查看: 4114|回復(fù): 0
AD9854產(chǎn)生頻率程序
ID:75926 發(fā)表于 2015-4-1 22:47 | 顯示全部樓層 |閱讀模式
  名稱:AD9854并口驅(qū)動
  編寫:
  日期:2014.3
  修改:無
  內(nèi)容:
#include "AD9854_Parallel.h"
        //uchar Freq1Word[6] = {0x01, 0x00, 0x00, 0x00, 0x00, 0x00};
        void Init_9854(void)  //INIT 9854
{// uint i;
WRB = 0;
UDCLK = 0;
// FSK_D = 0;
RESET = 1;
RESET = 0;
//1.先寫控制字
//Bit5-Bit7為任意;Bit4為比較器PD;Bit3保留.一般為低;Bit2為QDAC的PD(Power-down);Bit1為DAC的PD;Bit0為DIG PD
Write_9854(0x1d,0x00);//10
//Bit7為任意;Bit6為PLL range;Bit5為旁路PLL;bit4-bit0為倍頻數(shù)////30晶振*10=300MHz系統(tǒng)
Write_9854(0x1e,0x4a);
//bit7為清零ACC1;bit6為清零ACC2(一般必須為低);bit5為三角掃頻;bit4為外用QDAC;bit3-bit1為模式選擇;bit0為使用內(nèi)/外更新時鐘
Write_9854(0x1f,0x00);
//Bit7為任意;bit6為旁路反正弦;bit5為OSK使能(默認(rèn)為1,單頻模式下無輸出);bit4為OSK INT;bit3-2為任意;bit1為設(shè)置串行模式下低位先傳;bit0為設(shè)置串行模式下SDO可用
Write_9854(0x20,0x60);//0x20,0x00
        //2.寫頻率
Write_frequence(Frequence);
//3.寫幅度
Write_Amplitude(0,Amplitude[0]);
Write_Amplitude(1,Amplitude[1]);
// UDCLK = 1;
// UDCLK = 0;
        void Write_9854(unsigned char address,unsigned char DATA)
WRB = 1;
ADDR =  address;
PDATA = DATA;
WRB = 0;
        //==============更新頻率====================================
void Write_frequence(unsigned long x)
WRB = 0;
UDCLK = 0;
Write_9854(0x08,0);
Write_9854(0x09,0);
x *= (429.4967296/Ref_Frequence); // 控制字 = 頻率(HZ) 2^48 /(2^16)/(300*10^6)
          Write_9854(0x07,(unsigned char)x);
  Write_9854(0x06,(unsigned char)(x>>8));
Write_9854(0x05,(unsigned char)(x>>16));
Write_9854(0x04,(unsigned char)(x>>24));
UDCLK = 1;
UDCLK = 0;
//==============更新幅度====================================
void Write_Amplitude(bit Channel,unsigned int Ampli)
WRB = 0;
UDCLK = 0;
if(Channel)
  { Write_9854(0x23,(Ampli>>8));
   Write_9854(0x24,Ampli);
  { Write_9854(0x21,(Ampli>>8));
   Write_9854(0x22,Ampli);
UDCLK = 1;
UDCLK = 0;
//函數(shù)名稱:void AD9854_SetSine(ulong Freq,uint Shape)
//函數(shù)功能:AD9854正弦波產(chǎn)生程序
//入口參數(shù):Freq   頻率設(shè)置,取值范圍0—(1/2)*SYSCLK
//          Shape  幅度設(shè)置,為12Bit,取值范圍為(0—4095),取值越大,幅度越大
//出口參數(shù):無
     uchar count;
  uchar Adress;
  Adress=0x04;              //選擇頻率控制字地址的處值
  Freq_convert(Freq);       //頻率轉(zhuǎn)換
  for(count=6;count>0;)     //寫入6字節(jié)的頻率控制字
      AD9854_WR_Byte(Adress++,FreqWord[--count]);
  AD9854_WR_Byte(0x21,Shape>>8);     //設(shè)置I通道幅度
  AD9854_WR_Byte(0x22,(uchar)(Shape&0xff));
  AD9854_WR_Byte(0x23,Shape>>8);     //設(shè)置Q通道幅度
  AD9854_WR_Byte(0x24,(uchar)(Shape&0xff));
  AD9854_UDCLK=1;                    //更新AD9854輸出
  AD9854_UDCLK=0;
本文轉(zhuǎn)自:http://www.xiaovdiy.cn/?post=99
主站蜘蛛池模板: 成人看片网| www.精品| 97成人在线 | 超碰免费在线 | 手机av免费| 男男av| 亚洲黄视频 | 亚洲激情自拍 | 欧美激情视频一区 | 黄色在线免费网站 | 欧美不卡在线 | 日韩资源在线 | 国产欧美成人 | 久久精品99久久久久久 | 一区二区视频在线 | 日韩成人精品 | 一级片免费网站 | 黄色一级影片 | 91青青草 | 中文字字幕在线 | 久久久久国产一区二区三区 | 四虎色| 天天爱夜夜操 | 在线一区二区视频 | 日本中文字幕在线视频 | 日韩精品一区二区三区四区 | 国产一级黄色大片 | 国产区在线 | 国产精品免费一区 | 成人av一区二区三区在线观看 | 日韩网站免费观看 | 日韩欧美中文 | 日韩精品一区在线观看 | 99久久婷婷 | 精品在线观看视频 | 久久精品国产一区 | 亚洲精品乱码久久久久久动漫 | 欧美成人免费 | 少妇av在线 | 国产精品婷婷 | 欧美精品日韩少妇 |
