查看: 2484|回復(fù): 0
16*16點陣?yán)皇斤@示proteus仿真與單片機(jī)源碼
ID:336726 發(fā)表于 2018-6-8 11:02 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
點陣顯示仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. //**********信息工程學(xué)院 陳國盛***************
  2. #include <reg51.h>
  3. #define tt 5
  4. unsigned int i;
  5. unsigned char j,k,m;
  6. sbit CLK1=P2^0;
  7. sbit CLK2=P2^1;
  8. unsigned char code lie_p3[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//
  9. unsigned char code lie_p1[]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//列掃描值
  10. unsigned char code zifu1[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  11.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};//字符模值
  12. unsigned char code zifu2[]={0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x00,0x00,0x00,0x20,0x00,0x24,0x9F,
  13.                                                         0x24,0x92,0xA4,0x92,0x64,0x92,0x24,0x92,0x24,0x92,0x24,0x9F,0x20,0x00,0x00,0x00,};//信
  14. unsigned char code zifu3[]={0x00,0x02,0x00,0x0C,0x00,0x00,0x3F,0xC0,0x2A,0x9C,0x2A,0x82,0x6A,0x82,0xAA,0xA2,
  15.                                                         0x2A,0x9A,0x2A,0x82,0x2A,0x82,0x3F,0xCE,0x00,0x00,0x00,0x10,0x00,0x0C,0x00,0x00,};//息
  16. unsigned char code zifu4[]={0x00,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x3F,0xFC,
  17.                                                         0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x00,0x04,0x00,0x00,};//工
  18. unsigned char code zifu5[]={0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,
  19.                                                         0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,};//程
  20. unsigned char code zifu6[]={0x02,0x20,0x0C,0x20,0x88,0x20,0x69,0x20,0x09,0x20,0x09,0x22,0x89,0x21,0x69,0x7E,
  21.                                                         0x09,0x60,0x09,0xA0,0x19,0x20,0x28,0x20,0xC8,0x20,0x0A,0x20,0x0C,0x20,0x00,0x00,};//學(xué)
  22. unsigned char code zifu7[]={0x00,0x00,0x7F,0xFF,0x44,0x20,0x5A,0x10,0x61,0xE0,0x08,0x01,0x30,0x82,0x24,0x8C,
  23.                                                         0x24,0xF0,0xA4,0x80,0x64,0x80,0x24,0xFC,0x24,0x82,0x28,0x82,0x30,0x8E,0x00,0x00,};//院
  24. unsigned char code zifu8[]={0x00,0x00,0x7F,0xFF,0x44,0x20,0x5A,0x10,0x61,0xE0,0x10,0x04,0x11,0x88,0x16,0xB0,
  25.                                                         0x18,0x82,0xF0,0x81,0x17,0xFE,0x10,0x80,0x10,0xA0,0x10,0x90,0x10,0x0C,0x00,0x00,};//陳
  26. unsigned char code zifu9[]={0x00,0x00,0x7F,0xFF,0x40,0x02,0x48,0x12,0x49,0x12,0x49,0x12,0x49,0x12,0x4F,0xF2,
  27.                                                         0x49,0x12,0x49,0x52,0x49,0x32,0x48,0x12,0x40,0x02,0x7F,0xFF,0x00,0x00,0x00,0x00,};//國
  28. unsigned char code zifu10[]={0x00,0x22,0x00,0xC2,0x3F,0x1E,0x24,0x12,0x24,0x92,0x24,0x5E,0x27,0x92,0x20,0x32,
  29.                                                         0xF8,0x52,0x26,0x9E,0x21,0x12,0xA2,0x92,0x6C,0x5E,0x21,0xE2,0x00,0x02,0x00,0x00,};//盛
  30. unsigned char code zifu11[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  31.                                                         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  32. //**********信息工程學(xué)院 陳國盛***************
  33. void delay1()
  34. {
  35.         for(i=200;i>0;i--)
  36.                 ;
  37.                 ;
  38. }
  39. void main()
  40. {
  41.         CLK1=0;
  42.         CLK2=0;
  43.         while(1)
  44.         {
  45.                 for(k=8;k>0;k--)
  46.                  {
  47.                         for(m=tt;m>0;m--)
  48.                         {
  49.                                 for(j=k;j>0;j--)
  50.                                 {
  51.                                         P3=16-j;
  52.                                          P0=zifu1[2*(k-j)];
  53.                                         CLK1=1;
  54.                                         CLK1=0;
  55.                                           P0=zifu1[2*(k-j)+1];
  56.                                         CLK2=1;
  57.                                         CLK2=0;
  58.                                          delay1();
  59.                                 }
  60. //**********信息工程學(xué)院 陳國盛***************
  61.                                 for(j=0;j<8-k;j++)
  62.                                 {
  63.                                         P3=j;
  64.                                          P0=zifu2[2*(8+k+j)];
  65.                                         CLK1=1;
  66.                                         CLK1=0;
  67.                                           P0=zifu2[2*(8+k+j)+1];
  68.                                         CLK2=1;CLK2=0;
