查看: 3108|回復: 0
分享一個可調時的基于51單片機時鐘芯片1302控制1602的程序,key1功能鍵,key2上調
ID:211302 發表于 2017-6-14 20:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar a,miao,shi,fen,ri,yue,nian,week,flag,temp,key1n;
#define yh 0x80  //第一行的初始位置
#define er 0x80+0x40 //第二行初始位置
//sbit dula=P2^6;
//sbit wela=P2^7;
sbit wr=P2^1;
sbit rs=P2^0;
sbit en=P2^2;
sbit SCLK=P2^3;
sbit IO=P2^4;
sbit RST=P2^5;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit key=P1^3;
sbit key1=P1^7;
sbit key2=P1^6;
sbit key3=P1^5;
sbit key4=P1^4;
sbit beep=P1^0;
uchar code tab1[]={"2017-  -  "};
uchar code tab3[]={"WeeK-1"};
uchar code tab4[]={"LOVE"};
uchar code tab2[]={"  :  :  "};
void delay(uint xms)//延時函數
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
/******************液晶寫入************************/
write_1602com(uchar com)//液晶寫入指令函數
        rs=0;//置為寫入命令
        P0=com;//送入數據
        delay(1);
        en=1;//拉高使能端
        delay(1);
        en=0;//完成高脈沖
write_1602dat(uchar dat)
        rs=1;//置為寫入數據
        P0=dat;//送入數據
        delay(1);
        en=1;
        delay(1);
        en=0;
/*********************over***********************/
/********************ds1302****************************/
void write_byte(uchar dat)
        ACC=dat;
        RST=1;
        for(a=8;a>0;a--)
                IO=ACC0;
                SCLK=0;
                SCLK=1;
                ACC=ACC>>1;
uchar read_byte()
        RST=1;
        for(a=8;a>0;a--)
                ACC7=IO;
                SCLK=1;
                SCLK=0;
                ACC=ACC>>1;
        return (ACC);
void write_1302(uchar add,uchar dat)
        RST=0;
        SCLK=0;
        RST=1;
        write_byte(add);
        write_byte(dat);
        SCLK=1;
        RST=0;
uchar read_1302(uchar add)
        uchar temp;
        RST=0;
        SCLK=0;
        RST=1;
        write_byte(add);
        temp=read_byte();
        SCLK=1;
        RST=0;
        return(temp);
uchar BCD_Decimal(uchar bcd)
uchar Decimal;
Decimal=bcd>>4;
return(Decimal=Decimal*10+(bcd&=0x0F));
void ds1302_init()
RST=0;
SCLK=0;
write_1302(0x80,miao|0x00);//允許寫
void write_sfm(uchar add,uchar dat)//寫時分秒
        uchar gw,sw;
        gw=dat%10;
        sw=dat/10;
        write_1602com(er+add);
        write_1602dat(0x30+sw);
        write_1602dat(0x30+gw);
void write_nyr(uchar add,uchar dat)
        uchar gw,sw;
        gw=dat%10;
        sw=dat/10;
        write_1602com(yh+add);
void write_week(uchar week)//寫星期函數
        write_1602com(er+5);
        switch(week)
                case 1:write_1602dat('1');//delay(5);
//                           write_1602dat('O');//delay(5);
//                           write_1602dat('N');
                           break;
                case 2:write_1602dat('2');//delay(5);
//                           write_1602dat('U');//delay(5);
//                           write_1602dat('E');
                           break;
                case 3:write_1602dat('3');//delay(5);
//                           write_1602dat('E');//delay(5);
//                           write_1602dat('D');
                           break;
                case 4:write_1602dat('4');//delay(5);
//                           write_1602dat('H');//delay(5);
                           break;
                case 5:write_1602dat('5');//delay(5);
//                           write_1602dat('R');//delay(5);
//                           write_1602dat('I');
                           break;
                case 6:write_1602dat('6');//delay(5);
//                           write_1602dat('T');//delay(5);
//                           write_1602dat('A');
                           break;
                case 7:write_1602dat('7');//delay(5);
                           break;
lcd_init()//液晶初始化函數
{       wr=0;
        write_1602com(0x38);//設置液晶工作模式
        write_1602com(0x0c);//開顯示不顯示光標
        write_1602com(0x06);//整屏不移動,指針加一
        write_1602com(0x01);
        write_1602com(yh+6);//字符寫入的位置
        for(a=0;a<10;a++)
        write_1602dat(tab1[a]);
        //delay(3);
