查看: 3964|回復: 0
SD卡嵌入FAT32系統實驗
ID:72008 發表于 2015-1-12 15:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
     把原子的程序思路和代碼移植到野火板子上,把兩者來了個強強聯合;實現了對SD卡的文件創建,和文件內容的實時讀寫。帶日歷程序。就這么點東西折騰了老子幾天;實現功能:1,實時時鐘;2,文件夾創建;3,讀SD卡文件內容。通過本實驗基本上可以熟悉FAT32文件系統的一些簡單應用函數功能。
FIL fnew;        /* file objects */
FATFS fs;                /* Work area (file system object) for logical drives */
FRESULT res;
UINT br, bw;                   /* File R/W count */
BYTE buffer[4096]={0};                         /* file copy buffer */
BYTE textFileBuffer[] = "HELLO WORLD ! 我是王衍。 ";
int main(void)
{       u8 i,t=0;
          uart_init(9600);
          delay_init();
          mem_init(SRAMIN);
          LCD_Init();
        LCD_Clear(0, 0, 240, 320, WHITE);
        Key_init();
          LED_GPIO_Config();
          NVIC_Configuration();
          RTC_Init();
          usmart_dev.init(SystemCoreClock/1000000);
                Sd_fs_init();
        while(RTC_Init())
                    LCD_DispStr(60,60,"RTC ERROR! ",RED);
                     delay_ms(200);
                    LCD_DispStr(60,60,"RTC Trying...",RED);
                LCD_DispStr(30,120,"    -  -  ",RED); //
             LCD_DispStr(10,140,"      :  :  ",RED); //
                f_mkdir("sub");
                  f_mkdir("sub/sub1");
                /* function disk_initialize() has been called in f_open */
#if 0         //如果將條件編譯內容注釋掉,則可以實時讀出SD卡某個文件的內容,只要文件內容改變了顯示(即讀出)也隨之變化。
        res = f_open(&fnew, "0:íõ«`.txt", FA_CREATE_ALWAYS | FA_WRITE );
    if (res == FR_OK)
       LCD_DispStr(20, 160, "start write!", RED);
       do{  res = f_write(&fnew, textFileBuffer, sizeof(textFileBuffer), &bw);
            if(res)
            {  LCD_DispStr(20, 160, "write error!", RED);
               break;
            LCD_DispStr(20, 180, "write ok!", RED);
      while (bw != sizeof(textFileBuffer)); //
        f_close(&fnew);
     LED2_TOGGLE;
#endif
                res = f_open(&fnew, "0:王玚 .txt", FA_OPEN_EXISTING | FA_READ);
                res = f_read(&fnew, buffer, sizeof(textFileBuffer), &br);
            LCD_DispEnCh(10, 80, buffer, RED);
                printf("\r\n %s ", buffer);
              delay_ms(100);
                printf("\r\n this is a fatfs test demo \r\n");
                /* Close open files */
                f_close(&fnew);
    /* Unregister work area prior to discard it */
    f_mount(0, NULL);
                if(t!=calendar.sec)
                           t=calendar.sec;
                           LCD_DisNum(30, 120, calendar.w_year, BLUE);
                           LCD_DisNum(85, 120, calendar.w_month, BLUE);
                           LCD_DisNum(110, 120, calendar.w_date, BLUE);
                        switch(calendar.week)
                                case 0:
                                        LCD_DispEnCh(150, 120, "星期一", BLUE);
                                        break;
                                case 1:
                                        LCD_DispEnCh(150, 120, "星期二",BLUE);
                                        break;
                                case 2:
                                        LCD_DispEnCh(150, 120, "星期三", BLUE);
                                        break;
                                case 3:
                                        LCD_DispEnCh(150, 120, "星期四", BLUE);
                                        break;
                                case 4:
                                        LCD_DispEnCh(150, 120, "星期五", BLUE);
                                        break;
                                case 5:
                                        LCD_DispEnCh(150, 120, "星期六", BLUE);
                                        break;
                                case 6:
                                        LCD_DispEnCh(150, 120,"星期天", BLUE);
                                        break;
                        LCD_DisNum(50, 140, calendar.hour, BLUE);
                        LCD_DisNum(80, 140, calendar.min, BLUE);
                        LCD_DisNum(110, 140, calendar.sec, BLUE);
                i++;
                if((i%20)==0)
                { //LCD_DisNum(125,150, mem_perused(SRAMIN), BLUE);
                                LED1_TOGGLE;
                delay_ms(10);
主站蜘蛛池模板: 国产精品一区二区三区不卡 | 男人添女荫道口图片 | 在线观看黄色av | 亚洲精品在线观看视频 | 欧美成人三级 | 日韩二三区 | 中文字幕理伦片免费看 | 国产伊人网 | a在线免费观看 | 国产视频成人 | 91日韩在线| 亚洲欧美在线播放 | 国产精品久久久久久亚洲影视 | 激情综合网站 | 一区二区三区在线观看视频 | 欧美精品一区在线 | 老女人性生活视频 | 亚洲天堂网在线观看 | 91精品又粗又猛又爽 | 一区二区三区久久久 | 免费不卡视频 | 亚洲一区二区三区四区在线 | 波多野结衣乳巨码无在线观看 | 老司机午夜免费精品视频 | 久热精品视频 | 国产黄在线| 国产成人在线免费观看 | 天天干天天操 | 在线观看黄色小说 | 一级黄色免费视频 | 亚洲欧美在线观看 | 91亚洲国产成人精品性色 | 国产午夜精品一区二区三区视频 | 97在线免费观看视频 | 久久国产一区 | 久久久夜 | 在线播放毛片 | 福利视频二区 | 九九热这里 | 在线观看黄网 | 欧美精品在线免费观看 |