  69.                                          delay1();
  70.                                 }
  71.                         }
  72.                  }
  73.                 for(k=8;k<16;k++)
  74.                 {
  75.                         for(m=tt;m>0;m--)
  76.                                 for(j=0;j<k;j++)
  77.                                  {
  78.                                         P3=j;
  79.                                          P0=zifu2[2*(16-k+j)];
  80.                                         CLK1=1;
  81.                                         CLK1=0;
  82.                                          P0=zifu2[2*(16-k+j)+1];
  83.                                         CLK2=1;
  84.                                         CLK2=0;
  85.                                          delay1();
  86.                                 }
  87.                 }
  88. //**********信息工程學(xué)院 陳國盛***************
  89.                 for(k=16;k>8;k--)
  90.                  {
  91.                         for(m=tt;m>0;m--)
  92.                                 for(j=k;j>0;j--)
  93.                                 {
  94.                                         P3=16-j;
  95.                                          P0=zifu2[2*(k-j)];
  96.                                         CLK1=1;
  97.                                         CLK1=0;
  98.                                           P0=zifu2[2*(k-j)+1];
  99.                                         CLK2=1;
  100.                                         CLK2=0;
  101.                                          delay1();
  102.                                 }
  103.                 }
  104.                 for(k=8;k>0;k--)
  105.                 {
  106.                         for(m=tt;m>0;m--)
  107.                         {
  108.                                 for(j=k;j>0;j--)
  109.                                 {
  110.                                         P3=16-j;
  111.                                          P0=zifu2[2*(k-j)];
  112.                                         CLK1=1;
  113.                                         CLK1=0;
  114.                                           P0=zifu2[2*(k-j)+1];
  115.                                         CLK2=1;
  116.                                         CLK2=0;
  117.                                          delay1();
  118.                                 }
  119. //**********信息工程學(xué)院 陳國盛***************
  120.                                 for(j=0;j<8-k;j++)
  121.                                 {
  122.                                         P3=j;
  123.                                         P0=zifu3[2*(8+k+j)];
  124.                                         CLK1=1;
  125.                                         CLK1=0;
  126.                                          P0=zifu3[2*(8+k+j)+1];
  127.                                         CLK2=1;
  128.                                         CLK2=0;
  129.                                         delay1();
  130.                                 }
  131.                         }
  132.                 }
  133.                 for(k=8;k<16;k++)
  134.                 {
  135.                         for(m=tt;m>0;m--)
  136.                                 for(j=0;j<k;j++)
  137.                                 {
  138.                                         P3=j;
  139.                                          P0=zifu3[2*(16-k+j)];
  140.                                         CLK1=1;
  141.                                         CLK1=0;
  142.                                           P0=zifu3[2*(16-k+j)+1];
  143.                                         CLK2=1;
  144.                                         CLK2=0;
  145.                                          delay1();
  146.                                 }
  147.                 }
  148. //**********信息工程學(xué)院 陳國盛***************
  149.                 for(k=16;k>8;k--)
  150.                 {
  151.                         for(m=tt;m>0;m--)
  152.                                 for(j=k;j>0;j--)
  153.                                 {
  154.                                         P3=16-j;
  155.                                          P0=zifu3[2*(k-j)];
  156.                                         CLK1=1;
  157.                                         CLK1=0;
  158.                                           P0=zifu3[2*(k-j)+1];
  159.                                         CLK2=1;
  160.                                         CLK2=0;
  161.                                          delay1();
  162.                                 }
  163.                 }