        write_1602com(er+8);
        for(a=0;a<8;a++)
        write_1602dat(tab2[a]);
        //delay(3);
        write_1602com(yh);
        for(a=0;a<4;a++)
        { write_1602dat(tab4[a]);
        write_1602com(er);
        for(a=0;a<6;a++)
        {  write_1602dat(tab3[a]) ;
void keyscan()
   key=0;
        if(key1==0)//key1為功能鍵
        delay(5);
        if(key1==0)
        while(!key1);
        key1n++;
        if(key1n==9)
                key1n=1;
        switch(key1n)
        case 1: TR0=0;//關閉定時器
                        //TR1=0;
                        write_1602com(er+0x0f);//寫入光標位置
                           write_1602com(0x0f);//設置光標為閃爍
                           temp=(miao)/10*16+(miao)%10;
                           write_1302(0x8e,0x00);
                           write_1302(0x80,0x80|temp);//miao
                           write_1302(0x8e,0x80);
                        beep=0;
                        delay(50);
                        beep=1;
                           break;
        case 2:  write_1602com(er+0x0c);//fen
                                 beep=0;
                        delay(50);
                        beep=1;
                     //write_1602com(0x0f);
                        break;
        case 3: write_1602com(er+9);//shi
                             beep=0;
                        delay(50);
                        beep=1;//write_1602com(0x0f);
                        break;
        case 4: write_1602com(er+5);//week
                             beep=0;
                        delay(50);
                        break;
        case 5: write_1602com(yh+0x0f);//ri
                            beep=0;
                        delay(50);
                        beep=1; //write_1602com(0x0f);
                        break;
        case 6: write_1602com(yh+0x0c);//yue
                            beep=0;
                        delay(50);
                        break;
        case 7: write_1602com(yh+0x09);//nian
                             beep=0;
                        delay(50);
                        break;
        case 8:
                        write_1602com(0x0c);//設置光標不閃爍
                        TR0=1;//打開定時器
                           write_1302(0x80,0x00|temp);//miao
                        beep=0;
                        delay(50);
                        beep=1;
            break;
        if(key1n!=0)//當key1按下以下。再按以下鍵才有效
        if(key2==0)  //上調鍵
        delay(5);
        if(key2==0)
        while(!key2);
        switch(key1n)
        case 1:miao++;
                        if(miao==60)
                                miao=0;
                        write_sfm(0x0e,miao);//寫入新的秒數
                        write_1602com(er+0x0f);//因為設置液晶的模式是寫入數據后,指針自動加一,在這里是寫回原來的位置
                                beep=0;
                        delay(50);
                        beep=1;//write_1602com(0x0b);
                        break;
        case 2:fen++;
                        if(fen==60)
                                fen=0;
                        write_sfm(0x0b,fen);
                        temp=(fen)/10*16+(fen)%10;
                           write_1302(0x82,temp);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        case 3:shi++;
                        if(shi==24)
                                shi=0;
                        write_sfm(8,shi);
                        temp=(shi)/10*16+(shi)%10;
                           write_1302(0x84,temp);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        case 4:week++;
                        if(week==8)
                                week=0;
                                write_week(week);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        case 5:ri++;
                        if(ri==31)
                                ri=0;
                        write_nyr(14,ri);
                        temp=(ri)/10*16+(ri)%10;
                           write_1302(0x86,temp);
