查看: 8241|回復: 6
請教大神:GY-VL53L0X激光模塊ARDUINO源碼串口輸出數據的意義?
ID:177184 發表于 2017-4-20 08:56 | 顯示全部樓層 |閱讀模式
18黑幣
GY-VL53L0X激光模塊
在串口輸出一下數據:
----- START TEST ----
Revision ID: 16
Device ID: 238
PRE_RANGE_CONFIG_VCSEL_PERIOD=7
decode: 16
FINAL_RANGE_CONFIG_VCSEL_PERIOD=5
decode: 12
ready
ambient count: 30
signal count: 569
distance 1800
status: 11
----- END TEST ----
其中distance 指的應該是距離,請教各位大神:其它量“ambient coun”、“signal count”、“status”、” decode“指的是什么?
附Arduino源碼:
//the original code by Ted Meyers
//posted here: https://groups.google.com/d/msg/ ... ZYuJOg/ICPrYNJGBgAJ
#include <Wire.h>
#define VL53L0X_REG_IDENTIFICATION_MODEL_ID         0xc0
#define VL53L0X_REG_IDENTIFICATION_REVISION_ID      0xc2
#define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD   0x50
#define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x70
#define VL53L0X_REG_SYSRANGE_START                  0x00
#define VL53L0X_REG_RESULT_INTERRUPT_STATUS         0x13
#define VL53L0X_REG_RESULT_RANGE_STATUS             0x14
#define address 0x29
byte gbuf[16];
void setup() {
  // put your setup code here, to run once:
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Serial.println("VLX53LOX test started.");
void loop() {
  Serial.println("----- START TEST ----");
  test();
  Serial.println("----- END TEST ----");
  Serial.println("");
  delay(1000);
void test() {
  byte val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_REVISION_ID);
  Serial.print("Revision ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_MODEL_ID);
  Serial.print("Device ID: "); Serial.println(val1);
  val1 = read_byte_data_at(VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("PRE_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
  val1 = read_byte_data_at(VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD);
  Serial.print("FINAL_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  write_byte_data_at(VL53L0X_REG_SYSRANGE_START, 0x01);
  byte val = 0;
  int cnt = 0;
  while (cnt < 100) { // 1 second waiting time max
    delay(10);
    val = read_byte_data_at(VL53L0X_REG_RESULT_RANGE_STATUS);
    if (val & 0x01) break;
    cnt++;
  if (val & 0x01) Serial.println("ready"); else Serial.println("not ready");
  read_block_data_at(0x14, 12);
  uint16_t acnt = makeuint16(gbuf[7], gbuf[6]);
  uint16_t scnt = makeuint16(gbuf[9], gbuf[8]);
  uint16_t dist = makeuint16(gbuf[11], gbuf[10]);
  byte DeviceRangeStatusInternal = ((gbuf[0] & 0x78) >> 3);
  Serial.print("ambient count: "); Serial.println(acnt);
  Serial.print("signal count: ");  Serial.println(scnt);
  Serial.print("distance ");       Serial.println(dist);
  Serial.print("status: ");        Serial.println(DeviceRangeStatusInternal);
uint16_t bswap(byte b[]) {
  // Big Endian unsigned short to little endian unsigned short
  uint16_t val = ((b[0] << 8) & b[1]);
  return val;
uint16_t makeuint16(int lsb, int msb) {
    return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void write_byte_data(byte data) {
  Wire.beginTransmission(address);
  Wire.write(data);
  Wire.endTransmission();
void write_byte_data_at(byte reg, byte data) {
  // write data word at address and register
  Wire.write(reg);
  Wire.write(data);
void write_word_data_at(byte reg, uint16_t data) {
  byte b0 = (data &0xFF);
  byte b1 = ((data >> 8) && 0xFF);
  Wire.write(reg);
  Wire.write(b0);
  Wire.write(b1);
byte read_byte_data() {
  Wire.requestFrom(address, 1);
  while (Wire.available() < 1) delay(1);
  byte b = Wire.read();
  return b;
byte read_byte_data_at(byte reg) {
  //write_byte_data((byte)0x00);
  write_byte_data(reg);
  return b;
uint16_t read_word_data_at(byte reg) {
  Wire.requestFrom(address, 2);
  while (Wire.available() < 2) delay(1);
  gbuf[0] = Wire.read();
  gbuf[1] = Wire.read();
  return bswap(gbuf);
void read_block_data_at(byte reg, int sz) {
  int i = 0;
  Wire.requestFrom(address, sz);
  for (i=0; i<sz; i++) {
    gbuf = Wire.read();
uint16_t VL53L0X_decode_vcsel_period(short vcsel_period_reg) {
  // Converts the encoded VCSEL period register value into the real
  // period in PLL clocks
  uint16_t vcsel_period_pclks = (vcsel_period_reg + 1) << 1;
  return vcsel_period_pclks;
ID:212906 發表于 2017-6-21 17:26 | 顯示全部樓層
請問,你的問題得到解決了么?最近也在搞這個,現在我測得的距離不太對,distance在距離近時直接變成20,status也在11和8之間跳。。。。。沒法用啊
ID:218037 發表于 2017-7-8 09:20 | 顯示全部樓層
會灰的魚 發表于 2017-6-21 17:26
請問,你的問題得到解決了么?最近也在搞這個,現在我測得的距離不太對,distance在距離近時直接變成20,st ...
您好,我想請教一下,這款傳感器的x和G接口需要接嗎   還有是直接用帶的針插進去就可以了么
ID:237173 發表于 2017-10-7 16:44 | 顯示全部樓層
您好,我也想問一些,這些引腳是怎么連的。我的串口輸出不了這些數據
ID:246093 發表于 2017-11-6 20:48 | 顯示全部樓層
兄弟,你會濾波嗎  QQ390643675
留下你的聯系方式行嗎
ID:288954 發表于 2018-3-7 22:29 | 顯示全部樓層
是這款模塊嗎?注意PS這個針腳,接地是IIC模式,不接地是串口模式!
ID:137100 發表于 2018-4-11 17:40 | 顯示全部樓層
請問是怎么接線呢
主站蜘蛛池模板: aaa成人| 五月天婷婷在线观看 | 一本到av | 日韩欧美精品一区 | 国产成人三级一区二区在线观看一 | a毛片在线观看 | 91视频亚洲| 欧美日韩精品在线 | 日日夜夜艹 | 日韩成人精品视频 | 免费一级大片 | 最近日本中文字幕 | 精品国产一区二区在线观看 | 久久精品在线观看 | 国产美女精品视频 | 一级黄色片免费观看 | 欧美日韩成人 | 中文字幕一级片 | 日韩精品少妇 | 99热精品在线观看 | 久热综合| 黄色免费短视频 | 超碰97av | www.伊人网 | 一区二区三区在线观看免费 | 国产亚洲欧美日韩高清 | 日韩a在线 | 成人欧美一区二区三区白人 | 日韩黄色影院 | 色涩av| 久久免费视频观看 | 精品日韩一区二区 | 黄色国产在线观看 | 黄色片视频 | 中文字幕一区二区在线播放 | 亚洲国产第一页 | 日韩久久网 | jlzzzjlzzz国产免费观看 | 国产美女视频 | 91网在线 | 老女人丨91丨九色 |
