查看: 4434|回復: 0
[單片機LCD驅動程序分享] LCD1602時間顯示
LCD1602 時間顯示
Proteus
AT89C51單片機源程序如下:
main.c
  1. /**
  2. * @file main.c
  3. * @author Kiyotaka
  4. * @brief Unix timestamp on LCD1602
  5. * @version 0.1
  6. * @date 2019-12-08
  7. *
  8. * @copyright Copyright (c) 2019
  9. *
  10. */
  11. #include "main.h"
  12. #include "lcd1602.h"
  13. void Delay1000ms(void);
  14. unsigned long int timestamp = 157579655;
  15. int main(void) {
  16.   LCD1602_Init();
  17.   LCD1602_Printf(0, 0, "Unix timestamp:");
  18.   while (1) {
  19.     LCD1602_Printf(0, 1, "%ld", timestamp++);
  20.     Delay1000ms();
  21.   }
  22. }
  23. void Delay1000ms(void) {  //@12.000MHz
  24.   unsigned char i = 8;
  25.   unsigned char j = 154;
  26.   unsigned char k = 122;
  27.   _nop_();
  28.   do {
  29.     do {
  30.       while (--k);
  31.     } while (--j);
  32.   } while (--i);
  33. }
lcd1602.c
  1. /**
  2. * @file lcd1602.c
  4. * @brief LCD1602 driver
  5. * @version 0.1
  7. *
  9. *
  10. */
  11. #include "lcd1602.h"
  12. typedef enum { GPIO_PIN_RESET = 0, GPIO_PIN_SET } GPIO_PinState;
  13. #define RS_CMD GPIO_PIN_RESET
  14. #define RS_DATA GPIO_PIN_SET
  15. /**
  16. * @brief 延時函數
  17. *
  18. * @param us 延時時間
  19. * @return None
  20. */
  21. static void Delay(int us) {
  22.   while (us-- > 0) {
  23.     _nop_();
  24.   }
  25. }
  26. /**
  27. * @brief 液晶I/O 口復位
  28. *
  29. * @return None
  30. */
  31. static void PinReset(void) {
  32.   LCD1602_E_Pin = GPIO_PIN_RESET;
  33.   LCD1602_RS_Pin = GPIO_PIN_RESET;
  34.   LCD1602_RW_Pin = GPIO_PIN_RESET;
  35.   LCD1602_Port = 0xFF;
  36. }
  37. /**
  38. * @brief LCD1602 等待液晶空閑
  39. *
  40. *@return None
  41. */
  42. static void WaitIdleTime(void) {
  43.   LCD1602_RS_Pin = RS_CMD;
  44.   LCD1602_RW_Pin = GPIO_PIN_SET;
  45.   LCD1602_Port = 0x00;
  46.   LCD1602_E_Pin = GPIO_PIN_SET;
  47.   do {
  48.     Delay(100);
  49.   } while ((LCD1602_Port & 0x80) >> 7);
  50.   PinReset();
  51. }
  52. /**
  53. * @brief LCD1602 寫數據/指令函數
  54. *
  55. * @param val 8位數據
  56. * @param is_data true 是數據, false 是指令
  57. * @return None
  58. */
  59. static void Write(unsigned char val, bit is_data) {
  60.   bit interrupt_stat = EA;
  61.   EA = 0;
  62.   WaitIdleTime();
  63.   LCD1602_RS_Pin = is_data;
  64.   LCD1602_Port = val;
  65.   LCD1602_E_Pin = GPIO_PIN_SET;
  66.   Delay(100);
  67.   PinReset();
  68.   EA = interrupt_stat;
  69. }
  70. /**
  71. * @brief LCD1602 初始化
  72. *
  73. * @return None
  74. */
  75. void LCD1602_Init(void) {
  76.   PinReset();
  77.   Write(0x38, RS_CMD);
  78.   Write(0x0C, RS_CMD);
  79.   Write(0x06, RS_CMD);
  80.   Write(0x01, RS_CMD);
  81. }
  82. /**
  83. * @brief LCD1602 顯示函數
  84. *
  85. * @param addr_x (0~15) 橫坐標
  86. * @param addr_y (0~1) 縱坐標
  87. * @param fmt 格式化字符串
  88. * @param ...
  89. * @return int
  90. */
  91. int LCD1602_Printf(int addr_x, int addr_y, const char *fmt, ...) {
  92.   char buf[20] = {0};
  93.   char *p = buf;
  94.   int ret = 0;
  95.   va_list args;
  96.   va_start(args, fmt);
  97.   ret = vsprintf(p, fmt, args);
  98.   va_end(args);
  99.   Write(0x80 + 0x40 * addr_y + addr_x, RS_CMD);
  100.   while (*p != '\0') {
  101.     if (*p == '\f') {
  102.       Write(0x01, RS_CMD);
  103.     } else if (isprint(*p) != 0) {
  104.       Write(*p, RS_DATA);
  105.     }
  106.     p++;
  107.   }
  108.   return ret;
  109. }
驅動程序(Keil + Proteus)
lcd1602.zip (47.8 KB, 下載次數: 24)
如果注釋為亂碼,Keil的Encoding設置成UTF-8
主站蜘蛛池模板: 九九热在线播放 | a在线播放| 久久免费精品视频 | 日本少妇中文字幕 | 激情91 | 成人一区二区三区 | 日韩欧美高清视频 | 高潮毛片又色又爽免费 | 亚洲一区日韩 | 午夜爽爽影院 | 免费在线观看毛片 | 日韩视频一区二区 | 日韩欧美精品一区 | 综合久久99 | 爱情岛论坛av | 亚洲第一av | av网页在线观看 | 在线a| 成人手机在线观看 | 极品尤物一区二区三区 | 日本特级淫片 | 亚洲人成免费 | 亚洲精品视频免费在线观看 | www.狠狠操 | 精品久久一区二区 | 亚洲精品观看 | 亚洲色网址 | 一区二区不卡视频 | 国产一区二区在线播放 | 最新超碰 | 在线视频日本 | 在线va | 国产精品看片 | 黄色精品网站 | 在线观看中文字幕 | 91av导航| 成人做爰免费视频免费看 | 91性高潮久久久久久久久 | 伊人精品在线 | 成人在线视频播放 | 狠狠干欧美 |