                        write_1602com(yh+15);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        case 6:yue++;
                        if(yue==13)
                                yue=0;
                        write_nyr(11,yue);
                        temp=(yue)/10*16+(yue)%10;
                           write_1302(0x88,temp);
                        write_1602com(yh+12);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        case 7:nian++;
                 if(nian==100)
                        nian=0;
                        write_nyr(8,nian);
                        write_1602com(yh+9);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
        if(key3==0)
        delay(5);
        if(key3==0)
        while(!key3);
        switch(key1n)
                case 1:miao--;
                                if(miao==-1)
                                        miao=59;
                                beep=0;
                        delay(50);
                        break;
                case 2:fen--;
                                if(fen==-1)
                                        fen=59;
                        write_sfm(11,fen);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
                case 3:shi--;
                           if(shi==-1)
                                        shi=23;
                        write_sfm(8,shi);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
                case 4:week--;
                                if(week==-1)
                                        week=7;
                        write_week(week);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
                case 5:ri--;
                                if(ri==-1)
                                        ri=30;
                        write_nyr(14,ri);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
                case 6:yue--;
                                if(yue==-1)
                                        yue=12;
                        write_nyr(11,yue);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
                case 7:nian--;
                 if(nian==-1)
                        nian=99;
                        write_nyr(8,nian);
                                beep=0;
                        delay(50);
                        beep=1;
                        break;
void init()
        TMOD=0x11;
        TH0=0;
        TL0=0;
        EA=1;
        ET0=1;
        TR0=1;
//void cmg(void)//數碼管鎖存函數
//dula=1;
//P0=0x00;
//dula=0;
//wela=1;
//P0=0x00;
//wela=0;
{                if(key4==0)//key1為功能鍵
        delay(5);
        if(key4==0)
        while(!key4);
                        beep=0;
                        delay(50);
                        beep=1;
        TR0=1;
//   cmg();//數碼管鎖存
        lcd_init();
        ds1302_init();
        init();
                //TH0=(65536-60000)/256;
        //TL0=(65536-60000)%256;
keyscan();
void timer0() interrupt 1
        miao = BCD_Decimal(read_1302(0x81));
        fen = BCD_Decimal(read_1302(0x83));
        shi  = BCD_Decimal(read_1302(0x85));
        ri  = BCD_Decimal(read_1302(0x87));
        yue = BCD_Decimal(read_1302(0x89));
        nian=BCD_Decimal(read_1302(0x8d));
        week=BCD_Decimal(read_1302(0x8b));
        //keyscan();
                write_sfm(14,miao);
        //write_1602com(er+0x0a);
        //write_1602dat(':');
        write_sfm(11,fen);
        //write_1602com(er+0x07);
        write_sfm(8,shi);
        //write_nyr(4,nian);
        write_nyr(14,ri);
    write_nyr(11,yue);
        //write_week(week);
主站蜘蛛池模板: 亚洲天堂色图 | 日韩视频二区 | 国产精品美女久久久久久久久 | 欧美精品网站 | 天天干天天操天天插 | 欧美激情成人 | 免费一区二区三区 | 黄色片网站视频 | 日韩精品一区二区三区四区 | 国产综合久久 | 精品在线观看视频 | 成人免费毛片嘿嘿连载视频 | 午夜免费av| 中文字幕av一区二区三区 | 欧美日韩国产精品 | 欧美一区二区在线 | 免费中文字幕日韩欧美 | 国产香蕉视频 | 自拍偷拍欧美日韩 | 日韩在线视频网站 | 夜夜操夜夜爽 | 精品久久影院 | 992tv在线| 国产精品毛片va一区二区三区 | 欧美一区二区三区在线观看 | 最新国产精品视频 | 国产欧美视频在线观看 | 青青视频网 | 一区二区三区四区视频在线观看 | 私人午夜影院 | 成人aa| 成年人av | 黄色片网站免费 | 久草热视频 | 中文字幕免费在线观看 | 日韩视频中文字幕 | 国产欧美日本 | 一本久久道 | 日韩精品视频在线免费观看 | 国产深夜福利 | 日本熟妇毛耸耸xxxxxx |
