查看: 23740|回復: 20
智能循跡小車電路圖單片機程序與proteus仿真
ID:287566 發表于 2018-3-4 22:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
發個智能循跡小車電路圖和程序及仿真圖,希望對大家有用
LM393比較器的作用:-端電平大于+端10mV,輸出低電平,
相反,輸出端導通,由上拉電阻R4(VCC)給輸出端高電平
檢測白線光電傳器不導通,端口2電平為0,
檢測到黑線光電傳器導通,端口2電平由VCC經R6分壓后得高電平
元件清單:
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar temp,signal,tt1;
  5. void delay_1ms(uint d)
  6. {
  7.         uint i;
  8.         while(d--)
  9.                 for(i=0;i<75;i++);
  10. }
  11. void motor_run()                   //電機起動
  12. {
  13.           P1=0x35;
  14.         delay_1ms(150);
  15.         P1=0x00;
  16.         delay_1ms(20);
  17. /*        ENA=1;
  18.         OUT1=0;
  19.         OUT2=1;
  20.         delay_1ms(800);
  21.         OUT2=0;
  22.         delay_1ms(200);
  23.
  24.         ENB=1;
  25.         OUT4=0;
  26.         OUT3=1;
  27.         delay_1ms(800);
  28.         OUT3=0;
  29.         delay_1ms(200);
  30. */
  31. }
  32. void motor_left()                         //左進
  33. {
  34.         P1=0x30;
  35.         delay_1ms(150);
  36.         P1=0x00;
  37.         delay_1ms(20);
  38. }
  39. void motor_right()                   //右進
  40. {
  41.         P1=0x05;
  42.         delay_1ms(150);
  43.         P1=0x00;
  44.         delay_1ms(20);
  45. }
  46. void motor_big_right()                         //粗右進
  47. {
  48.         P1=0x55;
  49.         delay_1ms(150);
  50.         P1=0x00;
  51.         delay_1ms(20);
  52. }
  53. void motor_big_left()
  54. {
  55.         P1=0x33;
  56.         delay_1ms(150);
  57.         P1=0x00;
  58.         delay_1ms(20);
  59. }
  60. void motor_stop()                                        //電機停止
  61. {
  62.          P1=0x00;
  63. }
  64. void motor_back()
  65. {
  66.         P1=0x53;
  67. }
  68. void main()
  69. {
  70.         tt1=0;
  71.         EA=1;
  72.         ET1=1;
  73.         TR1=1;
  74.         TMOD=0x01;
  75.         TH1=-(1000/256);
  76.         TL1=-(1000%256);
  77.         while(1)
  78.         {
  79.                  temp=P2;
  80.                 signal=temp&0xff;                   //得到紅外反向信號
  81.                 switch(signal)
  82.                 {
  83.                         case 0xff:           //無偏差
  84.                                 motor_run();
  85.                                 break;
  86.                         case 0xfd:           //1輪右偏
  87.                                 motor_left();
  88.                                 break;
  89.                         case 0xef:            //4輪左偏
  90.                                 motor_right();
  91.                                 break;
  92.                         case 0xfb:     //2輪右偏出軌
  93.                         case 0xf9:           //1、2輪右偏
  94.                                  motor_big_left();
  95. //                                delay_1ms(10);
  96.                                 break;
  97.                         case 0xdf:           //5左偏出軌
  98.                         case 0xcf:      //4、5輪左偏
  99.                                  motor_big_right();
  100. //                                delay_1ms(10);
  101.                                 break;
  102.                         case 0xfe:           //0最右偏出軌
  103.                         case 0xfa:
  104.                                  motor_big_left();
  105. //                                delay_1ms(10);
  106.                                 break;
  107.                         case 0xbf:     //6最左偏出軌
  108.                          case 0x9f:
  109.                                 motor_big_right();
  110. //                                delay_1ms(10);
  111.                                 break;
  112.
  113.                         case 0xeb:         //前兩傳感器壓在黑線上
  114.                         case 0xdb:         //后兩傳感器壓在黑線上
  115.                         case 0xbe:         //中間兩傳感器壓在黑線上
  116.                         case 0xac:                 //前四傳感器壓在黑線上
  117.                         case 0x9a:                //后四傳感器壓在黑線上
  118.                                 motor_back();
  119.                                 delay_1ms(200);
  120.                                 motor_stop();
  121.