  164.                 for(k=8;k>0;k--)
  165.                 {
  166.                         for(m=tt;m>0;m--)
  167.                         {
  168.                                 for(j=k;j>0;j--)
  169.                                 {
  170.                                         P3=16-j;
  171.                                          P0=zifu3[2*(k-j)];
  172.                                         CLK1=1;
  173.                                         CLK1=0;
  174.                                           P0=zifu3[2*(k-j)+1];
  175.                                         CLK2=1;
  176.                                         CLK2=0;
  177.                                          delay1();
  178.                                 }
  179. //**********信息工程學(xué)院 陳國盛***************
  180.                                 for(j=0;j<8-k;j++)
  181.                                 {
  182.                                         P3=j;
  183.                                          P0=zifu4[2*(8+k+j)];
  184.                                         CLK1=1;
  185.                                         CLK1=0;
  186.                                           P0=zifu4[2*(8+k+j)+1];
  187.                                         CLK2=1;
  188.                                         CLK2=0;
  189.                                          delay1();
  190.                                 }
  191.                         }
  192.                 }
  193.                 for(k=8;k<16;k++)
  194.                 {
  195.                         for(m=tt;m>0;m--)
  196.                                 for(j=0;j<k;j++)
  197.                                 {
  198.                                         P3=j;
  199.                                          P0=zifu4[2*(16-k+j)];
  200.                                         CLK1=1;
  201.                                         CLK1=0;
  202.                                           P0=zifu4[2*(16-k+j)+1];
  203.                                         CLK2=1;
  204.                                         CLK2=0;
  205.                                          delay1();
  206.                                 }
  207.                 }
  208. //**********信息工程學(xué)院 陳國盛***************
  209.                 for(k=16;k>8;k--)
  210.                 {
  211.                         for(m=tt;m>0;m--)
  212.                                 for(j=k;j>0;j--)
  213.                                 {
  214.                                         P3=16-j;
  215.                                          P0=zifu4[2*(k-j)];
  216.                                         CLK1=1;
  217.                                         CLK1=0;
  218.                                          P0=zifu4[2*(k-j)+1];
  219.                                         CLK2=1;
  220.                                         CLK2=0;
  221.                                          delay1();
  222.                                 }
  223.                 }
  224.                 for(k=8;k>0;k--)
  225.                 {
  226.                         for(m=tt;m>0;m--)
  227.                         {
  228.                                 for(j=k;j>0;j--)
  229.                                 {
  230.                                         P3=16-j;
  231.                                          P0=zifu4[2*(k-j)];
  232.                                         CLK1=1;
  233.                                         CLK1=0;
  234.                                          P0=zifu4[2*(k-j)+1];
  235.                                         CLK2=1;
  236.                                         CLK2=0;
  237.                                          delay1();
  238.                                 }
  239. //**********信息工程學(xué)院 陳國盛***************
  240.                                 for(j=0;j<8-k;j++)
  241.                                 {
  242.                                         P3=j;
  243.                                         P0=zifu5[2*(8+k+j)];
  244.                                         CLK1=1;
  245.                                         CLK1=0;
  246.                                          P0=zifu5[2*(8+k+j)+1];
  247.                                         CLK2=1;
  248.                                         CLK2=0;
  249.                                         delay1();
  250.                                 }
  251.                         }
  252.                 }
  253.                 for(k=8;k<16;k++)
  254.                 {
  255.                         for(m=tt;m>0;m--)
  256.                                 for(j=0;j<k;j++)
  257.                                 {
  258.
