查看: 7115|回復(fù): 2
vl5310x 激光傳感器
ID:183944 發(fā)表于 2017-3-27 21:07 | 顯示全部樓層 |閱讀模式
程序/* This example shows how to get single-shot range
measurements from the VL53L0X. The sensor can optionally be
configured with different ranging profiles, as described in
the VL53L0X API user manual, to get better performance for
a certain application. This code is based on the four
"SingleRanging" examples in the VL53L0X API.
The range readings are in units of mm. */
#include <Wire.h>
#include <VL53L0X.h>
VL53L0X sensor;
// Uncomment this line to use long range mode. This
// increases the sensitivity of the sensor and extends its
// potential range, but increases the likelihood of getting
// an inaccurate reading because of reflections from objects
// other than the intended target. It works best in dark
// conditions.
//#define LONG_RANGE
// Uncomment ONE of these two lines to get
// - higher speed at the cost of lower accuracy OR
// - higher accuracy at the cost of lower speed
//#define HIGH_SPEED
//#define HIGH_ACCURACY
void setup()
  Serial.begin(9600);
  Wire.begin();
  sensor.init();
  sensor.setTimeout(500);
#if defined LONG_RANGE
  // lower the return signal rate limit (default is 0.25 MCPS)
  sensor.setSignalRateLimit(0.1);
  // increase laser pulse periods (defaults are 14 and 10 PCLKs)
  sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodPreRange, 18);
  sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodFinalRange, 14);
#endif
#if defined HIGH_SPEED
  // reduce timing budget to 20 ms (default is about 33 ms)
  sensor.setMeasurementTimingBudget(20000);
#elif defined HIGH_ACCURACY
  // increase timing budget to 200 ms
  sensor.setMeasurementTimingBudget(200000);
#endif
void loop()
  Serial.print(sensor.readRangeSingleMillimeters());
  if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
  Serial.println();
相關(guān)帖子
ID:216250 發(fā)表于 2017-7-1 00:28 | 顯示全部樓層
本帖最后由 ChristinaAPI 于 2017-7-1 03:19 編輯
Can we see what your .h files you're using look like?
#include <wire.h>
Edit:
Nevermind I think I found the sample you mentioned here: https://github.com/pololu/vl53l0x-arduino
Thank you so much for this post it really helped out alot !!
參與人數(shù) 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
ID:1 發(fā)表于 2017-7-1 03:27 | 顯示全部樓層
ChristinaAPI 發(fā)表于 2017-7-1 00:28
#include
And thanks to American friends, too
也很感謝美國的的朋友
主站蜘蛛池模板: 性做久久久久久久免费看 | 欧美精品日韩 | 免费看黄色网址 | 欧美黑人一区二区三区 | 欧美在线 | 亚洲一级黄色片 | 久久午夜视频 | 国产欧美一区二区三区视频在线观看 | 亚洲经典av | 亚洲精品在线看 | 国产精品嫩草影院桃色 | 欧美视频久久 | 亚洲一区二区欧美 | 不卡免费视频 | 午夜在线小视频 | 国产日韩精品在线 | 亚洲网站在线 | 免费日韩视频 | 亚洲va | 天天干天天做 | 日韩av资源 | 精品在线观看视频 | 毛片视频免费 | 二区三区在线观看 | 天天射天天舔 | 日本视频在线播放 | 黄色www. | 国产精品一区在线观看 | 91av在线看 | 国产做受视频 | 欧美成人毛片 | 一区二区不卡视频 | 免费国产一区 | 精品久久久久久久久久久 | 久久久久久久av | 国产亚洲欧美一区二区 | 国产三级在线观看视频 | 亚洲精品社区 | 日本黄色片视频 | 五月婷婷六月天 | 欧美在线免费观看视频 |
