查看: 3802|回復: 4
ardunio仿真實現網頁控制廣告燈閃爍程序
ID:744206 發表于 2020-5-5 09:50 | 顯示全部樓層 |閱讀模式
效果說明:HTML制作一個簡易網頁,網頁上有兩個按鈕ON,OFF。
建立Arduino和所制作的網頁之間的通訊,但按下ON時,廣告燈閃爍,當按下OFF時,廣告燈熄滅。
電路圖:
代碼:
  1. #include<EtherCard.h>
  2. #include<SPI.h>
  3. static byte myip[] = {192,168,43,21};//設置本機同網段ip【根據你自己的IP設置】
  4. static byte gwip[] = {192, 168, 43, 1};
  5. static byte mymac[] = {0xDD, 0xDD, 0xDD, 0xDD, 0xDD, 0x95};
  6. byte Ethernet::buffer[700];
  7. BufferFiller bfill;
  8. int LED_PIN[] = {2, 3, 4, 5};
  9. int cnt = 0;
  10. boolean flag = false;
  11. char *on = "ON";
  12. char *off = "OFF";
  13. char *statusLabel;
  14. char *buttonLabel;
  15. void light_on()//設置開燈
  16. {
  17.     if (cnt % 2 == 0)
  18.     {
  19.         for (int i = 0; i < 4; i++)
  20.         {
  21.             digitalWrite(LED_PIN[ i], HIGH);
  22.             delay(100);
  23.         }
  24.     }
  25.     else
  26.     {
  27.         for (int i = 0; i < 4; i++)
  28.         {
  29.             digitalWrite(LED_PIN[ i], LOW);
  30.             delay(100);
  31.         }
  32.     }
  33. }
  34. void light_off()//設置關燈
  35. {
  36.     for (int i = 0; i < 4; i++)
  37.     {
  38.         digitalWrite(LED_PIN[ i], LOW);
  39.     }
  40. }
  41. void setup()
  42. {
  43.     Serial.begin(9600);
  44.     if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
  45.         Serial.println("Failed to access Ethernet controller");
  46.     if (!ether.staticSetup(myip, gwip))
  47.         Serial.println("Failed to set IP address");
  48.     ether.printIp("LocalIP: ", ether.myip);
  49.     ether.printIp("GWIP: ", ether.gwip);
  50.     Serial.println();
  51.     for (int i = 0; i < 4; i++)
  52.     {
  53.         pinMode(LED_PIN[ i], OUTPUT);
  54.     }
  55. }
  56. void loop()
  57. {
  58.     word len = ether.packetReceive();
  59.     word pos = ether.packetLoop(len);
  60.     if (pos)
  61.     {
  62.         char *data = (char *)Ethernet::buffer + pos;
  63.         if (strstr(data, "GET /?status=ON") != 0)
  64.         {
  65.             Serial.println("Received ON ");
  66.             flag = true;
  67.         }
  68.         if (strstr(data, "GET /?status=OFF") != 0)
  69.         {
  70.             Serial.println("Received OFF ");
  71.             flag = false;
  72.         }
  73.         if (flag)
  74.         {
  75.             statusLabel = on;
  76.             buttonLabel = off;
  77.         }
  78.         else
  79.         {
  80.             statusLabel = off;
  81.             buttonLabel = on;
  82.         }
  83.         bfill = ether.tcpOffset();
  84.         bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
  85.                           "Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
  86.                           "<html><head><title>WebLed</title></head>"
  87.                           "<body>LED燈 Status: $S "
  88.                           "<a href=\"/?status=$S\"><input type=\"button\" value=\"$S\"></a>"
  89.                           "</body></html>"),
  90.                      statusLabel, buttonLabel, buttonLabel);
  91.         ether.httpServerReply(bfill.position());
  92.     }
  93.     if (flag)
  94.     {
  95.         light_on();
  96.     }
  97.     else
  98.     {
  99.         light_off();
  100.     }
  101.     cnt += 1;
  102. }
效果:
網頁控制led.zip (36.41 KB, 下載次數: 15)
ID:85865 發表于 2020-5-5 20:47 | 顯示全部樓層
這個可用外網來控制嗎
ID:396751 發表于 2020-5-22 11:38 | 顯示全部樓層
仿真部分是如何實現的呢?
ID:396751 發表于 2020-5-22 11:39 | 顯示全部樓層
請問一下  仿真部分是如何實現的呢?
ID:396751 發表于 2020-5-22 11:41 | 顯示全部樓層
樓主  藍牙智能小車APP的下載鏈接失敗了
主站蜘蛛池模板: 波多野结衣亚洲一区 | 午夜成人影片 | 视频在线观看一区 | 性欧美69 | 亚洲一区二区在线播放 | 黄色片在线 | 国产三级在线观看 | 91麻豆产精品久久久久久夏晴子 | 欧美另类小说 | 深夜福利视频在线观看 | 黄色片网站在线观看 | 国产人成| 三级视频在线 | 91调教打屁股xxxx网站 | 国产精品99久久久久久久久 | 天堂va蜜桃一区二区三区 | 日韩视频一区二区三区 | 精品亚洲一区二区三区四区五区 | 久久精品国产成人av | 日韩在线一区二区 | 欧美日韩一区在线观看 | 特一级黄色片 | 色伊人网 | 亚洲视频在线观看免费 | 丁香六月综合 | 精品亚洲国产成人av制服丝袜 | 日本精品久久 | 亚洲精品福利视频 | 97在线免费视频 | 久久88 | 亚洲综合激情网 | 国产欧美一区二区三区视频在线观看 | 日本a网站| 激情五月综合网 | 黄色一级录像 | 欧美成人精品欧美一级私黄 | 一级黄色免费 | 亚洲毛片网 | 成人在线视频免费观看 | 日韩精品网站 | 成年人国产 |