  259.                                         P3=j;
  260.                                          P0=zifu5[2*(16-k+j)];
  261.                                         CLK1=1;
  262.                                         CLK1=0;
  263.                                          P0=zifu5[2*(16-k+j)+1];
  264.                                         CLK2=1;
  265.                                         CLK2=0;
  266.                                          delay1();
  267.                                 }
  268.                 }
  269. //**********信息工程學(xué)院 陳國盛***************
  270.                 for(k=16;k>8;k--)
  271.                 {
  272.                                 for(m=tt;m>0;m--)
  273.                                         for(j=k;j>0;j--)
  274.                                         {
  275.                                                 P3=16-j;
  276.
  277.                                                  P0=zifu5[2*(k-j)];
  278.                                                 CLK1=1;CLK1=0;
  279.
  280.                                                   P0=zifu5[2*(k-j)+1];
  281.                                                 CLK2=1;CLK2=0;
  282.                                                  delay1();
  283.                                         }
  284.                          }
  285.                          for(k=8;k>0;k--)
  286.                          {
  287.                                 for(m=tt;m>0;m--)
  288.                                 {
  289.                                         for(j=k;j>0;j--)
  290.                                         {
  291.                                                 P3=16-j;
  292.
  293.                                                  P0=zifu5[2*(k-j)];
  294.                                                 CLK1=1;CLK1=0;
  295.
  296.                                                   P0=zifu5[2*(k-j)+1];
  297.                                                 CLK2=1;CLK2=0;
  298.                                                  delay1();
  299.                                         }
  300. //**********信息工程學(xué)院 陳國盛***************
  301.                                         for(j=0;j<8-k;j++)
  302.                                         {
  303.                                                 P3=j;
  304.
  305.                                                  P0=zifu6[2*(8+k+j)];
  306.                                                 CLK1=1;CLK1=0;
  307.
  308.                                                   P0=zifu6[2*(8+k+j)+1];
  309.                                                 CLK2=1;CLK2=0;
  310.                                                  delay1();
  311.                                         }
  312.                                 }
  313.                          }
  314.                          for(k=8;k<16;k++)
  315.                          {
  316.                                 for(m=tt;m>0;m--)
  317.                                         for(j=0;j<k;j++)
  318.                                          {
  319.
  320.                                                 P3=j;
  321.
  322.                                                  P0=zifu6[2*(16-k+j)];
  323.                                                 CLK1=1;CLK1=0;
  324.
  325.                                                   P0=zifu6[2*(16-k+j)+1];
  326.                                                 CLK2=1;CLK2=0;
  327.                                                  delay1();
  328.                                         }
  329.                          }
  330. //**********信息工程學(xué)院 陳國盛***************
  331.                          for(k=16;k>8;k--)
  332.                          {
  333.                                 for(m=tt;m>0;m--)
  334.                                         for(j=k;j>0;j--)
  335.                                         {
  336.                                                 P3=16-j;
  337.
  338.                                                  P0=zifu6[2*(k-j)];
  339.                                                 CLK1=1;CLK1=0;
  340.
  341.                                                   P0=zifu6[2*(k-j)+1];
  342.                                                 CLK2=1;CLK2=0;
  343.                                                  delay1();
  344.                                         }
  345.                          }
  346.                          for(k=8;k>0;k--)
  347.                          {
  348.                                 for(m=tt;m>0;m--)
  349.                                 {
  350.                                         for(j=k;j>0;j--)
  351.                                         {
  352.                                                 P3=16-j;
  353.
  354.                                                  P0=zifu6[2*(k-j)];
  355.                                                 CLK1=1;CLK1=0;
  356.
  357.                                                   P0=zifu6[2*(k-j)+1];
  358.                                                 CLK2=1;CLK2=0;
  359.                                                  delay1();
  360.                                         }
  361. //**********信息工程學(xué)院 陳國盛***************
  362.                                         for(j=0;j<8-k;j++)
  363.                                         {
  364.                                                 P3=j;
  365.
  366.                                                  P0=zifu7[2*(8+k+j)];
  367.                                                 CLK1=1;CLK1=0;
  368.
