下載附件
2022-1-16 09:27 上傳
- module main(
- input clk, //50Mhz 時(shí)鐘輸入
- output reg [7:0] seg_code, //數(shù)碼管段碼 8位 A~DP
- output reg [3:0] bit_code //數(shù)碼管位碼 4位 ~1:千位 ~2:百位 ~4:十位 ~8:個(gè)位
- function [7:0] display; //16進(jìn)制數(shù)碼管段碼查詢
- input [3:0] hex;
- begin
- case(hex)
- 4'h0:display = 8'h3F;
- 4'h1:display = 8'h06;
- 4'h2:display = 8'h5B;
- 4'h3:display = 8'h4F;
- 4'h4:display = 8'h66;
- 4'h5:display = 8'h6D;
- 4'h6:display = 8'h7D;
- 4'h7:display = 8'h07;
- 4'h8:display = 8'h7F;
- 4'h9:display = 8'h6F;
- 4'hA:display = 8'h77;
- 4'hB:display = 8'h7C;
- 4'hC:display = 8'h39;
- 4'hD:display = 8'h5E;
- 4'hE:display = 8'h79;
- 4'hF:display = 8'h71;
- endcase
- end
- endfunction
- reg [15:0] hex = 0; //數(shù)碼管通過16進(jìn)制顯示出此寄存器的值
- reg [15:0] i = 0;
- reg [1:0] j = 0;
- reg [31:0] k = 0;
- always @(posedge clk) begin //CLK上升沿觸發(fā)
- //數(shù)碼管動(dòng)態(tài)掃描 (FPGA的段碼和位碼可以并行發(fā)送 所以不需要消影)
- i = i + 1'd1;
- if(i == 16'd50000) begin //50000個(gè)時(shí)鐘即為1ms
- i = 0;
- j <= j + 1'd1;
- //共陰或共陽(yáng) 如果顯示不正確 可將 seg_code 或 bit_code 前的 ~號(hào)去除 并檢查A~DP的Pin是否設(shè)置顛倒
- case(j)
- 2'd0:seg_code <= ~display(hex[15:12]);
- 2'd1:seg_code <= ~display(hex[11:8]);
- 2'd2:seg_code <= ~display(hex[7:4]);
- 2'd3:seg_code <= ~display(hex[3:0]);
- endcase
- bit_code <= ~(1'd1 << j);
- end
- //16進(jìn)制累加 1秒+1
- k = k + 1'd1;
- if(k == 50000000) begin
- k = 1'd0;
- hex <= hex + 1'd1;
- end
- end
- endmodule
復(fù)制代碼 |
評(píng)分
查看全部評(píng)分
