查看: 3434|回復: 0
當距離變化過快這個程序就不執行電機的程序了,測量和顯示還是可以進行的
ID:194551 發表于 2017-5-28 18:44 | 顯示全部樓層 |閱讀模式
附上程序
#include "reg52.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 12000000L          //系統頻率
#define BAUD 115200             //串口波特率
#define uint unsigned int
#define uchar unsigned char
#define Busy    0x80 //用于檢測LCM狀態字中的Busy標識
//////液晶屏數據口///////
sbit LCM_RS  =P2^0;//定義液晶屏信號引腳
sbit LCM_RW  =P2^1;
sbit LCM_E   =P2^2;
#define LCM_Data  P0//液晶數端口
unsigned char code uctech[] = {"0123456789ABCDEF:"};
sfr AUXR  = 0x8e;               //輔助寄存器
#define T1MS (65536-FOSC/8000)      //1000MS模式
sbit ONA                =P2^3;//電機1A
sbit ONB                =P2^4;//電機1B
sbit ONC                =P2^6;//電機2A
sbit OND                =P2^7;//電機2B
sbit Echo1              =P3^2;//超聲波數據
sbit Trig1              =P2^5;//超聲波啟動
void delay(unsigned int z)//延時
   unsigned int x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
//1ms延時
void Delay5Ms(void)
   delay(5);
void WriteDataLCM(unsigned char WDLCM)
//ReadStatusLCM(); //檢測忙
LCM_RS = 1;
LCM_Data = WDLCM;
Delay5Ms();
LCM_RW = 0;
LCM_E = 1; //若晶振速度太高可以在這后加小的延時
Delay5Ms();
LCM_E = 0; //延時
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
//if (BuysC) ReadStatusLCM(); //根據需要檢測忙
LCM_RS = 0;
LCM_Data = WCLCM;
Delay5Ms();
LCM_RW = 0;
LCM_E = 1;
Delay5Ms();
LCM_E = 0;
#if 0
//讀數據
unsigned char ReadDataLCM(void)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態
unsigned char ReadStatusLCM(void)
LCM_Data = ~0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
#endif
void LCMInit(uchar i) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設置,不檢測忙信號
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
WriteCommandLCM(0x08,1); //關閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標移動設置
WriteCommandLCM(i,1); // 顯示開及光標設置
void LCMInitc(uchar i)
WriteCommandLCM(0x06,0); //光標歸位
WriteCommandLCM(i,0); //關光標,閃爍
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData,uchar i)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X,0); //這里不檢測忙信號,發送地址碼
LCMInitc(i);
Delay5Ms();
LCMInitc(0x0c);
WriteDataLCM(DData);
//按指定位置顯示一串字符
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x20) //若到達字串尾則退出
   if (X <= 0xF) //X坐標應小于0xF
     DisplayOneChar(X, Y,DData[ListLength],0x0c); //顯示單個字符
     ListLength++;
     X++;
void tim0init()
    //AUXR |= 0x80;                   //定時器0為1T模式
    TMOD = 0x00;                    //設置定時器為模式0(16位自動重裝載)
    TL0 = 0x66;                  //初始化計時值
    TH0 = 0xfc;
    TR0 = 1;                        //定時器0開始計時
    ET0 = 1;                        //使能定時器0中斷
     TMOD|=0x11;                   //設T1為方式1,GATE=1;
         EA=1;                           //開啟總中斷
         TH1=0;
         TL1=0;
         ET1=1;             //允許T1中斷
         TR1=0;
     EA = 1;
WORD U16FLAG;
unsigned int time_c,Dista1;
unsigned char timeH,timeL;
bit succeed_flag;
void  StartModule()
//    unsigned int distance;
     #if 1
         Trig1=1;   //啟動模塊
         delay(1);
         Trig1=0;
     U16FLAG=58477;
     while((!Echo1)&&U16FLAG++);
     TR1=1;                            //開啟計數
     U16FLAG=58477;
     while((Echo1)&&U16FLAG++);
     TR1=0;
         time_c=TH1*256+TL1;
         TH1=0;
         TL1=0;
         Dista1=(time_c*1.7)/100;//算出來是CM
         delay(50);
         #endif
void timer1() interrupt 3 using 1
  TH0=0;
  TL0=0;                                                         //中斷溢出標志
uint tim0[20];
//定時器中斷
void tm0_isr() interrupt 1 using 1
        tim0[0]++;
   if(Dista1>110)//加速正轉
   tim0[3]=(Dista1-80);
   tim0[2]=65536-FOSC/(tim0[3]*200);
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
          case 1: ONA=0;ONB=1;ONC=1;OND=1;break;
          case 2: ONA=1;ONB=0;ONC=1;OND=1;break;
          case 3: ONA=1;ONB=1;ONC=0;OND=1;break;
          case 4: ONA=1;ONB=1;ONC=1;OND=0;tim0[0]=0; break;
   if(Dista1>80&&Dista1<140)//勻速正轉
     tim0[2]=65536-FOSC/3000;
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
    else if(Dista1<=20)//加速反轉
       tim0[3]=(50-Dista1) ;
          TL0=tim0[2];
          TH0=tim0[2]>>8;
      switch(tim0[0])
          case 1: ONA=1;ONB=1;ONC=0;OND=1;break;
          case 3: ONA=0;ONB=1;ONC=1;OND=1;break;
          case 4: ONA=1;ONB=1;ONC=1;OND=0;tim0[0]=0;break;
  else if(Dista1<=50)//勻速反轉
          TL0=tim0[2];
          TH0=tim0[2]>>8;
      switch(tim0[0])
  else if(Dista1>50&&Dista1<80)//不轉
    ONA=1;ONB=1;ONC=1;OND=1;
    tim0[0]=0;
   else if(Dista1>140)//         勻速轉
         tim0[2]=65536-FOSC/6000;
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
    tim0init();
        LCMInit(0x0c); //LCM初始化
    Delay5Ms(); //延時片刻(可不要
    DisplayListChar(8, 1,"C");//在指定,列顯示字符串
           DisplayListChar(9, 1,"M");//在指定,列顯示字符串
          StartModule();
          DisplayOneChar(4,1,uctech[Dista1/1000%10],0x0c);//顯示個位
      DisplayOneChar(5,1,uctech[Dista1/100%10],0x0c);//顯示個位
      DisplayOneChar(6,1,uctech[Dista1/10%10],0x0c);//顯示個位
      DisplayOneChar(7,1,uctech[Dista1%10],0x0c);//顯示個位
主站蜘蛛池模板: 国产成人久久精品麻豆二区 | 成人国产精品视频 | 欧美综合激情 | 韩国黄色网址 | 久久伊人网站 | 欧美精品www | 黄色片亚洲 | 在线一区视频 | 在线播放黄色 | 91福利网 | 久久精品美女 | 成人欧美一区二区三区黑人孕妇 | 91日韩欧美 | 福利在线观看 | 久久久九九| 日本亚洲精品 | 91亚色视频| 超碰av在线| av中文在线| 欧美一二 | av综合网站| 91小视频在线观看 | 国产又黄又爽视频 | 国产午夜三级一区二区三 | 婷婷久久五月天 | 高清国产mv在线观看 | 国产精品国产精品国产专区不卡 | 欧美成视频 | 黄色国产精品 | 日产久久视频 | 精品三级在线观看 | 欧美视频免费看 | 成人免费福利 | av手机天堂 | 国产精品美女久久 | 日韩视频中文字幕 | 就要干就要操 | 人人看人人草 | 毛片www | 91麻豆精品国产91久久久久久久久 | 亚洲国产日韩在线 |