  369.                                                   P0=zifu7[2*(8+k+j)+1];
  370.                                                 CLK2=1;CLK2=0;
  371.                                                  delay1();
  372.                                         }
  373.                                 }
  374.                          }
  375.                          for(k=8;k<16;k++)
  376.                          {
  377.                                 for(m=tt;m>0;m--)
  378.                                         for(j=0;j<k;j++)
  379.                                          {
  380.
  381.                                                 P3=j;
  382.
  383.                                                  P0=zifu7[2*(16-k+j)];
  384.                                                 CLK1=1;CLK1=0;
  385.
  386.                                                   P0=zifu7[2*(16-k+j)+1];
  387.                                                 CLK2=1;CLK2=0;
  388.                                                  delay1();
  389.                                         }
  390.                          }
  391. //**********信息工程學(xué)院 陳國盛***************
  392.                          for(k=16;k>8;k--)
  393.                          {
  394.                                 for(m=tt;m>0;m--)
  395.                                         for(j=k;j>0;j--)
  396.                                         {
  397.                                                 P3=16-j;
  398.
  399.                                                  P0=zifu7[2*(k-j)];
  400.                                                 CLK1=1;CLK1=0;
  401.
  402.                                                   P0=zifu7[2*(k-j)+1];
  403.                                                 CLK2=1;CLK2=0;
  404.                                                  delay1();
  405.                                         }
  406.                          }
  407.                          for(k=8;k>0;k--)
  408.                          {
  409.                                 for(m=tt;m>0;m--)
  410.                                 {
  411.                                         for(j=k;j>0;j--)
  412.                                         {
  413.                                                 P3=16-j;
  414.
  415.                                                  P0=zifu7[2*(k-j)];
  416.                                                 CLK1=1;CLK1=0;
  417.
  418.                                                   P0=zifu7[2*(k-j)+1];
  419.                                                 CLK2=1;CLK2=0;
  420.                                                  delay1();
  421.                                         }
  422. //**********信息工程學(xué)院 陳國盛***************
  423.                                         for(j=0;j<8-k;j++)
  424.                                         {
  425.                                                 P3=j;
  426.
  427.                                                  P0=zifu8[2*(8+k+j)];
  428.                                                 CLK1=1;CLK1=0;
  429.
  430.                                                   P0=zifu8[2*(8+k+j)+1];
  431.                                                 CLK2=1;CLK2=0;
  432.                                                  delay1();
  433.                                         }
  434.                                 } }
  435.                         for(k=8;k<16;k++)
  436.                          {
  437.                                 for(m=tt;m>0;m--)
  438.                                         for(j=0;j<k;j++)
  439.                                          {
  440.
  441.                                                 P3=j;
  442.
  443.                                                  P0=zifu8[2*(16-k+j)];
  444.                                                 CLK1=1;CLK1=0;
  445.
  446.                                                   P0=zifu8[2*(16-k+j)+1];
  447.                                                 CLK2=1;CLK2=0;
  448.                                                  delay1();
  449.                                         }
  450.                          }
  451. //**********信息工程學(xué)院 陳國盛***************
  452.                          for(k=16;k>8;k--)
  453.                          {
  454.                                 for(m=tt;m>0;m--)
  455.                                         for(j=k;j>0;j--)
  456.                                         {
  457.                                                 P3=16-j;
  458.
  459.                                                  P0=zifu8[2*(k-j)];
  460.                                                 CLK1=1;CLK1=0;
  461.
  462.                                                   P0=zifu8[2*(k-j)+1];
  463.                                                 CLK2=1;CLK2=0;
  464.                                                  delay1();
  465.                                         }
  466.                          }
  467.                          for(k=8;k>0;k--)
  468.                          {
  469.                                 for(m=tt;m>0;m--)
  470.                                 {
  471.                                         for(j=k;j>0;j--)
  472.                                         {
  473.                                                 P3=16-j;
  474.
  475.                                                  P0=zifu8[2*(k-j)];
  476.                                                 CLK1=1;CLK1=0;
  477.
  478.                                                   P0=zifu8[2*(k-j)+1];
  479.                                                 CLK2=1;CLK2=0;
  480.                                                  delay1();
  481.                                         }
  482. //**********信息工程學(xué)院 陳國盛***************
  483.                                         for(j=0;j<8-k;j++)
  484.                                         {
  485.                                                 P3=j;
  486.
