查看: 2381|回復: 0
stm8對電機調速程序
ID:206568 發表于 2017-6-1 16:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include"canshu.h"
uint t;
uchar time2_2h=4,time2_2l=4;
void TIM2_Init()
TIM2_CCMR2 = TIM2_CCMR2 | 0x70;// Output modePWM2.
                                //通道2被設置成比較輸出方式
                                // OC2M = 111,PWM模式2
                                // 向上計數時,若計數器小于比較值,為無效電平
                                // 即當計數器在0到比較值時,輸出為1,否則為0
TIM2_CCMR1 = TIM2_CCMR1 | 0x70;
TIM2_CCMR3 = TIM2_CCMR3 | 0x70;
TIM2_CCER1 = TIM2_CCER1 | 0x33;// CC polarity low,enable PWMoutput      */
                                // CC2P = 1,低電平為有效電平
                                // CC2E = 1,開啟輸出引腳
TIM2_CCER2 = TIM2_CCER2 | 0x03;
//初始化自動裝載寄存器,決定PWM方波的頻率,Fpwm=16000000/1000=16kHZ
  TIM2_ARRH = 16000/255;
  TIM2_ARRL = 16000%255;
   TIM2_CCR1H =time2_2h;
  TIM2_CCR1L = time2_2l=4;
//初始化比較寄存器,決定PWM方波的占空比
  TIM2_CCR2H =1000/255;
  TIM2_CCR2L =1000%255;
  TIM2_CCR3H = 1000/255;
  TIM2_CCR3L = 1000%255;
//初始化時鐘分頻器為1,即計數器的時鐘頻率為Fmaster=4MHZ
  TIM2_PSCR =0x00;//因為用了繼電器,所以喲分頻,可到0x08,256分頻
//啟動計數
TIM2_CR1 = TIM2_CR1 | 0x01;
//外部中斷觸發
void exit_init()
   PC_DDR&=~0x04;
   PC_CR1|=0x04;
   PC_CR2|=0x04;
   EXTI_CR1|= 0x10;
#pragma vector=0x07 // 這里很關鍵!看下面說明。
__interrupt void EXTI_PC1(void)
  asm("sim");
  switch(EXTI_CR1)
  case 0x10:EXTI_CR1=0x20;exit_flag=1;break;
  case 0x20:EXTI_CR1=0x10;exit_flag=2;break;
  default :exit_flag=0;break;
if(exit_flag==2)
    t++;
   exit_flag=0;
   if(t%10==0)
      ulong chaju;
      now_nus=TIM4_CNTR;
      now_ms=cishu;
     chaju_ms=now_ms-last_ms;
   if(cishu_flag==1)
     cishu_flag=0;
     chaju_ms=30000+now_ms-last_ms;
      chaju_nus=now_nus-last_nus;
      chaju=chaju_ms*250+chaju_nus;
      now_rads=(1250000/chaju);
      last_nus=now_nus;
      last_ms=now_ms;
      last_rads[rads_flag++]=now_rads;
      if(rads_flag==10)
        rads_flag=0;
    pid_error=now_rads-last_radss;
    pid_error1=last_radss-last_radsss;
     last_radsss=last_radss;
     last_radss =now_rads;
   asm("rim");
#pragma vector=TIM2_OVR_UIF_vector
     __interrupt void TIM3_OVF_IRQHandler(void)
         TIM2_SR1 = 0x00;
         ds1820_flag=1;
//定時器2產生60s的中斷
void TIM2_time()
     TIM2_EGR=0x01; //手動產生更新事件,重新初始化計數器,并允許產生一個更新事件
    //設置定時器初值
    TIM2_CNTRH=0; //不能使用TIM3_CNTR直接設值,
    TIM2_CNTRL=0;
    //設定自動重裝寄存器值
    //這里得注意不能使用TIM2_ARR的方式進行設值,TIM2是十六位的。
    //TIM2_ARR=0xFA,實際上是賦給高字節了,TIM2_ARRH=0xFA,而不是想象中的賦給低字節。
    TIM2_ARRH=0x72; //488hz 488 /29280  = 60s (1S)
    TIM2_ARRL=0x60; //0x007d   意味著每產生一次中斷時間為60S
    TIM2_PSCR=0x0f; //預分頻32275
    TIM2_IER=0x01; //中斷允許位使能
    TIM2_CR1=0x01; //使能計時器
主站蜘蛛池模板: 日本黄a三级三级三级 | 亚洲精品成人网 | 午夜丁香 | 欧美日韩在线一区二区 | 三上悠亚一区二区 | 日本加勒比在线观看 | 日韩黄色一级片 | 毛片毛片毛片毛片毛片 | 岛国精品在线播放 | 精品一区在线播放 | 欧美成人一级 | 天堂99| 中文字幕一区二区三区四区视频 | 高清乱码男女免费观看 | 国产丝袜视频 | 91视频播放 | 偷拍一区二区三区 | 国产一区二区三区免费视频 | 日本视频免费 | 欧美一区二区三区在线 | av福利在线观看 | 精品视频免费在线观看 | 成人免费看 | 亚洲成人av在线 | 毛片网站大全 | 欧美做受喷浆在线观看 | 国产精品区二区三区日本 | 国产精品久久久久久妇女6080 | 一道本在线观看 | 99久久久国产精品 | 69精品人人人人 | 久久国产综合 | 可以看的毛片 | 中文字幕亚洲欧美 | 欧美综合在线视频 | 中文字幕精品一区久久久久 | 91伊人| 日韩综合在线 | 中文字字幕码一二三区 | 日本韩国三级 | 99精品久久久 |
