查看: 5018|回復: 2
msp430g2231簡單程序
ID:75926 發表于 2015-4-2 22:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序功能:
MSP430 IO上電為輸入 高阻
P1.0 as ACLK output P1.4 as SMCLK output
按下S2可控制綠色LED亮滅
P1.1 和 P1.5 用于輸出PWM波形
P1.2用于輸出脈寬變化的PWM(8種占空比)
fx.h文件
#ifndef FX_H_
#define FX_H_
#define EnableWDT WDTCTL = WDTPW + WDTHOLD
void InitClkModule(void);
void InitGPIO(void);
void InitTimerA(void);
void InitADC10(void);
void InitUSI(void);
void YrApplication(void);
void InitSys(void);
#endif
fx.c文件
#include  <msp430g2231.h>
if (CALBC1_1MHZ == 0xFF || CALDCO_1MHZ == 0xFF)
while(1); // If calibration constants erased, trap CPU!!
// Configure Basic Clock
BCSCTL1 = CALBC1_1MHZ; // Set range vloclk is 12kHz
DCOCTL = CALDCO_1MHZ; // Set DCO step + modulation DCOCLK = 1MHz
//Insert User Code Here
BCSCTL2 |= SELM_0 + DIVM_0 + DIVS_3;      // MCLK = DCOCLK = 1MHz, SMCLK = DCOCLK/8
BCSCTL3 |= LFXT1S_2;                      // ACLK = VLOCLK 6pF
void InitGPIO(void)
P1DIR |= BIT0 + BIT1 + BIT2 + BIT4 + BIT5 + BIT6; // P1.0 P1.1 P1.2 P1.4 P1.5and P1.6 are configured as output pin
P1SEL |= BIT0 + BIT1 + BIT2 + BIT4 + BIT5; // P1.0 as ACLK output P1.1 and P1.5 as compare out0 out putP1.4 as SMCLK output
P1IES |= BIT3;                  // P1.3 Hi/lo edge
P1IFG &= ~BIT3;                 // P1.3 IFG cleared
P1IE |= BIT3;                   // P1.3 interrupt enabled
TACTL = TASSEL_2 + MC_2 + TAIE + TACLR; // SMCLK, enable TimerA interrupt
//TACTL = TASSEL_2 + MC_1 + TAIE + TACLR; // SMCLK, enable TimerA interrupt
TACCTL1 = OUTMOD_7; //PWM: reset/set mode
TACCTL0 = OUTMOD_4;
CCR0 = 0x7fff;
CCR1 = 0;
void InitUSI(void)
void InitSys(void)
InitClkModule();
InitGPIO();
InitTimerA();
main.c文件
#include  "fx.h"
unsigned int i = 0;
unsigned char flag = 1;
void main(void)
EnableWDT; // stop the watchdog
InitSys();
_BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/interrupt
while(1);
#pragma vector=PORT1_VECTOR
__interrupt void Port1_ISR()
                     //The code below is a reference handle process,the interrupt related with the port never used should be delete。
if((P1IFG&BIT0) == BIT0)
//Handle the Interrupt generated by P1IN.0
P1IFG &= ~BIT0;  //Clear the IFG
else if((P1IFG&BIT1) ==BIT1)
//Handle the Interrupt generated by P1IN.1
P1IFG &= ~BIT1;  //Clear the IFG
else if((P1IFG&BIT2) ==BIT2)
//Handle the Interrupt generated by P1IN.2
P1IFG &= ~BIT2;  //Clear the IFG
else if((P1IFG&BIT3) ==BIT3)
//Handle the Interrupt generated by P1IN.3
P1IFG &= ~BIT3;  //Clear the IFG
P1OUT ^= BIT6;                         // P1.0 = toggle
else if((P1IFG&BIT4) ==BIT4)
//Handle the Interrupt generated by P1IN.4
P1IFG &= ~BIT4;  //Clear the IFG
else if((P1IFG&BIT5) ==BIT5)
//Handle the Interrupt generated by P1IN.5
P1IFG &= ~BIT5;  //Clear the IFG
else if((P1IFG&BIT6) ==BIT6)
//Handle the Interrupt generated by P1IN.6
P1IFG &= ~BIT6;  //Clear the IFG
//Handle the Interrupt generated by P1IN.7
P1IFG &= ~BIT7;  //Clear the IFG
//LPM3_EXIT;           //退出中斷后退出低功耗模式。若退出中斷后要保留低功耗模式,將本句屏蔽
#pragma vector=USI_VECTOR
__interrupt void USI_ISR()
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR()
#pragma vector=TIMERA1_VECTOR
__interrupt void TIMERA1_ISR() // the interrupt source is CC1~2
switch (TAIV)
   case 2:
                  //capture/compare1 interrupt
   break;
   case 4:
                  //capture/compare2 interrupt MSP430G2231 donot have the compare2 module
   break;
   case 10:
                 //TAIFG Timer overflow interrupt
    P1OUT ^= BIT6; // change the status of green led when TimerA overflow
    TACTL &= ~BIT0;
    if(flag)//i++;
    i += 4095;
    else //i--;
    i -=4095;
    if(i > 0x7fff) flag = 0;
    if(i == 0) flag = 1;
    CCR1 = i; //change the duty-cycle
   break;
#pragma vector=TIMERA0_VECTOR
__interrupt void TIMERA0_ISR() // the interrupt source is CC0
收藏收藏 分享淘帖 頂1 踩
ID:75612 發表于 2015-4-3 12:24 | 只看該作者
謝謝 我試試
ID:70678 發表于 2015-4-15 10:15 | 只看該作者
怎么看不懂i啊
主站蜘蛛池模板: 一区二区三区视频在线播放 | 日韩免费小视频 | 欧美精品乱码99久久蜜桃 | 天天夜夜操 | 欧美成人精品一区二区 | 成人免费毛片男人用品 | 日本在线一区二区三区 | 国产一区精品在线观看 | 天堂视频在线免费观看 | 日日爽天天 | 日韩国产中文字幕 | 亚洲一区二区av | 亚洲精品视频免费在线观看 | 国产成人三级一区二区在线观看一 | 天天干天天插 | 国产精品一区二区久久 | 亚洲激情一区二区 | 亚洲精品视频在线播放 | 久久久天堂国产精品女人 | 亚洲免费成人 | 九九爱视频 | 欧美日韩国产在线观看 | 天天爽天天操 | 免费的黄色网址 | 亚洲在线 | 精品国产乱码久久久久久蜜柚 | 久久免费高清视频 | 日韩欧美一级片 | 在线色网站 | www四虎 | 日本少妇视频 | 91亚洲国产成人精品性色 | 亚洲综合视频在线观看 | a毛片视频 | 欧美日本精品 | 日韩国产精品一区二区 | 97超碰人人 | 欧美成人精品欧美一级乱黄 | 久久精品欧美一区 | 国产激情一区二区三区 | 成人看片网 |