  487.                                                  P0=zifu9[2*(8+k+j)];
  488.                                                 CLK1=1;CLK1=0;
  489.
  490.                                                   P0=zifu9[2*(8+k+j)+1];
  491.                                                 CLK2=1;CLK2=0;
  492.                                                  delay1();
  493.                                         }
  494.                                 } }
  495.                                 for(k=8;k<16;k++)
  496.                          {
  497.                                 for(m=tt;m>0;m--)
  498.                                         for(j=0;j<k;j++)
  499.                                          {
  500.
  501.                                                 P3=j;
  502.
  503.                                                  P0=zifu9[2*(16-k+j)];
  504.                                                 CLK1=1;CLK1=0;
  505.
  506.                                                   P0=zifu9[2*(16-k+j)+1];
  507.                                                 CLK2=1;CLK2=0;
  508.                                                  delay1();
  509.                                         }
  510.                          }
  511. //**********信息工程學(xué)院 陳國盛***************
  512.                          for(k=16;k>8;k--)
  513.                          {
  514.                                 for(m=tt;m>0;m--)
  515.                                         for(j=k;j>0;j--)
  516.                                         {
  517.                                                 P3=16-j;
  518.
  519.                                                  P0=zifu9[2*(k-j)];
  520.                                                 CLK1=1;CLK1=0;
  521.
  522.                                                   P0=zifu9[2*(k-j)+1];
  523.                                                 CLK2=1;CLK2=0;
  524.                                                  delay1();
  525.                                         }
  526.                          }
  527.                          for(k=8;k>0;k--)
  528.                          {
  529.                                 for(m=tt;m>0;m--)
  530.                                 {
  531.                                         for(j=k;j>0;j--)
  532.                                         {
  533.                                                 P3=16-j;
  534.
  535.                                                  P0=zifu9[2*(k-j)];
  536.                                                 CLK1=1;CLK1=0;
  537.
  538.                                                   P0=zifu9[2*(k-j)+1];
  539.                                                 CLK2=1;CLK2=0;
  540.                                                  delay1();
  541.                                         }
  542. //**********信息工程學(xué)院 陳國盛***************
  543.                                         for(j=0;j<8-k;j++)
  544.                                         {
  545.                                                 P3=j;
  546.
  547.                                                  P0=zifu10[2*(8+k+j)];
  548.                                                 CLK1=1;CLK1=0;
  549.
  550.                                                   P0=zifu10[2*(8+k+j)+1];
  551.                                                 CLK2=1;CLK2=0;
  552.                                                  delay1();
  553.                                         }
  554.                                 }
  555.                                 }
  556.         for(k=8;k<16;k++)
  557. ……………………
  558. …………限于本文篇幅 余下代碼請從51黑下載附件…………
陳.rar (68.51 KB, 下載次數(shù): 18)
主站蜘蛛池模板: 日本伊人久久 | 93久久精品日日躁夜夜躁欧美 | 国产精品1234 | 成人精品免费视频 | av免费不卡 | av中文在线 | 亚洲激情综合 | 日韩黄网 | 一区二区av | 亚洲精品福利视频 | 九九视频这里只有精品 | 日韩精品一区二区三区免费视频 | 免费网站av | 免费看大片a | av在线一区二区 | 欧美久久久久久久久久 | 亚洲无人区一线二线三线 | 日韩黄色一级片 | 欧美日韩免费在线观看 | 激情婷婷综合 | 91福利网站 | 精品在线播放 | 欧美日韩国产二区 | 中文字幕播放 | 欧美一级片免费 | 91精品久久久久 | 成人一区二区三区 | 国产一级特黄aaa大片 | 日韩高清精品免费观看 | 国产精品免费在线播放 | 91伊人| 亚洲少妇视频 | 欧美午夜在线观看 | 欧美成人精品欧美一级乱黄 | 天天干干干 | www.日本高清 | 精品国产一二三区 | 免费日韩视频 | 天天综合影院 | 中文久久乱码一区二区 | 日韩在线精品视频 |
