查看: 8460|回復: 0
51單片機簡易波形發生器Proteus仿真程序,產生方波、正弦波、鋸齒波、三角波
ID:649951 發表于 2021-3-10 15:12 | 顯示全部樓層 |閱讀模式
1.可實現方波、正弦波、鋸齒波、三角波四種波形
2.通過LCD1602顯示頻率、步進值
3.可用按鍵調整頻率
  1. #include<reg52.h>                                           //包含頭文件
  2. #include<intrins.h>
  3. #define uchar unsigned char                           //宏定義
  4. #define uint unsigned int
  5. sbit s1=P3^5;                                                    //定義按鍵的接口
  6. sbit s2=P3^6;
  7. sbit s3=P3^7;
  8. sbit s4=P3^4;
  9. sbit led0=P3^0;                                                        //定義四個LED,分別表示不同的波形
  10. sbit led1=P3^1;
  11. sbit led2=P3^2;
  12. sbit led3=P3^3;
  13.
  14. sbit lcdrs=P2^7;                                           //液晶控制引腳,還有一個控制腳是RW,因為我們只需要向液晶里寫數據系那是就好了,所以,我們直接將RW引腳接地
  15. sbit lcden=P2^6;
  16. char num,boxing,u;                                           //定義全局變量
  17. int pinlv=100,bujin=1,bujin1=1;                   //頻率初始值是10Hz,步進值默認是0.1,顯示步進值變量
  18. uchar code table[]="0123456789";                //定義顯示的數組
  19. uchar code table1[]="Fout=     Wave form:";        //初始化顯示字符
  20. unsigned long int m;                                   //定義長整形變量 m
  21. int a,b,h,num1;                                                        //定義全局變量
  22. //自定義字符
  23. uchar code zifu[]={                   //此數組內數據為液晶上顯示波形符號的自定義字符
  24.                                                 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
  25.                                                 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00,          //正弦波           0  1
  26.                                                 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
  27.                                                 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00,          //矩形波           2  3
  28.                                                 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
  29.                                                 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,          //三角波           4  5
  30.                                                 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00,            //鋸齒波           6
  31. };
  32. uchar code sin[64]={           //此數組內的數據為,da輸出對應電壓值對應的數字量,0是0V,255是5V
  33. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  34. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  35. };                                          //正弦波取碼
  36. uchar code juxing[64]={                //一個周期是采樣64個點, 所以數組內是64個數據
  37. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  38. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  39. };                                          //矩形波取碼
  40. uchar code sanjiao[64]={
  41. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  42. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  43. };                                                //三角波取碼
  44. uchar code juchi[64]={
  45. 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
  46. 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
  47. };                                          //鋸齒波取碼
  48. void delay(uint xms)         //延時函數
  49. {
  50.         int a,b;
  51.         for(a=xms;a>0;a--)
  52.                 for(b=110;b>0;b--);
  53. }
  54. void write_com(uchar com)                //寫命令函數
  55. {
  56.         lcdrs=0;
  57.         P0=com;
  58.         delay(1);
  59.         lcden=1;
  60.         delay(1);
  61.         lcden=0;
  62. }
  63. void write_date(uchar date)                //寫數據函數
  64. {
  65.         lcdrs=1;
  66.         P0=date;
  67.         delay(1);
  68.         lcden=1;
  69.         delay(1);
  70.         lcden=0;
  71. }
  72. //自定義字符集
  73. void Lcd_ram()
  74. {
  75.         uint i,j,k=0,temp=0x40;
  76.         for(i=0;i<7;i++)
  77.         {
  78.            for(j=0;j<8;j++)
  79.            {
  80.             write_com(temp+j);
  81.             write_date(zifu[k]);
  82.             k++;
  83.            }
  84.            temp=temp+8;
  85.         }
  86. }
  87. void init_lcd()                                        //初始化函數
  88. {
  89.         uchar i;
  90.         lcden=0;                                        //默認開始狀態為關使能端,見時序圖
  91.         Lcd_ram();
  92.         write_com(0x0f);
  93.         write_com(0x38);                        //顯示模式設置,默認為0x38,不用變。
  94.         write_com(0x01);                        //顯示清屏,將上次的內容清除,默認為0x01.
  95.         write_com(0x0c);                        //顯示功能設置0x0f為開顯示,顯示光標,光標閃爍;0x0c為開顯示,不顯光標,光標不閃
  96.         write_com(0x06);                        //設置光標狀態默認0x06,為讀一個字符光標加1.
  97.         write_com(0x80);                        //設置初始化數據指針,是在讀指令的操作里進行的
  98.         for(i=10;i<20;i++)                           //顯示初始化
  99.         {
  100.                 write_date(table1[i]);                   //顯示第一行字符
  101.         }
  102.         write_com(0x80+0x40);                           //選擇第二行
  103.         for(i=0;i<9;i++)
  104.         {
  105.                 write_date(table1[i]);                   //顯示第二行字符
  106.         }
  107.         write_com(0x80+10);                                   //選擇第一行第十個位置
  108.         write_date(0);
  109.         write_date(1);
  110.         write_date(0);
  111.         write_date(1);
  112.         write_date(0);
  113.         write_date(1);                                           //顯示自定義的波形圖案
  114.         write_com(0x80+0x40+0x09);                   //選擇第二行第九個位置
  115.         write_date(' ');
  116.         write_date('1');
  117.         write_date('0');
  118.         write_date('.');
  119.         write_date('0');
  120.         write_date('H');
  121.         write_date('z');                                   //顯示初始的頻率值
  122. }
  123. void initclock()                           //定時器初始化函數
  124. {
  125.         TMOD=0x01;                                   //定時器的工作方式
  126.         TH0=a;
  127.         TL0=b;                                           //定時器賦初值
  128.         EA=1;                                           //打開中斷總開關
  129.         ET0=1;                                           //打開定時器允許中斷開關
  130.         TR0=1;                                           //打開定時器定時開關
  131. }
全部資料51hei下載地址:
51黑論壇_1、函數發生器.rar (7.53 MB, 下載次數: 119)
參與人數 1黑幣 +12 收起 理由
1134549525 + 12 很給力!
主站蜘蛛池模板: 九九九久久久 | 亚洲午夜18毛片在线看 | 在线观看黄色小视频 | 国产在线天堂 | 91国在线| 福利片在线观看 | 日本aaaa| 日本不卡二区 | 男女视频免费 | 亚洲一级免费视频 | 999精品在线 | 99在线观看视频 | 国产成人三级一区二区在线观看一 | 国产一区二区视频在线播放 | 可以免费看黄色的网站 | 天天色影院 | 久久久精品国产sm调教网站 | 日本伊人网 | 国产精品国产成人国产三级 | 亚洲欧美另类在线 | 欧美一级淫片bbb一84 | 久久视频在线 | 美女毛片视频 | 日本视频一区二区三区 | 国产精品一二三四区 | 欧美在线观看一区 | 精品国产一区二区三区久久久蜜月 | 每日更新av| 中文字幕1区 | 明日边缘| 国产高清毛片 | 国产成人精品一区二区 | 国产一区二区三区在线观看视频 | 午夜影院在线观看 | 日本一级黄色大片 | 四虎视频在线观看 | 午夜激情影视 | 天天爱夜夜操 | 夜夜操夜夜操 | 日韩精品一区二区在线 | 欧美在线观看一区 |