  122. //                                delay_1ms(1000);
  123.                         default:
  124. ……………………
  125. …………限于本文篇幅 余下代碼請從51黑下載附件…………
智能循跡小車電路圖和程序及仿真圖.rar (128.98 KB, 下載次數: 452)
參與人數 3黑幣 +63 收起 理由
1234567890qwert + 5
明天26號 + 8 贊一個!
收藏收藏12 分享淘帖 頂6 踩
ID:79874 發表于 2018-6-26 07:17 | 只看該作者
謝謝分享
ID:359143 發表于 2018-6-26 12:43 | 只看該作者
有電路圖嗎?
ID:349520 發表于 2019-4-29 22:26 | 只看該作者
不錯真厲害
ID:349520 發表于 2019-4-29 22:27 | 只看該作者
是三個輪子的嗎
ID:526864 發表于 2019-5-4 11:45 | 只看該作者
感謝分享
ID:540727 發表于 2019-5-17 17:35 來自觸屏版 | 只看該作者
樓主有實物么
ID:580160 發表于 2019-7-9 09:14 | 只看該作者
贊一個
ID:581439 發表于 2019-7-11 16:57 | 只看該作者
沒有PCB。。。
ID:582476 發表于 2019-7-11 18:07 | 只看該作者
機械渣渣最近在做,需要電路仿真,大佬可以發一份,謝謝!
ID:583531 發表于 2019-7-13 16:23 | 只看該作者
這個不錯
ID:440128 發表于 2019-7-22 11:19 | 只看該作者
雙選愛 發表于 2018-4-25 23:19
可以發一份給我嗎?
郵箱:
人家憑什么發給你,明明都有為什么不直接下載?
ID:616896 發表于 2019-11-17 22:16 | 只看該作者
謝謝分享
ID:673779 發表于 2019-12-25 18:12 | 只看該作者
為什么我用protues8.8打不開
ID:720325 發表于 2020-4-1 16:20 | 只看該作者
真好請問是怎么做的
ID:722299 發表于 2020-5-18 10:31 | 只看該作者
問一下這是幾個輪子的,程序4,5輪完全不懂
ID:758501 發表于 2020-6-6 09:47 | 只看該作者
為什么我打不開仿真的那個文件?
ID:56932 發表于 2020-6-11 22:36 | 只看該作者
謝謝分享
ID:757948 發表于 2020-6-12 11:17 | 只看該作者
zhangaoxiang66 發表于 2020-6-6 09:47
為什么我打不開仿真的那個文件?
我也打不開
ID:1032785 發表于 2023-5-23 10:21 | 只看該作者
整的太好了
ID:1088383 發表于 2023-8-26 15:32 | 只看該作者
為什么都不用黑幣下載,要發到你郵箱去
主站蜘蛛池模板: 性一交一乱一伧老太 | 伊人av在线 | 在线一区二区视频 | 中文字幕一区二区三区四区视频 | 手机在线看片1024 | 99热亚洲| 成av人片一区二区三区久久 | 亚洲综合婷婷 | 亚洲福利在线观看 | 欧美在线播放视频 | 成人av在线看 | 成人网址在线观看 | 人人草在线视频 | 天堂av在线播放 | 国产综合视频在线观看 | 中国特级毛片 | www.日韩在线 | 欧美激情综合 | 综合激情网站 | 美日韩在线 | 欧美日韩中文字幕在线 | 日韩精品极品 | 亚洲人天堂| 久久国产精 | 日韩欧美在线观看 | 依人在线 | av久久| 国产91精品在线观看 | 久久免费视频观看 | 日本熟妇毛耸耸xxxxxx | 亚洲天堂网址 | 成人动漫一区二区 | av在线天堂| 免费看a级片 | 日韩欧美精品一区 | 一级免费黄色片 | 亚洲一级大片 | 黄色一级大片 | 一级黄片毛片 | 国产黄色精品视频 | 国产色自拍 |
