频 | 国产成人免费视频 |
